[CDO 1.0] CDOInvalidationNotification [message #423929] |
Thu, 09 October 2008 23:53  |
When a remote client makes a change and commits it, it seems that the
CDOInvalidationNotification which other clients receive contains only the
notifier object, and no information about which feature changed, or the
previous or new values. It's left to me to write diff'ing code to figure
that out ;) Is this going to be fixed in future versions, or has it
already been fixed on trunk? It'd be nice if the type of the notification
was INVALIDATE_ADD, INVALIDATE_ADD_MANY, INVALIDATE_REMOVE,
INVALIDATE_SET, etc., so that client code could decide whether to forward
it as a regular ADD, ADD_MANY, etc. notification, or to do something like
wrap it in a write transaction (if they are using EMF Transactions, which
we are.)
Re: CDOInvalidationNotification [message #423934 is a reply to message #423929] |
Fri, 10 October 2008 04:35  |
--------------090901030904010608070300
Tom,
CDO 2.0 has several mechansims to catch up with remote changes. They
differ in the amount of change information being delivered and thus in
the burden put on the network:
1) CDOSessionInvalidationEvent is the oldest and simplest form. The
event is emitted to registered IListeners of a CDOSession *if*
PassiveUpdate is enabled for the session.
* An event that is emitted to registered {@link IListener listeners} of a {@link CDOSession} if
* {@link CDOSession#setPassiveUpdateEnabled(boolean) passive update} is enabled for the session.
* @author Eike Stepper
* @see CDOInvalidationNotification
* @see CDOChangeSubscriptionPolicy
* @noimplement This interface is not intended to be implemented by clients.
*public interface *CDOSessionInvalidationEvent *extends *CDOSessionEvent
*public static final **long *LOCAL_ROLLBACK = CDORevision.UNSPECIFIED_DATE;
* Returns the transaction that was committed and thereby caused this event to be emitted if this transaction is
* local, or <code>null</code> if the transaction was remote.
*public *CDOView getView();
* Returns the time stamp of the server transaction if this event was sent as a result of a successfully committed
* transaction or <code>LOCAL_ROLLBACK</code> if this event was sent due to a local rollback.
*public **long *getTimeStamp();
* Returns a set of the {@link CDOID CDOIDs} and versions of the modified objects.
*public *Set<CDOIDAndVersion> getDirtyOIDs();
* Returns a collection of the {@link CDOID CDOIDs} of the removed objects.
* @since 2.0
*public *Collection<CDOID> getDetachedObjects();
2) CDOInvalidationNotification is a *custom* EMF notification that is
emitted to adapters of the EObjects in a CDOView *if*
InvalidationNotification is enabled for the view. Since the
notifications are constructed out of the information in a
CDOSessionInvalidationEvent (i.e. CDOIDs) they don't carry detailed
change deltas. All the Notification methods related to change deltas
throw UOEs.
* A custom EMF {@link Notification notification} that is emitted to {@link Adapter adapters} of the objects in a
* {@link CDOView view} if {@link CDOView#setInvalidationNotificationEnabled(boolean) invalidation notification} is
* enabled for the view. Since the notifications are constructed out of the information in a
* {@link CDOSessionInvalidationEvent} (i.e. {@link CDOID CDOIDs}) they don't carry detailed change deltas. All the
* methods related to change deltas throw {@link UnsupportedOperationException UnsupportedOperationExceptions}.
* @author Simon McDuff
* @see CDOSessionInvalidationEvent
*public interface *CDOInvalidationNotification *extends *Notification
*public static final **int *INVALIDATE = EVENT_TYPE_COUNT + 1;
3) |CDOChangeSubscriptionPolicy |a is the newest form (only in 2.0) and
the one that delivers the most detailed information about the actual
change. The change information is delivered to object adapters. To
compensate the bandwidth burden of the change info per object you must
exactly specify for which objects it is provides. With one of the
shipped policies or an own one you can do this per view:
* Specifies a change subscription policy.
* <p>
* To activate a policy, you must do the following: <br>
* <code> view.setChangeSubscriptionPolicy(CDOChangeSubscriptionPolicy .ALL); </code>
* <p>
* To register an object, you must add an adapter to the object in which you are interested:<br>
* <code>eObject.eAdapters().add(myAdapter);</code>
* <p>
* By activating this feature, each object having at least one adapter that matches the current policy will be
* registered with the server and will be notified for each change occurring in the scope of any other transaction.
* <p>
* {@link CDOChangeSubscriptionPolicy#NONE} - Disabled. <br>
* {@link CDOChangeSubscriptionPolicy#ALL} - Enabled for all adapters used.<br>
* {@link CDOChangeSubscriptionPolicy#ONLY_CDO_ADAPTER} - Enabled only for adapters that implement {@link CDOAdapter}. <br>
* Any other class that implement {@link CDOChangeSubscriptionPolicy} will enable for whatever rules defined in that
* class. <br>
* <p>
* If <code>myAdapter</code> in the above example matches the current policy, <code>eObject</code> will be registered
* with the server and you will receive all changes from other transaction.
* <p>
* When the policy is changed all objects in the cache will automatically be recalculated.
* <p>
* You can subscribe to temporary objects. Even if you cannot receive notifications from other {@link CDOTransaction}
* for these because they are only local to you, at commit time these objects will be registered automatically.
* <p>
* <b>Note:</b> It can be used with <code>CDOSession.setPassiveUpdate(false)</code>. In this case, it will receive
* changes without having the objects changed.
* @since 2.0
*public interface *CDOChangeSubscriptionPolicy
*public static final *CDOChangeSubscriptionPolicy NONE = *new *CDOChangeSubscriptionPolicy()
*public **boolean *shouldSubscribe(EObject eObject, Adapter adapter)
*return false*;
*public static final *CDOChangeSubscriptionPolicy ONLY_CDO_ADAPTER = *new *CDOChangeSubscriptionPolicy()
*return *adapter *instanceof *CDOAdapter;
*public static final *CDOChangeSubscriptionPolicy ALL = *new *CDOChangeSubscriptionPolicy()
*return true*;
*public **boolean *shouldSubscribe(EObject eObject, Adapter adapter);
Cheers
/Eike
> the notifier object, and no information about which feature changed,
> or the previous or new values. It's left to me to write diff'ing code
> to figure that out ;) Is this going to be fixed in future versions, or
> has it already been fixed on trunk? It'd be nice if the type of the
> notification was INVALIDATE_ADD, INVALIDATE_ADD_MANY,
> INVALIDATE_REMOVE, INVALIDATE_SET, etc., so that client code could
> decide whether to forward it as a regular ADD, ADD_MANY, etc.
> notification, or to do something like wrap it in a write transaction
> (if they are using EMF Transactions, which we are.)
<html>
<head>
http-equiv="Content-Type">
</head>
Tom,<br>
<br>
the burden put on the network:<br>
<br>
PassiveUpdate is enabled for the session.<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- ======================================================== --><!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#3f5fbf">/**</font><br>
<font color="#ffffff">
FUDForum. Page generated in 0.07922 seconds
