Scheme editor, ecore to gmf [message #423482] |
Wed, 01 October 2008 04:45  |
--------------000807080606060209060807
I like create scheme editor with gmf. First i create ecore model with
three nodes. One node is main scheme and two others for example
rectangle and ellipse. But my model is now working. Please help me how
create scheme with nodes like rectangle, ellipse, circle and so on!
Thanks!
Andrei.
Content-Type: text/xml;
name="five.ecore"
Content-Disposition: inline;
filename="five.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="scheme"
nsURI="iaes.ru/scheme" nsPrefix="schemepref">
<eClassifiers xsi:type="ecore:EClass" name="MainScheme">
<eStructuralFeatures xsi:type="ecore:EReference" name="BusRef" upperBound="-1"
eType="#//Bus"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="CloserRef" upperBound="-1"
eType="#//Closer"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Bus">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Closer">
</eClassifiers>
</ecore:EPackage>
--------------000807080606060209060807--
Re: Scheme editor, ecore to gmf [message #423663 is a reply to message #423658] |
Mon, 06 October 2008 06:57  |
--------------040001080005060309040509
Andrei,
It's a GMF question so best to ask on the GMF newsgroups. If I recall
correctly you asked it also on the GMF newsgroup already where I
mentioned you likely needed some containment references in your model.
Keep in mind that in general, the amount of help you get will be
proportional to the amount of information you provide...
Andrei wrote:
>> Can you elaborate on this not working part?
> I need to create diagramm like 1.png. My ecore model is not do this.
> Can you help me with ecore model or give me a link to example ?
Content-Type: multipart/related;
boundary="------------050202050905070207080402"
