Home » Modeling » EMF » OrderBy example?
OrderBy example? [message #425252] Thu, 20 November 2008 17:03 Go to next message
Hello all,
In continuing my work with Teneo, I have a Disease class containing one or
more DiseaseStages. I have the XSD working for this, but now I need to
ensure the DiseaseStages are ordered (Susceptible, Exposed, Infectious,
and Recovered, for example). Is OrderBy the correct way to do this? If so,
is there an example using OrderBy somewhere? I read in a previous post
(thanks, Martin!) you must use the OneToMany annotation with OrderBy, but
I'm not sure where to place them. Do these annotations replace the
ecore:reference and ecore:opposite attributes, or do they work with them?
If OrderBy isn't correct, could you please point me in the right
direction? Thanks in advance!
Here's my disease.xsd, (which contains DiseaseStage as well). Disease
contains an element called stages, which is associated OneToMany with
DiseaseStage via the ecore:reference and ecore:opposite mechanism. The
stages need to be ordered by DiseaseStage:ordinal.
<xs:schema xmlns="qq.mob.disease.xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
targetNamespace="qq.mob.disease.xsd" elementFormDefault="qualified"
attributeFormDefault="unqualified">
<xs:complexType name="Diseases">
<xs:sequence>
<xs:element name="disease" type="Disease" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="Disease">
<xs:annotation>
<xs:appinfo source="teneo.jpa">
@Entity
@Table(name="Disease")
</xs:appinfo>
</xs:annotation>
<xs:sequence>
<xs:element name="title" type="xs:string">
<xs:annotation>
<xs:appinfo>@Basic</xs:appinfo>
<xs:documentation>name of disease spelled out</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="stages" type="xs:anyURI"
ecore:reference="DiseaseStage" ecore:opposite="disease"
maxOccurs="unbounded" >
<xs:annotation>
<xs:documentation>Stages for this disease</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="force" type="xs:double">
<xs:annotation>
<xs:documentation>force of infection</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
<xs:attribute name="id" type="xs:long"/>
</xs:complexType>
<xs:complexType name="DiseaseStage">
<xs:annotation>
@Entity
@Table(name="DiseaseStage")
</xs:appinfo>
</xs:annotation>
<xs:sequence>
<xs:element name="code" type="xs:string">
<xs:annotation>
<xs:documentation>one character code</xs:documentation>
</xs:annotation>
</xs:element>
<xs:annotation>
<xs:documentation>name of stage spelled out</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="ordinal" type="xs:int">
<xs:annotation>
<xs:documentation>governs the order of progression through the
stages</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="duration" type="xs:int">
<xs:annotation>
<xs:documentation>value of -1 means forever</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="suseptable" type="xs:boolean">
<xs:annotation>
<xs:documentation>does this stage represent
susceptible?</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="infected" type="xs:boolean">
<xs:annotation>
<xs:documentation>does this stage represent infected?</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="infectious" type="xs:boolean">
<xs:annotation>
<xs:documentation>does this stage represent infectious?</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="immune" type="xs:boolean">
<xs:annotation>
<xs:documentation>does this stage represent immune?</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="disease" type="xs:anyURI" ecore:opposite="stages"
ecore:reference="Disease">
<xs:annotation>
<xs:documentation>Disease this stage is part of.</xs:documentation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:complexType name="PooledState">
<xs:sequence/>
</xs:complexType>
</xs:schema>
Re: OrderBy example? [message #425267 is a reply to message #425252] Fri, 21 November 2008 06:39 Go to previous messageGo to next message
Hi John,
Orderby is specified by adding an OrderBy annotation:
@OrderBy("name")
so something like this:
<xs:element name="stages" type="xs:anyURI" ecore:reference="DiseaseStage" ecore:opposite="disease"
<xs:annotation>
@OrderBy("ordinal")
</xs:appinfo>
</xs:annotation>
</xs:element>
so it is not necessary to have a OneToMany annotation.
gr. Martin
John G wrote:
> Hello all, In continuing my work with Teneo, I have a Disease class
> containing one or more DiseaseStages. I have the XSD working for this,
> but now I need to ensure the DiseaseStages are ordered (Susceptible,
> Exposed, Infectious, and Recovered, for example). Is OrderBy the correct
> way to do this? If so, is there an example using OrderBy somewhere? I
> read in a previous post (thanks, Martin!) you must use the OneToMany
> annotation with OrderBy, but I'm not sure where to place them. Do these
> annotations replace the ecore:reference and ecore:opposite attributes,
> or do they work with them? If OrderBy isn't correct, could you please
> point me in the right direction? Thanks in advance!
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:annotation>
> @Entity
> </xs:appinfo>
> </xs:annotation>
> <xs:sequence>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> <xs:annotation>
> @Entity
> </xs:appinfo>
> </xs:annotation>
> <xs:sequence>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> through the stages</xs:documentation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> ecore:opposite="stages" ecore:reference="Disease">
> <xs:annotation>
> </xs:annotation>
> </xs:element>
> </xs:sequence>
> </xs:complexType>
> <xs:sequence/>
> </xs:complexType>
> </xs:schema>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: OrderBy example? [message #425287 is a reply to message #425267] Fri, 21 November 2008 10:27 Go to previous messageGo to next message
Thanks, Martin, for your reply.
