Home » Modeling » EMF » Teneo not passing hibernate.properties?
Teneo not passing hibernate.properties? [message #424959] Tue, 11 November 2008 17:13 Go to next message
I'm testing a small Teneo-based class, but when I try to initialize my
dataStore, I get a warning, and the program terminates during setup. The
warning is:
org.hibernate.connection.UserSuppliedConnectionProvider - No connection
properties specified - the user must supply JDBC connections
But earlier in the run output I see my hibernate.properties read
correctly, including the JDBC connection info. How do I pass this
information through Teneo to Hibernate?
I can post my log and my source code if it would help.
Re: Teneo not passing hibernate.properties? [message #424960 is a reply to message #424959] Tue, 11 November 2008 18:27 Go to previous messageGo to next message
Hi John,
Yes, can you provide the log, the source code and your hibernate.properties file?
gr. Martin
John G wrote:
> Hello,
> warning is:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo not passing hibernate.properties? [message #424975 is a reply to message #424960] Wed, 12 November 2008 09:51 Go to previous messageGo to next message
Martin Taal wrote:
> Hi John,
file?
> gr. Martin
Thanks Martin, for taking the time to look at this. I am still learning,
so there's probably something obviously wrong here.
Here's the source (I separated the files with long '****' lines):
package qq.hibernate;
import java.util.Enumeration;
import java.util.List;
import org.apache.log4j.Logger;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.hibernate.Query;
import org.hibernate.Session;
import org.hibernate.SessionFactory;
import org.junit.After;
import org.junit.AfterClass;
import org.junit.Before;
import org.junit.BeforeClass;
import org.junit.Test;
import qq.mob.location.Airport;
import qq.mob.location.LocationPackage;
import qq.mob.pool.PoolPackage;
public class TestAirports {
@BeforeClass
public static void setUpBeforeClass() throws Exception {
@AfterClass
public static void tearDownAfterClass() throws Exception {
@Before
public void setUp() throws Exception {
@After
public void tearDown() throws Exception {
@Test
public final void testAirports() {
final Logger LOG = Logger.getLogger(TestAirports.class);
LOG.info("inside test");
// create the DataStore
final String dataStoreName = "AirportDataStore";
final HbDataStore dataStore =
HbHelper.INSTANCE.createRegisterDataStore(dataStoreName);
LOG.info("after creating dataStore");
// Configure the EPackages used by this DataStore
dataStore.setEPackages(new EPackage[] {PoolPackage.eINSTANCE,
LocationPackage.eINSTANCE});
LOG.info("after setting package");
// Initialize the DataStore. This sets up the Hibernate mapping
and
// creates the corresponding tables in the database.
dataStore.initialize();
LOG.info("after initialize");
Enumeration items = dataStore.getProperties().elements();
final SessionFactory sessionFactory =
dataStore.getSessionFactory();
// Open a new session and start a transaction.
Session session = sessionFactory.openSession();
session.beginTransaction();
//do something here with the data
Query query = session.createQuery("FROM Flight");
List airports = query.list();
Airport airport = (Airport) airports.get(0);
System.out.println(airport.getTitle());
session.getTransaction().commit();
session.close();
Here's my hibernate.properties file:
### Query Language ###
## define query language constants / function names
hibernate.query.substitutions yes 'Y', no 'N'
## select the classic query parser
#hibernate.query.factory_class
org.hibernate.hql.classic.ClassicQueryTranslatorFactory
### Platforms ###
## JNDI Datasource
#hibernate.connection.datasource jdbc/test
#hibernate.connection.username db2
#hibernate.connection.password db2
## HypersonicSQL
#hibernate.dialect org.hibernate.dialect.HSQLDialect
#hibernate.connection.driver_class org.hsqldb.jdbcDriver
#hibernate.connection.username sa
#hibernate.connection.url jdbc:hsqldb:./build/db/hsqldb/hibernate
#hibernate.connection.url jdbc:hsqldb:hsql://localhost
#hibernate.connection.url jdbc:hsqldb:test
## H2 (www.h2database.com)
#hibernate.dialect org.hibernate.dialect.H2Dialect
#hibernate.connection.driver_class org.h2.Driver
#hibernate.connection.url jdbc:h2:mem:./build/db/h2/hibernate
#hibernate.connection.url jdbc:h2:testdb/h2test
#hibernate.connection.url jdbc:h2:mem:imdb1
#hibernate.connection.url jdbc:h2:tcp://dbserv:8084/sample;
#hibernate.connection.url jdbc:h2:ssl://secureserv:8085/sample;
