Home » Modeling » EMF » Re: CDO 1.0.4 problem: Revision not found
Re: CDO 1.0.4 problem: Revision not found [message #425557] Mon, 01 December 2008 10:59 Go to next message
Christian,
Since Ganymede CDO is supported through the EMF newsgroup, which I
included in this discussion.
A long time passed since 1.0.0 and I must admit that I can not
immediately remember what exactly can cause such upgrade problems. In
our maintenance stream this should usually not happen. Please let us
wait if Simon can remember of any changes in the maintenance stream that
could cause your problem...
Cheers
/Eike
Christian Hauser schrieb:
> Hello CDO gurus
> I'm running Eclipse 3.4.1 with EMF and updated CDO from 1.0.0 to
> 1.0.4. Then I started a CDO server and after the server came up I
> started my application that should use the server.
> However, I get the following error:
> Thread-2 [debug] Selecting revision: OID2
> Thread-2 [debug] Selecting object type: OID2
> Thread-2 [debug.sql] SELECT cdo_class FROM cdo_objects WHERE cdo_id=2
> Thread-2 [debug.sql] SELECT classifier, package FROM cdo_classes WHERE
> id=1
> Thread-2 [debug.sql] SELECT uri FROM cdo_packages WHERE id=1
> Thread-2 [debug] SELECT cdo_version, cdo_created, cdo_revised,
> cdo_resource, cdo_container, cdo_feature FROM PersonList WHERE
> cdo_id=2 AND cdo_revised=0
> [ERROR] Revision not found: 2
> java.lang.IllegalStateException: Revision not found: 2
> at
> org.eclipse.emf.cdo.server.internal.db.ClassMapping.readAttr ibutes(ClassMapping.java:560)
> at
> org.eclipse.emf.cdo.server.internal.db.ClassMapping.readRevi sion(ClassMapping.java:528)
> at
> org.eclipse.emf.cdo.server.internal.db.ClassMapping.readRevi sion(ClassMapping.java:501)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreReader.readRev ision(DBStoreReader.java:236)
> at
> org.eclipse.emf.cdo.internal.server.RevisionManager.loadRevi sion(RevisionManager.java:210)
> at
> org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:283)
> at
> org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:145)
> at
> org.eclipse.emf.cdo.internal.server.protocol.LoadRevisionInd ication.getRevision(LoadRevisionIndication.java:171)
> at
> org.eclipse.emf.cdo.internal.server.protocol.LoadRevisionInd ication.responding(LoadRevisionIndication.java:147)
> at
> org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:54)
> at
> org.eclipse.emf.cdo.internal.server.protocol.CDOReadIndicati on.execute(CDOReadIndication.java:38)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
> at java.lang.Thread.run(Thread.java:619)
> Any help on what I might do wrong is highly appreciated. The complete
> log is at the bottom of this mail (please snip when replying).
> Thanks in advance,
> Christian
> COMPLETE LOG:
> Configuration location:
> file:/D:/files/eclipse/workspaces/emf_testing/.metadata/.plu gins/org.eclipse.pde.core/CDOServer.product/
> Configuration file:
> file:/D:/files/eclipse/workspaces/emf_testing/.metadata/.plu gins/org.eclipse.pde.core/CDOServer.product/config.ini
> loaded
> Install location:
> file:/D:/files/eclipse/builds/eclipse-SDK-3.4.1/eclipse/
> Framework located:
> file:/D:/files/eclipse/builds/eclipse-SDK-3.4.1/eclipse/plug ins/org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar
> Framework classpath:
> Splash location:
> null
> Debug options:
> file:/D:/files/eclipse/workspaces/emf_testing/.metadata/.plu gins/org.eclipse.pde.core/CDOServer.product/.options
> loaded
> osgi> Time to load bundles: 187
> Starting application: 750
> main [debug.om] Starting bundle org.eclipse.net4j.util
> main [debug.lifecycle] Activating ManagedContainer
> main [debug.lifecycle] Activating {}
> main [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1
> Registry.autoCommit = true
> Registry.transaction = null
> HashMapRegistry.map =
> org.eclipse.net4j.acceptors[jvm]=Factory[org.eclipse.net4j.a cceptors,
> jvm]
> org.eclipse.net4j.connectors[jvm]=Factory[org.eclipse.net4j. connectors,
> jvm]
> org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.n et4j.randomizers,
> default]
> org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net 4j.userManagers,
> file]
> org.eclipse.net4j.clientProtocols[cdo]=Factory[org.eclipse.n et4j.clientProtocols,
> cdo]
> org.eclipse.net4j.serverProtocols[cdo]=Factory[org.eclipse.n et4j.serverProtocols,
> cdo]
