Home » Modeling » EMF » [Databinding] [Validation] Handling OCL validation within databinding
[Databinding] [Validation] Handling OCL validation within databinding [message #424507] |
Tue, 28 October 2008 14:45  |
Originally posted by: jconlon.apache.org
I want to use the OCL Live validation constraints associated with the
model, to validate my ui databinding values. Haven't noticed this nuance
in the various discussions in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203492
So am using an EMFUpdateValueStrategy as my targetToModelStrategy for
binding EMF model elements to ui controls, but I need either
to 1. validate using the constraint before the set or 2. perform the set
take the error and via the transaction facility roll the model back to a
previous value reseting the user interface as well.
It is the second approach that I have been attempting. Am doing this by
overriding the EMFUpdateValueStrategy doSet(IObservableValue
observableValue, Object value), and tying in a
ModelValidationService.getInstance().addValidationListener() prior to
the doSet.
Then if the ValidationListener records a failure result I return the
failed results from the doSet. This at least shows it on the status
label, but my ui control keeps the old invalid value displayed. In other
words the ui control shows a value now out of sync with the model.
Two questions -
Is there an alternative to this hack approach?
If not how can I resync the ui with the model after the rollback?
thanks for any ideas,
John
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424513 is a reply to message #424507] |
Tue, 28 October 2008 16:23   |
John,
Comments below.
> nuance in the various discussions in
Wow, that's a long one.
That's tricky. Certainly with intrinsic constraints it's possible to
validate a data value say, but often constraints span multiple features
and can't be checked until the state has changed.
> 2. perform the set take the error and via the transaction facility
> roll the model back to a previous value reseting the user interface as
> well.
Unfortunately I'm not all that familiar with the transaction APIs. If
worst comes to worst, I imagine you can hook your way into
EditingDomainEObjectObservableList.execute but I also imagine the
transaction enabled stack might already do good things...
> the doSet.
Christian will know what that means, but he probably doesn't know much
about data binding...
> other words the ui control shows a value now out of sync with the model.
The rollback type of approach would produce notifications...
> Two questions -
Good questions.
It should just do that based on notifications...
> John
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424523 is a reply to message #424513] |
Tue, 28 October 2008 20:21   |
Ed,
see comments...
Ed Merks wrote:
> John,
> Comments below.
scary too.
That the boat I'm in.
>> well.
Yes the transaction stack does the right thing even when using
databinding ui(s). It's on the ui side that keeping things coordinated
is the problem though. see below...
>> the doSet.
That listerner is notified when the ValidationService does it's thing
public void validationOccurred(ValidationEvent event) {
if(event.getSeverity()!=IStatus.OK){
Fairly straight forward way to find out that something bad may have
happened and grab and react to the status.
It does but does, but these do not change the ui.??
>> Two questions -
> Good questions.
I would have thought so too.
As an example of this out-of-sync condition: One of my OCL Live
constraints, constrains an
attribute to only have a value from 0 to 9.99. Entering the value 55
into the bound
text box will show the user a Live Validation Dialog followed by a
Command Failed
Dialog showing the proper error messages from the OCL constraint to the
user. After the change would have expected the text control to revert to
the value the model rolled back to
which is 5.5. But no, the ui stays at 55.
puzzling,
John
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424525 is a reply to message #424523] |
Wed, 29 October 2008 05:13   |
John E. Conlon schrieb:
> Ed,
> see comments...
> Ed Merks wrote:
>> John,
>> Comments below.
> scary too.
>> features and can't be checked until the state has changed.
>>> as well.
>> If worst comes to worst, I imagine you can hook your way into
>>> the doSet.
Interesting because EMF-Observables work in both ways and I'm using this
successfully in my CDO-Applications.
A workaround might be to force an UI-Update after having done the
rollback with:
- Binding#updateTargetToModel()
- Viewer#refresh()
Still the really interesting thing is way the the UI is not kept in sync
when a rollback is issued.
To commonly deal with your use case it looks like you need something
like UpdateValueStrategy#setAfterSetValidator(IValidator), right? File a
bug and explain your use case and post the Bug-Id here.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424532 is a reply to message #424525] |
Wed, 29 October 2008 12:21   |
Hi Tom,
See comments below...
>> Ed,
>> see comments...
>> Ed Merks wrote:
>>> John,
>>> Comments below.
>> scary too.
>>>> as well.
>>>> the doSet.
Not so familiar with CDO, but do you have constraints the cause
rollbacks of your sets?
> rollback with:
> - Viewer#refresh()
Thanks for the hint.
My workaround is to pass the binding to my subclassed
EMFUpdateValueStrategy and in the overriden
doSet(IObservableValue observableValue, Object value)
and if the super.doSet causes a Live Validation error (resulting in a
rollback) perform a
binding.updateModelToTarget();
this does the trick of syncing the ui!
Perhaps this is because there may be an area of the code in the doSet
that ignores model changes?
Actually would have expected sending an IStatus that was an Error (not
OK) would have triggered this behavior. WDYT?
File a
Here it is...
252612
thanks for look at this Tom,
John
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424561 is a reply to message #424532] |
Wed, 29 October 2008 20:32   |
John,
Regarding you comment about there may be an area of the code in the
doSet that ignores model changes, you might want to look at Bugzilla 238222:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238222
I might be wrong, but it seems to be related to the problem you are
having. Anyway, here a work-around is described.
http://dev.eclipse.org/newslists/news.eclipse.platform/msg75 775.html
HTH!
> Hi Tom,
>>> Ed,
>>> see comments...
>>> Ed Merks wrote:
>>>> John,
>>>> Comments below.
>>> scary too.
>>>>> as well.
>>>>> this by
>>>>> the doSet.
>>>>> model.
>> rollback with:
>> - Viewer#refresh()
> rollback) perform a
> File a
> Here it is...
> 252612
> John
Re: [Databinding] [Validation] Handling OCL validation within databinding [message #424586 is a reply to message #424561] |
Thu, 30 October 2008 13:58  |
Hi AJ,
See comments below.
AJ wrote:
> John,
> 238222:
I think your right. I uploaded a testcase to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252612
that basically changes the model during the doSet, and I get the same
behavior.
> HTH!
In that testcase I also show the workaround.
thanks AJ,
John
>> Hi Tom,
>>>> Ed,
>>>> see comments...
>>>> Ed Merks wrote:
>>>>> John,
>>>>> Comments below.
>>>> scary too.
>>>>>> as well.
>>>>>> this by
>>>>>> the doSet.
>>>>>> model.
>>> rollback with:
>>> - Viewer#refresh()
>> rollback) perform a
>> File a
>> Here it is...
>> 252612
>> John
Current Time: Sat Jul 19 08:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.09014 seconds
