Home » Modeling » EMF » [EMF] Loading UML Magicdraw models
[EMF] Loading UML Magicdraw models [message #423840] Tue, 07 October 2008 15:24 Go to next message
I need load UML models exported from MagicDraw. To load these models i
configure UML environment as said in the section Programmatic Migration in
the article:
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
Well, but when a run my program these exception is throwed:
rs.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:365)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:222)
at
br.edu.gmf.udt.m2m.atl.ATLExecutor.createASMMetamodel(ATLExe cutor.java:235)
at br.edu.gmf.udt.m2m.atl.ATLExecutor.initInputModels(ATLExecut or.java:288)
at
br.edu.gmf.udt.m2m.atl.ATLExecutor.makeTransformation(ATLExe cutor.java:256)
at
br.edu.gmf.udt.m2m.atl.ATLExecutor.executeTransformations(AT LExecutor.java:335)
at br.edu.gmf.udt.AbsExecutor.generateTests(AbsExecutor.java:28 )
at br.edu.gmf.udt.UDTExecutor.main(UDTExecutor.java:53)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'http:///_zrN_0SUoEdmNXYQzyImvfA.profile.uml2' not found.
( file:///C:/Users/Netuh/Desktop/eclipse%20Place/workspace/UDT 2/IN, 18218,
99)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2566)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2398)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1276)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1445)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1010)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:992)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:501)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:179)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:377)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:2747)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:648)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(XMLNSDocumentScannerImpl.java:140)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 510)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1205)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 10 more
Any idea is very helpful.
Thanks in advance,
Waldemar Neto
PS: sorry if my question was a crossing question, because i usaing the
plugin ATL for load these models.
Re: [EMF] Loading UML Magicdraw models [message #423841 is a reply to message #423840] Tue, 07 October 2008 15:37 Go to previous messageGo to next message
Waldemar,
It's best to ask on the UML2 newsgroup because I don't have a clue about
how profile magic works. I've added it to the "to" list of the reply,
so no need to repost.
Waldemar Neto wrote:
> Migration in the article:
> at
> at
> at
> at
> at
> 18218, 99)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 10 more
> Thanks in advance,
> Waldemar Neto
Re: [EMF] Loading UML Magicdraw models [message #423844 is a reply to message #423841] Tue, 07 October 2008 18:01 Go to previous messageGo to next message
Hi Waldemar ,
I'm no expert with MagicDraw but it is my understanding that they do not use
the opensource UML2 API and their serialization may (probably) be
incompatible.
see: http://wiki.eclipse.org/MDT-UML2-Tool-Compatibility
You will have to somehow convert their format to the .uml format before the
tips in the migration guide can help. The code in that guide indicate how
to open up models serialized with the .uml format.
Can you provide a snippet of the model you are trying to open from
MagicDraw.
- James.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gcgdp3$udi$1@build.eclipse.org...
> Waldemar,
> how profile magic works. I've added it to the "to" list of the reply, so
> no need to repost.
>> Hi,
>> in the article:
>> at
>> at
>> at
>> at
>> at
>> 99)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .. 10 more
>> Thanks in advance,
>> Waldemar Neto
Re: [EMF] Loading UML Magicdraw models [message #423847 is a reply to message #423844] Tue, 07 October 2008 19:39 Go to previous message
hi,
well, i m sure that is compatible. Using the eclipse plugin ATL gui, the
models from Magicdraw are loaded correctly (as so as the Omondo models)
using the mdt.uml2 as metamodel. But, by the java code these exception is
throwed. I think that i need register some Resource.
i read these post, is a near problem, but i didnt understood the solution.
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg00956.html
the header of xmi generated by the magic draw is:
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:MagicDrawProfile="http:///schemas/MagicDrawProfile/_CxnngHntEd2tfOBIvlYxCw/0"
xmlns:UMLProfileforJava="http:///schemas/UMLProfileforJava/_CjXwIHntEd2tfOBIvlYxCw/0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xsi:schemaLocation="http:///schemas/MagicDrawProfile/_CxnngHntEd2tfOBIvlYxCw/0
UML_Standard_Profile.MagicDraw_Profile.profile.uml#_Dexor3nt Ed2tfOBIvlYxCw
UML_Profile_for_Java.profile.uml#_DevzQXntEd2tfOBIvlYxCw">
<uml:Model xmi:id="eee_1045467100313_135436_1" name="Data" viewpoint="">
<ownedComment xmi:id="_15_5_5cd0205_1220296941577_29498_210"
body="Author:Netuh.&#xA;Created:9/1/08 4:22
PM.&#xA;Title:.&#xA;Comment:.&#xA;"
annotatedElement="eee_1045467100313_135436_1"/>
<packageImport xmi:id="_0primitiveTypesData">
<importedPackage xmi:type="uml:Model"
href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packageImport xmi:id="_0javaPrimitiveTypesData">
href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
</packageImport>
Thanks again.
Waldemar Neto
Previous Topic:[EMF] [Teneo] : benchmarks ? And Return of Experience ?
Next Topic:CDO, transient features, and views?
Current Time: Sat Jul 19 09:27:02 EDT 2025
Powered by FUDForum. Page generated in 0.03450 seconds