> org.eclipse.net4j.bufferProviders[default]=Factory[org.eclip se.net4j.bufferProviders,
> default]
> org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors,
> tcp]
> org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse .net4j.Negotiators,
> challenge]
> org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors,
> tcp]
> org.eclipse.net4j.executorServices[default]=Factory[org.ecli pse.net4j.executorServices,
> default]
> org.eclipse.net4j.connectors[http]=Factory[org.eclipse.net4j .connectors,
> http]
> org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors,
> tcp]
> org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions,
> cdo]
> org.eclipse.net4j.acceptors[http]=Factory[org.eclipse.net4j. acceptors,
> http]
> extensionRegistryListener =
> org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@22ab57
> main [debug.lifecycle] Activating []
> main [debug.om] Starting bundle org.eclipse.emf.cdo
> main [debug.om] Starting bundle org.eclipse.net4j.http.server
> main [debug.om] Starting bundle org.eclipse.net4j.tcp
> main [debug.lifecycle.dump] DUMP PluginElementProcessorList@2
> processors =
> org.eclipse.emf.internal.cdo.util.ChannelInjector@e49dcd
> org.eclipse.net4j.util.security.ChallengeNegotiatorConfigure r @1343ed0
> org.eclipse.net4j.Net4jTransportInjector@107f45d
> org.eclipse.net4j.http.internal.server.RandomizerInjector@13c0b53
> org.eclipse.net4j.internal.tcp.TCPSelectorInjector@10b9279
> org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@192a848
> main [debug.lifecycle.dump] DUMP PluginContainer@3
> ManagedContainer.factoryRegistry =
> jvm]
> jvm]
> default]
> file]
> cdo]
> cdo]
> default]
> tcp]
> challenge]
> tcp]
> default]
> http]
> tcp]
> cdo]
> http]
> ManagedContainer.postProcessors =
> ManagedContainer.elementRegistry =
> ManagedContainer.maxElementID = 0
> ManagedContainer.elementListener =
> org.eclipse.net4j.util.container.ManagedContainer$1@979e8b
> main [debug.om] Plugin container created: ManagedContainer
> main [debug.om] Starting bundle org.eclipse.emf.cdo.server
> main [debug.om] Starting application org.eclipse.emf.cdo.server.app
> [INFO] CDO Server starting
> main [debug.repository] Configuring CDO server from
> D:\files\eclipse\workspaces\emf_testing\org.eclipse.emf.cdo. server.product\rootfiles\configuration\cdo-server.xml
> main [debug.repository] Configuring repository repo1 (type=default)
> main [debug.om] Starting bundle org.eclipse.emf.cdo.common
> main [debug.model] Created
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> name=cdocore, dynamic=false, metaIDRange=null, parentURI=null)
> main [debug.model] Created CDOClass(ID=0, name=CDOObject)
> main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)
> main [debug.model] Added package:
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> name=cdoresource, dynamic=false, metaIDRange=null, parentURI=null)
> main [debug.model] Created CDOClass(ID=0, name=CDOResource)
> main [debug.model] Created CDOFeature(ID=9, name=path, type=STRING)
> main [debug.model] Adding feature: CDOFeature(ID=9, name=path,
> type=STRING)
> main [debug.model] Created CDOFeature(ID=2, name=contents,
> type=CDOClass(ID=0, name=CDOObject))
> main [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
> main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)
> main [debug.om] Starting bundle org.eclipse.emf.cdo.server.db
> main [debug.om] Starting bundle org.eclipse.net4j.db
> main [debug.lifecycle] Activating Repository[repo1]
> main [debug.lifecycle] Activating DBStore@4
> main [debug.sql] CREATE TABLE cdo_features (id INTEGER, class INTEGER,
> feature INTEGER, name VARCHAR(255), type INTEGER, reference_package
> VARCHAR(255), reference_classifier INTEGER, many SMALLINT, containment
> SMALLINT, idx INTEGER)
> main [debug.sql] -- Table/View 'CDO_FEATURES' already exists in Schema
> 'APP'.
> main [debug.sql] CREATE TABLE cdo_classes (id INTEGER, package
> INTEGER, classifier INTEGER, name VARCHAR(255), abstract SMALLINT)
> main [debug.sql] -- Table/View 'CDO_CLASSES' already exists in Schema
> 'APP'.
> main [debug.sql] CREATE TABLE cdo_packages (id INTEGER, uri
> VARCHAR(255), name VARCHAR(255), ecore CLOB, dynamic SMALLINT,
> range_lb BIGINT, range_ub BIGINT, parent VARCHAR(255))
> main [debug.sql] -- Table/View 'CDO_PACKAGES' already exists in Schema
> 'APP'.
