Home » Modeling » EMF » Trouble with Proxy Resolution
Trouble with Proxy Resolution [message #423581] Thu, 02 October 2008 10:55 Go to next message
I am having trouble with proxy resolution. My model doesn't use
containment relationships, they are all references.
A hasManyBs
B hasManyCs
An instance of A is created during resource load and added to the resource
contents.
When I do "a.hasManyBs.toArray()" the Bs resolve but are not contained in
the resource.
If I then try to do "b.hasManyCs.toArray()", the proxy resolution seems to
fail because B does not belong to a resource.
I have tried to add each object to the resource as they are loaded but I
get exceptions when doing that. I am not sure if this is the correct
approach or not anyway.
What approach should I use to make this model behave as expected in EMF?
Re: Trouble with Proxy Resolution [message #423588 is a reply to message #423581] Thu, 02 October 2008 11:48 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Greg,
When the Bs are resolved, the ResourceSet is ultimately responsible for
resolving them by loading the resources that contain the Bs. Thus, the
Bs should already be contained by resources in the same resource set as
A, but they would never be expected to be in the same *resource* as A
because then they wouldn't have been proxies in the first place.
I think the question is how does proxy resolution yield B instances that
aren't in any resource. They must be in a resource. Does your
application somehow customize the proxy-resolution code in the
ResourceSet (the getEObject(...) method)?
Christian
> A hasManyBs
> B hasManyCs
> resource contents.
> in the resource.
> to fail because B does not belong to a resource.
Re: Trouble with Proxy Resolution [message #423589 is a reply to message #423581] Thu, 02 October 2008 11:50 Go to previous messageGo to next message
Greg,
Comments below.
> A hasManyBs
> B hasManyCs
> resource contents.
> in the resource.
This sounds impossible. To resolve they must be found in a resource...
> seems to fail because B does not belong to a resource.
It sounds like it failed earlier on B. How can B not be in a resource?
> I get exceptions when doing that.
Each object should have been in a resource when it was saved and all
these inter-object references should be resolved against those.
> I am not sure if this is the correct approach or not anyway.
No, it's not. You should not have to intervene.
If there are no containment references, all objects need to be in the
root of the resource initially when you save, and then you'll definitely
need to use an XMIResourceImpl because an XMLResourceImpl won't save
anything except the first root object (which is probably the source of
your problem).
Re: Trouble with Proxy Resolution [message #423596 is a reply to message #423589] Thu, 02 October 2008 14:29 Go to previous messageGo to next message
The source for the data is not an XML file it is a custom data format. I
have a custom ResourceImpl that I expected to represent the whole data
set. It is in this ResourceImpl that I thought I needed to add the
objects to the resource contents as they were being resolved.
When object B is getting resolved through the proxy mechanism I have code
in the getEObjectById that populates the data. This part seems to work
correctly but does not automatically add it to the resource since it is
not contained.
Re: Trouble with Proxy Resolution [message #423597 is a reply to message #423588] Thu, 02 October 2008 14:33 Go to previous messageGo to next message
Yes we customize the proxy resolution since we are not reading from an XML
file and we have customized data source. We put the code to populate the
object into the getEObjectById and use the URI to look the data value up
in our data store. It is at this point that I thought I needed to add the
resolved object instance to the resource.
Re: Trouble with Proxy Resolution [message #423598 is a reply to message #423596] Thu, 02 October 2008 14:37 Go to previous messageGo to next message
Greg,
I see. If the objects are not indirectly contained by the resource,
then they need to be directly contained...
> format. I have a custom ResourceImpl that I expected to represent the
> whole data set. It is in this ResourceImpl that I thought I needed to
> add the objects to the resource contents as they were being resolved.
> code in the getEObjectById that populates the data. This part seems
> to work correctly but does not automatically add it to the resource
> since it is not contained.
Re: Trouble with Proxy Resolution [message #423599 is a reply to message #423597] Thu, 02 October 2008 14:42 Go to previous messageGo to next message
Greg,
So what kind of exceptions do you get? If you have some way of fluffing
up the object on demand, you need to ensure it's attached to the
resource while doing that...
> XML file and we have customized data source. We put the code to
> populate the object into the getEObjectById and use the URI to look
> the data value up in our data store. It is at this point that I
> thought I needed to add the resolved object instance to the resource.
Re: Trouble with Proxy Resolution [message #423602 is a reply to message #423599] Thu, 02 October 2008 15:12 Go to previous messageGo to next message
I tracked it down to the TransactionChangeListener.
IllegalStateException ise =
new IllegalStateException(Messages.noWriteTx);
Here is my method from my ResourceImpl :
protected EObject getEObjectByID(String id) {
EObject result = null;
MMObj obj = MMObj.getInstance(getModelSource().getModel(), ObjId
.getInstance(Long.valueOf(id)));
// If the MMObj is in a deleted status, then do not continue
if (obj.getChgStatus() == ChgStatus.DELETED_ITEM) {
return null;
} else {
MetaModelResourceSync synch = ResourceSyncFactory
.getResourceSyncByOTC(obj.getObjTypeCode());
if (synch != null) {
result = (EObject) synch.load(this, obj.getId().getValue());
this.contents.add(result);
return result;
Re: Trouble with Proxy Resolution [message #423608 is a reply to message #423602] Thu, 02 October 2008 16:26 Go to previous messageGo to next message
Hi, Greg,
Your TransactionalEditingDomain will consider this addition of the
object to a resource as a model change, which requires a read/write
transaction. Ordinary proxy resolution is compatible with a read-only
context because it doesn't actually change the "abstract state" of any
EObjects or Resources.
You will need to do one of:
- execute a command with the Transaction.UNPROTECTED option to
add the object to the resource. This option is required in
case the current thread has a read-only transaction in progress,
which is probably likely. Also, you probably don't want this
change to be undoable
- toggle the eDeliver() state of the resource off and on around
the insertion of the object, so that the editing domain doesn't
hear about the change
HTH,
Christian
> IllegalStateException ise = new
> return null;
> } else {
> return result;
Re: Trouble with Proxy Resolution [message #423609 is a reply to message #423608] Thu, 02 October 2008 16:51 Go to previous message
That is what was missing. Thanks to both of you for the help
Previous Topic:Eclipse/JUnit test works, Maven test fails...
Next Topic:NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="true"
Current Time: Sat Jul 19 07:04:49 EDT 2025
Powered by FUDForum. Page generated in 0.05437 seconds
