Home » Modeling » EMF » Instantiating an ecore metamodel
Instantiating an ecore metamodel [message #423666] Mon, 06 October 2008 07:46 Go to next message
Originally posted by: mahdider.students.uni-mainz.de
this is a beginner's question but I did not find a solution for it up to
now. I want to create models, which conform to a given metamodel,
described in ecore. I expected some way of "instantiating" an xy.ecore
metamodel, but I could not find such a solution within the eclipse
modeling distribution.
What is the recommended way to deal with custom metamodels and models?
The models will later be transformed via QVTO, where checks for
conformance can of course be done. Still, I wonder if there is some tool
support for creating models based on a given metamodel?
Kind Regards,
Mahdi D-Manesh
Re: Instantiating an ecore metamodel [message #423667 is a reply to message #423666] Mon, 06 October 2008 08:06 Go to previous messageGo to next message
Mahdi,
Comments below.
Mahdi D-Manesh wrote:
> Hello,
> to now. I want to create models, which conform to a given metamodel,
I'm not sure how many meta levels we're cross in this question. If you
have Xyz.ecore there's be an XyzFactory and you's use
XyzFactory.eINSTANCE.createAbc where Abc is some EClass in Xyz.ecore.
Now Abc itself can be any type of model (with any number of metas in
front of it). So Abc might be XSDComplexTypeDefinition, i.e., it might
represent a <xsd:complexType> in an XML Schema. But we can't know in
EMF itself how an instance of a complex type should be created. We can
read and write XML Schemas and manipulate the metamodel, but deciding
how instances that conform to it should be created is something that
must be built and designed specifically for that meta model. Of course
for this specific example, what we've done is implement XSDEcoreBuilder
which provides mechanism for converting an XSD model instance to an
Ecore model instance; from that corresponding Ecore model, we can create
an instance that conforms to the Ecore model and hence indirectly we're
creating an instance that conforms to the XSD. This is one approach you
could consider.
> tool support for creating models based on a given metamodel?
Of course it might be that your question is really simple. You might
notice for example, that when you've opened a *.ecore with the Sample
Ecore Editor, you can right click on an EClass and invoke Create Dynamic
Instance... to create an instance that corresponds to your Ecore...
> Kind Regards,
> Mahdi D-Manesh
Re: Instantiating an ecore metamodel [message #423668 is a reply to message #423667] Mon, 06 October 2008 08:31 Go to previous message
Hi Ed,
actually it was really about the very simple case!
My issue was that I tried to find that menu from the *.ecore root and
not from an element like the package.
Thanks again for the fast response and for the detailed explanation.
Kind Regards,
Mahdi
Ed Merks schrieb:
> Mahdi,
> Comments below.
>> Hello,
> could consider.
>> Kind Regards,
>> Mahdi D-Manesh
Previous Topic:model with 2 nodes
Next Topic:multiple namespaces in one editor supported?
Current Time: Sat Jul 19 08:53:59 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
