Home » Modeling » EMF » Save EList
Save EList [message #424852] Thu, 06 November 2008 21:13 Go to next message
i have an Object with two multi-valued attributes. One of these
attributes is editable over a gmf editor. the other attribute is
effected programmatically. When i save the object, there is only the
first attribute saved. The second is not in the xmi representation. Why
is that?
Thanks for your help
Jörg Oelerink
Re: Save EList [message #424859 is a reply to message #424852] Fri, 07 November 2008 05:45 Go to previous messageGo to next message
Jörg,
Maybe it's marked with EStructuralFeature.transient being true? Of
maybe EObject.eIsSet(<feature>) returns false indicating the value is
not or or isn't different from the default.
Jörg wrote:
> Hello,
> Why is that?
> Jörg Oelerink
Re: Save EList [message #424897 is a reply to message #424859] Mon, 10 November 2008 05:43 Go to previous messageGo to next message
thanks a lot,but it depends on the containment feature. I add every
single element on this way:
resource.getContents().add((EObject) entry.getValue());
is there a better way, so i can have containments, which are saved in
the xmi representation?
Greetings
Ed Merks schrieb:
> Jörg,
> Jörg wrote:
>> Hello,
>> Why is that?
>> Jörg Oelerink
Re: Save EList [message #424899 is a reply to message #424897] Mon, 10 November 2008 06:25 Go to previous messageGo to next message
Jörg,
I see. Only an XMIResourceImpl will save multiple root objects, because
it serializes a "fake" XMI root elememt. An XMLResourceImpl will only
save a single root object, so you'd need to define a class whose
instances can hold multiple objects and use one of those as the root.
Jörg wrote:
> Hello,
> Greetings
> Ed Merks schrieb:
>> Jörg,
>> Jörg wrote:
>>> Hello,
>>> Why is that?
>>> Jörg Oelerink
Re: Save EList [message #424936 is a reply to message #424899] Tue, 11 November 2008 04:36 Go to previous messageGo to next message
hmm multiple roots would be okay, i need the correct childrentree. but
in the xml representation he has now one root with no childs. The
rootelement has children in a contained elist. How can i get them into
the resource. the add method ignores now the none root elements.
Jörg
Ed Merks schrieb:
> Jörg,
> Jörg wrote:
>> Hello,
>> Greetings
>> Ed Merks schrieb:
>>> Jörg,
>>> Jörg wrote:
>>>> Hello,
>>>> Why is that?
>>>> Jörg Oelerink
Re: Save EList [message #424938 is a reply to message #424936] Tue, 11 November 2008 06:55 Go to previous messageGo to next message
Jörg,
Keep in mind that generally adding a child to the contents of a resource
will remove it from the parent. So perhaps you need to be more careful
that if eContainer() != null and if eResource() != null that you don't
try to add that object to the root of a resource because it's already
indirectly contained by a resource.
Jörg wrote:
> Hello,
> Thanks
> Jörg
> Ed Merks schrieb:
>> Jörg,
>> because it serializes a "fake" XMI root elememt. An XMLResourceImpl
>> will only save a single root object, so you'd need to define a class
>> whose instances can hold multiple objects and use one of those as the
>> root.
>> Jörg wrote:
>>> Hello,
>>> in the xmi representation?
>>> Greetings
>>> Ed Merks schrieb:
>>>> Jörg,
>>>> is not or or isn't different from the default.
>>>> Jörg wrote:
>>>>> Hello,
>>>>> the first attribute saved. The second is not in the xmi
>>>>> representation. Why is that?
>>>>> Jörg Oelerink
Re: Save EList [message #424951 is a reply to message #424938] Tue, 11 November 2008 10:22 Go to previous message
Thanks a lot. Now i got it.
Ed Merks schrieb:
> Jörg,
> Jörg wrote:
>> Hello,
>> Thanks
>> Jörg
>> Ed Merks schrieb:
>>> Jörg,
>>> root.
>>> Jörg wrote:
>>>> Hello,
>>>> Greetings
>>>> Ed Merks schrieb:
>>>>> Jörg,
>>>>> Jörg wrote:
>>>>>> Hello,
>>>>>> Jörg Oelerink
Previous Topic:Where can I get TreeNodeItemProvider or MappingItemProvider examples?
Next Topic:[EMF] Problems registering package namespaces.
Current Time: Sun Jul 20 07:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.04027 seconds
