Home » Modeling » EMF » [CDO] Being able to retrieve ResourcePath from a MemStore implementation
[CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424741] |
Tue, 04 November 2008 10:51  |
I am trying to write a custom implementation of MemStore, but I've been
struggling with one issue I have.
I need to able to get the path of the revisions I am willing to write when
write(CommitContext) of the MemStoreAccessor is called.
The CommitextContext contains the new and dirty Revisions but not the
path, even by digging into code, I am not able to determine the path of
the revisions that need to be written from a pure cdo server perspective
which I need to be able to implement our own version of the MemStore.
Any help with this will be much appreciated,
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424755 is a reply to message #424754] |
Tue, 04 November 2008 18:24   |
Good!!
NOw when users ask the following:
/aaa/bbb/ccc
This contains 4 objects :
A- CDOResource (RootResource) name = null, folderID =null
B- CDOResourceFolder name = aaa, folderID =null
C- CDOResourceFolder name = bbb, folderID = B
D- CDOResource name = ccc, folderID = C
The client would call first QUeryResource.. after it could call
QUeryResource or readRevision!! It depends of many things.
When folder==null and name == null this means it looks for the RootResource!
Let me know if you need more advices
Simon
Now
kaab wrote:
> Hi Simon,
> Thanks for all your help,
> I am making some progress using the path reconstruction, and fully
> implemented a backed version of the Store in the filesystem.
> The second part of my work is when a user try to load a resource, in
> this case I'm not sure I understand the way MemStore behaves. The user
> enters a path trying to load a resource for example "/aaa/bbb/ccc", on
> the server side I get a QueryResourceContext with the first part of the
> name and null as the folderID,after that the MemStore is not called
> anymore and the resource is loaded, so I don't know how to determine the
> full path for a query when a user does one.
> Anyone can advice on that matter ?
> Thank you very much,
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424918 is a reply to message #424763] |
Mon, 10 November 2008 10:54   |
Hi guys,
Thanks for all your help and information.
I'm sorry to get back to you so late, I've been sick last week and I just
got back to work.
I'm doing some debug after I changed the path to use the CDOID only,
instead of keeping complete path, which would be bad in case of moving
resources, like Eike mentioned.
Right now, I'm using a seperate folder for the RootResource and the padded
string to store the revisions. I've been thinking in storing
RootResourceFolders by their names in some file in order to keep track of
the correpondancy between TopLevel reource folder Names and CDOIDs, cause
I've noticed that they are also queried trough queryResources (as long as
the RootRessource) and so they are queried by their names and not their
CDOIDs, is this Right ?
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424919 is a reply to message #424918] |
Mon, 10 November 2008 11:37   |
Hi Kaab,
Happy to hear that you are feeling better!! :-)
kaab wrote:
> Hi guys,
> just got back to work. I'm doing some debug after I changed the path to
> use the CDOID only, instead of keeping complete path, which would be bad
> in case of moving resources, like Eike mentioned. Right now, I'm using a
> seperate folder for the RootResource and the padded string to store the
> revisions. I've been thinking in storing RootResourceFolders by their
> names in some file in order to keep track of the correpondancy between
> TopLevel reource folder Names and CDOIDs, cause I've noticed that they
> are also queried trough queryResources (as long as the RootRessource)
> and so they are queried by their names and not their CDOIDs, is this
> Right ?
Right but...
They could be queried by CDOID as well. It depends how the client
request an objects.
getResource("/aa/aa/bb/cc") // By Name
getObject(id) // by id.. could be a resource.
Simon
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424922 is a reply to message #424920] |
Mon, 10 November 2008 14:40   |
Hi Kaab,
Which errors you are noticing? Stack trace will be good!! :-)
THe code you showed me could be good or not.
In which context you are using it in the server side. I mean... WHat are
the Request/Indication are you using it for ?
SImon
kaab wrote:
> I'm sorry to bother you so often, but after I've prepared to run a full
> test, I'm noticing a lot of errors when reading CDORevisions, speacially
> for resolving cdoClassRefs. The way we read and write revisions is
> mainly inspired from CDO code. And it is now implemented this way :
> final FileOutputStream output = new FileOutputStream(f);
> final ExtendedDataOutputStream ext = ExtendedDataOutputStream.wrap(output);
> final CDODataOutputImpl cdodo = new CDODataOutputImpl(ext) {
> // Not sure about these two
> @Override
> protected CDOPackageURICompressor getPackageURICompressor() {
> return (CDOPackageURICompressor)session;
> @Override
> public CDOIDProvider getIDProvider() {
> return (CDOIDProvider)session;
> ((CDORevisionImpl)revision).write(cdodo, CDORevision.UNCHUNKED);
> If this code is not OK, than I would really appreciate your suggestions
> to serialize the revisions into the filesystem. This code was tested and
> was working but it now causing problems, so I would like to make sure
> it's safe using it.
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424963 is a reply to message #424920] |
Wed, 12 November 2008 02:40   |
Kaab,
The special CDODataInputStream and CDODataOutputStream were designed to
be used for data transfer over the network. I think it can be used for
transfer to/from files as well but the package URI compressor does not
make sense then because it relies on a compressor being available at the
other side of the stream as well. Please file a Bugzilla so that I can
change the code to ignore null values for package URI compressors and
just write/read an uncompressed URI in that case. An IDProvider is only
needed at client side when committing a transaction. At the server side
you can implement an IDProvider as the identity function (just return
the down casted argument).
Cheers
/Eike
kaab schrieb:
> full test, I'm noticing a lot of errors when reading CDORevisions,
> speacially for resolving cdoClassRefs. The way we read and write
> revisions is mainly inspired from CDO code. And it is now implemented
> this way :
> @Override
> @Override
> suggestions to serialize the revisions into the filesystem. This code
> was tested and was working but it now causing problems, so I would
> like to make sure it's safe using it.
Re: [CDO] Being able to retrieve ResourcePath from a MemStore implementation [message #424964 is a reply to message #424963] |
Wed, 12 November 2008 02:43  |
Eike Stepper schrieb:
> Kaab,
> to be used for data transfer over the network. I think it can be used
> for transfer to/from files as well but the package URI compressor does
> not make sense then because it relies on a compressor being available
> at the other side of the stream as well. Please file a Bugzilla so
> that I can change the code to ignore null values for package URI
> compressors and just write/read an uncompressed URI in that case.
Argh, I did not remember that we have a NOOP implementation of the
package URI compressor.
Simon's suggestion to use CDOPackageURICompressor.UNCOMPRESSED is of
course better than special handling of null values.
Please do not file a Bugzilla ;-)
Cheers
/Eike
Current Time: Sat Jul 19 18:01:56 EDT 2025
Powered by FUDForum. Page generated in 0.08531 seconds
