Home » Modeling » EMF » Implementing Setters for Derived references
Implementing Setters for Derived references [message #425144] Sun, 16 November 2008 22:17 Go to next message
I have a base class which contains a list of products (0 to many)
I have a whole sub set of these which always take 2 products and these
products are a sub type of Product. For convenience (particularly for ocl)
I want to add two derived references for these
i.e.
class Base
EList<Product> products
class TwoFooProducts extends Base
FooProduct p1; // derived from products.get(0)
FooProduct p2; // derived from products.get(1)
To implement this I set p1 & p2 as derived, transient and volatile. I then
need to provide implementations of getP1(), basicSetP1() and setP1 &
similar for p2. Not entirely sure what I should be doing in the setters in
regards to the NotificationChain?
e.g. I've so far implemented basicSetP1 as follows but suspect this is not
correct.
public NotificationChain basicSetP1(FooProduct newP1,
NotificationChain msgs)
if (getProduct().size() == 0)
getProduct().add(newP1);
else
getProduct().set(0, newP1);
return msgs;
public void setP1(FooProduct newP1)
basicSetP1(newP1, null);
How should I have implemented these?
Re: Implementing Setters for Derived references [message #425146 is a reply to message #425144] Mon, 17 November 2008 03:30 Go to previous messageGo to next message
Hi !
maybe you should use mechanism described in this bug :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701
for more information Ed merks or Christian W Damus will more capable
> ocl) I want to add two derived references for these
> i.e.
> class Base
> then need to provide implementations of getP1(), basicSetP1() and setP1
> & similar for p2. Not entirely sure what I should be doing in the
> setters in regards to the NotificationChain?
> not correct.
> else
> return msgs;
Re: Implementing Setters for Derived references [message #425165 is a reply to message #425146] Mon, 17 November 2008 18:22 Go to previous messageGo to next message
Thanks Tristan
I thought that bugzilla was still a bit of an R&D project, not ready for
general use.
Are you saying that some part of it is ready for use?
thanks
Andrew
Tristan FAURE wrote:
> Hi !
>> i.e.
>> class Base
>> not correct.
>> else
>> return msgs;
Re: Implementing Setters for Derived references [message #425170 is a reply to message #425165] Tue, 18 November 2008 01:54 Go to previous message
Andrew,
It's not quite ready yet...
Andrew H wrote:
> Thanks Tristan
> for general use.
> thanks
> Andrew
>> Hi !
>>> these products are a sub type of Product. For convenience
>>> (particularly for ocl) I want to add two derived references for these
>>> i.e.
>>> class Base
>>> I then need to provide implementations of getP1(), basicSetP1() and
>>> setP1 & similar for p2. Not entirely sure what I should be doing in
>>> the setters in regards to the NotificationChain?
The list implements InternalEList which has the methods you need. One
problem though is you can't use inverseAdd/inverseRemove with a position
and of course you can't set the second item of the list if the first
doesn't exist yet.
>>> is not correct.
>>> else
>>> return msgs;
Previous Topic:Attributes of type EnumSet<E>?
Next Topic:FeatureID=-1
Current Time: Sun Jul 20 06:01:30 EDT 2025
Powered by FUDForum. Page generated in 0.04046 seconds
