Home » Modeling » EMF » CDO Server crashes at startup with MySQL adapter
CDO Server crashes at startup with MySQL adapter [message #425510] Fri, 28 November 2008 09:18 Go to next message
I'm stuck on a ClassLoader trouble while I start my CDO Server.
I created a product configuration with all required plugins
It is OK with a derby database but fails with an MySQL Adapter.
It appears that the DBUtil of the 'org.eclipse.net4j.db' uses the OM
ClassLoader of 'the org.eclipse.net4j.db'. But the MysqlDataSource is not
loaded is this classloader. See exception below...
How can I fix this?
Thanks for your contribution.
Olivier
cdo-server.xml
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="/temp/users.db"/>
</acceptor>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="supportingRevisionDeltas" value="false"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<!-- type: horizontal | vertical | <any user-contributed type>-->
<mappingStrategy type="horizontal">
<property name="toManyReferences" value="ONE_TABLE_PER_CLASS"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
<property name="mappingPrecedence" value="MODEL"/>
<property name="qualifiedNames" value="true"/>
</mappingStrategy>
<dbAdapter name="mysql"/>
<dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost/cdodb1"
user="root"/>
</store>
</repository>
</cdoServer>
CDOWithMySQLServer.product
<?pde version="3.4"?>
<product name="CDOMySQL Server" id="org.eclipse.emf.cdo.server.product"
application="org.eclipse.emf.cdo.server.app" version="1.0.0"
useFeatures="false">
<configIni use="default">
</configIni>
<launcherArgs>
<vmArgsMac>-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
</launcherArgs>
<windowImages/>
<launcher>
<solaris/>
<win useIco="false">
<bmp/>
</win>
</launcher>
<vm>
</vm>
<plugins>
<plugin id="javax.servlet"/>
<plugin id="org.apache.derby"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.auth"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.emf.cdo"/>
<plugin id="org.eclipse.emf.cdo.common"/>
<plugin id="org.eclipse.emf.cdo.server"/>
<plugin id="org.eclipse.emf.cdo.server.db"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.net4j"/>
<plugin id="org.eclipse.net4j.db"/>
<plugin id="org.eclipse.net4j.db.mysql"/>
<plugin id="org.eclipse.net4j.tcp"/>
<plugin id="org.eclipse.net4j.util"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
</plugins>
</product>
Traces
Configuration location:
file:/D:/Eclipse/Applications/EMF-Database
Connectors/eclipse-modeling-3.4-win32-Teneo/workspace_CDO/.m etadata/.plugins/org.eclipse.pde.core/New_configuration/
Configuration file:
Connectors/eclipse-modeling-3.4-win32-Teneo/workspace_CDO/.m etadata/.plugins/org.eclipse.pde.core/New_configuration/conf ig.ini
loaded
Install location:
Connectors/eclipse-modeling-3.4-win32-Teneo/eclipse/
Framework located:
Connectors/eclipse-modeling-3.4-win32-Teneo/eclipse/plugins/ org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar
Framework classpath:
Splash location:
null
Debug options:
Connectors/eclipse-modeling-3.4-win32-Teneo/workspace_CDO/.m etadata/.plugins/org.eclipse.pde.core/New_configuration/.opt ions
loaded
osgi> Time to load bundles: 0
Starting application: 1143
[INFO] CDO Server starting
main [debug.repository] Configuring CDO server from
D:\Eclipse\Applications\EMF-Database
Connectors\eclipse-modeling-3.4-win32-Teneo\eclipse\config\c do-server.xml
main [debug.repository] Configuring repository repo1 (type=default)
[ERROR] java.lang.ClassNotFoundException:
org.eclipse.net4j.db.DBException: java.lang.ClassNotFoundException:
at org.eclipse.net4j.db.DBUtil.createDataSource(DBUtil.java:69)
at org.eclipse.net4j.db.DBUtil.createDataSource(DBUtil.java:58)
at org.eclipse.net4j.db.DBUtil.createDataSource(DBUtil.java:53)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreFactory.getDat aSource(DBStoreFactory.java:116)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreFactory.create Store(DBStoreFactory.java:52)
at
org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigureStore(RepositoryConfigurator.java:130)
at
org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigureRepository(RepositoryConfigurator.java:111)
at
org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigure(RepositoryConfigurator.java:80)
at
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion.doStart(CDOServerApplication.java:50)
at
org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplicat ion.java:61)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at org.eclipse.net4j.util.ReflectUtil.instantiate(ReflectUtil.j ava:414)
at org.eclipse.net4j.db.DBUtil.createDataSource(DBUtil.java:65)
... 22 more
Re: CDO Server crashes at startup with MySQL adapter [message #425514 is a reply to message #425510] Fri, 28 November 2008 09:59 Go to previous messageGo to next message
Oliver,
Which version of CDO are you using? For 1.x we've found the
easiest way to get the MySQL driver onto the classpath is to add
the jar to the org.eclipse.net4j.db.mysql lib directory. You should
find that your eclipse installation has the org.eclipse.net4j.db.mysql
plugin unpacked, so you can directly add the MySQL driver jar
into it. You may need to edit the manifest.mf file to set the version
the same as the one that you have. After adding the jar and
modifying the manifest, just restart eclipse.