#hibernate.connection.url jdbc:h2:ssl://secureserv/testdb;cipher=AES
## MySQL
#hibernate.dialect org.hibernate.dialect.MySQLDialect
hibernate.dialect org.hibernate.dialect.MySQLInnoDBDialect
#hibernate.dialect org.hibernate.dialect.MySQLMyISAMDialect
hibernate.connection.driver_class com.mysql.jdbc.Driver
hibernate.connection.url jdbc:mysql://localhost:3306/epidb
#hibernate.connection.url jdbc:mysql://localhost:3306/epi_small
#hibernate.connection.url jdbc:mysql://localhost:3306/epi_synth
#hibernate.connection.url jdbc:mysql://BioServer.qn-niat.net:3306/epidb
#hibernate.connection.url jdbc:mysql://BioServer.qn-niat.net:3306/epi_small
#hibernate.connection.url jdbc:mysql://BioServer.qn-niat.net:3306/epi_synth
hibernate.connection.username epiuser
hibernate.connection.password grendelhash
## Oracle
#hibernate.dialect org.hibernate.dialect.OracleDialect
#hibernate.dialect org.hibernate.dialect.Oracle9Dialect
#hibernate.connection.driver_class oracle.jdbc.driver.OracleDriver
#hibernate.connection.username ora
#hibernate.connection.password ora
#hibernate.connection.url jdbc:oracle:thin:@localhost:1521:orcl
#hibernate.connection.url jdbc:oracle:thin:@localhost:1522:XE
## PostgreSQL
#hibernate.dialect org.hibernate.dialect.PostgreSQLDialect
#hibernate.connection.driver_class org.postgresql.Driver
#hibernate.connection.url jdbc:postgresql:template1
#hibernate.connection.username pg
## DB2
#hibernate.dialect org.hibernate.dialect.DB2Dialect
#hibernate.connection.driver_class com.ibm.db2.jcc.DB2Driver
#hibernate.connection.driver_class COM.ibm.db2.jdbc.app.DB2Driver
#hibernate.connection.url jdbc:db2://localhost:50000/somename
#hibernate.connection.url jdbc:db2:somename
## TimesTen
#hibernate.dialect org.hibernate.dialect.TimesTenDialect
#hibernate.connection.driver_class com.timesten.jdbc.TimesTenDriver
#hibernate.connection.url jdbc:timesten:direct:test
## DB2/400
#hibernate.dialect org.hibernate.dialect.DB2400Dialect
#hibernate.connection.username user
#hibernate.connection.password password
## Native driver
#hibernate.connection.url jdbc:db2://systemname
## Toolbox driver
#hibernate.connection.driver_class com.ibm.as400.access.AS400JDBCDriver
#hibernate.connection.url jdbc:as400://systemname
## Derby (not supported!)
#hibernate.dialect org.hibernate.dialect.DerbyDialect
#hibernate.connection.driver_class org.apache.derby.jdbc.EmbeddedDriver
#hibernate.connection.url jdbc:derby:build/db/derby/hibernate;create=true
## Sybase
#hibernate.dialect org.hibernate.dialect.SybaseDialect
#hibernate.connection.driver_class com.sybase.jdbc2.jdbc.SybDriver
#hibernate.connection.password sasasa
#hibernate.connection.url jdbc:sybase:Tds:co3061835-a:5000/tempdb
## Mckoi SQL
#hibernate.dialect org.hibernate.dialect.MckoiDialect
#hibernate.connection.driver_class com.mckoi.JDBCDriver
#hibernate.connection.url jdbc:mckoi:///
#hibernate.connection.url jdbc:mckoi:local://C:/mckoi1.0.3/db.conf
#hibernate.connection.username admin
#hibernate.connection.password nimda
## SAP DB
#hibernate.dialect org.hibernate.dialect.SAPDBDialect
#hibernate.connection.driver_class com.sap.dbtech.jdbc.DriverSapDB
#hibernate.connection.url jdbc:sapdb://localhost/TST
#hibernate.connection.username TEST
#hibernate.connection.password TEST
#hibernate.query.substitutions yes 'Y', no 'N'
## MS SQL Server
#hibernate.dialect org.hibernate.dialect.SQLServerDialect
## JSQL Driver
#hibernate.connection.driver_class com.jnetdirect.jsql.JSQLDriver
#hibernate.connection.url jdbc:JSQLConnect://1E1/test
## JTURBO Driver
#hibernate.connection.driver_class com.newatlanta.jturbo.driver.Driver
#hibernate.connection.url jdbc:JTurbo://1E1:1433/test
## WebLogic Driver
#hibernate.connection.driver_class weblogic.jdbc.mssqlserver4.Driver
#hibernate.connection.url jdbc:weblogic:mssqlserver4:1E1:1433
## Microsoft Driver (not recommended!)
com.microsoft.jdbc.sqlserver.SQLServerDriver
jdbc:microsoft:sqlserver://1E1;DatabaseName=test;SelectMethod=cursor
## The New Microsoft Driver
com.microsoft.sqlserver.jdbc.SQLServerDriver
#hibernate.connection.url jdbc:sqlserver://localhost
## jTDS (since version 0.9)
#hibernate.connection.driver_class net.sourceforge.jtds.jdbc.Driver
#hibernate.connection.url jdbc:jtds:sqlserver://1E1/test
## Interbase
#hibernate.dialect org.hibernate.dialect.InterbaseDialect
#hibernate.connection.username sysdba
#hibernate.connection.password masterkey
## DO NOT specify hibernate.connection.sqlDialect
## InterClient
#hibernate.connection.driver_class interbase.interclient.Driver
jdbc:interbase://localhost:3060/C:/firebird/test.gdb
## Pure Java
#hibernate.connection.driver_class org.firebirdsql.jdbc.FBDriver
jdbc:firebirdsql:localhost/3050:/firebird/test.gdb
## Pointbase
#hibernate.dialect org.hibernate.dialect.PointbaseDialect
#hibernate.connection.driver_class com.pointbase.jdbc.jdbcUniversalDriver
#hibernate.connection.url jdbc:pointbase:embedded:sample
#hibernate.connection.username PBPUBLIC
#hibernate.connection.password PBPUBLIC
## Ingres
## older versions (before Ingress 2006)
#hibernate.dialect org.hibernate.dialect.IngresDialect
#hibernate.connection.driver_class ca.edbc.jdbc.EdbcDriver
#hibernate.connection.url jdbc:edbc://localhost:II7/database
## Ingres 2006 or later
#hibernate.connection.driver_class com.ingres.jdbc.IngresDriver
jdbc:ingres://localhost:II7/database;CURSOR=READONLY;auto=multi
## Mimer SQL
#hibernate.dialect org.hibernate.dialect.MimerSQLDialect
#hibernate.connection.driver_class com.mimer.jdbc.Driver
#hibernate.connection.url jdbc:mimer:multi1
#hibernate.connection.username hibernate
#hibernate.connection.password hibernate
## InterSystems Cache
#hibernate.dialect org.hibernate.dialect.Cache71Dialect
#hibernate.connection.driver_class com.intersys.jdbc.CacheDriver
#hibernate.connection.username _SYSTEM
#hibernate.connection.password SYS
#hibernate.connection.url jdbc:Cache://127.0.0.1:1972/HIBERNATE
### Hibernate Connection Pool ###
#hibernate.connection.pool_size 1
### C3P0 Connection Pool###
hibernate.c3p0.max_size 20
hibernate.c3p0.min_size 5
hibernate.c3p0.timeout 1800
hibernate.c3p0.max_statements 100
hibernate.c3p0.idle_test_period 3000
hibernate.c3p0.acquire_increment 2
hibernate.c3p0.validate false