When I placed the @OrderBy("ordinal") into my XSD, reloaded my genmodel,
regenerated my model code, then re-ran my test, I got an error:
1671 [main] ERROR org.hibernate.util.XMLHelper - Error parsing XML: XML
String(808) The content of element type "class" must match
" (meta*,subselect?,cache?,synchronize*,comment?,tuplizer*,(id |composite-id),discriminator?,natural-id?,(version|timestamp )?,(property|many-to-one|one-to-one|component|dynamic-compon ent|properties|any|map|set|list|bag|idbag|array|primitive-ar ray)*,((join*,subclass*)|joined-subclass*|union-subclass*),l oader?,sql-insert?,sql-update?,sql-delete?,filter*,resultset *,(query|sql-query)*) ".
I examined the hibernate-mapping xml which the logger printed to the
console; line 808 of that xml closes class DiseaseStageImpl, but I don't
see any problem with it (by no means am I an xml expert, though!) I also
checked the classes declared around there, just in case, and they also
looked OK.
Where did I go wrong?
Here's my XSD (this time with the @OrderBy content). The logger (console)
output follows that.
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:annotation>
@Entity
</xs:appinfo>
</xs:annotation>
<xs:sequence>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
@OrderBy("ordinal")
</xs:appinfo>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:annotation>
@Entity
</xs:appinfo>
</xs:annotation>
<xs:sequence>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
<xs:annotation>
</xs:annotation>
</xs:element>
</xs:sequence>
</xs:complexType>
<xs:sequence/>
</xs:complexType>
</xs:schema>
Logger output (console):
0 [main] INFO qq.hibernate.TestTeneo - inside test
62 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Creating emf
data store and registering it under name: EipCaseDataStore
156 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore -
Initializing protocol/extension for hibernate
156 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Returning
created emf data store, initialize this newly created data store!
156 [main] INFO qq.hibernate.TestTeneo - after creating dataStore
562 [main] INFO qq.hibernate.TestTeneo - after setting package
577 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Registering point:
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder classname:
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder default: true
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator classname:
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator default: true
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder
classname:
default: true
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper classname:
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper default: true
593 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.mapping.strategy.EntityNameStrategy classname:
org.eclipse.emf.teneo.mapping.strategy.impl.EntityResolvingN ameStrategy
default: true
org.eclipse.emf.teneo.mapping.strategy.SQLNameStrategy classname:
org.eclipse.emf.teneo.mapping.strategy.impl.TeneoSQLNameStra tegy default:
true
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceContentH andler
classname:
default: true
org.eclipse.emf.teneo.annotations.xml.XmlElementToEStructura lFeatureMapper
classname:
default: true
- Registering point: org.eclipse.emf.teneo.PersistenceOptions classname:
org.eclipse.emf.teneo.PersistenceOptions default: true
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.OneToManyAttributeA nnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator
classname:
org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator default:
true
org.eclipse.emf.teneo.annotations.mapper.BidirectionalManyTo ManyAnnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.UnidirectionalManyT oManyAnnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.OneToManyReferenceA nnotator
classname:
default: true
609 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.annotations.mapper.OneToOneReferenceAn notator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.ManyToOneReferenceA nnotator
classname:
default: true
- Registering point: org.eclipse.emf.teneo.hibernate.HbContext classname:
org.eclipse.emf.teneo.hibernate.HbContext default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rAccessor
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rFeatureIDAccessor
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rFeatureIDPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.EListProper tyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.EReferenceP ropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapE ntryFeatureURIPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapE ntryPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapP ropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler
classname:
default: true
- Registering point: org.eclipse.emf.teneo.hibernate.EMFInterceptor
classname: org.eclipse.emf.teneo.hibernate.EMFInterceptor default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableFeatureMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HbExtraLazyPer sistableEList
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.MapHibernatePe rsistableEMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator
classname:
org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator default:
true
org.eclipse.emf.teneo.hibernate.mapper.MappingContext classname:
org.eclipse.emf.teneo.hibernate.mapper.MappingContext default: true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper default: true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper default:
true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper default:
true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.IdMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.IdMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper default: true
org.eclipse.emf.teneo.hibernate.mapping.EMFInitializeCollect ionEventListener
classname:
default: true
org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper classname:
org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper default: true
org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er classname:
org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er default:
true
org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r classname:
org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r default: true
