[TENEO] IdentifierGenerator [message #425368] |
Sat, 22 November 2008 13:44  |
This is somewhat related to my earlier post (IPersistable interface with
a myid property that could get implemented by all entities in the model)
I tried to dig a little more and here is my "second" question reloaded:
1. Could I use the strategy property of the GenericGenerator to indicate
the use of a custom IdentifierGenerator ?
2. Could this custom IdentifierGenerator extend the TableHiLoGenerator?
3. Is there any way I could inject the name of the entity being
persisted into this custom TableHiLoGenerator? Note that the adnotation
will be made on the IPersistable interface.
Please see my earlier post for the spadcore.ecore attachment.
Thanks a lot for your patience
Liviu
Re: [TENEO] IdentifierGenerator [message #425388 is a reply to message #425380] |
Mon, 24 November 2008 00:21  |
Ha ha, thanks, :-),
gr. Martin
Liviu wrote:
> Yep, that hit the spot - its all answered and crystal clear.
> I could just say thanks, but then again sounds better: You The Man.
> Like Tyrell and Lorenzo all rolled into one.
> Check this out - googled it specially for you:
> http://www.theonion.com/content/node/34216
> Liviu
> Martin Taal wrote:
>> Hi Liviu,
>> Yes the strategy attribute should have the class name of your
>> IdentifierGenerator.
>> The IdentifierGenerator.generate method has a session and a object
>> parameter. The object is the entity which gets persisted. You can cast
>> this object to EObject and ask for the eclass and use the eclass name
>> and epackage or use the classname.
>> Looking at the Hibernate source code I think it can make sense to
>> implement your own TableHiLoGenerator which combines the logic from the
>> TableHiLoGenerator and TableGenerator and uses the class/eclass as an
>> additional parameter in the sql queries.
>> gr. Martin
>> Liviu wrote:
>>> Hello,
>>> Liviu
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.03624 seconds
