Home » Modeling » EMF » XSD to Java code generation with multiple import of the same namespace
XSD to Java code generation with multiple import of the same namespace [message #425606] Wed, 03 December 2008 07:01 Go to next message
I'd encountered a problem with generating Java code by EMF XSD generation
functionality within Eclipse 3.2.2. Within the *.xsd file a multiple
import of the same namespace was used, see egzample:
<!-- Imports -->
<xsd:import schemaLocation="Part1.xsd"
namespace="http://TestLibB"></xsd:import>
<xsd:import schemaLocation="Part2.xsd"
I'd like to ask if the XSD to Java code generation functionality in
Eclipse 3.4 respecting multiple import of the same namespace in a XSD file
and generates valid Java code?
The W3C Specification says it is up to a XML Schema application
(EMF XSD to Java transformation) to ignore multiple
imports of the same namespace or not.
http://www.w3.org/TR/xmlschema-1
4.2.3 References to schema components across namespaces
Note: ... Given that the schemaLocation attribute is only a hint,
it is open to applications to ignore all but the first <import> for
a given namespace, regardless of the actual value of schemaLocation,
but such a strategy risks missing useful information when new
schemaLocations are offered.
Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425607 is a reply to message #425606] Wed, 03 December 2008 07:19 Go to previous messageGo to next message
Blazej,
Comments below.
> generation functionality within Eclipse 3.2.2.
That's pretty old. Can you reproduce it with EMF 2.4?
> Within the *.xsd file a multiple import of the same namespace was
> used, see egzample:
> <!-- Imports -->
> file and generates valid Java code?
When resolving a name in that namespace it should visit all the imports
and will try to resolve each one.
> application (EMF XSD to Java transformation) to ignore
> multiple imports of the same namespace or
> not.
> namespaces
> for a given namespace, regardless of the actual value of
> schemaLocation, but such a strategy risks missing useful
> information when new schemaLocations are
> offered. -----
The XSD model itself has always strictly followed the hints given by all
the schema locations, but the resolution mechanism is extensible and
things like WTP support an XML catalog than can be used to take
precedence over the hints within the schema (to support things like
redirecting a HTTP URL to a local cached version of that schema).
> Regards, Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425616 is a reply to message #425607] Wed, 03 December 2008 08:01 Go to previous messageGo to next message
Hello!
Just to add some more to my concern:
I checked it with EMF 2.4 and it turned out that when I use this scenario
and want to generate Java:
1. if I use Xerces validator and the
<!-- Imports -->
<xsd:import schemaLocation="Part1.xsd">>
<xsd:import schemaLocation="Part2.xsd">>
it gives an error when I want to use an element from Part2.xsd reading
that it can not be defined.
2. using the same Validator and changing this declaration to:
some Intermediate.xsd
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://TestLib/B">
<xsd:include schemaLocation="Part1.xsd"></xsd:include>
<xsd:include schemaLocation="Part2.xsd"></xsd:include>
</xsd:schema>
and then imported single:
<xsd:import namespace="http://TestLib/B"
schemaLocation="Intermediate.xsd"></xsd:import>
results in no error indication.
Then generating Java files from these two results in almost the same
source.
The only difference is one generated java class file which includes class
file import statement below.
-> import org.eclipse.emf.ecore.xml.type.XMLTypePackage
But it is not included in the file generated at second step.
Does it shows that the multiple import statement does not work correctly?
How to check if the generated source code valid?
Thank you Ed for replying in just minutes after me posting!
Blazej
>> used, see egzample:
>> <!-- Imports -->
>> not.
>> namespaces
>> offered. -----
>> Regards, Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425626 is a reply to message #425616] Wed, 03 December 2008 09:04 Go to previous messageGo to next message
Blazej,
Comments below.
Blazej Kroll wrote:
> Hello!
> scenario and want to generate Java:
> 1. if I use Xerces validator and the <!-- Imports -->
> </xsd:schema>
> source.
> class file import statement below. -> import
> org.eclipse.emf.ecore.xml.type.XMLTypePackage But it
It's a little too vague for me to understand what you're driving at.
Does it compile? :-P Can it read and write valid instances? What kinds
of things are defined in these other two schemas? Is an EPackage with
nsURI http://TestLibB produced? Does it contain EClassifiers for all
the types defined in that namespace? Does the document root of that
package have features for all the elements and attributes defined in
that namespace (from both files)?
> Regards,
> Blazej
>>> used, see egzample:
>>> <!-- Imports -->
>>> XSD file and generates valid Java code?
>> imports and will try to resolve each one.
>>> not.
>>> namespaces
>>> hint, it is open to applications to ignore all but the first
>>> <import> for a given namespace, regardless of the actual value
>>> of schemaLocation, but such a strategy risks missing useful
>>> offered. -----
>> all the schema locations, but the resolution mechanism is extensible
>> and things like WTP support an XML catalog than can be used to take
>>> Regards, Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425708 is a reply to message #425626] Fri, 05 December 2008 06:26 Go to previous messageGo to next message
to clarify the issue I'm facing:
I want to generate Java from XML Schema.
I am facing a validation error from Xerces when using multiple imports in
an xml schema file like:
After looking for a workaround I tried to make it another way (not to see
the validator's error)
and make a fsingle file which includes the necessary Part1.xsd and
Part2.xsd files and then import that file in the main Schema from which I
will generate the Java code.
Some file which gatheres all the necessery ones called Intermediate.xsd
which includes:
</xsd:schema>
and then in the main file to generate Java code I use single import
operation:
So the validator is giving no errors.
Just to summer things up I want to make sure that from the EMF side both
these scenarioes (multiple import usage) generate a valid Java code
despite the validator's error in the first case.
Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425710 is a reply to message #425708] Fri, 05 December 2008 06:43 Go to previous messageGo to next message
Blazej,
Comments below.
Blazej Kroll wrote:
> Hello, to clarify the issue I'm facing:
> in an xml schema file like:
It seems to me they ought to support that.
> see the validator's error)
> which I will generate the Java code.
> Intermediate.xsd which includes:
> </xsd:schema>
> operation:
Yes, that should work.
> both these scenarioes (multiple import usage) generate a valid Java
> code despite the validator's error in the first case.
Yes, EMF should treat them as entirely equivalent and should generate
the same code for each.
> Regards,
> Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425725 is a reply to message #425710] Fri, 05 December 2008 10:36 Go to previous messageGo to next message
Originally posted by: blazej.kroll.gmail.com
Thank you for the answer Ed.
Just to close the subject. Can I expect the multiple import to work in
EMF 2.2 or 2.3? Or is it a new introduced thing?
Blazej
Ed Merks pisze:
> Blazej,
> Comments below.
>> </xsd:schema>
>> operation:
>> Regards,
>> Blazej
Re: XSD to Java code generation with multiple import of the same namespace [message #425730 is a reply to message #425725] Fri, 05 December 2008 11:04 Go to previous message
Błażej,
It's always worked.
Błażej Kroll wrote:
> Hello,
> Regards,
> Blazej
> Ed Merks pisze:
>> Blazej,
>> Comments below.
>>> imports in an xml schema file like:
>>> to see the validator's error)
>>> </xsd:schema>
>>> operation:
>>> Regards,
>>> Blazej
Previous Topic:ExtendedMetaData and inheritance
Next Topic:EList performance issues
Current Time: Sun Jul 20 15:36:06 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
