Home » Modeling » EMF » How to cross reference between models.
How to cross reference between models. [message #425676] |
Thu, 04 December 2008 09:46  |
I require to reference from one Model (A) to Model (B),
It seems this is possible, and EMF would actually generate an editor for
both models? can someone please point to some documentation on how to do
this with XML Schema?
(I haven't tried, but can I use i.e. anyURI to point to a resource in an
other schema?).
<xsd:element name="author" type="xsd:anyURI"
maxOccurs=="10"
ecore:reference="Writer"/>
Thank You / Christophe Bouhier
Re: How to cross reference between models. [message #425684 is a reply to message #425676] |
Thu, 04 December 2008 10:47   |
Christophe,
Comments below.
Christophe Bouhier wrote:
> Hello,
> for both models?
Yes.
> can someone please point to some documentation on how to do this with
> XML Schema?
Even the Library.xsd from the tutorial supports this.
> an other schema?).
> maxOccurs=="10"
Exactly. So you can actually create two library files, one with a book
the other with a writer, then use Load Resource... to load either
resource in the other resource's editor. Once you do that, you can
create a reference between the book and the writer the same was if if
they were in the same file and when you save, you'll see how the
references between the resources are stored.
Re: How to cross reference between models. [message #425700 is a reply to message #425684] |
Fri, 05 December 2008 05:46   |
Hi Ed,
Is this the extended model (Library) tutorial?
This I think is what I need, but how do I do this with two .xsd files?
(The example is for rational rose model).
Thx Christophe
Ed Merks wrote:
> Christophe,
> Comments below.
>> Hello,
>> for both models?
> Yes.
>> XML Schema?
>> an other schema?).
>> maxOccurs=="10"
Re: How to cross reference between models. [message #425709 is a reply to message #425700] |
Fri, 05 December 2008 06:28   |
--------------040808000600090105000300
Christophe,
The schema in this tutorial supports what I described
Tutorial: Generating an EMF Model using XML Schema
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html>
The same approach works with any number of XSD files. Just use
xsd:anyURI along with ecore:reference and you'll end up with a
non-containment EReference that supports cross file references.
> Hi Ed,
> Thx Christophe
> Ed Merks wrote:
>> Christophe,
>> Comments below.
>>> Hello,
>>> for both models?
>> Yes.
>>> with XML Schema?
>>> in an other schema?).
>>> maxOccurs=="10"
>> book the other with a writer, then use Load Resource... to load
>> either resource in the other resource's editor. Once you do that,
>> you can create a reference between the book and the writer the same
>> was if if they were in the same file and when you save, you'll see
>> how the references between the resources are stored.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Christophe,<br>
<br>
The schema in this tutorial supports what I described<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
</blockquote>
non-containment EReference that supports cross file references.<br>
<br>
<br>
<blockquote cite="mid:4939066A.7050608@gmail.com" type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
Thx Christophe
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Christophe,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Hello,
<br>
<br>
<br>
for both models?
<br>
</blockquote>
Yes.
<br>
<blockquote type="cite">can someone please point to some
documentation on how to do this with XML Schema?
<br>
</blockquote>
<br>
<blockquote type="cite"><br>
an other schema?).
<br>
<br>
<br>
maxOccurs=="10"
<br>
<br>
</blockquote>
book the other with a writer, then use Load Resource... to load either
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------040808000600090105000300--
Re: How to cross reference between models. [message #425712 is a reply to message #425709] |
Fri, 05 December 2008 07:51   |
Ah thanks, I just noticed the fine prints in the wizard page "Specify
one or more....", christophe
Ok, I now have an editor with two packages. I see two extension
parsers are generated, so this is indeed what I need.
Now, what I haven't figured out yet is, if both packages have an element
named "Car", how do I define a unique reference to either "Car" in
package A or in package B? Is it possible by pre-pending a namespace in
the URI of the ecore:reference?
And if this is possible at all, how does the editor handle a case
whereby a referenced element in another resource is not open in the editor?
Many thanks, Christophe
Ed Merks wrote:
> Christophe,
>> Hi Ed,
>> Thx Christophe
>> Ed Merks wrote:
>>> Christophe,
>>> Comments below.
>>>> Hello,
>>>> for both models?
>>> Yes.
>>>> with XML Schema?
>>>> maxOccurs=="10"
Re: How to cross reference between models. [message #425713 is a reply to message #425712] |
Fri, 05 December 2008 07:56  |
--------------080302050007060707000209
Christophe,
Comments below.
> element named "Car", how do I define a unique reference to either
> "Car" in package A or in package B?
Two definitions of Car doesn't sound so good.
> Is it possible by pre-pending a namespace in the URI of the
> ecore:reference?
The value specified in ecore:reference="..." is processed *exactly *is
it would if it appeared in type="...". I.e., it must be a QName and if
it's in a different namespace, the schema must contain an important
(just as it would if you specified the QName in the type="...")...
> editor?
Try it and see. :-P
Cross document references are resolved as they are visited and result in
demand loading additional resources into the resource set. So you'll
end up with an editor that's editing multiple resources.
> Ed Merks wrote:
>> Christophe,
>>> Hi Ed,
>>> Thx Christophe
>>> Ed Merks wrote:
>>>> Christophe,
>>>> Comments below.
>>>>> Hello,
>>>>> editor for both models?
>>>> Yes.
>>>>> with XML Schema?
>>>>> maxOccurs=="10"
<html>
<head>
<title></title>
</head>
Christophe,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:493923D4.4070309@gmail.com" type="cite">Ah
<br>
<br>
<br>
<br>
<br>
element named "Car", how do I define a unique reference to either "Car"
in package A or in package B? </blockquote>
Two definitions of Car doesn't sound so good.<br>
<blockquote cite="mid:493923D4.4070309@gmail.com" type="cite">Is it
possible by pre-pending a namespace in the URI of the ecore:reference?
<br>
</blockquote>
The value specified in ecore:reference="..." is processed <b>exactly </b>is
(just as it would if you specified the QName in the type="...")...<br>
<blockquote cite="mid:493923D4.4070309@gmail.com" type="cite"><br>
editor?
<br>
</blockquote>
Try it and see. :-P<br>
<br>
in demand loading additional resources into the resource set. So
you'll end up with an editor that's editing multiple resources.<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-rfc2396E" href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html">< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html></a>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
Thx Christophe
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
for both models?
<br>
</blockquote>
Yes.
<br>
<br>
</blockquote>
<br>
an other schema?).
<br>
<br>
<br>
maxOccurs=="10"
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------080302050007060707000209--
Current Time: Sun Jul 20 12:27:06 EDT 2025
Powered by FUDForum. Page generated in 0.04425 seconds