> main [debug.sql] CREATE TABLE cdo_supertypes (type_id INTEGER,
> supertype_package VARCHAR(255), supertype_classifier INTEGER)
> main [debug.sql] -- Table/View 'CDO_SUPERTYPES' already exists in
> Schema 'APP'.
> main [debug.sql] CREATE TABLE cdo_repository (starts BIGINT, started
> BIGINT, stopped BIGINT, next_cdoid BIGINT, next_metaid BIGINT)
> main [debug.sql] -- Table/View 'CDO_REPOSITORY' already exists in
> Schema 'APP'.
> main [debug.sql] SELECT MAX(next_cdoid) FROM cdo_repository
> main [debug.sql] SELECT MAX(next_metaid) FROM cdo_repository
> [WARN] Detected restart after crash
> main [debug.sql] UPDATE cdo_repository SET starts=starts+1,
> started=1228145788395, stopped=0, next_cdoid=-1, next_metaid=-1
> main [debug.sql] SELECT MAX(id) FROM cdo_packages
> main [debug.sql] SELECT MAX(id) FROM cdo_classes
> main [debug.sql] SELECT MAX(id) FROM cdo_features
> main [debug.lifecycle] Activating horizontal
> main [debug.lifecycle] Activating ObjectTypeCache@5
> main [debug.lifecycle.dump] DUMP ObjectTypeCache@5
> mappingStrategy = horizontal
> table = null
> idField = null
> typeField = null
> initializeLock = java.lang.Object@1c67248
> main [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@6
> MappingStrategy.store = DBStore@4
> MappingStrategy.properties =
> toManyReferences=ONE_TABLE_PER_REFERENCE
> qualifiedNames=false
> toOneReferences=LIKE_ATTRIBUTES
> MappingStrategy.referenceTables =
> MappingStrategy.classRefs =
> MappingStrategy.resourceClassMapping = null
> MappingStrategy.resourcePathMapping = null
> MappingStrategy.resourceTable = null
> MappingStrategy.resourceIDField = null
> MappingStrategy.resourcePathField = null
> objectTypeCache = ObjectTypeCache@5
> main [debug.lifecycle.dump] DUMP DBStore@4
> Store.type = db
> Store.repository = Repository[repo1]
> Store.lastMetaID = -1
> LongIDStore.lastObjectID = -1
> dbSchema = null
> dbAdapter = derby-embedded-10.3.2.1
> dbConnectionProvider = org.apache.derby.jdbc.EmbeddedDataSource@9be2b5
> nextPackageID = 2
> nextClassID = 3
> nextFeatureID = 7
> main [debug.lifecycle] Activating PackageManager@7
> main [debug.sql] SELECT uri, dynamic, range_lb, range_ub, parent FROM
> cdo_packages
> main [debug.model] Created proxy package
> http://www.ruag.com/panther/person/model/1.0.0, dynamic=true,
> metaIDRange=[MID1:MID17],
> parentURI=http://www.ruag.com/panther/person/model/1.0.0
> CDOPackage(URI=http://www.ruag.com/panther/person/model/1.0.0,
> name=null, dynamic=true, metaIDRange=[MID1:MID17], parentURI=null)
> main [debug.lifecycle.dump] DUMP PackageManager@7
> CDOPackageManagerImpl.packages =
> http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> http://www.ruag.com/panther/person/model/1.0.0=CDOPackage(URI=http://www.ruag.com/panther/person/model/1.0.0,
> CDOPackageManagerImpl.cdoCorePackage =
> CDOPackageManagerImpl.cdoResourcePackage =
> main [debug.sql] SELECT id, name, ecore FROM cdo_packages WHERE uri =
> 'http://www.ruag.com/panther/person/model/1.0.0'
> main [debug.model] Setting server info:
> name=null, dynamic=true, metaIDRange=[MID1:MID17], parentURI=null) --> 1
> main [debug.sql] SELECT id, classifier, name, abstract FROM
> cdo_classes WHERE package=1
> main [debug.model] Created CDOClass(ID=0, name=PersonList)
> main [debug.model] Setting server info: CDOClass(ID=0,
> name=PersonList) --> 1
> main [debug.model] Adding class: CDOClass(ID=0, name=PersonList)
> main [debug.sql] SELECT supertype_package, supertype_classifier FROM
> cdo_supertypes WHERE type_id=1
> main [debug.sql] SELECT id, feature, name, type, reference_package,
