[CDO] maybe some mistakes about CDO and Teneo [message #423502] |
Wed, 01 October 2008 10:39  |
I already have experienced CDO using my meta model and sharing them with
CDO using the default CDO tutorial and ui.
I configure my server to work with a db store and MySQL database. But
when i launch my prototype I'm surprised that it's not only references
to my models that are stored in my database but all my model
I thought that was the teneo job to do a mapping between attributes
models and tables
So am I using Teneo implicitly ? or it's not the good way to use CDO and
i have to configure Teneo and adapt my code to store models in base ?
Re: [CDO] maybe some mistakes about CDO and Teneo [message #423507 is a reply to message #423505] |
Wed, 01 October 2008 11:17   |
The benefit of Teneo over the standard CDO DBStore is that you have much more control on how your
model is mapped to the database, for example on topics such as naming of tables and columns, where
the foreign keys are placed, join tables (or not), handling of different inheritance mapping
strategies (incl. mappedsuperclass), etc. Teneo does a good job by generating a default mapping and
you can control many things by options or in even more detail by adding JPA annotations to your model.
Maybe Eike can add/complement my remarks (I don't know DBStore that well).
gr. Martin
Tristan FAURE wrote:
> Sory my not very fluent english
> In my mind :
> - to store models in database (OR mapping) we need teneo.
> - to have a server managing model sharing we need CDO
> but it seems i think wrong because my database (with dbstore) contains
> my model entities and it seems there is a OR mapping (i've a table for
> each EClass).
> So I don't see Teneo and HibernateStore configuration benefits.
> I hope it's more clear :/
> Eike Stepper a écrit :
>> Tristan FAURE schrieb:
>>> Hi
>>> with CDO using the default CDO tutorial and ui.
>> Well done! ;-)
>>> references to my models that are stored in my database but all my model
>> Could you please rephrase this sentence. I don't understand what you
>> want to point out...
>>> models and tables
>> If it's true that you properly configured a DBStore (and not the
>> HibernateStore) for your repository, then no ;-)
>>> or it's not the good way to use CDO and i have to configure Teneo and
>> What do you mean by "store models in base"?
>> Maybe your problem becomes clearer for me if you try to explain it in
>> other words.
>> Cheers
>> /Eike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] maybe some mistakes about CDO and Teneo [message #423511 is a reply to message #423510] |
Wed, 01 October 2008 11:39  |
> OK !
> Both of your answers clarify me some aspects of the architecture
> I thank you a lot, every day I'm more surprised about EMF complexity
> and richness
Me, too ;-)
>> No problem, I just have to ask ;-)
>>> In my mind :
>>> contains my model entities and it seems there is a OR mapping (i've
>>> a table for each EClass).
>> CDO is a 2+ tier framework for distributed shared models and it
>> always includes some flavour of persistence (ok, with the exception
>> of the MEMStore). This persistence can be backed by arbitrary
>> backends for which you need a backend adapter in form of an IStore
>> implementation. Currently we support two types of backends, JDBC
>> connections to a relational database and Hibernate session factories
>> (itself probaly backed by a JDBC connection). These two types handle
>> the O/R mapping differently. Further CDO does not mandate relational
>> backends. The upcoming ObjectivityStore will be an example for
>> non-relational persistence.
>> In the case of the HibernateStore only Hibernate is responsible for
>> the mapping and this mapping can be controlled by a mapping that is
>> annotated to the Ecore model or generated automatically (and only
>> this part is what Teneo is used for). Questions to this part of CDO
>> and Teneo should best be answered by Martin ;-)
>> If you're using Teneo without CDO you'll probably end up in a 2 tier
>> architecture (at least if your client is not a web application).
>> I know that these architectural aspects are sometimes a bit confusing
>> due to the flexibility we thought we should add to framework. Did
>> this answer your question?
>> Cheers
>> /Eike
>>>>> Hi
>>>>> them with CDO using the default CDO tutorial and ui.
>>>> Well done! ;-)
>>>>> But when i launch my prototype I'm surprised that it's not only
>>>>> model
>>>> you want to point out...
>>>>> attributes models and tables
>>>> in other words.
>>>> Cheers
>>>> /Eike
FUDForum. Page generated in 0.04559 seconds