--------------050202050905070207080402
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Andrei,<br>
<br>
model. Keep in mind that in general, the amount of help you get will
be proportional to the amount of information you provide...<br>
<br>
<br>
<br>
Andrei wrote:
<blockquote cite="mid:gcbsqd$8jv$1@build.eclipse.org" type="cite">
<blockquote type="cite">Can you elaborate on this not working part?
<br>
</blockquote>
<br>
<br>
<br>
<br>
<hr size="4" width="90%"><br>
<center><img src="cid:part1.06010103.09050800@gmail.com"></center>
</blockquote>
</body>
</html>
Content-Type: image/png
Content-ID: <part1.06010103.09050800@gmail.com>
iVBORw0KGgoAAAANSUhEUgAAAXQAAADoCAYAAAD/sB/fAAAABHNCSVQICAgI fAhkiAAAAAlw
SFlzAAAN1wAADdcBQiibeAAAABl0RVh0U29mdHdhcmUAd3d3Lmlua3NjYXBl Lm9yZ5vuPBoA
ACAASURBVHic7d15tBxVvfbx749KQBO8CZNMlyEoMzLPMikKIkMYRECE5RUB JxB1OeALr4oT
FxRU9BUWKKAiqIBIAAEBkUHGiIiICQg4MAkGBAIEKH7vH3s3vU+nu0+fc7q7 qqufz1q9TtXu
GnYIeVLZtQdzd7rJzDYEru3wcAeeBh4DHgVuAM519390tVIiIkPAehDomwC3 T+ASDvwMONTd
n+lOrUREqm+RoivQhAH7AbeZ2SpFV0ZEZFCUMdBr1gTONjMruiIiIoNgUh/u 8Rfg7BbfTQGm
AssAmwBrE57Qa7YHDgdO7WUFRUSqoB9t6Je6+24dnrs5cA7wxqR4jruv1cUq iohUUqmaXNz9
VmBvYEFSvKaZbVFQlUREBkapAh3A3e8CLmwofksRdRERGSSlC/Tolw37KxVS CxGRAdKPl6Lj
cX/D/nKF1KIJM5sMrE54kfsY8JD6y4tIGZQ10F9o2J/X6kAz+ymwWNy9wd2/ PtrFzWx14MSk
6FR3v7zN8ZOBI4D3A2sAk5OvczO7Fvgx8EN3f2W0+4uI9EJZA32Fhv1/tjl2 N0L3R4AXO7z+
dGBmsn9lqwPjC9mzCf3im8mAHePnQ2b2Xne/t8N6iIh0TVnb0Hds2L+miEqY 2RrAr2gd5o02
By43s6V6VysRkeZK94RuZssC70uKHiRM2lWEU4Alkv0cuILQxj8PWBXYFpiR HLMa8BXgg/2p
oohIUKpAN7PVCBNzLZMUf9G7Pfqps7psAOyUFN0D7OPu9zQctyjwReCzSfGB ZvZpd3+69zUV
EQn6EejLmdmebe4/hRDgWwJ7AIsm31/q7mf1tnot7dGwv39jmAO4+4vA0Wb2 JmDXWLw4YdqC
Wb2toohIXT8CfRPgF+M4bxZwYJfrMhZpu/n97v7HUY4/nnqgA2yBAl1E+qhU TS6JvwGHFNy/
e3qyPc3MMnfP2xx/C3AzMBe4C/hNLysnItKorIG+CjDXzI4DvlVQ3+4nku2l CN0cG6ckeJW7
