Home » Modeling » EMF » [Teneo] Generated Many to Many not populating resolving table
[Teneo] Generated Many to Many not populating resolving table [message #424364] Fri, 24 October 2008 11:53 Go to next message
I have these two entities:
<xsd:complexType name="User">
<xsd:annotation>
<xsd:documentation>
<xsd:p>The basic user entity. Role is a one to many, many to
one association</xsd:p>
</xsd:documentation>
</xsd:annotation>
<xsd:sequence minOccurs="0" maxOccurs="1">
</xsd:element>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="userRole"
type="secmsec:Role">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa"> @OneToMany(indexed=false,
mappedBy="role") @JoinTable(name="UserRole")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id
@GeneratedValue(strategy=IDENTITY)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name="firstName" type="xsd:string" />
</xsd:complexType>
<xsd:element name="user" type="secmsec:User">
</xsd:element>
<xsd:complexType name="Role">
name="permission" type="secmsec:Permission" ecore:opposite="role"/>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="roleUser"
<xsd:annotation>
mappedBy="user") @JoinTable(name="UserRole")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name="name" type="xsd:string">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Column(unique=true)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
I want to manually control the ids for Role, thus not @GeneratedValue.
This generates the required userrole table without problem. However when
I try to use Hibernate to populate this table never gets populated. Not
sure if it is my use of Hibernate or if I am missing a annotation.
I am using this code
// We will insert records for each of the cases below
Session sess = getCurrentSession();
Transaction tx = sess.beginTransaction();
try
// add the standard Role objects
Role adminRole = secmsecFactory.eINSTANCE.createRole();
adminRole.setId(1);
adminRole.setName("admin");
sess.save(adminRole);
// add the standard User for admin
User adminUser = secmsecFactory.eINSTANCE.createUser();
adminUser.setFirstName("Super");
adminUser.setId(1);
adminUser.getUserRole().add(adminRole);
sess.save(adminUser);
tx.commit();
Thx.
David
Re: [Teneo] Generated Many to Many not populating resolving table [message #424440 is a reply to message #424364] Mon, 27 October 2008 05:07 Go to previous messageGo to next message
--------------030605010608040600010302
Hi David,
I tested it and the main reason why this does not work is that you have specified mapped-by on both
sides. Setting mapped-by on an association means that the association is handled from the other
side. Let me explain: say you have an association between types A and B, the efeature on the A side
is called toB and on the B side toA. Then if you have a onetomany annotation with mappedby on toB
then when persisting A the association to B is not stored because hibernate assumes that B (the
other side) manages the relation. This can be solved by setting cascade options on toB also, which
will result in B also being persisted (with the relation to A).
Using mappedBy makes the most sense if you want to control where the joincolumn is placed in a
association using foreign keys, so with a jointable you don't need it. Also the mappedBy you
specified had the wrong values afaics it should have been roleUser instead of user and userRole
instead of role.
Some other things which I would change:
- I would not use containment between user and role, afaics these are just standard references
between 2 types. In emf references/associations are modeled in xsd using anyuri and ecore:reference
- You did not specify ecore:opposite therefore Teneo/EMF can not see that this is a bidirectional
relation
- You used a OneToMany while you mention that it is a ManyToMany relation
I have attached the xsd I have used to get it working correctly, the xsd contains the changes above.
