Re: Generate impl and interfaces in different projects [message #425013 is a reply to message #425011] |
Thu, 13 November 2008 07:01  |
--------------070402060705040408030209
David,
The factory interface will always want to refer to the class for
implementing its default instance.
David Michonneau wrote:
> What about the case where we suppress EMF code in the generated interfaces?
> David
> "Ed Merks" <Ed.Merks@gmail.com> wrote in message
> news:gfh386$map$2@build.eclipse.org...
>> David,
>> No. Things like XyzPackage.eINSTANCE and XyzFactory.eINSTANCE need to
>> refer to a/the implementation class, so the interfaces and impls are
>> mutually dependent and as such, I'm not sure you can separate them into
>> two projects...
>>> Hi,
>>> I would like to generate the implementation classes and the interface
>>> ones in two different projects. Is there a simple way to do it?
>>> Thanks,
>>> David
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
implementing its default instance.<br>
<br>
<br>
<blockquote cite="mid:gfh3g8$51c$1@build.eclipse.org" type="cite">
<pre wrap="">What about the case where we suppress EMF code in the generated interfaces?
David
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gfh386$map$2@build.eclipse.org">news:gfh386$map$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">David,
two projects...
</pre>
<pre wrap="">Hi,
David
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------070402060705040408030209--
FUDForum. Page generated in 0.05255 seconds