vwRs1etKiYi0UtZuixCekE8CTijo/nMb9s81sw+YWVn/EhSRIdePQL8KWL7F ZwVgLcIL0fcC
pwHzG87/pJkd3od6NjqvYX9R4HTgYTP7dpzqV0SkNPoR6Avc/dEWn0fcfY67 3+Lu57j7B4H1
gN83XON4M3ttH+r6Kne/nzA3e6NlCNMA3GJmc8zsWDOb0eQ4EZG+Kl2Ti7s/ COwJ/Dspng4c
UEB1jiD0P29lDeA44H4z+7WZ7aIl80SkKKULdAB3/weh+SV1UAH1eJLQHPRT YLTBTW8DLgOu
MbMVe103EZFGpQz0qLENu9P5VDrR8VO0uz/t7vsD6wJnAKON/twBuN7Mpo2/ eiIiY1fmQG+c
sXA5M1us6ZF1WYfXHnN7vLvf4+6HAssC+xIGSy1ocfgMRk7PKyLSc6UNdHd/ AUgHFhnw+lFO
m9rh5f9rXJUi1Mvdz3f3vQnhfghwY5NDDzSz1433PiIiY1XaQI+LSizeUPxU k0PTOdAbj29l
3IGecvf/uPsP3H0b4F2E2RhrpgDbdeM+IiKdKG2gA+swsq37hRZTAaRlnT6h rz3aARasbmb7
m9laox3v7hcApzYUL9thfUREJqzMgb5vw/6dLY5LA73TJ/S2g4LMbBPgScJo 0XPpvMvktQ37
nf4FIyIyYaUM9DgX+acailut+Zn2OlnJzNo2p5jZCozeFPJXIO2lss0ox9dM b9h/pMPzREQm
rHSBbmarAD9h5LzoDlzQ4pSHk+3FgL1GucWx1BeVbsrdnwLS6XJ3MLNOJt56 W8P+fR2cIzKw
YtPklNGPlH7oR6C/1sxWbfNZ08y2MrOZZnYe4el4nYZrXOTud7W4/u8a9r9h Zis3O9DMjqbz
peF+lmwvApzRbq1QM3snsF9SNNfd/9DhvUQGhpktYmYfNrMbCB0VnjGzu83s jHbTYJjZimZ2
avxo3d1ecPeufggLWngXP08Da7a53xsJvUvSc54gDNtfF3gDoT3+puT7xwlP 9rX9Dze57rLA
sw3XfYwwidh/x2MmE4b/nwC81HDsJ7v931YffYr+EDoU3N7mz+s8YPcW566f HDej6F9LFT9l
nwr2ZeAgd5/T6gB3v8/MLmDkS9SlgG+3ue4HCXOwLN/muo+Z2deALyfFrwd+ BGBm84HX0Hww
003At9rcX2TgmNnyhEXSV2pz2BLAL83sne7e6r2X9Ejp2tATDwDbu/svOzj2 g8D9HV73eA9d
DDvxVeDnLb6bSvMwnwsc4O4vd3gPkdIzs9cQllSshfkCwkPLfsBbgU8D/6gd Dvy/fs+QKuUL
9MeBSwjdBNdw98b28abcfR5hEq1L2hz2PHCUux/daWU8/DtxP+BzjOwe2UwO nA1s4u5/6/Qe
IgPiA4TmVAjvubZ096Pc/Wfu/ht3PxHYmPo7rRnAMQXUc6hZbNvq3gXNFgc2 HcMpC4D/APPc
/dEu3H9z4H2EhTOmE9YnvR04zd2fSI7bjHo/8bnu/jBtmNl0wmjQbQn/s04j LMbxEPAH4Cx3
f2ii9RcpGzPLCHMrzSCMzN7UW3RSMLM3AncTeqk9BiwfH4wws/WpjydZzd0f 6HXdh03XA11E
qsXM9qXe6+uL7v6FUY7/JvCxuLuFu98ayxXoPVa2JhcRKZ+Z8ecrLLxOQTNp l9/dxnvTOJ/T
WM/JzGzMuRb705e9k8ioFOgiMpo3x583uHsno59vJnQdvofQ3t4xM1sj9mf/ K7DAzB6Iyzy2