> reference_classifier, many, containment FROM cdo_features WHERE class=1
> main [debug.model] Created CDOFeature(ID=0, name=personen,
> type=CDOClassRef(http://www.ruag.com/panther/person/model/1.0.0, 1))
> main [debug.model] Setting server info: CDOFeature(ID=0,
> name=personen,
> --> 1
> main [debug.model] Adding feature: CDOFeature(ID=0, name=personen,
> main [debug.model] Created CDOClass(ID=1, name=Person)
> main [debug.model] Setting server info: CDOClass(ID=1, name=Person) --> 2
> main [debug.model] Adding class: CDOClass(ID=1, name=Person)
> cdo_supertypes WHERE type_id=2
> reference_classifier, many, containment FROM cdo_features WHERE class=2
> main [debug.model] Created CDOFeature(ID=0, name=vorname, type=STRING)
> main [debug.model] Setting server info: CDOFeature(ID=0, name=vorname,
> type=STRING) --> 2
> main [debug.model] Adding feature: CDOFeature(ID=0, name=vorname,
> type=STRING)
> main [debug.model] Created CDOFeature(ID=1, name=nachname, type=STRING)
> main [debug.model] Setting server info: CDOFeature(ID=1,
> name=nachname, type=STRING) --> 3
> main [debug.model] Adding feature: CDOFeature(ID=1, name=nachname,
> type=STRING)
> main [debug.model] Created CDOFeature(ID=2, name=plz, type=INT)
> main [debug.model] Setting server info: CDOFeature(ID=2, name=plz,
> type=INT) --> 4
> main [debug.model] Adding feature: CDOFeature(ID=2, name=plz, type=INT)
> main [debug.model] Created CDOFeature(ID=3, name=wohnort, type=STRING)
> main [debug.model] Setting server info: CDOFeature(ID=3, name=wohnort,
> type=STRING) --> 5
> main [debug.model] Adding feature: CDOFeature(ID=3, name=wohnort,
> type=STRING)
> main [debug.model] Created CDOFeature(ID=4, name=geburtsdatum, type=DATE)
> main [debug.model] Setting server info: CDOFeature(ID=4,
> name=geburtsdatum, type=DATE) --> 6
> main [debug.model] Adding feature: CDOFeature(ID=4, name=geburtsdatum,
> type=DATE)
> name=CDOResource) --> -2
> main [debug.sql] SELECT MAX(cdo_id) FROM CDOResource
> main [debug] Max CDOID of table CDOResource: 1
> main [debug.sql] SELECT MAX(cdo_id) FROM PersonList
> main [debug] Max CDOID of table PersonList: 0
> main [debug] Max CDOID of table Person: 4
> main [debug.sql] SELECT MAX(range_ub) FROM cdo_packages
> [INFO] Repaired after crash: maxObjectID=6, maxMetaID=17
> main [debug.lifecycle] Activating SessionManager@8
> main [debug.lifecycle.dump] DUMP SessionManager@8
> sessions =
> lastSessionID = 0
> main [debug.lifecycle] Activating ResourceManager@9
> main [debug.lifecycle.dump] DUMP ResourceManager@9
> idToPathMap =
> pathToIDMap =
> main [debug.lifecycle] Activating RevisionManager@10
> main [debug.lifecycle.dump] DUMP RevisionManager@10
> CDORevisionResolverImpl.revisions =
> CDORevisionResolverImpl.currentLRUCapacity = 10000
> CDORevisionResolverImpl.revisedLRUCapacity = 100
> CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10'000]
> CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100]
> cdoPathFeature = CDOFeature(ID=9, name=path, type=STRING)
> main [debug.lifecycle.dump] DUMP Repository@11
> name = repo1
> store = DBStore@4
> uuid = null
> properties =
> revisedLRUCapacity=100
> supportingAudits=true
> currentLRUCapacity=10000
> verifyingRevisions=false
> overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f
> supportingRevisionDeltas = false
> supportingAudits = true
> verifyingRevisions = null
> packageManager = PackageManager@7
> sessionManager = SessionManager@8
> resourceManager = ResourceManager@9
> revisionManager = RevisionManager@10
> elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@1296d1d
