Home » Modeling » EMF » [Teneo/JPA] can an @EmbeddedId use type=xsd:IDREF?
[Teneo/JPA] can an @EmbeddedId use type=xsd:IDREF? [message #425215] Wed, 19 November 2008 16:09 Go to next message
I have an @EmbeddedId compound key problem.
LensToLensOptionRelation is a join table relating two object.
Because it's a join table it has a composite key.
Here's the XSD for one side of the relationship:
<xsd:complexType name="LensToLensOptionRelation">
<xsd:annotation><xsd:appinfo source="teneo.jpa">
@Entity @Table( name="CSAZZZZT" )
</xsd:appinfo></xsd:annotation>
<xsd:sequence>
<xsd:element name="key"
type=" com.vsp.supplier.model.lens:LensToLensOptionRelationComposit eKey ">
<xsd:annotation><xsd:appinfo ource="teneo.jpa">
@EmbeddedId
</xsd:element>
So basically, the LensToLensOptionRelation uses a composite key for it's
ID. So far so good.
First off, I made the relationship a int that returns the ID of the
object that the foreign key is referring to.
If the composite key only uses primitive types, it can do the query
correctly:
<xsd:complexType name="LensToLensOptionRelationCompositeKey">
@Embeddable
<xsd:sequence>
</xsd:sequence>
<xsd:attribute name="lensId" type="xsd:int">
@Column(name="PRODUCT_CD")
</xsd:attribute>
However, the lensId actually points to a lens object and I'd like a Lens
object returned in my generated API. So inside the composite key I
change it to look like this:
@Embeddable
<xsd:sequence>
</xsd:sequence>
type="xsd:IDREF" ecore:reference="com.vsp.supplier.model.lens:Lens"
</xsd:attribute>
The @Column info is the same, but now I'm asking for a reference to an
actual Lens object instead of just an int.
Unfortunately, this makes the query fail.
Instead of looking for PRODUCT_CD the query looks like this:
select this_.lens_lensid_lensid as lens1_8_0_
when it should be something like
select this_.product_cd
I assume it's generating that out of the object names, but this is a
legacy database, so that column name doesn't exist. It seems like it's
ignoring the @Column's name attribute.
Any ideas, or am I violating the laws of physics here?
Jason Henriksen
Re: [Teneo/JPA] can an @EmbeddedId use type=xsd:IDREF? [message #425218 is a reply to message #425215] Wed, 19 November 2008 18:10 Go to previous messageGo to next message
GAH! Problem was in my JPA annotation. Teneo work fine.
(Brilliantly in fact)
The corrected XSD is printed here in case it helps anyone else out:
@Embeddable</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
</xsd:sequence>
type="xsd:IDREF"
ecore:reference="com.vsp.supplier.model.lens:Lens">
<xsd:annotation>
@ManyToOne
@JoinColumn(name="PRODUCT_CD" insertable="false" updatable="false")
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
> <xsd:sequence>
> @EmbeddedId
> </xsd:element>
> ID. So far so good.
> correctly:
> @Embeddable
> <xsd:sequence>
> </xsd:sequence>
> </xsd:attribute>
> @Embeddable
> <xsd:sequence>
> </xsd:sequence>
> type="xsd:IDREF"
> </xsd:attribute>
> Jason Henriksen
Re: [Teneo/JPA] can an @EmbeddedId use type=xsd:IDREF? [message #425220 is a reply to message #425218] Wed, 19 November 2008 18:27 Go to previous message
Good to hear! I was just about to let you know that I would be looking at your post tomorrow morning...
gr. Martin
> </xsd:annotation>
> <xsd:sequence>
> </xsd:sequence>
> type="xsd:IDREF"
> <xsd:annotation>
> @ManyToOne
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
>> <xsd:sequence>
>> @EmbeddedId
>> </xsd:appinfo></xsd:annotation> </xsd:element>
>> it's ID. So far so good.
>> correctly:
>> @Embeddable
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:attribute>
>> Lens object returned in my generated API. So inside the composite key
>> I change it to look like this:
>> @Embeddable
>> <xsd:sequence>
>> </xsd:sequence>
>> type="xsd:IDREF"
>> </xsd:attribute>
>> it's ignoring the @Column's name attribute.
>> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:HibernateResource vs XmiResourceImpl performances ?
Next Topic:Existing genmodel not picked up
Current Time: Sat Jul 19 22:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.04793 seconds