### Proxool Connection Pool###
## Properties for external configuration of Proxool
hibernate.proxool.pool_alias pool1
## Only need one of the following
hibernate.proxool.existing_pool true
#hibernate.proxool.xml proxool.xml
#hibernate.proxool.properties proxool.properties
### Plugin ConnectionProvider ###
## use a custom ConnectionProvider (if not set, Hibernate will choose a
built-in ConnectionProvider using hueristics)
#hibernate.connection.provider_class
org.hibernate.connection.DriverManagerConnectionProvider
org.hibernate.connection.DatasourceConnectionProvider
org.hibernate.connection.C3P0ConnectionProvider
org.hibernate.connection.ProxoolConnectionProvider
### Transaction API ###
## Enable automatic flush during the JTA beforeCompletion() callback
## (This setting is relevant with or without the Transaction API)
#hibernate.transaction.flush_before_completion
## Enable automatic session close at the end of transaction
#hibernate.transaction.auto_close_session
## the Transaction API abstracts application code from the underlying JTA
or JDBC transactions
#hibernate.transaction.factory_class
org.hibernate.transaction.JTATransactionFactory
org.hibernate.transaction.JDBCTransactionFactory
## to use JTATransactionFactory, Hibernate must be able to locate the
UserTransaction in JNDI
## default is java:comp/UserTransaction
## you do NOT need this setting if you specify
hibernate.transaction.manager_lookup_class
#jta.UserTransaction jta/usertransaction
#jta.UserTransaction javax.transaction.UserTransaction
#jta.UserTransaction UserTransaction
## to use the second-level cache with JTA, Hibernate must be able to
obtain the JTA TransactionManager
#hibernate.transaction.manager_lookup_class
org.hibernate.transaction.JBossTransactionManagerLookup
org.hibernate.transaction.WeblogicTransactionManagerLookup
org.hibernate.transaction.WebSphereTransactionManagerLookup
org.hibernate.transaction.OrionTransactionManagerLookup
org.hibernate.transaction.ResinTransactionManagerLookup
### Miscellaneous Settings ###
## print all generated SQL to the console
hibernate.show_sql false
## format SQL in log and console
hibernate.format_sql true
## add comments to the generated SQL
#hibernate.use_sql_comments true
## generate statistics
#hibernate.generate_statistics true
## auto schema export
#hibernate.hbm2ddl.auto create-drop
#hibernate.hbm2ddl.auto update
#hibernate.hbm2ddl.auto validate
## specify a default schema and catalog for unqualified tablenames
#hibernate.default_schema test
#hibernate.default_catalog test
## enable ordering of SQL UPDATEs by primary key
#hibernate.order_updates true
## set the maximum depth of the outer join fetch tree
hibernate.max_fetch_depth 1
## set the default batch size for batch fetching
#hibernate.default_batch_fetch_size 8
## rollback generated identifier values of deleted entities to default
values
#hibernate.use_identifer_rollback true
## enable bytecode reflection optimizer (disabled by default)
#hibernate.bytecode.use_reflection_optimizer true
### JDBC Settings ###
## specify a JDBC isolation level
#hibernate.connection.isolation 4
## enable JDBC autocommit (not recommended!)
#hibernate.connection.autocommit true
## set the JDBC fetch size
#hibernate.jdbc.fetch_size 25
## set the maximum JDBC 2 batch size (a nonzero value enables batching)
#hibernate.jdbc.batch_size 5
#hibernate.jdbc.batch_size 0
## enable batch updates even for versioned data
hibernate.jdbc.batch_versioned_data true
## enable use of JDBC 2 scrollable ResultSets (specifying a Dialect will
cause Hibernate to use a sensible default)
#hibernate.jdbc.use_scrollable_resultset true
## use streams when writing binary types to / from JDBC
hibernate.jdbc.use_streams_for_binary true
## use JDBC 3 PreparedStatement.getGeneratedKeys() to get the identifier
of an inserted row
#hibernate.jdbc.use_get_generated_keys false
## choose a custom JDBC batcher
# hibernate.jdbc.factory_class
## enable JDBC result set column alias caching
## (minor performance enhancement for broken JDBC drivers)
# hibernate.jdbc.wrap_result_sets
## choose a custom SQL exception converter
#hibernate.jdbc.sql_exception_converter
### Second-level Cache ###
## optimize chache for minimal "puts" instead of minimal "gets" (good for
clustered cache)
#hibernate.cache.use_minimal_puts true
## set a prefix for cache region names
hibernate.cache.region_prefix hibernate.test
## disable the second-level cache
#hibernate.cache.use_second_level_cache false
## enable the query cache
#hibernate.cache.use_query_cache true
## store the second-level cache entries in a more human-friendly format
#hibernate.cache.use_structured_entries true
## choose a cache implementation
#hibernate.cache.provider_class org.hibernate.cache.EhCacheProvider
#hibernate.cache.provider_class org.hibernate.cache.EmptyCacheProvider
hibernate.cache.provider_class org.hibernate.cache.HashtableCacheProvider
#hibernate.cache.provider_class org.hibernate.cache.TreeCacheProvider
#hibernate.cache.provider_class org.hibernate.cache.OSCacheProvider
#hibernate.cache.provider_class org.hibernate.cache.SwarmCacheProvider
## choose a custom query cache implementation
#hibernate.cache.query_cache_factory
### JNDI ###
## specify a JNDI name for the SessionFactory
#hibernate.session_factory_name hibernate/session_factory
## Hibernate uses JNDI to bind a name to a SessionFactory and to look up
the JTA UserTransaction;
## if hibernate.jndi.* are not specified, Hibernate will use the default
InitialContext() which
## is the best approach in an application server
#file system
#hibernate.jndi.class com.sun.jndi.fscontext.RefFSContextFactory
#hibernate.jndi.url file:/
#WebSphere
#hibernate.jndi.class com.ibm.websphere.naming.WsnInitialContextFactory
#hibernate.jndi.url iiop://localhost:900/
Here's the log output:
0 [main] INFO qq.hibernate.TestAirports - inside test
171 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Creating emf
data store and registering it under name: AirportDataStore
265 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore -
Initializing protocol/extension for hibernate
265 [main] INFO org.eclipse.emf.teneo.hibernate.HbHelper - Returning
created emf data store, initialize this newly created data store!
