Home » Modeling » EMF » StrictCompoundCommand
StrictCompoundCommand [message #425271] Fri, 21 November 2008 07:20 Go to next message
Originally posted by: swt.magellium.fr
Hello all !
I want to create a CompoundCommand composed of two commands, where the
second command must wait for the result of the first command in order to
be executed.
I think this is achieved by using a StrictCompoundCommand
(non-pessimistic), and by wrapping the second command in a
CommandWrapper (the second command is then created when it's wrapper is
prepared). This works well, except for undo.
When the command is prepared, my first sub-command is executed, and the
wrapper of the second one is prepared, so the second command is created
and prepared.
When the command is executed, the second sub-command is executed (the
first was already executed during prepare).
That is ok.
But then, if I "undo" the command, only the last sub-command (the second
one) is undone !
This is logic regarding redo : it will only have to re-execute the last
sub-command. But I also need to undo the first sub-command to obtain the
real expected undo effect !
I imagine this is a well known problem. Can someone help me with this ??
Thanks in advance !
Stephane
Re: StrictCompoundCommand [message #425273 is a reply to message #425271] Fri, 21 November 2008 07:25 Go to previous messageGo to next message
It seems that using pessimistic solves the undo problem. Is this the
right way to do it ?
And so, in which cases can non-pessimistic be useful ?
Thanks in advance again!
> Hello all !
> be executed.
> and prepared.
> That is ok.
> one) is undone !
> Thanks in advance !
> Stephane
Re: StrictCompoundCommand [message #425284 is a reply to message #425273] Fri, 21 November 2008 09:26 Go to previous message
SWT,
Comments below.
It seems so.
When the enablement of commands does not depend on those before it.
>> Hello all !
>> the second command must wait for the result of the first command in
>> order to be executed.
>> is prepared). This works well, except for undo.
>> the wrapper of the second one is prepared, so the second command is
>> created and prepared.
>> That is ok.
>> second one) is undone !
>> last sub-command. But I also need to undo the first sub-command to
>> obtain the real expected undo effect !
Do all the comments in the Javadoc for StrictCompoundCommand apply for
your case?
>> Thanks in advance !
>> Stephane
Previous Topic:EMF 2.5M3 with Eclipse SDK 3.5 M2
Next Topic:Auto unload - memory management
Current Time: Sat Jul 19 22:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.25952 seconds