HQwY51z6LaGb8wtmdqeZHTFauJvZJmZ2CaGL8pNmdpGZ9X0xnW5Rk4uItBSn yqi9G/q/7v6l
Ds9b2d3/3lDWtsklvv+6FFi6ySVvBXZy9/80uddJwMdbVOVXhH7xeeMXZvYu 4Mc0Hzl+jLt/
pcU1S0tP6CLSzmbJdrv1dUdoDPPRmNkawDWMDPN0AZnNgTObnLcxcFRS9Bwj e6TtAnyoyXlr
EXql1cLcCZ0car5sZoeP4ZdQCgp0EWknXVSm40Afh29S73V2LmHJyWmE9vva gvF7mVnjfEnH
EPq9Pwa8hTDj6jRgV+rrJ+zd5H7/S1izAMIgxGWBJQkL1Nf+FfB1M1ty/L+k /lOgi0g76Qyi
E+5W3Ezs6rhL3L0aONjd57r7Ane/mBDqtaf1xllYa12kT3P3a73uMuAL8but 0jZ4M1sT2D3u
/tDdP+buj7v7i3Eg47sJ40oWJ/S/HxgKdBFpZ4lke7QF0sdrn2T7M42jrN39 RuD8uPuW2gLs
cars2sjVi5pctzYifBKwXlK+F+GpPgc+33iSu19JaHuHCfTSKYICXUTaqT2h L3D3l3p0j9p6
A3PdfXaLY2pdIScnx79CaPsGWK3xBHf/J2Htg2kN1317/HmVuz/Y4n4Xxp9b jdbDpkwU6CLS
Tq2pY7KZWdsjx6/29DyrzTFXECbrg9C+jrs/S71b5EnNpu519+vd/bmG4tr0 3He3ud+f4s9J
wOptjisVBbqItFN7sbgInS/x2LE4rcAqcbfl9BvuvoAw1xPAqslXv48/Vwbm mNk5cQnJVvd7
HbBc3H3UzKY3+xCmAa55Y+e/omIp0EWknaeS7df14PpTqS8G/3i7Awk9WQDS ZSa/SOiqCKE5
5j3A7Wb2KzNrtnRk+pL3BMLawc0+6Wpjvfh194QCXUTaeTLZbrl+wASkT/1P tDwqqAX6q+e4
+5+BjxLa01PvAK43s6vihIE145nSd2CW2Bv4uQtEpKfSvufrAa1eWo5gZvsQ Zly8MDaXtJIG
8WgPmLW8GnE9dz/TzG4mTHN9ACPXKdgR+KGZ7RNnfUzv8WjjtVpobIMvLQW6 iLTzR8LyipMJ
S8h16n2ELn+PmNlKzYbeR88m282G/NPk+4W6T7r7PcBBZvZFQrAfRD3f9iI0 xZxDWBeh5vDY
z70y1OQiIi3Fp+tab5DtOjkn9obZOu7e1ybMIQy3r3WH7DTQWy424+73ufv7 CT1Zzk++qvUn
T89ddZT7DZxJlpkB2zPyZYEMvhy40XOfN+qRIu3dAmwIbGpma8en4XY2Igyj B7iq3YHu7mb2
IKFrYMu1SuMSeMvE3UeT8sWBtdz99obr3htnTXw7YSqAlWP5PDN7kjBgahVa MLNFCYvk3NPD
/vddN4kwwmqPoisiPfGYZTbDc39+9ENFWjoHqE1UdRitZzasSZeeu7qD688l BPpMRk60ldqV
0CYPcBuAmR0MfJ/QbLNE4wnu/oKZXUxofklfhv6ZMCXwTm3qtDNwMfCSmW1T W6Sj7BahPqeB
VM+y1EfViYyLu19PvRvfEWbWsunFzLYgtFkDPEJ4uh9NLfRXNbOtWhyzf/yZ U38x+wDhoXS6
ma3X9Cx4TfyZdon8dfy5Xpyyt5l3x58LCEtMDoRJ1PuAMnOPmW0OlS5yx8Hr P+HV3bAdJ6r3
hkPjuY2np98xe/bs186bN6/2Qihb6O4iY/cD4KuE/5/OM7P93f269AAz2xb4 RVL0ucZ5WVq4
CPg64QHzG2b2Vnd/IbnuTtT/krg0Gfk5mxDwGfB/CD1c0vq8ntB9EeoDkCAM 6/9C3D7BzHZO