265 [main] INFO qq.hibernate.TestAirports - after creating dataStore
1343 [main] INFO qq.hibernate.TestAirports - after setting package
1390 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Registering point:
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder classname:
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder default: true
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator classname:
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator default: true
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter
classname:
default: true
1406 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder
classname:
default: true
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper classname:
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper default: true
org.eclipse.emf.teneo.classloader.ClassLoaderStrategy classname:
org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy default: true
1421 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.mapping.strategy.EntityNameStrategy classname:
org.eclipse.emf.teneo.mapping.strategy.impl.EntityResolvingN ameStrategy
default: true
org.eclipse.emf.teneo.mapping.strategy.SQLNameStrategy classname:
org.eclipse.emf.teneo.mapping.strategy.impl.TeneoSQLNameStra tegy default:
true
org.eclipse.emf.teneo.annotations.xml.XmlPersistenceContentH andler
classname:
default: true
org.eclipse.emf.teneo.annotations.xml.XmlElementToEStructura lFeatureMapper
classname:
default: true
1437 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Registering point: org.eclipse.emf.teneo.PersistenceOptions classname:
org.eclipse.emf.teneo.PersistenceOptions default: true
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.OneToManyAttributeA nnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator
classname:
org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator default:
true
org.eclipse.emf.teneo.annotations.mapper.BidirectionalManyTo ManyAnnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.UnidirectionalManyT oManyAnnotator
classname:
default: true
1452 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator classname:
org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator default: true
org.eclipse.emf.teneo.annotations.mapper.OneToManyReferenceA nnotator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.OneToOneReferenceAn notator
classname:
default: true
org.eclipse.emf.teneo.annotations.mapper.ManyToOneReferenceA nnotator
classname:
default: true
- Registering point: org.eclipse.emf.teneo.hibernate.HbContext classname:
org.eclipse.emf.teneo.hibernate.HbContext default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rAccessor
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rFeatureIDAccessor
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rFeatureIDPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.EListProper tyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.EReferenceP ropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapE ntryFeatureURIPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapE ntryPropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.FeatureMapP ropertyHandler
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler
classname:
default: true
- Registering point: org.eclipse.emf.teneo.hibernate.EMFInterceptor
classname: org.eclipse.emf.teneo.hibernate.EMFInterceptor default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableFeatureMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.HbExtraLazyPer sistableEList
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapping.elist.MapHibernatePe rsistableEMap
classname:
default: true
org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator
classname:
org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator default:
true
org.eclipse.emf.teneo.hibernate.mapper.MappingContext classname:
org.eclipse.emf.teneo.hibernate.mapper.MappingContext default: true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper default: true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper default:
true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper default:
true
- Registering point: org.eclipse.emf.teneo.hibernate.mapper.IdMapper
classname: org.eclipse.emf.teneo.hibernate.mapper.IdMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper default: true
org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper classname:
org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper default: true
org.eclipse.emf.teneo.hibernate.mapping.EMFInitializeCollect ionEventListener
classname:
default: true
org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper classname:
org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper default: true
org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er classname:
org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er default:
true
org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r classname:
org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r default: true
org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r classname:
org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r default: true
org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper classname:
org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er classname:
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er default:
true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper
classname: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper default:
true
org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper default: true
org.eclipse.emf.teneo.jpox.mapper.property.TableMapper classname:
org.eclipse.emf.teneo.jpox.mapper.property.TableMapper default: true
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator classname:
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator default: true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.MappingContext
classname: org.eclipse.emf.teneo.jpox.mapper.MappingContext default: true
- Registering point: org.eclipse.emf.teneo.jpox.mapper.NamingHandler
classname: org.eclipse.emf.teneo.jpox.mapper.NamingHandler default: true
org.eclipse.emf.teneo.hibernate.annotations.HbAnnotationMode lBuilder
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbEAnnotationPar serImporter
default: true
org.eclipse.emf.teneo.hibernate.annotations.HbXmlPersistence Mapper
default: true
1468 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r default: true
1515 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
org.eclipse.emf.teneo.hibernate.annotations.HbEFeatureAnnota tor default:
true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyAttri buteAnnotator
default: true
org.eclipse.emf.teneo.hibernate.annotations.HbEDataTypeAnnot ator default:
true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyRefer enceAnnotator
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbOneToOneRefere nceAnnotator
default: true
classname:
org.eclipse.emf.teneo.hibernate.annotations.HbManyToOneRefer enceAnnotator
default: true
default: true
classname:
default: true
default: true
true
classname:
default: true
true
classname:
default: true
classname:
default: true
classname:
default: true
1515 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore -
Initializing Hb Session DataStore
>>>>> Creating HB Configuration
1593 [main] INFO org.hibernate.cfg.Environment - Hibernate 3.2.4.sp1
1718 [main] INFO org.hibernate.cfg.Environment - loaded properties from
resource hibernate.properties: {hibernate.connection.password=****,
hibernate.c3p0.acquire_increment=2,
hibernate.jdbc.batch_versioned_data=true,
hibernate.query.substitutions=yes 'Y', no 'N',
hibernate.cache.region_prefix=hibernate.test,
hibernate.c3p0.idle_test_period=3000, hibernate.show_sql=false,
hibernate.proxool.pool_alias=pool1, hibernate.c3p0.max_statements=100,
hibernate.bytecode.use_reflection_optimizer=false,
hibernate.c3p0.validate=false, hibernate.c3p0.timeout=1800,
hibernate.jdbc.use_streams_for_binary=true, hibernate.max_fetch_depth=1,
hibernate.c3p0.min_size=5, hibernate.format_sql=true,
hibernate.connection.username=epiuser,
hibernate.connection.driver_class=com.mysql.jdbc.Driver,
hibernate.cache.provider_class=org.hibernate.cache.Hashtable CacheProvider,
hibernate.c3p0.max_size=20,
hibernate.connection.provider_class=org.hibernate.connection .C3P0ConnectionProvider,
hibernate.proxool.existing_pool=true,
hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect,
hibernate.connection.url=jdbc:mysql://localhost:3306/epidb}
1734 [main] INFO org.hibernate.cfg.Environment - using java.io streams
to persist binary types
1734 [main] INFO org.hibernate.cfg.Environment - Bytecode provider name
: cglib
1749 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4
java.sql.Timestamp handling
1874 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Searching extension org.eclipse.emf.teneo.PersistenceOptions
1874 [main] INFO
org.eclipse.emf.teneo.classloader.ClassClassLoaderStrategy - Class loader
strategy set to:
- Initargs passed, using constructor for class
1874 [main] DEBUG org.eclipse.emf.teneo.PersistenceOptions - Properties
of PersistenceOptions:
teneo.mapping.fetch_containment_eagerly: false
teneo.naming.version_column: e_version
teneo.mapping.disable_econtainer: false
teneo.mapping.default_cache_strategy: NONE
teneo.mapping.sql_name_escape_character: `
teneo.mapping.set_default_cascade_on_non_containment:
teneo.mapping.map_all_lists_as_idbag: false
teneo.naming.max_sql_name_length: -1
teneo.mapping.default_temporal: TIMESTAMP
teneo.mapping.emap_as_true_map: true
teneo.mapping.default_varchar_length: -1
teneo.naming.default_id_column: e_id
teneo.mapping.also_map_as_class: true
teneo.mapping.add_index_for_fk: false
teneo.naming.java_class_entity_names: false
teneo.naming.join_table_naming_strategy: unique
teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
teneo.mapping.always_version: true
teneo.naming.idbag_id_column_name: ID
teneo.mapping.max_comment_length: 0
teneo.mapping.set_entity_automatically: true
teneo.mapping.hibernate_mapping_file: false
teneo.naming.set_foreign_key_name: true
teneo.mapping.cascade_policy_on_containment: ALL
teneo.naming.id_feature_as_primary_key: true
teneo.naming.set_generated_value_on_id_feature: true
teneo.runtime.update_schema: true
teneo.naming.strategy: lowercase
teneo.mapping.UserDateTimeType:
org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
teneo.mapping.always_map_list_as_bag: false
teneo.naming.join_column_naming_strategy: unique
teneo.mapping.set_proxy: false
teneo.mapping.UserDateType: org.eclipse.emf.teneo.hibernate.mapping.XSDDate
teneo.mapping.cascade_policy_on_non_containment:
teneo.mapping.ignore_eannotations: false
teneo.naming.default_id_feature: e_id
teneo.mapping.optimistic_locking: true
teneo.mapping.map_embeddable_as_embedded: false
teneo.mapping.cascade_all_on_containment:
teneo.mapping.join_table_for_non_contained_associations: true
- Created extensionPoint instance: org.eclipse.emf.teneo.PersistenceOptions
1874 [main] WARN org.eclipse.emf.teneo.extension.DefaultExtensionManager
- The extension: org.eclipse.emf.teneo.PersistenceOptions is declared as a
singleton but this getInstance call passed initialization parameters so
it is not cached, org.eclipse.emf.teneo.PersistenceOptions
1874 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbDataStore -
Generating mapping file from in-mem ecore
1890 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
- Caching extension instance as singleton point:
classname:
default: true
1905 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
default: true
1905 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder -
Creating pamodel for the following epackages
1905 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder - pool
2124 [main] DEBUG
location
2140 [main] DEBUG
Create base pannotated model
2140 [main] DEBUG
Deprecated eannotations with http://annotations.elver.org or
http://ejb.elver.org are ignored.