Teneo will now throw an exception if you have set mappedby on both sides of the relation as this can
lead to difficult to understand issues.
gr. Martin
David Wynter wrote:
> <xsd:annotation>
> <xsd:documentation>
> <xsd:p>The basic user entity. Role is a one to many, many to one
> association</xsd:p>
> </xsd:annotation>
> </xsd:element>
> name="userRole" type="secmsec:Role">
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> </xsd:element>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> try
> adminRole.setId(1);
> adminUser.setId(1);
> tx.commit();
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="role.xsd"
Content-Disposition: inline;
filename="role.xsd"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4NPHhzZDpz Y2hlbWEgdGFy
Z2V0TmFtZXNwYWNlPSJodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2VtZi90ZW5l by90ZXN0L3Jv
bGUiIHhtbG5zOmVjb3JlPSJodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2VtZi8y MDAyL0Vjb3Jl
Ig0JeG1sbnM6dGhpcz0iaHR0cDovL3d3dy5lY2xpcHNlLm9yZy9lbWYvdGVu ZW8vdGVzdC9y
b2xlIiB4bWxuczp4c2Q9Imh0dHA6Ly93d3cudzMub3JnLzIwMDEvWE1MU2No ZW1hIj4NCTx4
c2Q6Y29tcGxleFR5cGUgbmFtZT0iVXNlciI+DQkJPHhzZDphbm5vdGF0aW9u Pg0JCQk8eHNk
OmRvY3VtZW50YXRpb24+DSAgICAgICAgPHhzZDpwPlRoZSBiYXNpYyB1c2Vy IGVudGl0eS4g
Um9sZSBpcyBhIG9uZSB0byBtYW55LCBtYW55IHRvIG9uZSBhc3NvY2lhdGlv bjwveHNkOnA+
DSAgICAgIDwveHNkOmRvY3VtZW50YXRpb24+DQkJPC94c2Q6YW5ub3RhdGlv bj4NCQk8eHNk
OnNlcXVlbmNlIG1pbk9jY3Vycz0iMCIgbWF4T2NjdXJzPSIxIj4NCQkJPHhz ZDplbGVtZW50
IG1pbk9jY3Vycz0iMCIgbWF4T2NjdXJzPSJ1bmJvdW5kZWQiIG5hbWU9InVz ZXJSb2xlIiB0
eXBlPSJ4c2Q6YW55VVJJIiBlY29yZTpvcHBvc2l0ZT0icm9sZVVzZXIiIGVj b3JlOnJlZmVy
ZW5jZT0idGhpczpSb2xlIj4NCQkJCTx4c2Q6YW5ub3RhdGlvbj4NCQkJCQk8 eHNkOmFwcGlu
Zm8gc291cmNlPSJ0ZW5lby5qcGEiPiBATWFueVRvTWFueShpbmRleGVkPWZh bHNlKSBASm9p
blRhYmxlKG5hbWU9IlVzZXJSb2xlIik8L3hzZDphcHBpbmZvPg0JCQkJPC94 c2Q6YW5ub3Rh
dGlvbj4NCQkJPC94c2Q6ZWxlbWVudD4NCQk8L3hzZDpzZXF1ZW5jZT4NCQk8 eHNkOmF0dHJp
YnV0ZSBuYW1lPSJpZCIgdHlwZT0ieHNkOmludCI+DQkJCTx4c2Q6YW5ub3Rh dGlvbj4NCQkJ
CTx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QElkIEBHZW5lcmF0 ZWRWYWx1ZShz
dHJhdGVneT1JREVOVElUWSk8L3hzZDphcHBpbmZvPg0JCQk8L3hzZDphbm5v dGF0aW9uPg0J
CTwveHNkOmF0dHJpYnV0ZT4NCQk8eHNkOmF0dHJpYnV0ZSBuYW1lPSJmaXJz dE5hbWUiIHR5
cGU9InhzZDpzdHJpbmciIC8+DQk8L3hzZDpjb21wbGV4VHlwZT4NCTx4c2Q6 ZWxlbWVudCBu
YW1lPSJ1c2VyIiB0eXBlPSJ0aGlzOlVzZXIiPg0JPC94c2Q6ZWxlbWVudD4N CTx4c2Q6Y29t
cGxleFR5cGUgbmFtZT0iUm9sZSI+DQkJPHhzZDpzZXF1ZW5jZSBtaW5PY2N1 cnM9IjAiIG1h
eE9jY3Vycz0iMSI+DQkJCTx4c2Q6ZWxlbWVudCBtaW5PY2N1cnM9IjAiIG1h eE9jY3Vycz0i
dW5ib3VuZGVkIiBlY29yZTpvcHBvc2l0ZT0idXNlclJvbGUiIG5hbWU9InJv bGVVc2VyIiB0
eXBlPSJ4c2Q6YW55VVJJIiBlY29yZTpyZWZlcmVuY2U9InRoaXM6VXNlciI+ DQkJCQk8eHNk
OmFubm90YXRpb24+DQkJCQkJPHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8u anBhIj4gQE1h
bnlUb01hbnkoaW5kZXhlZD1mYWxzZSkgQEpvaW5UYWJsZShuYW1lPSJVc2Vy Um9sZSIpPC94
c2Q6YXBwaW5mbz4NCQkJCTwveHNkOmFubm90YXRpb24+DQkJCTwveHNkOmVs ZW1lbnQ+DQkJ
PC94c2Q6c2VxdWVuY2U+DQkJPHhzZDphdHRyaWJ1dGUgbmFtZT0iaWQiIHR5 cGU9InhzZDpp
bnQiPg0JCQk8eHNkOmFubm90YXRpb24+DQkJCQk8eHNkOmFwcGluZm8gc291 cmNlPSJ0ZW5l
by5qcGEiPkBJZDwveHNkOmFwcGluZm8+DQkJCTwveHNkOmFubm90YXRpb24+ DQkJPC94c2Q6
YXR0cmlidXRlPg0JCTx4c2Q6YXR0cmlidXRlIG5hbWU9Im5hbWUiIHR5cGU9 InhzZDpzdHJp
bmciPg0JCQk8eHNkOmFubm90YXRpb24+DQkJCQk8eHNkOmFwcGluZm8gc291 cmNlPSJ0ZW5l
by5qcGEiPkBDb2x1bW4odW5pcXVlPXRydWUpPC94c2Q6YXBwaW5mbz4NCQkJ PC94c2Q6YW5u
b3RhdGlvbj4NCQk8L3hzZDphdHRyaWJ1dGU+DQk8L3hzZDpjb21wbGV4VHlw ZT4NCjwveHNk
OnNjaGVtYT4=
--------------030605010608040600010302--
Re: [Teneo] Generated Many to Many not populating resolving table [message #424508 is a reply to message #424440] Tue, 28 October 2008 14:47 Go to previous messageGo to next message
Here is a new problem. I changed that really large xsd to use the
ManyToMany annotation. The element in question has 17 many to many
relationships in this large model. The XSD reloads to the genmodel
without error, then the Model source code generates without error.