> lastMetaID = 17
> main [debug] Configuring Net4j server from
> main [debug.lifecycle] Activating BufferPool[4'096]
> BufferPoolMonitor [debug.buffer] Start monitoring
> main [debug.lifecycle.dump] DUMP BufferPool@12
> BufferProvider.bufferCapacity = 4096
> BufferProvider.providedBuffers = 0
> BufferProvider.retainedBuffers = 0
> provider = BufferFactory[4'096]
> pooledBuffers = 0
> main [debug.lifecycle] Activating TCPSelector
> main [debug.lifecycle.dump] DUMP TCPSelector@13
> selector = sun.nio.ch.WindowsSelectorImpl@1a3aa2c
> clientOperations =
> serverOperations =
> thread = Thread[TCPSelector,5,main]
> running = true
> main [debug.lifecycle] Activating TCPAcceptor[0.0.0.0:2'036]
> main [debug] Ordering server operation REGISTER
> sun.nio.ch.ServerSocketChannelImpl[unbound]
> TCPSelector [debug] Executing server operation REGISTER
> TCPSelector [debug] Registering
> main [debug.lifecycle.dump] DUMP TCPAcceptor@14
> Acceptor.negotiator = null
> Acceptor.bufferProvider = BufferPool[4'096]
> Acceptor.protocolFactoryRegistry =
> jvm]
> jvm]
> default]
> file]
> cdo]
> cdo]
> default]
> tcp]
> challenge]
> tcp]
> default]
> http]
> tcp]
> cdo]
> http]
> Acceptor.protocolPostProcessors =
> Acceptor.receiveExecutor =
> java.util.concurrent.ThreadPoolExecutor@1ca1588
> Acceptor.connectorListener =
> org.eclipse.internal.net4j.acceptor.Acceptor$1@4bb369
> Acceptor.acceptedConnectors =
> selector = TCPSelector
> selectionKey = sun.nio.ch.SelectionKeyImpl@9dd6e2
> startSynchronously = true
> synchronousStartTimeout = 4000
> startLatch = java.util.concurrent.CountDownLatch@1abdac9[Count = 0]
> serverSocketChannel = sun.nio.ch.ServerSocketChannelImpl[/0.0.0.0:2036]
> address = 0.0.0.0
> port = 2036
> [INFO] CDO Server started
> Application Started: 2859
> TCPSelector [debug] Accepting
> TCPSelector [debug] Accepted socketChannel
> java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036
> remote=/127.0.0.1:3195]
> TCPSelector [debug.lifecycle] Activating
> ServerTCPConnector[127.0.0.1:3'195]
> TCPSelector [debug.connector] Setting state CONNECTING (was
> disconnected) for ServerTCPConnector[127.0.0.1:3'195]
> TCPSelector [debug.lifecycle] Activating Channel[Control]
> TCPSelector [debug.lifecycle] Activating ChannelReceiveSerializer@15
> TCPSelector [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@15
> Worker.daemon = false
> Worker.activationTimeout = 2000
> Worker.deactivationTimeout = 2000
> Worker.activationLatch =
> java.util.concurrent.CountDownLatch@14426a6[Count = 0]
> Worker.workerThread = Thread[ReceiveSerializer-1,5,main]
> QueueWorker.queue =
> QueueWorker.pollMillis = 100
> TCPSelector [debug.lifecycle.dump] DUMP ControlChannel@16
> Channel.channelID = 0
> Channel.channelMultiplexer = ServerTCPConnector[127.0.0.1:3'195]
> Channel.channelIndex = -1
> Channel.receiveExecutor =
> Channel.receiveHandler = null
> Channel.receiveSerializer = ChannelReceiveSerializer@15
> Channel.sendQueue =
> registrations = SynchronizingCorrelator{}
> TCPSelector [debug] Ordering server operation REGISTER
> TCPSelector [debug.connector] Setting state CONNECTED (was connecting)
> TCPSelector [debug.lifecycle.dump] DUMP TCPServerConnector@17
> Connector.userID = null
> Connector.protocolFactoryRegistry =
> jvm]
> jvm]
> default]
> file]
> cdo]
> cdo]
> default]
> tcp]
> challenge]
> tcp]
> default]
> http]
> tcp]
> cdo]
> http]
> Connector.protocolPostProcessors =
> Connector.negotiator = null
> Connector.negotiationContext = null
> Connector.bufferProvider = BufferPool[4'096]
> Connector.receiveExecutor =
> Connector.nextChannelID = 1
