Overlay icons for validation [message #423852] |
Wed, 08 October 2008 03:16  |
Hello!
I would like to create overlay icons for the EMF providers that change
depending on the current validation status. To perform the validation in
ItemProviderAdapter.overlayImage(Object, Object) seems a little too
expensive. I don´t want to include the status in the model either.
Best way seems to extend the notifyChanged method and to store the
status in a map for singleton adapters.
Any other approaches?
Kristian
Re: Overlay icons for validation [message #424179 is a reply to message #423852] |
Mon, 20 October 2008 03:33   |
Thanks Mario and Ed for your advice!
Here some snippets for those who want to achieve the same (based on the
generated RCP):
Editor::createPages:
labelDecorator = new MyLabelDecorator();
viewer.setLabelProvider(new DecoratingLabelProvider(new
AdapterFactoryLabelProvider(adapterFactory), labelDecorator ));
Editor::updateProblemIndication:
labelDecorator.setDiagnostics(diagnostic);
In MyLabelDecorator (implements ILabelDecorator):
public void setDiagnostics(Diagnostic diagnostic)
Map<Object, Integer> oldSeverityMap = severityMap;
severityMap = new HashMap<Object, Integer>();
processDiagnostic(diagnostic, severityMap);
notifyViewer(oldSeverityMap, severityMap);
private void notifyViewer(Map<Object, Integer> oldSeverityMap,
Map<Object, Integer> newSeverityMap)
List<Object> changedObjects = new ArrayList<Object>();
changedObjects.addAll(oldSeverityMap.keySet());
changedObjects.addAll(newSeverityMap.keySet());
fireLabelEvent(new LabelProviderChangedEvent(this,
changedObjects.toArray()));
private ComposedImage decorateSeverity(Image image, Integer severity)
List<Object> images = new ArrayList<Object>(2);
images.add(image);
if (severity == Diagnostic.WARNING)
images.add(X3DModelEditPlugin.INSTANCE.getImage("full/ovr16/warning_co "));
else
images.add(X3DModelEditPlugin.INSTANCE.getImage("full/ovr16/error_co "));
ComposedImage ci = new ComposedImage(images){
public List<Point> getDrawPoints(Size size)
List<Point> results = new ArrayList<Point>();
results.add(new Point());
Point overlay = new Point();
overlay.x = 0;
overlay.y = 7;
results.add(overlay);
return results;
return ci;
Have fun!
Kristian
Re: Overlay icons for validation [message #424181 is a reply to message #424179] |
Mon, 20 October 2008 03:51   |
Kristian,
That's very cool. Maybe we should provide something like this directly
in the framework. If you open a bugzilla enhancement request with this
as the contribution, I'll definitely look into it. It would make my
demos better! Thanks for sharing!!
> the generated RCP):
> oldSeverityMap, Map<Object, Integer> newSeverityMap)
> images.add(image);
> else
> @Override
> overlay.x = 0;
> overlay.y = 7;
> return results;
> return ci;
> Have fun!
> Kristian
FUDForum. Page generated in 0.05388 seconds
