Home » Modeling » EMF » Extending/overriding the generated EMF model
Extending/overriding the generated EMF model [message #423218] |
Wed, 24 September 2008 23:36  |
Hi all,
We all know the obvious (documented) way to extend/override a model is to
add your own methods in the implementation class and if applicable remove
the @generated tag and all will be well.
However, there are some valid claims (valid in my opinion) that user code
should not be mixed in with generated code. One suggestion is to extend the
implementation class, but then one must be careful to make sure that the
factory creates the correct implementation class, that is, the extended
version. So the factory has to be updated, but maintaining that we don't
modify generated code we extend the factory implementation, but that would
break the factory interface attribute eInstance as it calls the static
"init" method in the generated implementation, so in the end there is no
choice but to either update the eInstance attribute to call an "init" method
in the extended factory, or to create an instance of the extended factory
manually.
What are the thoughts on this issue? Should methods be overridden and
classes extended in the generated implementations? Or is there some sensible
way to separate manually written code which gives advantages when testing
code coverage on non-generated code?
Bob
Re: Extending/overriding the generated EMF model [message #423234 is a reply to message #423218] |
Thu, 25 September 2008 06:46   |
Bob,
Comments below.
Bob wrote:
> Hi all,
Darned, another purist shows up! Personally I think the claims are
largely driven by the thinnest of reasons and ignore the costs and
complexity that being pure introduces.
> version.
And what about if you need to add methods to the interface not just
implementations to the class? If adding EOperations is sufficient, they
how about defining operations with body annotations an not modifying the
generated code at all?
Also derived classes have to use the right base class.
> manually.
You'll need to modify a bunch of things, including base classes if you
have a hierarchy of classes. And of course downstream models that
extend your model would have to be aware of this as well.
Snap out of it! :-P Use Mint to highlight your @generated methods so
you can pretend you're looking at a separate file that has just your
changes.
No.
Are the clients who use your code going to care that you've separated
things and tested them separately? I think all they'll care about is
that your code works. And they'll prefer it to be as simple as possible
with as little byte code as necessary.
> Thanks
> Bob
Re: Extending/overriding the generated EMF model [message #423333 is a reply to message #423234] |
Sun, 28 September 2008 21:17   |
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gbfq61$376$1@build.eclipse.org...
> Bob,
> Comments below.
> Bob wrote:
>> Hi all,
Guess what, I'm not the purist :), I prefer to do it the way all EMF
documentation suggests, because of the complexity that could be introduced
from the proposed solution, and anything I haven't thought of yet. But I
deliberately wrote the post as best I could to take the purist argument so I
could gather all the pros and cons possible. It worked :), but I have more
questions so that I can present the best argument on my side (or prove
myself wrong, I came here looking to do one of the two).
>> One suggestion is to extend the implementation class, but then one must
>> be careful to make sure that the factory creates the correct
>> implementation class, that is, the extended version.
I'm not sure I understand, but wouldn't this still be possible just
providing the implementation in the extended implementation class and
leaving the generated implementation that throws an unsupported exception
(or whatever the default is?).
> If adding EOperations is sufficient, they how about defining operations
> with body annotations an not modifying the generated code at all?
I don't understand again about the annotations, is there some documenation I
can read on this area?
>> but maintaining that we don't modify generated code we extend the
>> factory implementation, but that would break the factory interface
>> attribute eInstance as it calls the static "init" method in the generated
>> implementation, so in the end there is no choice but to either update the
>> eInstance attribute to call an "init" method in the extended factory, or
>> to create an instance of the extended factory manually.
> have a hierarchy of classes. And of course downstream models that extend
Care to make a list for me? :). Personally I think it is super-ugly
modifying that eInstance attribute.
However, on the purist argument, which I must admit has some merit,
separation could be good, wouldn't a purist claim that EMF is not designed
well to allow separation of custom code and generated? I mean, trusting a
generated model and having completely separate custom code would allow focus
on testing the custom code and code coverage tools to be configured to only
report on the custom code.
> Snap out of it! :-P Use Mint to highlight your @generated methods so you
> can pretend you're looking at a separate file that has just your changes.
I'll take a look at Mint.
> things and tested them separately? I think all they'll care about is that
> your code works. And they'll prefer it to be as simple as possible with
We are the clients, but none-the-less, the clients shouldn't have any idea
about any of the implementation, in fact in most cases I would expect that
the client doesn't need to know that it is even an EMF model, UNLESS, they
specifically want to use EMF technology - perhaps that is another argument,
probably to exploit the best features the client would want to know that it
is EMF?
Cheers
Bob.
