Home » Modeling » EMF » Observing derived features
Observing derived features [message #425369] Sat, 22 November 2008 14:03 Go to next message
Hey,
I'm trying to create a list based view on a derived feature.
I guess that since it is derived I won't get any notifications for that
feature unless I manually create such notifications somewhere?
In this case I would let the eObjects under consideration somehow adapt
themselves:
- Internally observe all features that the derived feature depends on
- Upon change recompute the derived feature value
- 'Somehow' generate a notification event for the derived feature
Is this the approach to take, and if so, how can I generate the
notification in step 3?
Thanks, Felix
Re: Observing derived features [message #425370 is a reply to message #425369] Sat, 22 November 2008 14:30 Go to previous messageGo to next message
By 'derived feature' you mean simply something that extends
EStructuralFeature somehow?
Or maybe you have entity A that has a List of B's
And C extends B
and you would like to show the list of B that are also C's and belong to A ?
Don't even know if I can help. Should my question seem silly maybe I'm
of no use to you.
Liviu
Felix Dorner wrote:
> Hey,
> themselves:
> Thanks, Felix
Re: Observing derived features [message #425371 is a reply to message #425370] Sat, 22 November 2008 14:34 Go to previous messageGo to next message
Or maybe derived feature = computed attribute (at runtime or otherwise
not contained in your entity aka emf class)?
Liviu wrote:
> Hi
> And C extends B
> of no use to you.
> Liviu
> Felix Dorner wrote:
>> Hey,
>> themselves:
>> Thanks, Felix
Re: Observing derived features [message #425372 is a reply to message #425371] Sat, 22 November 2008 15:21 Go to previous messageGo to next message
Hey,
yeah this one. By derived I mean formally an attribute that
is simply computed from other attributes, something that doesn't add information
to an object. As a stupid example, consider a class 'Library' which has a list
of 'Books', each having an 'Author'. A derived feature for a 'Library' would for
example be 'allAuthors' which would simply be the set of all authors of which
the library has at least one book...
Re: Observing derived features [message #425373 is a reply to message #425369] Sat, 22 November 2008 16:34 Go to previous messageGo to next message
Felix,
Comments below.
Felix Dorner wrote:
> Hey,
> that feature unless I manually create such notifications somewhere?
If you use a "normal" list implementation, when you update it, it will
notify as normal.
> themselves:
If you override eNotificationRequired to return true, eNotify will
always be called, so you could use that to for the object to adapt itself.
You could just modify the list and have it notify as normal.
> Thanks, Felix
Re: Observing derived features [message #425381 is a reply to message #425372] Sun, 23 November 2008 07:12 Go to previous messageGo to next message
--------------090305090402000709030001
Content-Type: text/plain; charset=ISO-8859-1
Felix Dorner wrote:
> Hey,
> information
> a list of 'Books', each having an 'Author'. A derived feature for a
> 'Library' would for example be 'allAuthors' which would simply be the
> set of all authors of which the library has at least one book...
Particulary for this kind of things, when I needed to create a list of
somethings filtered and ordererd and stuff I would relay on HQL for the
query, take the results and create a dinamic EClass (whose name is
variable) that has a single attribute "elements".
We instantiate the class and have the list of objects here.
For the "main" (aka leader, Library like object) we put on it an adapter
that notifies the dinamic object an all changes.
See the attachment for some hints.
Your example looks like a HQL left join with some restrictions.
Dont know if it helps but I guess Ed already answered your question.
