Home » Modeling » EMF » Aspect Orientet Programming (AOP) using reflective feature delegation?
Aspect Orientet Programming (AOP) using reflective feature delegation? [message #423638] Fri, 03 October 2008 13:15 Go to next message
given a dynamic model or a generated model with "feature delegation"
set to "Reflective". In both cases, overriding, the eGet, eSet etc
methods in the base class allow you to intercept the set/get calls.
That opens the door for aspect oriented programming! That
means you can intercept the set and get methods and create
advices like "around".
My question is: is there already some code/project that does
AOP for EMF using reflective feature delegation?
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Aspect Orientet Programming (AOP) using reflective feature delegation? [message #423639 is a reply to message #423638] Fri, 03 October 2008 13:30 Go to previous messageGo to next message
Michael,
Comments below.
Michael Scharf wrote:
Note that we added a new pattern "Dynamic" in EMF 2.5 that accomplishes
the same goal, but still delegates through tailorable getX methods.
CDO makes good use of this type of thing too...
Eike did some stuff with AOP for legacy models with CDO, but I don't
know of anyone else.
> Michael
Re: Aspect Orientet Programming (AOP) using reflective feature delegation? [message #423640 is a reply to message #423639] Fri, 03 October 2008 14:06 Go to previous messageGo to next message
Cool, then I'll take a look at 2.5 and at CDO.
Michael
Ed Merks wrote:
> Michael,
>> Hi,
>> Michael
Michael Scharf
Re: Aspect Orientet Programming (AOP) using reflective feature delegation? [message #423641 is a reply to message #423639] Fri, 03 October 2008 14:11 Go to previous messageGo to next message
Ed,
Is there any documentation or bug report to learn more about that
feature?
Michael
Michael Scharf
Re: Aspect Orientet Programming (AOP) using reflective feature delegation? [message #423642 is a reply to message #423641] Fri, 03 October 2008 14:24 Go to previous message
--------------050904020906090205080802
Michael,
I know it's really hard to find what you need among all the copious
documentation we provide
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232414
But there was a bug that was fixed in this week's I-build. It's
basically the same pattern as always, eGet(<x>) calls getX but rather
than return a variable, it calls eDynamicGet(<x>). So the net effect is
exactly the same, but by filtering through the generated method, it's
easier to override the behavior.
> Ed,
>> accomplishes the same goal, but still delegates through tailorable
>> getX methods.
> feature?
> Michael
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Michael,<br>
<br>
documentation we provide<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=232414">https://bugs.eclipse.org/bugs/show_bug.cgi?id=232414</a><br>
</blockquote>
<br>
But there was a bug that was fixed in this week's I-build.&nbsp; It's
basically the same pattern as always, eGet(&lt;x&gt;) calls getX but
rather than return a variable, it calls eDynamicGet(&lt;x&gt;).&nbsp; So the
net effect is exactly the same, but by filtering through the generated
method, it's easier to override the behavior.<br>
<br>
<br>
<blockquote cite="mid:gc5n7o$4hb$2@build.eclipse.org" type="cite">Ed,
<br>
<br>
<blockquote type="cite">Note that we added a new pattern "Dynamic" in
EMF 2.5 that accomplishes the same goal, but still delegates through
<br>
</blockquote>
<br>
<br>
feature?
<br>
<br>
Michael
<br>
</blockquote>
</body>
</html>
--------------050904020906090205080802--
Previous Topic:[Teneo] upper case on only some generated column names
Next Topic:How to write an EMF model which has to implemment an external Java interface
Current Time: Sat Jul 19 14:18:48 EDT 2025
Powered by FUDForum. Page generated in 0.04639 seconds