2140 [main] DEBUG
Parse annotations
2140 [main] DEBUG org.eclipse.emf.teneo.extension.DefaultExtensionManager
classname:
default: true
2155 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter -
Processing package pool
2155 [main] DEBUG
Processing pool
2155 [main] DEBUG
Number of parsed typename annotations 0
2155 [main] DEBUG
Processing EpiPool
2155 [main] DEBUG
2155 [main] DEBUG
Processing eclass EpiPool
2155 [main] DEBUG
Processing healthyIn
2155 [main] DEBUG
2155 [main] DEBUG
Processing healthyOut
2155 [main] DEBUG
2155 [main] DEBUG
Processing populationIn
2155 [main] DEBUG
2155 [main] DEBUG
Processing populationOut
2155 [main] DEBUG
2155 [main] DEBUG
Processing poolState
2155 [main] DEBUG
2155 [main] DEBUG
Processing PoolState
2155 [main] DEBUG
2155 [main] DEBUG
Processing eclass PoolState
2155 [main] DEBUG
Processing disease
2155 [main] DEBUG
2155 [main] DEBUG
Processing suseptableIn
2155 [main] DEBUG
2155 [main] DEBUG
Processing suseptableOut
2155 [main] DEBUG
2155 [
Re: Teneo not passing hibernate.properties? [message #424980 is a reply to message #424975] Wed, 12 November 2008 10:30 Go to previous messageGo to next message
Hi John,
It is a guess but it seems to be related to this line in the properties:
hibernate.connection.provider_class org.hibernate.connection.C3P0ConnectionProvider
do you have the c3p0 jar file in the classpath?
What happens if you comment out this line?
gr. Martin
John G wrote:
> Martin Taal wrote:
>> Hi John,
> file?
>> gr. Martin
> @BeforeClass
> @AfterClass
> @Before
> @After
> @Test
> and // creates the corresponding tables in the database.
> dataStore.getSessionFactory(); // Open a new
> session.close();
> ### Platforms ###
> ## JNDI Datasource
> ## HypersonicSQL
> ## MySQL
> ## Oracle
> ## PostgreSQL
> ## DB2
> ## TimesTen
> ## DB2/400
> ## Native driver
> ## Toolbox driver
> ## Sybase
> ## Mckoi SQL
> ## SAP DB
> ## MS SQL Server
> ## JSQL Driver
> ## JTURBO Driver
> ## WebLogic Driver
> ## The New Microsoft Driver #hibernate.connection.driver_class
> ## Interbase
> ## InterClient
> ## Pure Java
> ## Pointbase
> ## Ingres
> ## Mimer SQL
> JTA or JDBC transactions
> values
> of an inserted row
> ## enable JDBC result set column alias caching ## (minor performance
> for clustered cache)
> ### JNDI ###
> #file system
> #WebSphere
> emf data store and registering it under name: AirportDataStore
> 1390 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Registering
> point: org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder
> classname: org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder
> default: true
> 1390 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator
> classname: org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator
> default: true
> 1390 [main] DEBUG
> point:
> classname:
> default: true
> 1406 [main] DEBUG
> point:
> classname:
> default: true
> 1406 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper
> classname: org.eclipse.emf.teneo.annotations.xml.XmlPersistenceMapper
> default: true
> 1406 [main] DEBUG
> point: org.eclipse.emf.teneo.classloader.ClassLoaderStrategy classname:
> 1421 [main] DEBUG
> point: org.eclipse.emf.teneo.mapping.strategy.EntityNameStrategy
> classname:
> default: true
> 1421 [main] DEBUG
> point: org.eclipse.emf.teneo.mapping.strategy.SQLNameStrategy classname:
> default: true
> 1421 [main] DEBUG
> point:
> classname:
> default: true
> 1421 [main] DEBUG
> point:
> classname:
> default: true
> 1437 [main] DEBUG
> 1437 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator
> default: true
> 1437 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator
> default: true
> 1437 [main] DEBUG
> point:
> classname:
> default: true
> 1437 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.SingleAttributeAnno tator
> classname:
> default: true
> 1437 [main] DEBUG
> point:
> classname:
> default: true
> 1437 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator
> classname: org.eclipse.emf.teneo.annotations.mapper.EDataTypeAnnotator
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.EMFInterceptor classname:
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator
> classname:
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.MappingContext classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.BasicMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.EmbeddedMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.EntityMapper classname:
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper classname:
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.IdMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper
> classname: org.eclipse.emf.teneo.hibernate.mapper.ManyAttributeMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper
> classname: org.eclipse.emf.teneo.hibernate.mapper.ManyToManyMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper classname:
> 1452 [main] DEBUG
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.OneToManyMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.hibernate.mapper.OneToOneMapper classname:
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.association.EmbeddedMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.ManyToManyMapp er
> classname:
> true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r
> classname: org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r
> classname: org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.association.OneToOneMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.BasicMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.ColumnMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er
> classname:
> true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.IdMapper classname:
> org.eclipse.emf.teneo.jpox.mapper.property.IdMapper default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.InheritanceMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.JoinColumnMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper
> classname: org.eclipse.emf.teneo.jpox.mapper.property.ManyBasicMapper
> default: true
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.property.TableMapper classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.MappingContext classname:
> 1452 [main] DEBUG
> point: org.eclipse.emf.teneo.jpox.mapper.NamingHandler classname:
> 1452 [main] DEBUG
> classname:
> default: true
> 1452 [main] DEBUG
> point:
> classname:
> default: true
> 1452 [main] DEBUG
> classname:
> default: true
> 1468 [main] DEBUG
> classname: org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r
> default: true
> 1515 [main] DEBUG
> classname:
> true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> classname:
> default: true
> 1515 [main] DEBUG
> default: true
> 1515 [main] DEBUG
> classname:
> true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> 1515 [main] DEBUG
> point:
> classname:
> default: true
> from resource hibernate.properties: {hibernate.connection.password=****,
> 1874 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Searching
> 1874 [main] INFO
> loader strategy set to:
> 1874 [main] DEBUG
> org.eclipse.emf.teneo.extension.DefaultExtensionManager - Initargs
> teneo.mapping.set_default_cascade_on_non_containment: 1874 [main] DEBUG
> teneo.mapping.cascade_policy_on_non_containment: 1874 [main] DEBUG
> teneo.mapping.cascade_all_on_containment: 1874 [main] DEBUG
> 1874 [main] DEBUG
Re: Teneo not passing hibernate.properties? [message #424999 is a reply to message #424980] Wed, 12 November 2008 13:52 Go to previous messageGo to next message
Hi Martin,
Yes, the C3P0 jar is on the classpath. I get the same error when that line
is commented out; I also tried commenting out the other C3P0 properties,
and got the same error.