> Connector.channels =
> Connector.channelsLock =
> org.eclipse.net4j.util.concurrent.RWLock@1c01ba9[Write locks = 0, Read
> locks = 0]
> Connector.connectorState = CONNECTED
> Connector.channelListener =
> org.eclipse.internal.net4j.connector.Connector$1@1582a7c
> Connector.finishedConnecting =
> java.util.concurrent.CountDownLatch@14d556e[Count = 1]
> Connector.finishedNegotiating =
> java.util.concurrent.CountDownLatch@23d275[Count = 1]
> TCPConnector.socketChannel =
> TCPConnector.selector = TCPSelector
> TCPConnector.selectionKey = sun.nio.ch.SelectionKeyImpl@5cc942
> TCPConnector.writeQueue =
> TCPConnector.inputBuffer = null
> TCPConnector.controlChannel = Channel[Control]
> TCPConnector.host = null
> TCPConnector.port = 0
> acceptor = TCPAcceptor[0.0.0.0:2'036]
> TCPSelector [debug.acceptor] Added connector
> TCPSelector [debug] Reading java.nio.channels.SocketChannel[connected
> local=/127.0.0.1:2036 remote=/127.0.0.1:3195]
> TCPSelector [debug.buffer] Created Buffer@18
> TCPSelector [debug.buffer] Obtained Buffer@18
> TCPSelector [debug.buffer] Read 12 bytes
> 02 00 00 00 01 00 00 00 03 63 64 6f
> TCPSelector [debug.lifecycle] Activating SignalProtocol[cdo]
> TCPSelector [debug.lifecycle.dump] DUMP CDOServerProtocol@19
> Protocol.channel = Channel[-32'768]
> Protocol.bufferProvider = BufferPool[4'096]
> Protocol.executorService =
> Protocol.infraStructure =
> org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @109da93
> SignalProtocol.streamWrapper = null
> SignalProtocol.signals =
> SignalProtocol.nextCorrelationID = 1
> TCPSelector [debug.connector] Opening channel ID 1 with protocol cdo
> TCPSelector [debug.lifecycle] Activating Channel[0]
> TCPSelector [debug.lifecycle] Activating ChannelReceiveSerializer@20
> TCPSelector [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@20
> java.util.concurrent.CountDownLatch@145e5a6[Count = 0]
> Worker.workerThread = Thread[ReceiveSerializer0,5,main]
> QueueWorker.queue =
> TCPSelector [debug.lifecycle.dump] DUMP Channel@21
> channelID = 1
> channelIndex = 0
> receiveExecutor = java.util.concurrent.ThreadPoolExecutor@1ca1588
> receiveHandler = SignalProtocol[cdo]
> receiveSerializer = ChannelReceiveSerializer@20
> sendQueue =
> TCPSelector [debug.buffer] Created Buffer@22
> TCPSelector [debug.buffer] Obtained Buffer@22
> TCPSelector [debug.channel] Handling buffer from client: Buffer@22 -->
> Channel[Control]
> TCPSelector [debug] Ordering server operation INTEREST WRITE
> remote=/127.0.0.1:3195] = true
> TCPSelector [debug.buffer] Retaining Buffer@18
> TCPSelector [debug] Executing server operation INTEREST WRITE
> TCPSelector [debug] Setting interest READ|WRITE (was read)
> TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected
> TCPSelector [debug.buffer] Writing 4 bytes
> 03 00 00 01
> TCPSelector [debug.buffer] Retaining Buffer@22
> remote=/127.0.0.1:3195] = false
> TCPSelector [debug] Setting interest READ (was read|write)
> TCPSelector [debug.buffer] Read 16 bytes (EOS)
> 00 00 00 01 00 01 01 00 05 72 65 70 6f 31 00 00
> TCPSelector [debug.channel] Handling buffer from multiplexer:
> Buffer@18 --> Channel[0]
> ReceiveSerializer0 [debug.signal] Received buffer for correlation 1
> ReceiveSerializer0 [debug.signal] Got signal id 1
> Thread-2 [debug.signal] ================ Indicating OpenSessionIndication
> Thread-2 [debug.protocol] Read repositoryName: repo1
> Thread-2 [debug.buffer] Retaining Buffer@18
> Thread-2 [debug.protocol] Read legacySupportEnabled: false
> Thread-2 [debug.signal] ================ Responding OpenSessionIndication
