Home » Modeling » EMF » Connector is not connected
Connector is not connected [message #425526] Sun, 30 November 2008 12:15 Go to next message
I am trying to run a CDO server but when I client (CDO Sessions View) tries
to connect, It gives the following exception:
[ERROR] Connector is not connected
java.lang.IllegalStateException: Connector is not connected
at
org.eclipse.net4j.internal.tcp.ControlChannel.assertConnecte d(ControlChannel.java:238)
at
org.eclipse.net4j.internal.tcp.ControlChannel.handleBufferFr omMultiplexer(ControlChannel.java:137)
at
org.eclipse.net4j.internal.tcp.TCPConnector.handleRead(TCPCo nnector.java:179)
at
org.eclipse.net4j.internal.tcp.TCPSelector.handleSelection(T CPSelector.java:255)
at org.eclipse.net4j.internal.tcp.TCPSelector.run(TCPSelector.j ava:170)
Any ideas,
Tankut
Re: Connector is not connected [message #425542 is a reply to message #425526] Mon, 01 December 2008 06:35 Go to previous messageGo to next message
Tankut,
I nearly overlooked you question because it is neither tagged with [CDO]
nor with [Net4j]. Just a hint for future questions ;-)
From your question I only see that a connection was not opened. This
copuld have so many reasons, including:
- server not started
- server started but acceptor not started
- acceptor listens on different port or address
- connector and acceptor started but network failed
- connector deactivated locally after initial requests had been sent
I'd really need more context information to answer your question. Could
you describe what you have done so far?
Additionally you could provide the client and server console logs (did
you enable tracing at both ends?)...
Cheers
/Eike
Tankut Koray schrieb:
> tries to connect, It gives the following exception:
> at
> at
> at
> at
> Any ideas,
> Tankut
Re: Connector is not connected [CDO] [message #425750 is a reply to message #425542] Sat, 06 December 2008 17:51 Go to previous messageGo to next message
Thanks Eike,
I was writing a reply with my logs but I have another look at configuration
of server and when I commented out the negotiator in my acceptor, every
thing is working fine now.
Just a note if someone will have the same issue,
Tankut
"Eike Stepper" <stepper@esc-net.de> wrote in message
news:gh0i5k$vfc$5@build.eclipse.org...
> Tankut,
> Additionally you could provide the client and server console logs (did you
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi,
>> at
>> at
>> at
>> at
>> Any ideas,
>> Tankut
Re: Connector is not connected [CDO] [message #425751 is a reply to message #425750] Sun, 07 December 2008 04:45 Go to previous message
Tankut,
Oh yes, the negotiators of a connector / acceptor pair must match
together or be empty both.
Good that you found it.
Cheers
/Eike
> Thanks Eike,
> configuration
> Tankut
>> Tankut,
>> [CDO] nor with [Net4j]. Just a hint for future questions ;-)
>> Could you describe what you have done so far?
>> (did you enable tracing at both ends?)...
>> Cheers
>> /Eike
>>> Hi,
>>> View) tries to connect, It gives the following exception:
>>> at
>>> at
>>> at
>>> at
>>> Any ideas,
>>> Tankut
Previous Topic:[TENEO] MappingException
Next Topic:"run as eclipse application" starts always old plugin
Current Time: Sat Jul 19 21:08:23 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
