Home » Modeling » EMF » [teneo] one-to-many mapping bug?
[teneo] one-to-many mapping bug? [message #423513] |
Wed, 01 October 2008 12:12  |
I have a problem mapping a non-containment one-to-many relationship the
way I want.
In the library example and using Teneo 1.0.0 I would like to map the
Writer.books reference (with opposite Book.author) as a column BOOK.AUTHOR
without any additional index column or any join table.
To do this I checked that the Writer.books reference is set to
ordered=false and set the JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS option
to false (the default is true although the Javadoc in PersistenceOptions
claims the opposite).
The problem I have is that I both get a column BOOK.AUTHOR and a column
BOOK.BOOK_AUTHOR. Can you confirm that this is a bug? Is this possibly
already fixed in CVS HEAD?
I found a working workaround by adding a @JoinColumn(name="AUTHOR")
annotation to the Writer.books reference. If I want to specify a different
column name, let's say AUTHOR_ID, I have to add a corresponding and
matching @JoinColumn to both references.
Knut Wannheden
Re: [teneo] one-to-many mapping bug? [message #423515 is a reply to message #423513] |
Wed, 01 October 2008 12:39   |
Hi Knut,
I have a testcase (using a list though and not a bag) which shows the correct behavior (one column
on the many side). Can you post the ecore then I can try myself with your model?
The error in the javadoc has been corrected in cvs, thanks for pointing that out.
gr. Martin
Knut Wannheden wrote:
> way I want.
> BOOK.AUTHOR without any additional index column or any join table.
> option to false (the default is true although the Javadoc in
> PersistenceOptions claims the opposite).
> different column name, let's say AUTHOR_ID, I have to add a
> corresponding and matching @JoinColumn to both references.
> Regards,
> Knut Wannheden
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] one-to-many mapping bug? [message #423553 is a reply to message #423550] |
Thu, 02 October 2008 03:57   |
Hi Knut,
See my other comments inline.
gr. Martin
> Hi Martin,
> After some more experimenting I found what causes the problem. It's the
> combination of using JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS="false"
> and JOIN_COLUMN_NAMING_STRATEGY="simple". The same problem occurs
> whether the reference is ordered or not (list or bag). I've included the
> Ecore model below (it is the EMF library model without any alterations).
MT>> Can you file a bugzilla for this?
> I have a few more remarks and questions on this topic:
> 1. IMHO "false" would have been a more sensible default for
> JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS as it would then still be
> possible to force the use of a join table by setting the reference to
> non-unique or using a corresponding annotation. With the option set to
> "true" it is impossible to not get a join table.
MT>> Yes it was false before, but I noticed with more complex models that not using join tables
resulted in name clashes when join columns are created. This can happen with models with inheritance
and mappedsuperclass (and multiple inheritance). These name clashes are very difficult to find and
analyse (models are large, no exception is thrown but your lists contain wrong values) and in the
end the naming conflict was not solvable in an automatic way. Generating names for joincolumns is a
more complex thing then it seems at first because the naming logic needs to remain stable (always
generate the same name for the same thing) also when the model changes.
Therefore the options are currently set to the safest values when using Teneo out-of-the-box.
> 2. Is there the possibility of specifying my own
> JOIN_COLUMN_NAMING_STRATEGY? I'd like something like "simple" but with
> an "_ID" suffix.
MT>> You can implement your own SQLNameStrategy (or extend a current one) and then set the class to
be used by Teneo as follows:
dataStore.getExtensionManager().registerExtension(SQLNameStr ategy.class.getName(),
MyNamingStrategy.class.getName());
before calling dataStore.initialize()
> 3. Also with the default naming strategy ("unique") I cannot simply
> change the name of the Book.author reference using a @JoinColumn
> annotation. Then I also end up with two join columns. Replace the
> reference with the following if you'd like to test that.
MT>> Hmm this seems to be wrong, can you file a bugzilla for this?