org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r classname:
org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r default: true
org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper classname:
org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er classname:
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er default:
true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper
classname: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper default:
true
org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.TableMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.TableMapper default: true
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator classname:
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator default: true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.MappingContext
classname: org.eclipse.emf.teneo.jpox.mapper.MappingContext default: true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.NamingHandler
classname: org.eclipse.emf.teneo.jpox.mapper.NamingHandler default: true
org.eclipse.emf.teneo.hibernate.annotations.HbAnnotationMode lBuilder
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbEAnnotationPar serImporter
default: true
org.eclipse.emf.teneo.hibernate.annotations.HbXmlPersistence Mapper
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbSingleAttribut eAnnotator
default: true
org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r default: true
org.eclipse.emf.teneo.hibernate.annotations.HbEFeatureAnnota tor default:
true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyAttri buteAnnotator
default: true
org.eclipse.emf.teneo.hibernate.annotations.HbEDataTypeAnnot ator default:
true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyRefer enceAnnotator
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToOneRefere nceAnnotator
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbManyToOneRefer enceAnnotator
default: true
default: true
classname:
default: true
default: true
classname:
default: true
true
classname:
default: true
true
classname:
default: true
classname:
default: true
classname:
default: true
609 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore -
Initializing Hb Session DataStore
>>>>> Creating HB Configuration
656 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.2.6
656 [main] INFO org.hibernate.cfg.Environment - loaded properties from
resource hibernate.properties:
{hibernate.connection.driver_class=com.mysql.jdbc.Driver,
hibernate.max_fetch_depth=1,
hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect,
hibernate.format_sql=true, hibernate.query.substitutions=yes 'Y', no 'N',
hibernate.connection.username=epiuser,
hibernate.connection.url=jdbc:mysql://localhost:3306/epidb_t,
hibernate.bytecode.use_reflection_optimizer=false,
hibernate.show_sql=false, hibernate.connection.password=****}
656 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name
: cglib
671 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4
java.sql.Timestamp handling
749 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Searching extension org.eclipse.emf.teneo.PersistenceOptions
749 [main] INFO
org.eclipse.emf.teneo.classloader.ClassClassLoaderStrategy - Class loader
strategy set to:
org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
- Initargs passed, using constructor for class
749 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - Properties
of PersistenceOptions:
teneo.mapping.fetch_containment_eagerly: false
teneo.naming.version_column: e_version
teneo.mapping.disable_econtainer: false
teneo.mapping.default_cache_strategy: NONE
teneo.mapping.sql_name_escape_character: `
teneo.mapping.set_default_cascade_on_non_containment:
teneo.mapping.map_all_lists_as_idbag: false
teneo.naming.max_sql_name_length: -1
teneo.mapping.default_temporal: TIMESTAMP
teneo.mapping.emap_as_true_map: true
teneo.mapping.default_varchar_length: -1
teneo.naming.default_id_column: e_id
teneo.mapping.also_map_as_class: true
teneo.mapping.add_index_for_fk: false
teneo.naming.join_table_naming_strategy: unique
teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
teneo.mapping.always_version: true
teneo.naming.idbag_id_column_name: ID
teneo.mapping.max_comment_length: 0
teneo.mapping.set_entity_automatically: true
teneo.mapping.hibernate_mapping_file: false
teneo.naming.set_foreign_key_name: true
teneo.mapping.cascade_policy_on_containment: ALL
teneo.naming.id_feature_as_primary_key: true
teneo.naming.set_generated_value_on_id_feature: true
teneo.runtime.update_schema: true
teneo.naming.strategy: lowercase
teneo.mapping.UserDateTimeType:
org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
teneo.mapping.always_map_list_as_bag: false
teneo.naming.join_column_naming_strategy: unique
teneo.mapping.set_proxy: false
teneo.mapping.UserDateType: org.eclipse.emf.teneo.hibernate.mapping.XSDDate
teneo.mapping.cascade_policy_on_non_containment:
teneo.mapping.ignore_eannotations: false
teneo.naming.default_id_feature: e_id
teneo.mapping.optimistic_locking: true
teneo.mapping.map_embeddable_as_embedded: false
teneo.mapping.cascade_all_on_containment:
teneo.mapping.join_table_for_non_contained_associations: true
- Created extensionPoint instance: org.eclipse.emf.teneo.PersistenceOptions
749 [main] WARN org.eclipse.emf.teneo.extension.DefaultExtensionManager
- The extension: org.eclipse.emf.teneo.PersistenceOptions is declared as a
singleton but this getInstance call passed initialization parameters so
it is not cached, org.eclipse.emf.teneo.PersistenceOptions
749 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore -
Generating mapping file from in-mem ecore
765 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Caching extension instance as singleton point:
classname:
default: true
781 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
default: true
781 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder -
Creating pamodel for the following epackages
781 [main] DEBUG
epicase
937 [main] DEBUG
epistate
952 [main] DEBUG
person
952 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - init
952 [main] DEBUG
location
952 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - pool
952 [main] DEBUG
disease
952 [main] DEBUG
epiperson
952 [main] DEBUG
Create base pannotated model
952 [main] DEBUG
Deprecated eannotations with http://annotations.elver.org or
http://ejb.elver.org are ignored.