Re: Teneo not passing hibernate.properties? [message #425003 is a reply to message #424999] Wed, 12 November 2008 15:51 Go to previous messageGo to next message
Hi John,
To be sure about the set of properties used by hibernate, can you create a hibernate.properties file
with just these properties:
hibernate.connection.password=grendelhash
hibernate.dialect=org.hibernate.dialect.MySQL5InnoDBDialect
Also after creating this properties file, can you check that it is copied to the build/output folder
(during build)? So that hibernate uses this one?
To give some background info. Here is the code Hibernate uses to select the connectionprovider.
Apparently in your case none of the if-statements pass so that it uses the
UserSuppliedConnectionProvider which always throws an exception. So one way or another hibernate
does not see the url, c3p0 or proxool properties...
You can try to set a breakpoint in ConnectionProviderFactory.newConnectionProvider to see what happens.
String providerClass = properties.getProperty(Environment.CONNECTION_PROVIDER);
if ( providerClass!=null ) {
try {
log.info("Initializing connection provider: " + providerClass);
connections = (ConnectionProvider) ReflectHelper.classForName(providerClass).newInstance();
catch (Exception e) {
log.fatal("Could not instantiate connection provider", e);
throw new HibernateException("Could not instantiate connection provider: " + providerClass);
else if ( properties.getProperty(Environment.DATASOURCE)!=null ) {
connections = new DatasourceConnectionProvider();
else if ( properties.getProperty(Environment.C3P0_MAX_SIZE)!=null ) {
connections = new C3P0ConnectionProvider();
else if (
properties.getProperty(Environment.PROXOOL_XML)!=null ||
properties.getProperty(Environment.PROXOOL_PROPERTIES)!=null ||
properties.getProperty(Environment.PROXOOL_EXISTING_POOL)!=n ull
connections = new ProxoolConnectionProvider();
else if ( properties.getProperty(Environment.URL)!=null ) {
connections = new DriverManagerConnectionProvider();
else {
connections = new UserSuppliedConnectionProvider();
gr. Martin
John G wrote:
> Hi Martin,
> line is commented out; I also tried commenting out the other C3P0
> properties, and got the same error.
The Netherlands
Re: Teneo not passing hibernate.properties? [message #425133 is a reply to message #425003] Fri, 14 November 2008 16:37 Go to previous messageGo to next message
Hello all,
Thanks, Martin, for your reply.
I have gone back to basics to eliminate potential problem areas because
obviously I have missed something. So...
I followed the steps in the library tutorial to create the library EMF
package, and tested it. It worked fine. I am using eclipse ganymede,
hibernate 3.2.6GA, and teneo 1.0.0.
I tried to followed the steps in the Teneo tutorial
( http://www.elver.org/hibernate/tutorialone/tutorial1_intro.h tml), but ran
into a confusing problem in the step titled "Create and Store EMF
Objects". Right after the "Hibernate database configuration" section is
the "Initialize the runtime layer" section, but the tutorial doesn't say
where to write this code. This wasn't obvious to me, so I created a new
class called TestLibrary in the project, and placed the rest of the code
in it. Was this the right thing to do? (I'm betting it isn't! ...but I
don't know what else to do for this. Any guidance? This may be where my
fundamental misunderstanding lies...)
Anyway, after placing the rest of the tutorial code into TestLibrary, I
ran the application from inside eclipse, and had errors similar to my
original ones!
Here's my code, hibernate.properties file, and console log.
#Code, copied right from the tutorial:
import org.eclipse.example.library.Book;
import org.eclipse.example.library.BookCategory;
import org.eclipse.example.library.Library;
import org.eclipse.example.library.LibraryFactory;
import org.eclipse.example.library.LibraryPackage;
import org.eclipse.example.library.Writer;
public class TestLibrary {
* @param args
// TODO Auto-generated method stub
// Create the DataStore.
final String dataStoreName = "LibraryDataStore";
final HbDataStore dataStore = HbHelper.INSTANCE
// Configure the EPackages used by this DataStore.
dataStore.setEPackages(new EPackage[] { LibraryPackage.eINSTANCE
// Initialize the DataStore. This sets up the Hibernate mapping and
// Open a new Session and start Transaction.
// Create a Library.
Library library = LibraryFactory.eINSTANCE.createLibrary();
library.setName("My Library");
// Make it persistent.
session.save(library);
// Create a writer...
Writer writer = LibraryFactory.eINSTANCE.createWriter();
writer.setName("JRR Tolkien");
// ...and one of his books.
