Home » Modeling » EMF » Overlay icons for validation
Overlay icons for validation [message #423852] Wed, 08 October 2008 03:16 Go to next message
Hello!
I would like to create overlay icons for the EMF providers that change
depending on the current validation status. To perform the validation in
ItemProviderAdapter.overlayImage(Object, Object) seems a little too
expensive. I don´t want to include the status in the model either.
Best way seems to extend the notifyChanged method and to store the
status in a map for singleton adapters.
Any other approaches?
Kristian
Re: Overlay icons for validation [message #423863 is a reply to message #423852] Wed, 08 October 2008 06:23 Go to previous messageGo to next message
Kristian,
Comments below.
Kristian Sons wrote:
> Hello!
I imagine you could use a specialized AdapterFactoryLabelProvider that
specializes the getImage method to act as a decorator so that you can
inject the decoration for any model without changing the basic item
providers for it and just tell the view to completely refresh all labels
after a validation...
> Kristian
Re: Overlay icons for validation [message #423865 is a reply to message #423852] Wed, 08 October 2008 06:57 Go to previous messageGo to next message
Kristian Sons schrieb:
> Hello!
> Kristian
Maybe I've got something wrong, but what about simply using a
DecoratingLabelProvider that wraps the orginal AdapterFactoryLabelProvider?
(If the validation status is not stored within your model, I think the
default eclipse decoration mechanism could be a good choice).
Mario
Re: Overlay icons for validation [message #424179 is a reply to message #423852] Mon, 20 October 2008 03:33 Go to previous messageGo to next message
Thanks Mario and Ed for your advice!
Here some snippets for those who want to achieve the same (based on the
generated RCP):
Editor::createPages:
labelDecorator = new MyLabelDecorator();
viewer.setLabelProvider(new DecoratingLabelProvider(new
AdapterFactoryLabelProvider(adapterFactory), labelDecorator ));
Editor::updateProblemIndication:
labelDecorator.setDiagnostics(diagnostic);
In MyLabelDecorator (implements ILabelDecorator):
public void setDiagnostics(Diagnostic diagnostic)
Map<Object, Integer> oldSeverityMap = severityMap;
severityMap = new HashMap<Object, Integer>();
processDiagnostic(diagnostic, severityMap);
notifyViewer(oldSeverityMap, severityMap);
private void notifyViewer(Map<Object, Integer> oldSeverityMap,
Map<Object, Integer> newSeverityMap)
List<Object> changedObjects = new ArrayList<Object>();
changedObjects.addAll(oldSeverityMap.keySet());
changedObjects.addAll(newSeverityMap.keySet());
fireLabelEvent(new LabelProviderChangedEvent(this,
changedObjects.toArray()));
private ComposedImage decorateSeverity(Image image, Integer severity)
List<Object> images = new ArrayList<Object>(2);
images.add(image);
if (severity == Diagnostic.WARNING)
images.add(X3DModelEditPlugin.INSTANCE.getImage("full/ovr16/warning_co "));
else
images.add(X3DModelEditPlugin.INSTANCE.getImage("full/ovr16/error_co "));
ComposedImage ci = new ComposedImage(images){
public List<Point> getDrawPoints(Size size)
List<Point> results = new ArrayList<Point>();
results.add(new Point());
Point overlay = new Point();
overlay.x = 0;
overlay.y = 7;
results.add(overlay);
return results;
return ci;
Have fun!
Kristian
Re: Overlay icons for validation [message #424181 is a reply to message #424179] Mon, 20 October 2008 03:51 Go to previous messageGo to next message
Kristian,
That's very cool. Maybe we should provide something like this directly
in the framework. If you open a bugzilla enhancement request with this
as the contribution, I'll definitely look into it. It would make my
demos better! Thanks for sharing!!
> the generated RCP):
> oldSeverityMap, Map<Object, Integer> newSeverityMap)
> images.add(image);
> else
> @Override
> overlay.x = 0;
> overlay.y = 7;
> return results;
> return ci;
> Have fun!
> Kristian
Re: Overlay icons for validation [message #424224 is a reply to message #424181] Mon, 20 October 2008 18:09 Go to previous messageGo to next message
Could you post the bug number for this? I'm also quite interested in
validation-based decoration in item providers.
Re: Overlay icons for validation [message #424226 is a reply to message #424224] Mon, 20 October 2008 18:11 Go to previous messageGo to next message
Cameron,
Feel free to open it yourself. I'd prefer someone in the community open
it...
>> directly in the framework. If you open a bugzilla enhancement
>> request with this
Re: Overlay icons for validation [message #424230 is a reply to message #424179] Tue, 21 October 2008 01:17 Go to previous messageGo to next message
Hi, Kristian,
I'm also looking for similar approach so thanks for sharing!
BTW, would you mind also posting the code for the processDiagnostic and
fireLabelEvent methods?
Re: Overlay icons for validation [message #424255 is a reply to message #424181] Tue, 21 October 2008 12:52 Go to previous messageGo to next message
Done. See https://bugs.eclipse.org/251565
Was unshure about the component so perhaps you have to move it.
Kristian
Re: Overlay icons for validation [message #424256 is a reply to message #424230] Tue, 21 October 2008 12:58 Go to previous messageGo to next message
Ben schrieb:
> Hi, Kristian,
Here we go:
private void processDiagnostic(Diagnostic diagnostic, Map<Object,
Integer> severityMap)
List<?> dataEntries = diagnostic.getData();
for(Object obj : dataEntries)
if (obj instanceof EObject)
severityMap.put(obj, diagnostic.getSeverity());
for (Diagnostic childDiagnostic : diagnostic.getChildren())
processDiagnostic(childDiagnostic, severityMap);
private void fireLabelEvent(final LabelProviderChangedEvent event)
Object[] listeners = listenerList.getListeners();
for (int i = 0; i < listeners.length; ++i) {
((ILabelProviderListener)
listeners[i]).labelProviderChanged(event);
BTW, this approach displays only overlays for those Objects generating
the Diagnostic. This is just the way I want it. But if you want also the
parents labeld you have to do a little more work...
Re: Overlay icons for validation [message #424257 is a reply to message #424226] Tue, 21 October 2008 13:04 Go to previous messageGo to next message
Ed Merks wrote:
> Cameron,
> it...
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=251566.
Re: Overlay icons for validation [message #424258 is a reply to message #424255] Tue, 21 October 2008 13:06 Go to previous message
Too funny. Per Ed's request I opened the same request exactly one bug
number later. Oh well, dups are cheap in bugzilla... :)
Previous Topic:Ecore: Upper bound not recognised?
Next Topic:[CDO] Hierarchical resources
Current Time: Sat Jul 19 15:16:21 EDT 2025
Powered by FUDForum. Page generated in 0.08450 seconds