952 [main] DEBUG
Parse annotations
952 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
968 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
968 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter -
Processing package epicase
968 [main] DEBUG
Processing epicase
968 [main] DEBUG
Number of parsed typename annotations 0
968 [main] DEBUG
Processing EpiCase
968 [main] DEBUG
968 [main] DEBUG
Processing eclass EpiCase
968 [main] DEBUG
Processing zcta
968 [main] DEBUG
968 [main] DEBUG
Processing disease
968 [main] DEBUG
968 [main] DEBUG
Processing epiDate
968 [main] DEBUG
968 [main] DEBUG
Processing sentenial
968 [main] DEBUG
968 [main] DEBUG
Processing stage
968 [main] DEBUG
968 [main] DEBUG
Processing EpiCases
968 [main] DEBUG
968 [main] DEBUG
Processing eclass EpiCases
968 [main] DEBUG
Processing epiCase
968 [main] DEBUG
968 [main] DEBUG
Processing package epistate
968 [main] DEBUG
Processing epistate
968 [main] DEBUG
968 [main] DEBUG
Processing EpiState
968 [main] DEBUG
968 [main] DEBUG
Processing eclass EpiState
968 [main] DEBUG
Processing timeStep
968 [main] DEBUG
968 [main] DEBUG
Processing TimeStep
968 [main] DEBUG
968 [main] DEBUG
Processing eclass TimeStep
968 [main] DEBUG
Processing healthy
968 [main] DEBUG
968 [main] DEBUG
Processing disease
968 [main] DEBUG
968 [main] DEBUG
Processing timeStamp
968 [main] DEBUG
968 [main] DEBUG
Processing TimeStepDisease
968 [main] DEBUG
968 [main] DEBUG
Processing eclass TimeStepDisease
968 [main] DEBUG
Processing disease
968 [main] DEBUG
968 [main] DEBUG
Processing stages
968 [main] DEBUG
968 [main] DEBUG
Processing TimeStepStage
968 [main] DEBUG
968 [main] DEBUG
Processing eclass TimeStepStage
968 [main] DEBUG
Processing code
968 [main] DEBUG
968 [main] DEBUG
Processing population
968 [main] DEBUG
968 [main] DEBUG
Processing package person
968 [main] DEBUG
Processing person
968 [main] DEBUG
968 [main] DEBUG
Processing EpiPerson
968 [main] DEBUG
968 [main] DEBUG
Processing eclass EpiPerson
968 [main] DEBUG
Processing zcta
968 [main] DEBUG
968 [main] DEBUG
Processing origin
968 [main] DEBUG
968 [main] DEBUG
Processing destination
968 [main] DEBUG
968 [main] DEBUG
Processing initialTime
968 [main] DEBUG
968 [main] DEBUG
Processing currentTime
968 [main] DEBUG
968 [main] DEBUG
Processing stayDuration
968 [main] DEBUG
968 [main] DEBUG
Processing transportMode
968 [main] DEBUG
968 [main] DEBUG
Processing personState
968 [main] DEBUG
968 [main] DEBUG
Processing id
968 [main] DEBUG
968 [main] DEBUG
Processing PersonState
968 [main] DEBUG
968 [main] DEBUG
Processing eclass PersonState
968 [main] DEBUG
Processing states
968 [main] DEBUG
968 [main] DEBUG
Processing State
968 [main] DEBUG
968 [main] DEBUG
Processing eclass State
968 [main] DEBUG
Processing disease
968 [main] DEBUG
968 [main] DEBUG
Processing effectiveContact
968 [main] DEBUG
968 [main] DEBUG
Processing lastTransitionTime
968 [main] DEBUG
968 [main] DEBUG
Processing stage
968 [main] DEBUG
968 [main] DEBUG
Processing TransportMode
968 [main] DEBUG
968 [main] DEBUG
Processing TransportModeObject
968 [main] DEBUG
968 [main] DEBUG
Processing package init
968 [main] DEBUG
Processing init
968 [main] DEBUG
968 [main] DEBUG
Processing DiseaseStageSummary
968 [main] DEBUG
968 [main] DEBUG
Processing eclass DiseaseStageSummary
968 [main] DEBUG
Processing title
968 [main] DEBUG
968 [main] DEBUG
968 [main] DEBUG
968 [main] DEBUG
Processing DiseaseSummary
968 [main] DEBUG
968 [main] DEBUG
Processing eclass DiseaseSummary
968 [main] DEBUG
Processing title
968 [main] DEBUG
968 [main] DEBUG
968 [main] DEBUG
968 [main] DEBUG
Processing stageSummary
968 [main] DEBUG
968 [main] DEBUG
Processing DocumentRoot
968 [main] DEBUG
968 [main] DEBUG
Processing eclass DocumentRoot
968 [main] DEBUG
Processing mixed
968 [main] DEBUG
984 [main] DEBUG
Processing xMLNSPrefixMap
984 [main] DEBUG
984 [main] DEBUG
Processing xSISchemaLocation
984 [main] DEBUG
984 [main] DEBUG
Processing epiInit
984 [main] DEBUG
984 [main] DEBUG
Processing EpiInit
984 [main] DEBUG
984 [main] DEBUG
Processing eclass EpiInit
984 [main] DEBUG
Processing initSummary
984 [main] DEBUG
984 [main] DEBUG
Processing epiPersons
984 [main] DEBUG
984 [main] DEBUG
Processing InitSummary
984 [main] DEBUG
984 [main] DEBUG
Processing eclass InitSummary
984 [main] DEBUG
Processing localeSummary
984 [main] DEBUG
984 [main] DEBUG
Processing LocaleSummary
984 [main] DEBUG
984 [main] DEBUG
Processing eclass LocaleSummary
984 [main] DEBUG
Processing title
984 [main] DEBUG
984 [main] DEBUG
984 [main] DEBUG
984 [main] DEBUG
Processing package location
984 [main] DEBUG
Processing location
984
Re: OrderBy example? [message #425406 is a reply to message #425287] Tue, 25 November 2008 10:31 Go to previous messageGo to next message
Hello all,
Sorry about the messy post..I thought I had formatted it for easy
reading...
Anyway, did I miss something obvious? Sorry if I'm being obtuse here, but
I can't seem to find anything wrong. Where else can I look?
Thanks in advance for any pointers.
Re: OrderBy example? [message #425408 is a reply to message #425406] Tue, 25 November 2008 10:49 Go to previous messageGo to next message
Hi John,
Sorry about this, I have missed your previous post. I was away for a few days so I did not have a
change to continuously follow the posts on the newsgroup. This seems to be a Teneo bug. I see what's
wrong (the join tag should be after all property tags in a class). I will use your model to
reproduce this, I will do this later today.
gr. Martin
John G wrote:
> Hello all,
> reading...