e+LEKXnfE3evcfcXO/g1lIKxyKtzIeC5FrvoEyd010o/XSvbboftVr7++utr gyF28dwv788v
S6oqzmdyK/WeLk6Y/Oq6uL0tYerZWrPIbGCz2oNJvEbLBS7M7FzqT+GzgC8T mmJ2Bb5LaAeH
ZI3SeN7F1FsZvgOcRFiQY33Ccnkbx+82d/fbkvOuoN7k8ivgOMKT+LaEeddX jN+93d3bvgco
EwV6MdIA7nq4b7/D9itfd/11tcEUCnTpCjNbB7id0QfnPE0IwhHtzqME+qrA HbTvnPE9d/9w
wzXXjddM/yXqJC0PwPnuvm/DeesRmoOmjOW8slO3xeIYI//n6UWZSNfEUZlv Jzw5t/IAsPVY
XyLGWQ/fzch+6amLgSObnHc34SVt2hMl/XNwO/UXuul5fyI00aSDhtLzrgM+ 0kHVS0UDi4ph
1Kf9rO13q0yhLj3j7jea2QaEEN0aWJfwVH0LcCNwqru3GsL/GGHuFRg5pUDt 2r82s80IA4O2
J/xL4G7gdHf/SZs6nWJmtxEC/03ACoS/WM4jPNXPb3HexXEir88COxCe1u8k dLX8Roft/6Wi
JpfidNqMMubml+132H4lNbmIDB81uRTHGrYbm0zG39SiZ3SRoaRAL5ba0UWk axToxVGQi0hX
KdCL180gb9Z0IyJDQoFerPEEdKft7SIyZBToxevuC1EwU7aLDCUFerHUji4i XaNALwcFuYhM
mAK9eHpKF5GuUKCXx3h7sSxcpkgXGUoK9OKNtxeLntBFZAQFenmoqUVEJkSB Xg5qRxeRCVOg
l4uCXETGTYFeDt17IapQFxlaCvRy0QtRERk3BXp5dK2pRUP/RYaTAr181I4u IuOiQC+Pbga5
Ql1kCCnQy2kiL0QV5iJDalLRFZARaoHsLfbHUiYysCyzxYBVgFXjzyWAKcDU +JmS/HwJmB8/
zyXb84GHgAeBBz33J/r5ayiCAr2cJhLkeicqA8MymwJsAmwBbATMIIT4cnT5 X5uW2XxiuAP3
ALcCt3juf+/mfYqkQC+XiQW5ntKl5CyzNYBtCQG+ObAekPXp9lOBdeNn16RO jwK3EAL+JuBG
z/3FPtWpqxTo5TXeINfzuZSGZTYJ2AbYPX5W7/DUnKS5BPgXI5tS0iaWydSb YtLPNGBlwhP/
qsDiLe61HDAzfgCetcyuBGYBl3nu/+qwzoVToJdPq3b0Tsv0hC6FiiG+O7Av sAswvc3hr1Bv
/rgVmEMI8H947i93uV5LEYJ9BrAx4V8ImwH/1XDo4sDe8fOKZXYrcDHwQ8/9 oW7WqdsU6OU1
7qYWNaJLESyz1YAPAP9DeOpt5lngauB3hACf7bk/04/6ee7/Bv4NzAbOB7DM DFiLEO6bA28D
1khOWwTYMn6+ZJldBpxOeHLP+1HvsVCgl0832tFF+sIymwzsCRwG7Ejz///+ Tmi+mAVc67kv
6F8N2/PcnfAvhHuAs+HVdv49CP/KeDP1Nv6MetPRQ5bZD4AzyvRSVf3Qy00j RKWULLNFLbMP
AvcBPyM82ab/Dz4IfB7YwHNfxXP/qOd+RZnCvBXPfa7n/nXPfXvg9cBBwOWE 5qGaFYFjgfss
szMssxkFVHUhCvRymsgIUYW79EwS5PcC3yO8dKx5CbgA2BlYzXM/znP/YwHV 7BrPfZ7n/mPP
fRdgNeDLwMPJIZOBQ4A5ZQh2BXq5aYSolIJllllmh9E8yB8CjgZW8tzf5blf GZsyKsVz/5vn
fizh1z4TuDL5ujHYV252jV5ToJfTROd1Eekay2xTwgvM01g4yI8A3uC5H++5 P1ZE/frNc889
