Home » Modeling » EMF » Programmatically creating EMF from XSD
Programmatically creating EMF from XSD [message #424853] Thu, 06 November 2008 22:08 Go to next message
I have a situation where 100s of xsd's need to be available as EMF in my
app. It would be nice to not have to make the part of the build process and
allow xsds (and their respective EMF models) to be added to the system at
runtime. What is the most appropriate programmatic technique for achieving
this?
Currently I have been looking at loading the xsds with the XSD API and then
using its XSDEcoreBuilder like in
http://www.theserverside.com/tt/articles/content/BindingXMLJ ava/article.html.
However, I was not sure where to get the extendedMetaData to pass to the
XSDEcoreBuilder constructor and whether this was required or not. I would
assume that all the metadata required (the complete xsd that could be used
to generate EMF) would be in the XSD model when the XSD was loaded, so this
should not be required (???).
Re: Programmatically creating EMF from XSD [message #424860 is a reply to message #424853] Fri, 07 November 2008 05:54 Go to previous message
Derek,
Comments below.
Derek Palma wrote:
> my app.
That's quite a few.
> at runtime.
Do you need generated code for these models or is dynamic EMF
sufficient? OSGi allows bundles to be added a runtime.
> What is the most appropriate programmatic technique for achieving this?
> then using its XSDEcoreBuilder like in
That seems a reasonable way.
> the XSDEcoreBuilder constructor and whether this was required or not.
There's a constructor which doesn't require one.
> I would assume that all the metadata required (the complete xsd that
> could be used to generate EMF) would be in the XSD model when the XSD
> was loaded, so this should not be required (???).
It might be the case that models in the XSDs depend on generated models
that already exist...
Previous Topic:[CDO] Does BDStore support non-auditing mode?
Next Topic:How to edit JET1- templates in Ganymade?
Current Time: Sat Jul 19 22:21:37 EDT 2025
Powered by FUDForum. Page generated in 0.03710 seconds