> but I can't seem to find anything wrong. Where else can I look? Thanks
The Netherlands
Re: OrderBy example? [message #425411 is a reply to message #425408] Tue, 25 November 2008 11:23 Go to previous messageGo to next message
Thanks, Martin, I really appreciate your time and effort helping me (and
everyone else, too!)
John
Re: OrderBy example? [message #425423 is a reply to message #425411] Tue, 25 November 2008 17:53 Go to previous messageGo to next message
Hi John,
I took your model and generated a mapping for it and with me it worked out fine. So with me the
order is (in the DiseaseStageImpl mapping):
<property name="id" lazy="false" insert="true" update="true" not-null="false" unique="false"
type="long">
<column not-null="false" unique="false" name="`id`"/>
</property>
<join table="disease_stages" inverse="true" optional="true">
<key update="true">
<column name="`diseasestage_e_id`" not-null="true" unique="false"/>
</key>
<many-to-one name="disease" entity-name="Disease" lazy="proxy" insert="true" update="true"
foreign-key="diseasestage_disease">
<column not-null="false" unique="false" name="`disease_e_id`"/>
</many-to-one>
</join>
while with you it is (note the property after the join):
<key update="true">
</key>
</many-to-one>
</join>
type="long">
</property>
which is incorrect.
Can you post the piece of code that initializes the datastore and sets the persistenceoptions?
gr. Martin
> John
The Netherlands
Re: OrderBy example? [message #425457 is a reply to message #425423] Wed, 26 November 2008 11:35 Go to previous messageGo to next message
Hi Martin,
Here's the code. I don't have anything to set persistenceoptions, though.
I will look this up and see if that's my problem.
package qq.hibernate;
import java.util.Iterator;
import java.util.List;
import javax.xml.datatype.DatatypeConfigurationException;
import javax.xml.datatype.DatatypeFactory;
import javax.xml.datatype.XMLGregorianCalendar;
import org.apache.log4j.Logger;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.hibernate.Query;
import org.hibernate.Session;
import org.hibernate.SessionFactory;
import org.junit.Test;
import qq.mob.disease.Disease;
import qq.mob.disease.DiseaseFactory;
import qq.mob.disease.DiseasePackage;
import qq.mob.disease.DiseaseStage;
import qq.mob.epicase.EpiCase;
import qq.mob.epicase.EpicaseFactory;
import qq.mob.epicase.EpicasePackage;
import qq.mob.epiperson.EpipersonPackage;
import qq.mob.epistate.EpistatePackage;
import qq.mob.person.PersonPackage;
* @author jgoetz
public class TestDisease {
@Test
public final void testDisease() {
final Logger LOG = Logger.getLogger(TestDisease.class);
LOG.info("Testing Disease and associated classes...");
// create the DataStore
final String dataStoreName = "EipCaseDataStore";
final HbDataStore dataStore = HbHelper.INSTANCE
.createRegisterDataStore(dataStoreName);
LOG.info("after creating dataStore");
// Configure the EPackages used by this DataStore
dataStore.setEPackages(new EPackage[] {
EpicasePackage.eINSTANCE,
EpistatePackage.eINSTANCE,
PersonPackage.eINSTANCE,
DiseasePackage.eINSTANCE,
EpipersonPackage.eINSTANCE
LOG.info("after setting package");
// Initialize the DataStore. This sets up the Hibernate mapping and
// creates the corresponding tables in the database.
dataStore.initialize();
LOG.info("after initialize");
final SessionFactory sessionFactory =
dataStore.getSessionFactory();
// Open a new session and start a transaction.
Session session = sessionFactory.openSession();
session.beginTransaction();
// Create a case
System.out.println("creating epicase");
EpiCase epicase = EpicaseFactory.eINSTANCE.createEpiCase();
System.out.println("creating disease");
Disease disease = DiseaseFactory.eINSTANCE.createDisease();
disease.setTitle("lollygagging");
disease.setForce(2.5);
System.out.println("Creating disease stages 1-6");
DiseaseStage disStage1 =
DiseaseFactory.eINSTANCE.createDiseaseStage();
DiseaseStage disStage2 =
DiseaseStage disStage3 =
DiseaseStage disStage4 =
DiseaseStage disStage5 =
DiseaseStage disStage6 =
disStage1.setDisease(disease);
disStage2.setDisease(disease);
disStage3.setDisease(disease);
disStage4.setDisease(disease);
disStage5.setDisease(disease);
disStage6.setDisease(disease);
disStage1.setTitle("healthy");
disStage2.setTitle("peaked");
disStage3.setTitle("undertheweather");
disStage4.setTitle("ill");
disStage5.setTitle("dead");
disStage6.setTitle("resurrected");
disStage1.setCode("X");
disStage2.setCode("Y");
disStage3.setCode("Z");
disStage4.setCode("W");
disStage5.setCode("P");
disStage6.setCode("Q");
disStage1.setDuration(10);
disStage2.setDuration(10);
disStage3.setDuration(10);
disStage4.setDuration(10);
disStage5.setDuration(10);
disStage6.setDuration(10);
disease.getStages().add(disStage1);
disease.getStages().add(disStage2);
disease.getStages().add(disStage3);
disease.getStages().add(disStage4);
disease.getStages().add(disStage5);
disease.getStages().add(disStage6);
XMLGregorianCalendar calXML = null;
try {
calXML =
DatatypeFactory.newInstance().newXMLGregorianCalendar(2006,
11,15,12,43,00,00,-7);
} catch (DatatypeConfigurationException e) {
e.printStackTrace();
epicase.setDisease("malapropsism");
epicase.setSentenial("Bogus Hospital");
epicase.setStage("IR");
epicase.setZcta("89997");
epicase.setEpiDate(calXML);
System.out.println("saving all the stuff");
// Make it persistent.