Book book = LibraryFactory.eINSTANCE.createBook();
book.setAuthor(writer);
book.setPages(305);
book.setTitle("The Hobbit");
book.setCategory(BookCategory.SCIENCE_FICTION);
// Add the Writer and Book to the Library. They are made
// persistent automatically because the Library is itself
// already persistent.
library.getWriters().add(writer);
library.getBooks().add(book);
session.close();
# hibernate.properties
hibernate.connection.username=fred
hibernate.connection.password=flintstone
hibernate.connection.url=jdbc:mysql://localhost:3306/library
# console output
Nov 14, 2008 1:06:08 PM org.eclipse.emf.teneo.hibernate.HbHelper
INFO: Creating emf data store and registering it under name:
LibraryDataStore
Nov 14, 2008 1:06:09 PM org.eclipse.emf.teneo.hibernate.HbHelper
INFO: Returning created emf data store, initialize this newly created data
store!
Nov 14, 2008 1:06:09 PM org.hibernate.cfg.Environment <clinit>
INFO: Hibernate 3.2.6
INFO: loaded properties from resource hibernate.properties:
{hibernate.connection.username=fred, hibernate.connection.password=****,
hibernate.connection.url=jdbc:mysql://localhost:3306/library,
hibernate.connection.driver_class=com.mysql.jdbc.Driver}
Nov 14, 2008 1:06:09 PM org.hibernate.cfg.Environment buildBytecodeProvider
INFO: Bytecode provider name : cglib
INFO: using JDK 1.4 java.sql.Timestamp handling
org.eclipse.emf.teneo.classloader.ClassLoaderResolver
setClassLoaderStrategy
INFO: Class loader strategy set to:
org.eclipse.emf.teneo.extension.DefaultExtensionManager getExtension
WARNING: The extension: org.eclipse.emf.teneo.PersistenceOptions is
declared as a singleton but this getInstance call passed initialization
parameters so it is not cached, org.eclipse.emf.teneo.PersistenceOptions
Nov 14, 2008 1:06:10 PM org.hibernate.cfg.HbmBinder
bindRootPersistentClassCommonValues
INFO: Mapping class: Book -> book
INFO: Mapping class: Library -> library
INFO: Mapping class: Writer -> writer
Nov 14, 2008 1:06:10 PM org.hibernate.cfg.HbmBinder bindCollection
INFO: Mapping collection: Writer.books -> writer_books
Nov 14, 2008 1:06:10 PM org.eclipse.emf.teneo.hibernate.HbDataStore
setDefaultProperties
WARNING: No hibernate cache provider set, using
WARNING: For production use please set the ehcache (or other) provider
explicitly and configure it
INFO: Hibernate property: hibernate.hbm2ddl.auto not set, setting to update
logProperties
INFO: teneo.mapping.fetch_containment_eagerly: false
logProperties
INFO: hibernate.cache.provider_class:
logProperties
INFO: teneo.naming.version_column: e_version
logProperties
INFO: teneo.mapping.disable_econtainer: false
logProperties
INFO: teneo.mapping.default_cache_strategy: NONE
logProperties
INFO: teneo.mapping.sql_name_escape_character: `
logProperties
INFO: teneo.mapping.set_default_cascade_on_non_containment:
logProperties
INFO: teneo.mapping.map_all_lists_as_idbag: false
logProperties
INFO: teneo.naming.max_sql_name_length: -1
logProperties
INFO: teneo.mapping.default_temporal: TIMESTAMP
logProperties
INFO: teneo.mapping.emap_as_true_map: true
logProperties
INFO: teneo.mapping.default_varchar_length: -1
logProperties
INFO: teneo.naming.default_id_column: e_id
logProperties
INFO: teneo.mapping.also_map_as_class: true
logProperties
INFO: teneo.mapping.add_index_for_fk: false
logProperties
INFO: teneo.naming.java_class_entity_names: false
logProperties
INFO: teneo.naming.join_table_naming_strategy: unique
logProperties
INFO: teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
logProperties
INFO: teneo.mapping.always_version: true
logProperties
INFO: teneo.naming.idbag_id_column_name: ID
logProperties
INFO: teneo.mapping.max_comment_length: 0
logProperties
INFO: teneo.mapping.set_entity_automatically: true
logProperties
INFO: teneo.mapping.hibernate_mapping_file: false
logProperties
INFO: teneo.naming.set_foreign_key_name: true
logProperties
INFO: teneo.mapping.cascade_policy_on_containment: ALL
logProperties
INFO: teneo.naming.id_feature_as_primary_key: true
logProperties
INFO: teneo.naming.set_generated_value_on_id_feature: true
logProperties
INFO: teneo.runtime.update_schema: true
logProperties
INFO: teneo.naming.strategy: lowercase
logProperties
INFO: teneo.mapping.UserDateTimeType:
logProperties
INFO: teneo.mapping.always_map_list_as_bag: false
logProperties
INFO: teneo.naming.join_column_naming_strategy: unique
logProperties
INFO: teneo.mapping.set_proxy: false
logProperties
INFO: teneo.mapping.UserDateType:
logProperties
INFO: teneo.mapping.cascade_policy_on_non_containment:
logProperties
INFO: teneo.mapping.ignore_eannotations: false
logProperties
INFO: hibernate.hbm2ddl.auto: update
logProperties
INFO: teneo.naming.default_id_feature: e_id
logProperties
INFO: teneo.mapping.map_embeddable_as_embedded: false
logProperties
INFO: teneo.mapping.optimistic_locking: true
logProperties
INFO: teneo.mapping.join_table_for_non_contained_associations: true
logProperties
INFO: teneo.mapping.cascade_all_on_containment:
bindCollectionSecondPass
INFO: Mapping collection: Library.writers -> writer
INFO: Mapping collection: Library.books -> book
initializeDataStore
WARNING: The teneo update schema option is not used anymore for hibernate,
use the hibernate option: hibernate.hbm2ddl.auto
org.hibernate.connection.UserSuppliedConnectionProvider configure
WARNING: No connection properties specified - the user must supply JDBC
connections
Exception in thread "main" org.hibernate.HibernateException: Hibernate
Dialect must be explicitly set
at
org.hibernate.dialect.DialectFactory.determineDialect(Dialec tFactory.java:57)
at
org.hibernate.dialect.DialectFactory.buildDialect(DialectFac tory.java:39)
at
org.hibernate.cfg.SettingsFactory.determineDialect(SettingsF actory.java:426)
at
org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFact ory.java:128)
at org.hibernate.cfg.Configuration.buildSettings(Configuration. java:2073)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1298)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:162)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:82)
at TestLibrary.main(TestLibrary.java:30)
Re: Teneo not passing hibernate.properties? [message #425135 is a reply to message #425133] Fri, 14 November 2008 17:20 Go to previous messageGo to next message
Hi John,
I see that you mention teneo 1.0.0, there was an issue in teneo 1.0.0 with hibernate.properties. Can
you use the latest M build of Teneo? Here is the link:
http://www.eclipse.org/modeling/download.php?file=/modeling/ emf/teneo/downloads/drops/1.0.1/R200809231814/emf-teneo-SDK- 1.0.1.zip
Btw, your code is fine in one class (:-) so your bet was fine). For 'real' code, I put the
initialization code in one class which provides hibernate sessions to the rest of the application.
gr. Martin
John G wrote:
> Hello all,
> ran into a confusing problem in the step titled "Create and Store EMF
> original ones!