Re: Extending/overriding the generated EMF model [message #423346 is a reply to message #423333] |
Mon, 29 September 2008 07:27   |
--------------010609010401040704080002
Bob,
Comments below.
>> Bob,
>> Comments below.
>> Bob wrote:
>>> Hi all,
Aren't you sneaky. :-P
The point is that EMF generates an interface and an implementation
class. The "separate hand written code" solution has only addressed the
second half of this. For the sake of argument, suppose you needed (more
like wanted I suppose) to add a static final constant to the
interface. If I remember the pattern correctly, it was something like
this. FooGen has all the generated interface. Foo extends FooGen and
you add your hand written stuff there. FooGenImpl is the generated
implementation class and implements Foo. Finally FooImpl extends
FooGenImpl and implements Foo. Or something like that. To me it was
always so horrible (and was made worse by the fact that we had a MetaFoo
that extended EClass and a MetaFooImpl that extended EClassImpl. as
well,or whatever the heck is was called). Reducing 6 artifacts down to
2 resulted in a significant footprint reduction.
Here's an example from SDO.ecore
<eClassifiers xsi:type="ecore:EClass" name="EDataObject"
eSuperTypes="../../org.eclipse.emf.ecore/model/Ecore.ecore#//EObject
#//DataObject">
<eOperations name="getInstanceProperties">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="body" value="return
<%org.eclipse.emf.ecore.sdo.util.SDOUtil%>.getInstanceProperties(this); "/>
</eAnnotations>
<eGenericType eClassifier="#//EJavaList">
<eTypeArguments eClassifier="#//Property"/>
</eGenericType>
</eOperations>
</eClassifiers>
Any operation can have a body annotation, which is the Java code that
will be stuffed into the generated Impl class's method. You can
surround fully qualified class names with <%a.b.C%> so that they will be
imported (if possible).
And that's only the start! :-P
I'd suggest, tongue in cheek, that they go find a well-designed
alternative and use that instead of bothering me. :-P
> I mean, trusting a
No, I don't buy that argument at all. Even when you have generated
code, you need to take responsibility for the functioning of the system
as a whole. And even if this were a strong argument, it still comes
down to a tools issue. Coverage of @generated methods isn't important
so filter them please...
> is EMF?
We do have options to suppress EMF metadata, suppress @model
annotations, suppress EMF types (EList -> List, EMap -> Map) so yes,
it's possible to create a "pure" API that has no evidence of EMF. This
makes some of our clients really happy. Similarly the SDO facade to
hide EMF made some clients really happy too (actually I assume that it
does because I've not seen significant evidence of that). In any case,
soon enough either the client directly, or their clients in turn
indirectly, want XML serialization, notification, copy, change recording
and all the other handy dandy things EMF provides. Casting solves such
problems nicely, but begs the question of what the purity really bought
given that casting is shockingly expensive and simply makes explicit
assumptions implicit instead...
> Cheers
> Bob.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Bob,<br>
<br>
Comments below.<br>
<br>
Bob wrote:
<blockquote cite="mid:gbpaad$p7u$1@build.eclipse.org" type="cite">
<pre wrap="">"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gbfq61$376$1@build.eclipse.org">news:gbfq61$376$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Bob,
Comments below.
Bob wrote:
</pre>
<pre wrap="">Hi all,
</pre>
</blockquote>
<pre wrap="">Darned, another purist shows up! Personally I think the claims are
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
Aren't you sneaky. :-P<br>
<pre wrap="">
</pre>
<pre wrap=""> One suggestion is to extend the implementation class, but then one must
</pre>
</blockquote>
<pre wrap="">And what about if you need to add methods to the interface not just
</pre>
</blockquote>
</pre>
</blockquote>
(more like wanted I suppose) to add a static final constant to the
MetaFoo that extended EClass and a MetaFooImpl that extended
EClassImpl. as well,or whatever the heck is was called). Reducing 6
artifacts down to 2 resulted in a significant footprint reduction.<br>
<pre wrap="">
</pre>
<pre wrap=""> If adding EOperations is sufficient, they how about defining operations
</pre>
</blockquote>
</pre>
</blockquote>
Here's an example from SDO.ecore<br>
<br>
#//DataObject"><br>
<eOperations name="getInstanceProperties"><br>
<eAnnotations
source=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/GenModel">"http://www.eclipse.org/emf/2002/GenModel"</a>><br>
&lt;%org.eclipse.emf.ecore.sdo.util.SDOUtil%> .getInstanceProperties(this); "/><br>
</eAnnotations><br>
<eGenericType eClassifier="#//EJavaList"><br>
<eTypeArguments eClassifier="#//Property"/><br>
</eGenericType><br>
</eOperations><br>
</eClassifiers><br>
<br>
will be imported (if possible).<br>
<pre wrap="">
</pre>
<pre wrap="">So the factory has to be updated,
</pre>
</blockquote>
<pre wrap="">Also derived classes have to use the right base class.