Andy.
"omoreau " <olivier.moreau@thalesgroup.com> wrote in message
news:150f537532d4cd42bf47dccd5c9b9871$1@www.eclipse.org...
> I created a product configuration with all required plugins It is OK with
> How can I fix this?
> Olivier
> cdo-server.xml
> <cdoServer>
> <negotiator type="challenge" description="/temp/users.db"/> -->
> </acceptor>
> <store type="db">
> </mappingStrategy>
> user="root"/>
> </store>
> </repository>
> </cdoServer>
> </configIni>
> <launcherArgs>
> <vmArgsMac>-XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
> </launcherArgs>
> <windowImages/>
> <launcher>
> <solaris/>
> <bmp/>
> </win>
> </launcher>
> <vm>
> </vm>
> <plugins>
> fragment="true"/>
> </plugins>
> </product>
> Traces
> Configuration file:
> loaded
> Install location:
> Framework located:
> Splash location:
> null
> Debug options:
> loaded
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 22 more
Re: CDO Server crashes at startup with MySQL adapter [message #425515 is a reply to message #425510] Fri, 28 November 2008 10:51 Go to previous messageGo to next message
Originally posted by: adomas.greicius.nomagic.com
Do your launcher validate. I don`t see any plugin that provides JDBC
drivers.
> How can I fix this?
> Olivier
> cdo-server.xml
> <cdoServer>
> </acceptor>
> <store type="db">
> </mappingStrategy>
> user="root"/>
> </store>
> </repository>
> </cdoServer>
> </configIni>
> <launcherArgs>
> </launcherArgs>
> <windowImages/>
> <launcher>
> <solaris/>
> <bmp/>
> </win>
> </launcher>
> <vm>
> </vm>
> <plugins>
> fragment="true"/>
> </plugins>
> </product>
> Traces
> Configuration file:
> loaded
> Install location:
> Framework located:
> Splash location:
> null
> Debug options:
> loaded
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
Re: CDO Server crashes at startup with MySQL adapter [message #425516 is a reply to message #425510] Fri, 28 November 2008 11:11 Go to previous message
Olivier,
We are currently using this bundle from the SpingSource repository:
http://www.springsource.com/repository/app/bundle/version/de tail?name=com.springsource.com.mysql.jdbc&version=5.1.6& amp;searchType=bundlesByName&searchQuery=mysql
please consider *voting* for these JIRAs to make it easier for us to
consume the SpringSource bundles:
https://issuetracker.springsource.com/browse/BRITS-92
https://issuetracker.springsource.com/browse/BRITS-91
Cheers
/Eike
omoreau schrieb:
> not loaded is this classloader. See exception below...
> How can I fix this?
> Olivier
> cdo-server.xml
> <cdoServer>
> </acceptor>
> <store type="db">
> </mappingStrategy>
> user="root"/>
> </store>
> </repository>
> </cdoServer>
> </configIni>
> <launcherArgs>
> </launcherArgs>
> <windowImages/>
> <launcher>
> <solaris/>
> <bmp/>
> </win>
> </launcher>
> <vm>
> </vm>
> <plugins>
> fragment="true"/>
> </plugins>
> </product>
> Traces
> Configuration file:
> loaded
> Install location:
> Framework located:
> Splash location:
> null
> Debug options:
> loaded
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
Previous Topic:Underscore rules in generated values
Next Topic:[CDO] [ECF] Invoking EMF operations remotely (client - server)
Current Time: Sat Jul 19 09:47:45 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