> <eStructuralFeatures xsi:type="ecore:EReference" name="author"
> lowerBound="1"
> eType="#//Writer" eOpposite="#//Writer/books">
> <eAnnotations source="teneo.jpa">
> <details key="appinfo"
> value="@JoinColumn(name="AUTHOR_ID")"/>
> </eAnnotations>
> </eStructuralFeatures>
> Here's the complete Ecore model:
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="library"
> nsURI="http://www.example.eclipse.org/Library" nsPrefix="library">
> <eClassifiers xsi:type="ecore:EClass" name="Book">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="title"
> lowerBound="1" eType="ecore:EDataType
> http://www.eclipse.org/emf/2003/XMLType#//String"/>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="pages"
> http://www.eclipse.org/emf/2003/XMLType#//Int"
> unsettable="true"/>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="category"
> lowerBound="1"
> eType="#//BookCategory" unsettable="true"/>
> lowerBound="1"
> eType="#//Writer" eOpposite="#//Writer/books"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EEnum" name="BookCategory">
> <eLiterals name="Mystery"/>
> <eLiterals name="ScienceFiction" value="1"/>
> <eLiterals name="Biography" value="2"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Library">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
> <eStructuralFeatures xsi:type="ecore:EReference" name="writers"
> upperBound="-1"
> eType="#//Writer" containment="true" resolveProxies="false"/>
> <eStructuralFeatures xsi:type="ecore:EReference" name="books"
> upperBound="-1"
> eType="#//Book" containment="true" resolveProxies="false"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Writer">
> upperBound="-1"
> eType="#//Book" eOpposite="#//Book/author"/>
> </eClassifiers>
> </ecore:EPackage>
> Regards,
> --knut
> Martin Taal wrote:
>> Hi Knut,
>> correct behavior (one column on the many side). Can you post the ecore
>> pointing that out.
>> gr. Martin
>>> Hi,
>>> the way I want.
>>> column BOOK.BOOK_AUTHOR. Can you confirm that this is a bug? Is this
>>> possibly already fixed in CVS HEAD?
>>> Regards,
>>> Knut Wannheden
The Netherlands
Re: [teneo] one-to-many mapping bug? [message #423555 is a reply to message #423553] |
Thu, 02 October 2008 04:04   |
Hi Martin,
Martin Taal wrote:
> Hi Knut,
> gr. Martin
>> Hi Martin,
>> the combination of using
>> JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS="false" and
>> JOIN_COLUMN_NAMING_STRATEGY="simple". The same problem occurs whether
>> the reference is ordered or not (list or bag). I've included the Ecore
OK. I will include the details of point 3 below as I think it is really
the same issue, just that it's more prominent using the "simple" naming
strategy.
> that not using join tables resulted in name clashes when join columns
> are created. This can happen with models with inheritance and
> difficult to find and analyse (models are large, no exception is thrown
> but your lists contain wrong values) and in the end the naming conflict
> is a more complex thing then it seems at first because the naming logic
> needs to remain stable (always generate the same name for the same
OK, makes perfectly sense.
>> an "_ID" suffix.
> one) and then set the class to be used by Teneo as follows:
Excellent!
--knut
Re: [teneo] one-to-many mapping bug? [message #423557 is a reply to message #423555] |
Thu, 02 October 2008 04:28  |
Hi Martin,
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=249440.
--knut
> Hi Martin,
> Martin Taal wrote:
>> Hi Knut,
>> gr. Martin
>>> Hi Martin,
> strategy.
>>> to "true" it is impossible to not get a join table.
>> very difficult to find and analyse (models are large, no exception is
>> thrown but your lists contain wrong values) and in the end the naming
>> joincolumns is a more complex thing then it seems at first because the
>> naming logic needs to remain stable (always generate the same name for
>>> with an "_ID" suffix.
> Excellent!
> Regards,
> --knut
Current Time: Sat Jul 19 10:53:42 EDT 2025
Powered by FUDForum. Page generated in 0.14429 seconds