</pre>
<pre wrap=""> but maintaining that we don't modify generated code we extend the
</pre>
</blockquote>
<pre wrap="">You'll need to modify a bunch of things, including base classes if you
</pre>
</blockquote>
</pre>
</blockquote>
And that's only the start! :-P<br>
<pre wrap="">
well to allow separation of custom code and generated?</pre>
</blockquote>
alternative and use that instead of bothering me. :-P<br>
<br>
<pre wrap=""> I mean, trusting a
</pre>
</blockquote>
so filter them please...<br>
<pre wrap="">
</pre>
<pre wrap="">What are the thoughts on this issue?
</pre>
</blockquote>
<pre wrap="">Snap out of it! :-P Use Mint to highlight your @generated methods so you
</pre>
</blockquote>
</pre>
<pre wrap="">Are the clients who use your code going to care that you've separated
</pre>
</blockquote>
is EMF?
</pre>
</blockquote>
yes, it's possible to create a "pure" API that has no evidence of
EMF. This makes some of our clients really happy. Similarly the SDO
facade to hide EMF made some clients really happy too (actually I
assume that it does because I've not seen significant evidence of
that). In any case, soon enough either the client directly, or their
clients in turn indirectly, want XML serialization, notification, copy,
change recording and all the other handy dandy things EMF provides.
Casting solves such problems nicely, but begs the question of what the
purity really bought given that casting is shockingly expensive and
simply makes explicit assumptions implicit instead...<br>
<pre wrap="">
Cheers
Bob.
</pre>
</blockquote>
</body>
</html>
--------------010609010401040704080002--
Re: Extending/overriding the generated EMF model [message #423405 is a reply to message #423346] |
Mon, 29 September 2008 19:48   |
------=_NextPart_000_0009_01C922E1.BADEA830
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks for your help, I've got plenty to work on. :)
I'm thinking that in most cases we can probably provided a wrapper or =
utility class that adds the additional functionality. From experience in =
our models this will be a good solution that will make all happy. Of =
course there are still some issues, like implementing comparable, adding =
a sub-class just to do that is crazyness :), of course a comparator can =
be written separately and used where necessary.
On the code coverage issue, we do want to ignore coverage on generated =
methods, we use Cobertura and unfortunately there is no way to have the =
tool just ignore a particular method, so that does pose a problem.
Anyway, we will work on a solution that hopefully does not involve =
extending impl classes :).
Bob.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message =
news:gbqe2g$sf2$1@build.eclipse.org...
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16705" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks for your help, I've got plenty =
to work on.=20
:)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I'm thinking that in most cases we can =
probably=20
provided a wrapper or utility class that adds the additional =
functionality. From=20
experience in our models this will be a good solution that will make all =
happy.=20
Of course there are still some issues, like implementing comparable, =
adding a=20
sub-class just to do that is crazyness :), of course a comparator can be =
written=20
separately and used where necessary.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>On the code coverage issue, we do want =
to ignore=20
coverage on generated methods, we use Cobertura and unfortunately there =
is no=20
way to have the tool just ignore a particular method, so that does pose =
a=20
problem.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Anyway, we will work on a solution that =
hopefully=20
does not involve extending impl classes :).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Bob.</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:Ed.Merks@gmail.com">Ed.Merks@gmail.com</A>> wrote in =
message=20
<A=20
href=3D"news:gbqe2g$sf2$1@build.eclipse.org">news:gbqe2g$sf2$1@build.ecli=
pse.org</A>...</DIV>
<DIV><FONT face=3DArial =
size=3D2></FONT> </DIV></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_0009_01C922E1.BADEA830--
Re: Extending/overriding the generated EMF model [message #423551 is a reply to message #423405] |
Thu, 02 October 2008 03:36  |
Hi Bob
In case you haven't already read it I thought you might be interested in
this article:
http://apps.itemis.de/roller/itemislabkiel/entry/eclipse_mod eling_framework_emf_adding.
--knut
> Thanks
> Bob.
> "Ed Merks" <Ed.Merks@gmail.com <mailto:Ed.Merks@gmail.com>> wrote in
> message news:gbqe2g$sf2$1@build.eclipse.org...
Current Time: Sun Jul 20 16:13:05 EDT 2025
Powered by FUDForum. Page generated in 0.03736 seconds