But when I come to generate the database schema using the initialise
method I get this
Exception in thread "main"
org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption: Only
typenames are allowed at the root of the annotation, see _ for the error
ManyToMany_(indexed=false) @JoinTable(name="HolderActionSubclassAgent")
here is the call stack
Thread [main] (Suspended (exception AnnotationParserException))
AnnotationParser.parse(ENamedElement, String) line: 49
HbEAnnotationParserImporter(EAnnotationParserImporter).proce ss(EAnnotation,
ENamedElement) line: 159
HbEAnnotationParserImporter(EAnnotationParserImporter).proce ssAnnotatedModelElement(PAnnotatedEModelElement,
EPackage) line: 93
HbEAnnotationParserImporter(EAnnotationParserImporter).proce ss(PAnnotatedEClass)
line: 83
HbEAnnotationParserImporter(EAnnotationParserImporter).proce ss(PAnnotatedEPackage)
line: 72
HbEAnnotationParserImporter(EAnnotationParserImporter).proce ss(PAnnotatedModel)
line: 64
PersistenceMappingBuilder.buildMapping(List<EPackage>,
PersistenceOptions, ExtensionManager) line: 110
PersistenceMappingBuilder.buildMapping(EPackage[], PersistenceOptions,
ExtensionManager) line: 67
HbSessionDataStore(HbDataStore).mapEPackages() line: 624
HbSessionDataStore.mapModel() line: 155
HbSessionDataStore.initialize() line: 73
HibernateUtil.init(boolean) line: 87
HibernateUtil.main(String[]) line: 115
But this element has identical structure to the others. Here are two of them
ecore:opposite="distributionSubclassAgent"
name="agentDistributionSubclass" type="xsd:anyURI"
ecore:reference="gensec:DistributionSubclass">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa"> @ManyToMany(indexed=false)
@JoinTable(name="DistributionSubclassAgent")</xsd:appinfo >
</xsd:annotation>
</xsd:element>
ecore:opposite="holderActionSubclassAgent"
name="agentHolderActionSubclass" type="xsd:anyURI"
ecore:reference="gensec:HolderActionSubclass">
<xsd:annotation>
@JoinTable(name="HolderActionSubclassAgent")</xsd:appinfo >
</xsd:annotation>
</xsd:element>
Not sure why it has a problem with this particular element.
David
Martin Taal wrote:
> Hi David,
> specified mapped-by on both sides. Setting mapped-by on an association
> means that the association is handled from the other side. Let me
> on the A side is called toB and on the B side toA. Then if you have a
> onetomany annotation with mappedby on toB then when persisting A the
> options on toB also, which will result in B also being persisted (with
> the relation to A).
> joincolumn is placed in a association using foreign keys, so with a
> jointable you don't need it. Also the mappedBy you specified had the
> userRole instead of role.
> just standard references between 2 types. In emf references/associations
> that this is a bidirectional relation
> of the relation as this can lead to difficult to understand issues.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> <xsd:annotation>
>> <xsd:documentation>
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> </xsd:element>
>> name="roleUser" type="secmsec:User">
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> when I try to use Hibernate to populate this table never gets
>> populated. Not sure if it is my use of Hibernate or if I am missing a
>> annotation.
>> try
>> adminRole.setId(1);
>> adminUser.setId(1);
>> tx.commit();
>> Thx.
>> David
Re: [Teneo] Generated Many to Many not populating resolving table [message #424512 is a reply to message #424508] Tue, 28 October 2008 16:01 Go to previous message
Hi David,
As I have your project/model, can you send me the xsd you currently have then I will check this
issue also.
gr. Martin
David Wynter wrote:
> method I get this
> EPackage) line: 93
> line: 83
> line: 72
> line: 64
> PersistenceOptions, ExtensionManager) line: 67
> them
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> David
> Martin Taal wrote:
>> Hi David,
>> have specified mapped-by on both sides. Setting mapped-by on an
>> association means that the association is handled from the other side.
>> efeature on the A side is called toB and on the B side toA. Then if
>> you have a onetomany annotation with mappedby on toB then when
>> assumes that B (the other side) manages the relation. This can be
>> solved by setting cascade options on toB also, which will result in B
>> ecore:reference
>> sides of the relation as this can lead to difficult to understand issues.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> <xsd:annotation>
>>> <xsd:documentation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> </xsd:element>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> <xsd:annotation>
>>> <xsd:appinfo
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> annotation.
>>> try
>>> adminRole.setId(1);
>>> adminUser.setId(1);
>>> tx.commit();
>>> Thx.
>>> David
The Netherlands
Previous Topic:[CDO] A locked CDOView has objects removed from its model
Next Topic:Memory footprint of common base objects
Current Time: Sun Jul 20 12:19:30 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