session.save(epicase);
System.out.println("saving disease");
session.save(disease);
System.out.println("saving stage 1");
session.save(disStage1);
System.out.println("saving stage 2");
session.save(disStage2);
System.out.println("saving stage 3");
session.save(disStage3);
System.out.println("saving stage 4");
session.save(disStage4);
System.out.println("saving stage 5");
session.save(disStage5);
System.out.println("saving stage 6");
session.save(disStage6);
// System.out.println("saving diseaseStagesType");
// session.save(disStagesType);
System.out.println("committing");
session.getTransaction().commit();
// now see if it's in there
Query query = session.createQuery("From EpiCase");
List epicases = query.list();
for (Iterator it = epicases.iterator(); it.hasNext();)
epicase = (EpiCase) it.next();
System.out.println("Disease:" + epicase.getDisease() + "
Reported by:" + epicase.getSentenial());
System.out.println("listing disease stages");
query = session.createQuery("From DiseaseStage");
List stages = query.list();
for (Iterator it = stages.iterator(); it.hasNext();)
disStage1 = (DiseaseStage) it.next();
System.out.println("Stage:" + disStage1.getTitle() + " Code:"
+ disStage1.getCode());
System.out.println("listing diseases");
query = session.createQuery("From Disease");
List diseases = query.list();
for (Iterator it = diseases.iterator(); it.hasNext();)
disease = (Disease) it.next();
System.out.println("Disease:" + disease.getTitle() + "
stages:");
stages = disease.getStages();
for (Iterator it2 = stages.iterator(); it2.hasNext();)
disStage1 = (DiseaseStage) it2.next();
System.out.println(" Stage:" + disStage1.getTitle() +
" Code:" + disStage1.getCode());
session.close();
Re: OrderBy example? [message #425461 is a reply to message #425457] Wed, 26 November 2008 13:06 Go to previous messageGo to next message
Hi John,
Hmm, it looks fine what you do. On which build/version of Teneo are you?
If you call setEPackages with just the DiseasePackage, what result do you get then?
gr. Martin
John G wrote:
> Hi Martin,
> though. I will look this up and see if that's my problem.
> * @author jgoetz
> @Test
> final SessionFactory sessionFactory = dataStore.getSessionFactory();
> // Create a case
> try {
> calXML =
> stages:");
> it2.hasNext();)
> session.close();
The Netherlands
Re: OrderBy example? [message #425464 is a reply to message #425461] Wed, 26 November 2008 14:36 Go to previous messageGo to next message
Hi Martin,
Thanks again for helping me.
I am using Teneo 1.0.1.
When I run my test program with just DiseasePackage, I get the same
org.hibernate.MappingException: invalid mapping error, once again on the
same line (line 99 of the mapping XML is the closing </class> of
DiseaseStageImpl).
Here's my log output, and my XSD is below that:
0 [main] INFO qq.hibernate.TestDisease - Testing Disease and
93 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Creating emf
171 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Returning
171 [main] INFO qq.hibernate.TestDisease - after creating dataStore
484 [main] INFO qq.hibernate.TestDisease - after setting package
484 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
500 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
classname:
default: true
default: true
true
classname:
default: true
classname:
default: true
515 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
classname:
true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
classname:
true
true
true
classname:
default: true
true
true
true
531 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
default: true
classname:
default: true
default: true
classname:
default: true
true
classname:
default: true
true
classname:
default: true
classname:
default: true
classname:
default: true
default: true
classname:
default: true
default: true
classname:
default: true
true
classname:
default: true
true
classname:
default: true
classname:
default: true
classname:
default: true
531 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore -
578 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.2.4.sp1
578 [main] INFO org.hibernate.cfg.Environment - loaded properties from
578 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name
: cglib
578 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4
671 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
671 [main] INFO
strategy set to:
671 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - Properties
687 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions -
687 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
687 [main] WARN org.eclipse.emf.teneo.extension.DefaultExtensionManager
687 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore -
classname:
default: true
703 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
default: true
703 [main] DEBUG
703 [main] DEBUG
disease
875 [main] DEBUG
875 [main] DEBUG
875 [main] DEBUG
Parse annotations
875 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
875 [main] DEBUG
Processing package disease
875 [main] DEBUG
Processing disease
875 [main] DEBUG
875 [main] DEBUG
Processing Disease
875 [main] DEBUG
Processing annotations
875 [main] DEBUG
Annotation content:
@Entity
875 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.AnnotationTokenizer - Tok: 2:
'Entity'
Tok: 2: 'Table'
Tok: 128: '('
Tok: 4: 'name'
Tok: 64: '='
Tok: 32: '"Disease"'
Tok: 256: ')'
Tok: 4096: ')'
875 [main] DEBUG
Number of parsed typename annotations 2
875 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode -
Converting Entity to EObject
890 [main] DEBUG
Found EReference entity for Entity
890 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode -
Converting Table to EObject
Primitive child: name: Disease
890 [main] DEBUG
Found EReference table for Table
890 [main] DEBUG
890 [main] DEBUG
Processing title
890 [main] DEBUG
890 [main] DEBUG
Processing stages
890 [main] DEBUG
890 [main] DEBUG
Annotation content:
@OrderBy("ordinal")
890 [main] DEBUG
'OrderBy'
Tok: 128: '('
Tok: 32: '"ordinal"'
Tok: 256: ')'
Tok: 4096: ')'
890 [main] DEBUG
Number of parsed typename annotations 1