> * @param args
> public static void main(String[] args) {
> dataStore.setEPackages(new EPackage[] { LibraryPackage.eINSTANCE });
> final SessionFactory sessionFactory = dataStore.getSessionFactory();
> book.setPages(305);
> session.close();
> # console output
> LibraryDataStore
> data store!
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> INFO: teneo.mapping.set_default_cascade_on_non_containment: Nov 14, 2008
> 1:06:10 PM org.eclipse.emf.teneo.hibernate.HbDataStore logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> INFO: teneo.mapping.cascade_policy_on_non_containment: Nov 14, 2008
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> logProperties
> INFO: teneo.mapping.cascade_all_on_containment: Nov 14, 2008 1:06:10 PM
> org.hibernate.cfg.HbmBinder bindCollectionSecondPass
> initializeDataStore
> hibernate, use the hibernate option: hibernate.hbm2ddl.auto
> connections
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: Teneo not passing hibernate.properties? [message #425157 is a reply to message #425135] Mon, 17 November 2008 14:33 Go to previous messageGo to next message
Martin Taal wrote:
> Hi John,
Hi Martin,
Again, thanks for helping me.
Bottom line (see below for details), the new plugins don't show up in the
plugin details list, nor are they available to add in the dependencies
dialog. Nothing unusual in the .log, either. What did I do wrong? I
thought installing a plugin was simply drop-and-restart...hate to be
sidetracked by such a simple problem. Doesn't seem to be any relevant info
on Google, either.
This is driving me nuts! Thanks for any sanity provided...
If you want the details, here's what I did. Please point out my errors! :
I downloaded the maintenance release zip file from the link you provided,
un-zipped (using 7-Zip) it into a temp folder, then copied the contents of
the unzipped features folder and plugin folder to my eclipse features and
plugins folders, respectively.
After starting eclipse, I opened help--> plugin details, and none of the
1.0.1 teneo plugins were listed (the 1.0.0 plugins were still there). I
also couldn't add them to my plugin dependencies (they weren't listed in
the dialog list).
Assuming I did something wrong by placing the 1.0.1 items next to the
1.0.0 items in their respective folders, I removed the original 1.0.0
folders and files from both features and plugins folders (leaving the
1.0.1 files & folders), re-started eclipse; this time, **no** teneo
plugins were found.
So, thinking it might be my eclipse installation, I unzipped a clean
eclipse ganymede, started it up, checked that teneo 1.0.0 was OK, shut it
down, unzipped the maintenance build and copied files as before, restarted
eclipse, and same problem: no teneo 1.0.1 plugins listed anywhere, even
though both 1.0.0 and 1.0.1 files were in place in features and plugins
folders.
So, removed the 1.0.1 files from features and plugins, restarted eclipse,
checked that teneo 1.0.0 was OK, then downloaded and tried the same steps
with the teneo emf-teneo-SDK-M200811151637.zip build, with the same
results.
Re: Teneo not passing hibernate.properties? [message #425159 is a reply to message #425157] Mon, 17 November 2008 14:51 Go to previous messageGo to next message
Hi John,
From eclipse 3.4 onwards it is not possible to copy plugins/features directly into the eclipse
installation directory.
Assuming that you are using eclipse 3.4 you should install plugins as follows:
- unzip the downloaded zip file
- copy the eclipse directory (which is the result of the unzip) into the dropins folder of your
- restart eclipse
and then hopefully they will show up...
gr. Martin
John G wrote:
> Martin Taal wrote:
>> Hi John,
>> with
> Hi Martin, Again, thanks for helping me. Bottom line (see below for
> details), the new plugins don't show up in the plugin details list, nor
> are they available to add in the dependencies dialog. Nothing unusual in
> the .log, either. What did I do wrong? I thought installing a plugin was
> simply drop-and-restart...hate to be sidetracked by such a simple
> problem. Doesn't seem to be any relevant info on Google, either.
> provided, un-zipped (using 7-Zip) it into a temp folder, then copied the
> contents of the unzipped features folder and plugin folder to my eclipse
> features and plugins folders, respectively. After starting eclipse, I
> opened help--> plugin details, and none of the 1.0.1 teneo plugins were
> listed (the 1.0.0 plugins were still there). I also couldn't add them to
> my plugin dependencies (they weren't listed in the dialog list).
> plugins were found. So, thinking it might be my eclipse installation, I
> unzipped a clean eclipse ganymede, started it up, checked that teneo
> 1.0.0 was OK, shut it down, unzipped the maintenance build and copied
> files as before, restarted eclipse, and same problem: no teneo 1.0.1
> plugins listed anywhere, even though both 1.0.0 and 1.0.1 files were in
> place in features and plugins folders.
> eclipse, checked that teneo 1.0.0 was OK, then downloaded and tried the
> same steps with the teneo emf-teneo-SDK-M200811151637.zip build, with
> the same results.
The Netherlands
Re: Teneo not passing hibernate.properties? [message #425164 is a reply to message #425159] Mon, 17 November 2008 17:07 Go to previous messageGo to next message
Hello Martin,
Thanks for that bit about dropins... after removing my previous
installations, and reading up on P2, I finally updated to Teneo 1.0.1 via
software updates, and now the Library example works just fine! I now have
to apply the same fix to my original problem, and I will let you know how
it works out. Thanks again for your time...I'm quite a few steps closer to
getting things to work!
Re: Teneo not passing hibernate.properties? [message #425249 is a reply to message #425164] Thu, 20 November 2008 15:34 Go to previous message
Hi Martin,
The Teneo update eliminated my original problem, and I am back to work!
Thanks again for all your help.
To recap (and for those finding this by search engine), I originally had a
problem where Teneo 1.0.0 wouldn't get correct hibernate.properties values
even though they were read earlier. The error was:
org.hibernate.connection.UserSuppliedConnectionProvider - No connection
properties specified - the user must supply JDBC connections
Updating to Teneo 1.0.1 (via eclipse software updates) fixed the problem.
Sincerely,
John
Previous Topic:[Teneo] How to disable automatic updating of DB schema when application starts
Next Topic:Rose Importer Patch and Question
Current Time: Sun Jul 20 18:03:51 EDT 2025
Powered by FUDForum. Page generated in 1.16667 seconds