94s9952BrYArkq9rwX6PZfaZ+I6hbxTo5ad2dCmEZTbNMvsOYdDNxslXaZB/ ZxDaxXvFc7/Z
c38HCwf7FOB44A7LbJt+1UeBXl7jD3LFukyQZbY/8BfgI9Rz4hngEyjIF9IQ 7LclX60LXGeZ
fT/2g+8pBfpg0AtR6QvLbLpldgFwLiP7kv8CWNtzP1lB3prnfjOhz/pHgf/E YgPeD9xlme3Q
y/sr0MtLL0SlryyzzYE7CCMka/4O7OG57132UZJl4bm/4rl/F1gb+Gny1fLA VZbZsZZZT7JX
gT4Y1I4uPWWZHQXcQBgaX/M9YB3PfVYhlRpwnvsjnvv+hOkPHo3FGXAccKVl tmy376lALzcF
ufSUZfZay+xC4GRCDw2Ap4F3e+4f9tznF1e7avDcLwc2JEx5ULMj8AfLbMtu 3kuBPjg6DnfD
FO4yKstsCeAqYK+keDawkef+82JqVU2xS+dOhNGztRGnywFXW2a7dOs+CvTy 01O6dJ1ltiJw
PbB1UnwKsLXnfn8xtaq22LZ+HGGahFqf/SnAxZbZe7txDwV6uXX6QrSxTKQl y2xNwmyH68ai
V4CPeu5HDurCDoPEc/8NYdKvv8aiScAPLbNPTPTaCvTy0xO6dI1ltgHh5Wdt xOdLwIGxV4b0
ief+V0Ko3xGLDPiGZfbViVxXgT5YNLBIxi3OV345sHQsmg/s5rmfV1ythlds V98euCYpPtoy
+8x4r6lAHwx6SpcJscxeTxiaXhss9BSwo+d+ZeuzpNfi4h67EAZu1Rxvmb1v PNdToJffeKfR
FQHAMnsd4cn8jbHoeWB3z/2W4molNfG9xf6M7NZ4umX2zrFeS4E+GDRqVMbF MlsUuAjYKBa9
DOznud9QXK2kUQz1vQjdRiG8KP25ZbbFWK6jQB88amqRsTgBeGuyf6hGfpZT 0vwyNxZNAS4Y
y6ReCvTBofnQZUwss12BjyVFn/PczyqoOtIBz/1xwopP/4pFKwJndnq+An0w 6IWojIlltgJw
VlI0y3P/WkHVkTHw3B8krGNaW/Vpd8vsiE7OVaAPlo5eiJpyfajFmfx+RL17 4j+B/ymuRjJW
sffRiUnRiXEMQVsK9MGhF6LSqU9SbzfPgQM8938XWB8Zn2MIq0UBLAacF19y t6RAHyxqapG2
4hwtn0+KPq8eLYPJc38JOID6QhlrAR9vd44CfXCoHV06cQIwNW7fSVjXUgaU 5/4A8Lmk6BjL
bPlWxyvQB4+CXJqyzN4MvCcpOtJzz4uqj3TNacAf4/bihL+0m1KgD5bO1hXV W9GhE1+EnpIU
nee5X1dUfaR74l/KaffTAy2zrZsdq0AfPHohKs3sR3006HPApwqsi3SZ534t 8LO4a0DTLqgK
9MGigUXSyieT7RM9938WVhPplU8BL8Tt7SyzTRsPUKAPJrWjy6sss+2ATeLu 84xsepGK8Nz/
DpyTFC20IIYCffCMGuRqQh866R/ss9XnvNK+mWzva5mtlH6pQB9cncy+KBVn ma0O7B53nZF/
4KViPPc/ERb2hjAj45Hp9wr0wdPJC1GF+vD4MPU/x5d67nOKrIz0xcnJ9qGW 2WK1HQX64FI7
ugDsnWyr7Xw4/Aq4P25PA3asfaFAH0wKcsEy24j6Ys/zGLk2pVSU5+7ABUnR zNqGAn2wqbll
uO2ZbF/iub9cWE2k39I1SPewzAwU6INKzS0CIwP9osJqIUW4GXg0bi8HbAkK 9EHXfNSoYr3y