Converting OrderBy to EObject
Primitive child: value: ordinal
890 [main] DEBUG
Found EReference orderBy for OrderBy
890 [main] DEBUG
Processing force
890 [main] DEBUG
890 [main] DEBUG
Processing id
890 [main] DEBUG
890 [main] DEBUG
Processing Diseases
890 [main] DEBUG
890 [main] DEBUG
Processing eclass Diseases
890 [main] DEBUG
Processing disease
890 [main] DEBUG
890 [main] DEBUG
890 [main] DEBUG
890 [main] DEBUG
Annotation content:
@Entity
890 [main] DEBUG
'Entity'
Tok: 2: 'Table'
Tok: 128: '('
Tok: 4: 'name'
Tok: 64: '='
Tok: 32: '"DiseaseStage"'
Tok: 256: ')'
Tok: 4096: ')'
890 [main] DEBUG
890 [main] DEBUG
Primitive child: name: DiseaseStage
890 [main] DEBUG
890 [main] DEBUG
890 [main] DEBUG
Processing code
890 [main] DEBUG
890 [main] DEBUG
Processing title
890 [main] DEBUG
890 [main] DEBUG
Processing ordinal
890 [main] DEBUG
890 [main] DEBUG
Processing duration
890 [main] DEBUG
890 [main] DEBUG
Processing suseptable
890 [main] DEBUG
890 [main] DEBUG
Processing infected
890 [main] DEBUG
890 [main] DEBUG
Processing infectious
890 [main] DEBUG
890 [main] DEBUG
Processing immune
890 [main] DEBUG
890 [main] DEBUG
Processing disease
890 [main] DEBUG
890 [main] DEBUG
Processing id
890 [main] DEBUG
890 [main] DEBUG
Processing PooledState
890 [main] DEBUG
890 [main] DEBUG
Processing eclass PooledState
890 [main] DEBUG
Copying annotations on edatatypes over eattribute annotations!
890 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - Add
default annotations
890 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
906 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator -
Registering epackages in model resolver, modelresolver instance is:
org.eclipse.emf.teneo.ERuntime
906 [main] DEBUG org.eclipse.emf.teneo.ERuntime - Determining concrete
classes for package disease
921 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator - Class
names are to be fully classified, registering all the epackages
921 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
default: true
true
- Initializing extension
- Found instance class java.lang.Class
true
classname:
default: true
classname:
default: true
classname:
default: true
937 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
classname:
default: true
classname:
default: true
classname:
default: true
937 [main]
Re: OrderBy example? [message #425465 is a reply to message #425464] Wed, 26 November 2008 15:20 Go to previous messageGo to next message
Hi John,
It is still unclear for me why it works with me and not with you. Which Teneo build (from which
date) are you using?
gr. Martin
John G wrote:
> Hi Martin,
> Thanks again for helping me. I am using Teneo 1.0.1.
> DiseaseStageImpl).
> emf data store and registering it under name: EipCaseDataStore
> 484 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Registering
> point: org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder
> classname: org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder
> default: true
> 500 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator
> classname: org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator
> default: true
> 500 [main] DEBUG
> point:
> classname:
> default: true
> 500 [main] DEBUG
> point:
> classname:
> default: true
> 500 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper
> classname: org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper
> default: true
> 500 [main] DEBUG
> point: org.eclipse.emf.teneo.mapping.strategy.EntityNameStrategy
> classname:
> default: true
> 500 [main] DEBUG
> point: org.eclipse.emf.teneo.mapping.strategy.SQLNameStrategy classname:
> default: true
> 500 [main] DEBUG
> point:
> classname:
> default: true
> 500 [main] DEBUG
> point:
> classname:
> default: true
> 500 [main] DEBUG
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.EMFInterceptor classname:
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.MappingContext classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper classname:
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper classname:
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.IdMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper
> classname: org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper
> classname: org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper classname:
> 515 [main] DEBUG
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper classname:
> 515 [main] DEBUG
> point:
> classname:
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er
> classname:
> true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r
> classname: org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r
> classname: org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er
> classname:
> true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper classname:
> org.eclipse.emf.teneo.jpox.mapper.property.IdMapper default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper
> default: true
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.TableMapper classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.MappingContext classname:
> 515 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.NamingHandler classname:
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> classname: org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r
> default: true
> 531 [main] DEBUG
> classname:
> true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> default: true
> 531 [main] DEBUG
> classname:
> true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> 531 [main] DEBUG
> point:
> classname:
> default: true
> from resource hibernate.properties:
> 'N', hibernate.connection.username=epiuser,
> 671 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Searching
> 671 [main] INFO
> loader strategy set to:
> 671 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Initargs
> teneo.mapping.set_default_cascade_on_non_containment: 671 [main] DEBUG
> teneo.mapping.cascade_policy_on_non_containment: 671 [main] DEBUG
> teneo.mapping.cascade_all_on_containment: 687 [main] DEBUG
> 687 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Created