> Thread-2 [debug.session] Opening session 1
> Thread-2 [debug.lifecycle] Activating Session[1, Channel[0]]
> Thread-2 [debug.lifecycle.dump] DUMP Session@23
> protocol = SignalProtocol[cdo]
> sessionID = 1
> legacySupportEnabled = false
> views =
> protocolListener = org.eclipse.emf.cdo.internal.server.Session$1@1f2edd2
> Thread-2 [debug.protocol] Writing sessionID: 1
> Thread-2 [debug.buffer] Obtained Buffer@22
> Thread-2 [debug.protocol] Writing repositoryUUID:
> Thread-2 [debug.protocol] Writing factory name:
> org.eclipse.emf.cdo.spi.common.CDOIDLongFactoryImpl
> Thread-2 [debug.protocol] Writing 0 library names
> Thread-2 [debug.protocol] Writing package info:
> uri=http://www.ruag.com/panther/person/model/1.0.0, dynamic=true,
> Thread-2 [debug.model] Writing CDOID of type 4 (META)
> Thread-2 [debug.channel] Handling buffer from client: Buffer@22 -->
> Channel[0]
> Thread-2 [debug] Ordering server operation INTEREST WRITE
> TCPSelector [debug.buffer] Writing 174 bytes (EOS)
> 00 00 00 00 00 00 00 01 01 00 24 31 66 66 35 64 32 32 36 2d 62 31 66
> 30 2d 34 30 66 62 2d 61 62 61 32 2d 30 63 33 31 62 33 38 63 37 36 34
> 66 00 01 00 33 6f 72 67 2e 65 63 6c 69 70 73 65 2e 65 6d 66 2e 63 64
> 6f 2e 73 70 69 2e 63 6f 6d 6d 6f 6e 2e 43 44 4f 49 44 4c 6f 6e 67 46
> 61 63 74 6f 72 79 49 6d 70 6c 00 00 00 00 00 01 00 2e 68 74 74 70 3a
> 2f 2f 77 77 77 2e 72 75 61 67 2e 63 6f 6d 2f 70 61 6e 74 68 65 72 2f
> 70 65 72 73 6f 6e 2f 6d 6f 64 65 6c 2f 31 2e 30 2e 30 00 01 01 04 00
> 00 00 00 00 00 00 01 00 00 00 11 00 00
> TCPSelector [debug.buffer] Read 11 bytes (EOS)
> 00 00 00 02 00 03 00 00 00 01 01
> ReceiveSerializer0 [debug.signal] Received buffer for correlation 2
> ReceiveSerializer0 [debug.signal] Got signal id 3
> ViewsChangedIndication
> Channel[0]
> TCPSelector [debug.buffer] Writing 5 bytes (EOS)
> 00 00 00 01 01
> TCPSelector [debug.buffer] Read 27 bytes (EOS)
> 00 00 00 03 00 04 01 00 11 2f 70 65 72 73 6f 6e 65 6e 2f 70 65 72 73
> 6f 6e 31 00
> ReceiveSerializer0 [debug.signal] Received buffer for correlation 3
> ReceiveSerializer0 [debug.signal] Got signal id 4
> Thread-2 [debug.signal] ================ Indicating ResourceIDIndication
> Thread-2 [debug.protocol] Read path: /personen/person1
> Thread-2 [debug] SELECT cdo_id FROM CDOResource WHERE
> path='/personen/person1'
> Thread-2 [debug.session] Registering resource: OID1 <-->
> /personen/person1
> Thread-2 [debug.signal] ================ Responding ResourceIDIndication
> Thread-2 [debug.protocol] Writing ID: OID1
> Thread-2 [debug.model] Writing CDOID of type 1 (OBJECT)
> Channel[0]
> TCPSelector [debug.buffer] Writing 13 bytes (EOS)
> 00 00 00 02 01 00 00 00 00 00 00 00 01
> 00 00 00 04 00 04 01 00 11 2f 70 65 72 73 6f 6e 65 6e 2f 70 65 72 73
> 6f 6e 31 00
> ReceiveSerializer0 [debug.signal] Received buffer for correlation 4
> Channel[0]
> 00 00 00 03 01 00 00 00 00 00 00 00 01
> 00 00 00 05 00 07 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 01
> 00 00 00 00
> ReceiveSerializer0 [debug.signal] Received buffer for correlation 5
> ReceiveSerializer0 [debug.signal] Got signal id 7
> Thread-2 [debug.protocol] Read referenceChunk: -1
> Thread-2 [debug.protocol] Reading 1 IDs
> Thread-2 [debug.model] Reading CDOID of type 1 (OBJECT)
> Thread-2 [debug.protocol] Read ID: OID1
> Thread-2 [debug.protocol] Writing 1 revisions
> Thread-2 [debug] Selecting revision: OID1
> Thread-2 [debug] Selecting object type: OID1
> Thread-2 [debug.sql] CREATE TABLE cdo_objects (cdo_id BIGINT,
> cdo_class INTEGER)
> Thread-2 [debug.sql] -- Table/View 'CDO_OBJECTS' already exists in
> Schema 'APP'.