LLNVgPXj7vPAFQVWR/osNrv8MinaAxTog0xP6MNty2T7N577c4XVRIpyabKt J/SKUJAPp3T1
mt8XVgspUvr7vgEo0AeZ2tGHWxrofyisFlIYz/0h4Im4u4RltpICvRpGBLlh CvXq2zDZVqAP
r/T3fkMF+mDTNLpDyDJbGlgh7j5DfZCJDJ87k+0NFOjVoCAfLusk23fHHg8y nO5KttdRoA82
DSwaTksm2/8qrBZSBunv/5IK9OrQU/rwmJ5sP1VYLaQM0t//6Qr0wdesHV2q LQ30JwurhZRB
+vuvQK8QPaEPDz2hS82IJ/RJhVVDuqUW5D6ihFdL9jSztfpeK+kd4y3xJ+gJ fdiNeEJXoFfL
wk/pzrLUF5aVapiWbL9SWC2kDNLf/0UU6NWw8FN6vfQ0z/3yIiolvWGZHUd9 pOgSRdZFCpf+
/j+lNvRq0bqiw2FEu2lhtZAyGPE+RYFeDQrx4ZIGup7Qh5ue0CvONCF65ekJ XWr0hF5Rekof
HmnPhqULq4WUQfr7/6QCXWTwzEm212l5lAyDdZPtOQr06tAL0SHhuT8MPB53 l7TMViqyPlKo
dF78OxXo1aRQr7502tQNWx4lVTdiXnwFerXoCX14KNCHnGW2DA3z4ivQRQZT ulLNRoXVQoqU
/r7/0XN3BXr1qNficLg92X6rZTa5sJpIUd6RbN8OWiS6ahTlQ8Jz/wtwX9yd Bry1wOpIMfZM
tmeBAr2KFOrD46Jke8+WR0nlWGYbADPi7pPAb0GBLjLI0kCfaZnpL/PhsVey fann/jIo0CtJ
jehD4ybqa0ouD2xVYF2kv/ZJtn9Z21CgV4/SfEh47q+Q/GEGPlJUXaR/LLNt gPXi7vPAq9Nj
K9CrSaE+PE5Ntt9tmf13YTWRfvl4sv0jz/3Z2o4CXWSAee6/J74QAyYBRxRY Hekxy2xVYGbc
deCb6fcKdJHBd1KyfZhltnhhNZFeOxLI4vblnvs96ZcKdJHBdwlwb9yeDnyg wLpIj1hmSwGH
JEUnNx6jQBcZcPHl6LeSomMtsyWLqo/0zJeB/4rbd3nuv248QIEuUg1nAH+N 20sCXyqwLtJl
cSDRoUnR0c2OU6CLVIDnvoCRvR8Ot8zWL6o+0nWnUG87v8xzv7TZQQp0kYrw 3GdR75OcAd8u
sDrSJZbZ/sC2cfdFRv7FPYICXaRajgJeitvbW2aHtDtYys0yW5qRvZi+5bnP bXW8Al2kQjz3
OYzsm/xty2zdVsdLecW5ec4mTOsA8BCjvBtRoItUz7HUVzSaAvzUMnttgfWR 8fk48M64/Qpw
sOf+TLsTFOgiFRNfkO4PzI9F6xJeqsmAsMw2Bb6WFH3Nc79mtPMU6CIVFBfA ODIpOsQyO7io
+kjn4hiC84BFY9FNwBc6OVeBLlJRnvsPCMFQc4ZltnNR9ZHRWWZTgEuBN8Si p4ADavOdj0aB
LlJthwN3xe3JwAWW2RYF1kdaiOvCng9sGYty4CDP/W+dXkOBLlJhnvvTwM7A g7FoKnCpZbZ2
YZWShcQeLWcCuyTFh3vul4zlOgp0kYrz3B8BdgIej0VLAVdYZm9ofZb0Swzz bwMHJsXHeO7f
H+u1FOgiQ8Bzv5fw9FdbDGEl4MY4R4gUxDKbROhr/tGk+Lue+1fGcz0FusiQ 8NxnA3sSli0D
WBb4rWW2XXG1Gl6W2VTgYuCgpPgnjOydNCYKdJEh4rlfTWh+eSoWTSM0v8xs fZZ0W5zb/GpG
tpmfArw3Toc8Lgp0kSHjud8AbAc8HIteQ+j98oniajU84gvpG4G0t9ExnvuR nrtP5NoKdJEh