> 687 [main] WARN
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - The
> 687 [main] DEBUG
> extension
> 687 [main] DEBUG
> 687 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Caching
> classname:
> default: true
> 687 [main] DEBUG
> extension org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder
> 703 [main] DEBUG
> 703 [main] DEBUG
> default: true
> 703 [main] DEBUG
> 703 [main] DEBUG
> disease
> 875 [main] DEBUG
> 875 [main] DEBUG
> 875 [main] DEBUG
> Parse annotations
> 875 [main] DEBUG
> extension
> 875 [main] DEBUG
> 875 [main] DEBUG
> classname:
> default: true
> 875 [main] DEBUG
> 875 [main] DEBUG
> Processing disease
> 875 [main] DEBUG
> 875 [main] DEBUG
> Processing Disease
> 875 [main] DEBUG
> Processing annotations 875 [main] DEBUG
> Annotation content:
> @Entity
> 875 [main] DEBUG
> 'Entity'
> Tok: 2: 'Table'
> Tok: 128: '('
> Tok: 4: 'name'
> Tok: 64: '='
> Tok: 256: ')'
> Tok: 4096: ')'
> 875 [main] DEBUG
> - Converting Entity to EObject 890 [main] DEBUG
> - Converting Table to EObject 890 [main] DEBUG
> org.eclipse.emf.teneo.annotations.parser.ComplexNode - Primitive child:
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing title
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing stages
> 890 [main] DEBUG
> Processing annotations 890 [main] DEBUG
> Annotation content:
> @OrderBy("ordinal")
> 890 [main] DEBUG
> 'OrderBy'
> Tok: 128: '('
> Tok: 256: ')'
> Tok: 4096: ')'
> 890 [main] DEBUG
> - Converting OrderBy to EObject 890 [main] DEBUG
> value: ordinal
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing force
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing id
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing Diseases
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing disease
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Annotation content:
> @Entity
> 890 [main] DEBUG
> 'Entity'
> Tok: 2: 'Table'
> Tok: 128: '('
> Tok: 4: 'name'
> Tok: 64: '='
> Tok: 256: ')'
> Tok: 4096: ')'
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing code
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing title
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing ordinal
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing duration
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing infected
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing immune
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing disease
> 890 [main] DEBUG
> 890 [main] DEBUG
> Processing id
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> 890 [main] DEBUG
> Add default annotations
> 890 [main] DEBUG
> extension org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator
> 890 [main] DEBUG
> 890 [main] DEBUG
> 906 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.mapping.strategy.EntityNameStrategy
> 921 [main] DEBUG
> 921 [main] DEBUG
> default: true
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.mapping.strategy.SQLNameStrategy
> 921 [main] DEBUG
> 921 [main] DEBUG
> default: true
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator
> 921 [main] DEBUG
> 921 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Initializing
> extension org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r
> 921 [main] DEBUG
> 921 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Found
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.hibernate.annotations.HbEFeatureAnnota tor
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> true
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> classname:
> default: true
> 921 [main] DEBUG
> extension org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> classname:
> default: true
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> 921 [main] DEBUG
> classname:
> default: true
> 921 [main] DEBUG
> extension
> 921 [main] DEBUG
> 921 [main] DEBUG
> extension
Re: OrderBy example? [message #425468 is a reply to message #425465] Wed, 26 November 2008 16:09 Go to previous messageGo to next message
Hi Martin,
My version of Teneo is 1.0.1.v200809211527. I tried using the latest
version (1.0.1R200809231814) by placing the unzipped eclipse folder into
the dropins folder of my eclipse installation, but eclipse wouldn't find
the plugins. I installed this version using eclipse updates, and eclipse
found the plugins without problems.
Re: OrderBy example? [message #425472 is a reply to message #425468] Wed, 26 November 2008 17:12 Go to previous messageGo to next message
Hi John,
Are you using Eclipse 3.4.1?
gr. Martin
John G wrote:
> Hi Martin,
> find the plugins. I installed this version using eclipse updates, and
> eclipse found the plugins without problems.
The Netherlands
Re: OrderBy example? [message #425481 is a reply to message #425472] Thu, 27 November 2008 03:21 Go to previous messageGo to next message
Hi John,
I noticed what you called the latest version. But there are much more recent maintenance builds
available here (see the bottom of the page):
http://www.eclipse.org/modeling/emf/downloads/?project=teneo
The latest from the 13th of November.
As it works with me and does not work with you I think it is best if you try to install this latest
maintenance version.
gr. Martin
Martin Taal wrote:
> Hi John,
> gr. Martin
> John G wrote:
>> Hi Martin,
>> into the dropins folder of my eclipse installation, but eclipse
>> wouldn't find the plugins. I installed this version using eclipse
>> updates, and eclipse found the plugins without problems.
The Netherlands
Re: OrderBy example? [message #425576 is a reply to message #425481] Mon, 01 December 2008 16:35 Go to previous message
Hello Martin,
As you suggested, I updated my Teneo to the latest maintenance version
M200811151637 and updated eclipse to 3.4.1, and now OrderBy doesn't cause
the mapping error anymore. It seems to be working fine now.
Thanks again for your time and help on this problem.
Previous Topic:Fetching a CDO object by CDOID
Next Topic:Re: CDO 1.0.4 problem: Revision not found
Current Time: Sun Jul 20 07:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.06776 seconds