> Thread-2 [debug.sql] SELECT cdo_class FROM cdo_objects WHERE cdo_id=1
> cdo_resource, cdo_container, cdo_feature, path FROM CDOResource WHERE
> cdo_id=1 AND cdo_revised=0
> Thread-2 [debug.revision] Setting version for CDOResource@OID1v0: v1
> Thread-2 [debug.revision] Setting created CDOResource@OID1v1:
> 26.11.2008 16:51:11
> Thread-2 [debug.revision] Setting revised CDOResource@OID1v1:
> 01.01.1970 01:00:00
> Thread-2 [debug.revision] Setting resourceID CDOResource@OID1v1: OID1
> Thread-2 [debug.revision] Setting containerID CDOResource@OID1v1: NULL
> Thread-2 [debug.revision] Setting containingFeatureID
> CDOResource@OID1v1: 0
> Thread-2 [debug] SELECT cdo_target FROM CDOResource_contents_refs
> WHERE cdo_source=1 AND cdo_version=1 ORDER BY cdo_idx
> /personen/person1
> Thread-2 [debug.revision] Adding revision: CDOResource@OID1v1,
> created=26.11.2008 16:51:11, revised=01.01.1970 01:00:00, current=true
> Thread-2 [debug.revision] Writing revision: ID=OID1,
> classRef=CDOClassRef(http://www.eclipse.org/emf/CDO/resource/1.0.0,
> 0), className=CDOResource, version=1, created=1'227'714'671'442,
> revised=0, resource=OID1, container=NULL, feature=0
> Thread-2 [debug.model] Writing CDOID of type 0 (NULL)
> Thread-2 [debug.revision] Writing feature CDOFeature(ID=9, name=path,
> type=STRING): /personen/person1
> Thread-2 [debug.revision] Writing feature CDOFeature(ID=2,
> name=contents, type=CDOClass(ID=0, name=CDOObject)): size=2
> Thread-2 [debug.revision] OID2
> Thread-2 [debug.revision] OID4
> Thread-2 [debug.protocol] Writing 0 additional revisions
> Channel[0]
Re: CDO 1.0.4 problem: Revision not found [message #425565 is a reply to message #425557] Mon, 01 December 2008 11:34 Go to previous messageGo to next message
Yes I remembered a fix we did previously that could cause that if you
are using an old database. (objects created with 1.0.0)
Can you confirm that you didn't reset your database ?
But without that fix you could not be able to modify that object.
This is what could cause the problems:
BEFORE
if (attributeMappings != null)
writeAttributes(storeWriter, (InternalCDORevision)revision);
AFTER
252982: [DB] exception when trying to commit changes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252982
Basically, before that patch some data wasn't inserted in the database..
like the version and revision value.
Simon
Eike Stepper wrote:
> Christian,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hello CDO gurus
>> id=1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance,
>> Christian
>> COMPLETE LOG:
>> Configuration file:
>> loaded
>> Install location:
>> Framework located:
>> Splash location:
>> null
>> Debug options:
>> loaded
>> jvm]
>> jvm]
>> default]
>> file]
>> cdo]
>> cdo]
>> default]
>> tcp]
>> challenge]
>> tcp]
>> default]
>> http]
>> tcp]
>> cdo]
>> http]
>> processors =
>> jvm]
>> jvm]
>> default]
>> file]
>> cdo]
>> cdo]
>> default]
>> tcp]
>> challenge]
>> tcp]
>> default]
>> http]
>> tcp]
>> cdo]
>> http]
>> type=STRING)
>> 'APP'.
>> 'APP'.
>> 'APP'.
>> Schema 'APP'.
>> Schema 'APP'.
>> table = null
>> idField = null
>> typeField = null
>> Store.type = db
>> dbSchema = null
>> nextPackageID = 2
>> nextClassID = 3
>> nextFeatureID = 7
>> cdo_packages
>> name=personen,
>> --> 1
>> type=STRING) --> 2
>> type=STRING)
>> type=STRING)
>> type=INT) --> 4
>> type=STRING) --> 5
>> type=STRING)
>> type=DATE)
>> sessions =
>> lastSessionID = 0
>> idToPathMap =
>> pathToIDMap =
>> name = repo1
>> store = DBStore@4
>> uuid = null
>> properties =
>> lastMetaID = 17
>> pooledBuffers = 0
>> clientOperations =
>> serverOperations =
>> running = true
>> jvm]
>> jvm]
>> default]
>> file]
>> cdo]
>> cdo]
>> default]
>> tcp]
>> challenge]
>> tcp]
>> default]
>> http]
>> tcp]
>> cdo]
>> http]
>> address = 0.0.0.0
>> port = 2036
>> QueueWorker.queue =
>> Channel.sendQueue =
>> jvm]
>> jvm]
>> default]
>> file]
>> cdo]
>> cdo]
>> default]
>> tcp]
>> challenge]
>> tcp]
>> default]
>> http]
>> tcp]
>> cdo]
>> http]
>> locks = 0]
>> QueueWorker.queue =
>> channelID = 1
>> channelIndex = 0
>> sendQueue =
>> Channel[Control]
>> 03 00 00 01
>> sessionID = 1
>> views =
>> Channel[0]
>> Channel[0]
>> 00 00 00 01 01
>> 6f 6e 31 00
>> /personen/person1
>> Channel[0]
>> 6f 6e 31 00
>> Channel[0]
Re: CDO 1.0.4 problem: Revision not found [message #425580 is a reply to message #425565] Tue, 02 December 2008 09:17 Go to previous message
Thanks Simon for your response. I didn't reset the database.
Now that I set up the database again it works. Thanks.
Christian
> BEFORE
> AFTER
> Simon
Previous Topic:OrderBy example?
Next Topic:EStore: remove method is invoked right after an adding
Current Time: Sat Jul 19 20:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.18959 seconds
