[CDO] What happened to CDOSession.getConnector()??? [message #424122] |
Thu, 16 October 2008 14:17  |
Hi Eike,
I just synchronized with last changes in CVS, and I found some methods
disappeared from CDOSession:
public IChannel getChannel();
public IConnector getConnector();
Could you give me some information regarding this change?
How do I set now FailOverStrategy to a session if I cannot get it's
connector? What Am I doing wrong?
Re: [CDO] What happened to CDOSession.getConnector()??? [message #424126 is a reply to message #424123] |
Thu, 16 October 2008 16:41   |
Hi Eike,
no inconvenience, just a little scared I sync and realize many errors
pop up, but that's the thing of being aligned with the bleeding-edge!
I understand that if you use CDOSessionConfiguration to start a session,
you'll be able to set the FailOverStrategy (since you need to create the
connector yourself). But why to hide CDOSession transport facilities?
IMHO, a CDOSession is too closely related with the transport facility.
Once you get a session, you'll ever be able to get to it's underlying
transport components. Of course, you are the expert, and know what is
more convenient to be exposed in the API and what is not! :)
Any changes to make CDO better is always welcome, so I have nothing to
say against it.
Best Regards,
ViK.
Eike Stepper escribió:
> Hi Vik,
> This is work in progress to provide reliable fail-over support. The idea
> of the CDOSessionConfiguration is to call only one of setConnector() or
> setFailOverStrategy(). Actually the first one will be just a convenience
> wrapper for a NOOPFailOverStrategy that just times out when the channel
> (i.e. the underlying connector) does not respond anymore. In the
> CDOSession instead of getChannel() you can call
> getProtocol().getChannel(). Maybe this new method is not yet public and
> I'm also not sure if I want to continue to expose these transport
> related facilities in the CDOSession API. In the end it will a matter of
> a particular fail-over strategy to use one or several configured
> connectors to swap the channel in the protocol of the session...
> Sorry for the inconvenience but I was blocked by some other annoying
> things.
> Cheers
> /Eike
> Víctor Roldán Betancort schrieb:
>> Hi Eike,
Re: [CDO] What happened to CDOSession.getConnector()??? [message #424129 is a reply to message #424126] |
Thu, 16 October 2008 15:37   |
> Hi Eike,
> session, you'll be able to set the FailOverStrategy (since you need to
> create the connector yourself). But why to hide CDOSession transport
> facilities? IMHO, a CDOSession is too closely related with the
> transport facility. Once you get a session, you'll ever be able to get
> to it's underlying transport components. Of course, you are the
> expert, and know what is more convenient to be exposed in the API and
> what is not! :)
This is also a bit of a preparation for non-Net4j transports although
that is not planned immediately. For the moment the CDOSession should
only know about its IChannel which is clearly not interesting for other
clients because it is always bound to its own internal
CDOClientProtocol. Generally an IChannel does not know its IConnector
(only through the much narrower interface IChannelMultiplexer) because
some time back I refactored cyclic dependencies between the channel and
the connector API. So the channel of the CDOSession is not usable for
other client data transfer and even not for determination of the
connector to open additional channels. In contrast to the past the
channel of the CDOSession is no longer created by the session itself but
rather injected from outside (DI). Basically this will be done by the
upcoming IFailOverStrategy.
Sounds a bit complicated? That's the price of the high flexibility ;-)
Cheers
/Eike
> say against it.
> Best Regards,
> ViK.
>> Hi Vik,
>> idea of the CDOSessionConfiguration is to call only one of
>> setConnector() or setFailOverStrategy(). Actually the first one will
>> be just a convenience wrapper for a NOOPFailOverStrategy that just
>> times out when the channel (i.e. the underlying connector) does not
>> respond anymore. In the CDOSession instead of getChannel() you can
>> call getProtocol().getChannel(). Maybe this new method is not yet
>> public and I'm also not sure if I want to continue to expose these
>> transport related facilities in the CDOSession API. In the end it
>> will a matter of a particular fail-over strategy to use one or
>> several configured connectors to swap the channel in the protocol of
>> the session...
>> things.
>> Cheers
>> /Eike
>>> Hi Eike,
>>> methods disappeared from CDOSession:
Re: [CDO] What happened to CDOSession.getConnector()??? [message #424130 is a reply to message #424129] |
Thu, 16 October 2008 17:30  |
Eike,
these ideas sound very promising! I'm sure lot of cool integrations with
CDO could arise from this decoupling. Is your mind already in e4? :P
ViK.
>> Hi Eike,
>> what is not! :)
> Cheers
> /Eike
>> say against it.
>> Best Regards,
>> ViK.
>>> Hi Vik,
>>> the session...
>>> things.
>>> Cheers
>>> /Eike
>>>> Hi Eike,
FUDForum. Page generated in 0.05199 seconds