5LnfBbyZ+kpHGfANy+xiLY7RO3Fw123AmrEoBw4bb5t5IwW6yJDy3B8khPqt SfHuwB2W2VaF
VKqiLLMpltmZhBegU2Pxc8C+nvvp3bqPAl1kiHnujxPm2k6XsFsZuM4y+7Rl poyYIMvsTYSn
8vclxXcDm3nuv+jmvfSbJTLkPPcXPfejgL2ovyydBPwvcLNltlFhlRtg8an8 eGA2sE7y1Q+A
zT33P3f7ngp0EQHAc78I2Ai4JSneDLjNMjvJMlu8mJoNHstsV8JT+GcIUy5A mP3yIM/9EM/9
uV7cV4EuIq+K7erbEhYhroVORpib+8+W2V4FVW0gWGYrW2YXAJcAqyZfXQ1s 5Ln/uJf3V6CL
yAie+0ue+/GEedTTxYhXAi60zG6zzHYrpnblFIP8VEKvob2Trx4j9C1/Wxyt 21MKdBFpynN/
0HPfDdgH+Gfy1abALAX7QkF+OPU5zF8BTgXW8tzP6Vd9FOgi0pbnfiGwNmEF nWeTr9Jg398y
W7TpBSrIMlvfMjuNhYMcQvPKVp77hzz3p5peoEcU6CIyKs/9Wc/9c8AMQu+X xmA/F3jIMvu6
ZbZms2sMOstsqmV2iGV2C2HN1sNYOMi3jc0rtza9SI8p0EWkY577E577Z2ke 7EsDnwT+Ypn9
1jI7eNBHnVpmmWW2jWX2PcJUCWcAmzcclgb5DX2vZGJSkTcXkcHkuT8BfNYy OxF4P3AosHpy
yHbxk1tmNwKzgFme+5y+V3aMLLPXERYF2R3YlTB/fKPnCasLfc9zv6mP1WtL gS4i4+a5/xs4
ETjRMtuB0AyxN7BYPCSjHu4nWmb3ApcBvwNujd0kCxX7129CePJ+G7ADI5tS UncBpwM/6nf7
eCcU6CLSFZ77tcC1cWrYg4F9CTMKpk27qwMfix8ss8cJc8nUPnOAf3S6KPJY xbrNADYmBPgW
hFGc7ZqfHyH8C+NMz/3mXtSrWxToItJV8an9ZOBky2wZQrPF7oR52BtHm9a+ 3zUpyy2zhwjr
oNY+/yKMtGz8PEcYiTm1yWcaYV6aVZNPJ6NdHbiDEOKXALMnOq1tvyjQRaRn 4cPvzQAAAX1J
REFU4uRfZwFnxW6NOxBGom5BmFZgepPTMkIQr0xoqum1HPgT4V8INwFXeO4P tz+lnBToItIX
nvuLwJXxU1sceQ3qTR8bEZpDlgOsR9WYT3jiv4cQ4LcQnsDn9+h+faVAF5FC xGaMOfHzo1q5
ZfYaRjaVrAIsAUyh3pwyJfn5EiObYNImmRFNN7F3TmUp0EWkVDz3F4C58SNj oIFFIiIVoUAX
EakIBbqISEUo0EVEKkKBLiJSEQp0EZGKUKCLiFSEAl1EpCIU6CIiFaFAFxGp CAW6iEhFKNBF
RCpCgS4iUhEKdBGRilCgi4hUhAJdRKQiFOgiIhWhQBcRqQgFuohIRSjQRUQq QoEuIlIRCnQR
kYpQoIuIVIQCXUSkIhToIiIVoUAXEakIBbqISEUo0EVEKkKBLiJSEQp0EZGK UKCLiFSEAl1E
pCIU6CIiFTEp3bHMiqqHiIhM0CLAf4quhPTUs0VXQET6YxHgWGB+0RWRrnsF +AlwU9EVEZH+
+P8Vf2CcE1j0dQAAAABJRU5ErkJggg==
--------------050202050905070207080402--
--------------040001080005060309040509--
FUDForum. Page generated in 0.24375 seconds