Liviu
name="EmfUtils.java"
Content-Disposition: inline;
filename="EmfUtils.java"
package ro.spad.core.utils;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.emf.ecore.ETypedElement;
import org.eclipse.emf.ecore.EcoreFactory;
public class EmfUtils {
private static Map<String, EClass> map = new HashMap<String, EClass>();
private static final String LISTA_ELEMENTE = "listaElemente";
public static EPackage eDynaSpadPackage = EcoreFactory.eINSTANCE.createEPackage();
eDynaSpadPackage.setName("dynaspad");
eDynaSpadPackage.setNsPrefix("dynaspad");
eDynaSpadPackage.setNsURI("http://www.spad.ro/dynaspad");
public static EObject createDummyListContainingEmfObject(EClass type)
final EcoreFactory efactory = EcoreFactory.eINSTANCE;
String className = getClassName(type);
EClass dummyListContainerClass;
if (!map.containsKey(className)){
dummyListContainerClass = efactory.createEClass();
dummyListContainerClass.setName(className);
EReference listaElementeReference = efactory.createEReference();
listaElementeReference.setName(LISTA_ELEMENTE);
listaElementeReference.setEType(type);
listaElementeReference.setContainment(false);
listaElementeReference.setLowerBound(0);
listaElementeReference.setUpperBound(ETypedElement.UNBOUNDED _MULTIPLICITY);
listaElementeReference.setUnique(false);
dummyListContainerClass.getEStructuralFeatures().add(listaEl ementeReference);
eDynaSpadPackage.getEClassifiers().add(dummyListContainerCla ss);
EPackage.Registry.INSTANCE.put(eDynaSpadPackage.getNsURI(), eDynaSpadPackage);
map.put(className, dummyListContainerClass);
}else{
dummyListContainerClass = map.get(className);
return eDynaSpadPackage.getEFactoryInstance().create(dummyListConta inerClass);
private static String getClassName(EClass type)
return "DummyListContaining"+type.getName();
public static EStructuralFeature getFirstStructuralFeature(EObject eObject, String featureName){
return (EStructuralFeature)eObject.eClass().getEStructuralFeature(f eatureName);
public static EReference getListaElementeStructuralFeatureFromDynaSPAD(EObject eObject){
return (EReference) getFirstStructuralFeature(eObject, LISTA_ELEMENTE);
--------------090305090402000709030001--
Re: Observing derived features [message #425382 is a reply to message #425373] Sun, 23 November 2008 09:56 Go to previous messageGo to next message
Hey Ed,
> notify as normal.
Hmm by this you mean something that implements ENotifyingList? I guess I
could set 'volatile' to false and use the generated getter as a starting
point. I guess it might be a good idea to finally return an unmodifiable
list though as it makes no sense for a client to externally change its
contents.
So that eNotify would look somehow like this:
eNotify(Notification n){
super.eNotify(n); // first play just normal
if (mustUpdateDerived(n)){ // do i need to update derived feature?
updateDerived(n); // modify the derived feature.
calling 'updateDerived' would modify the NotifyingList, so eNotify would
be invoked again. Now the observers of the derived feature will get
notified and the mustUpdateDerived() guard would be jumped over,
otherwise I'd provoke an infinite loop. Maybe this could be improved but
I just hope i got the pattern.
Thanks a lot.
Felix
Re: Observing derived features [message #425392 is a reply to message #425382] Mon, 24 November 2008 08:07 Go to previous message
Felix,
Comments below.
Felix Dorner wrote:
> Hey Ed,
>> will notify as normal.
> I could set 'volatile' to false and use the generated getter as a
> starting point.
Yes.
> I guess it might be a good idea to finally return an unmodifiable list
> contents.
Yes, using something like EcoreEList.Unmodifiable.
>> itself.
> be invoked again.
Yes.
> Now the observers of the derived feature will get notified and the
> mustUpdateDerived() guard would be jumped over, otherwise I'd provoke
> an infinite loop.
You would want to derive from your own value. :-P
> Maybe this could be improved but I just hope i got the pattern.
The XSD model uses this pattern.
> Thanks a lot.
> Felix
Previous Topic:[Transactions] Deadlock using WorkspaceSynchronizer.Delegate
Next Topic:Updating Link's label
Current Time: Sat Jul 19 19:41:27 EDT 2025
Powered by FUDForum. Page generated in 0.04225 seconds
