Home » Modeling » EMF » Date attribute in Ecore model
Date attribute in Ecore model [message #423494] Wed, 01 October 2008 08:17 Go to next message
I have an Ecore model that includes an attribute with the type
Date. As part of the early stages of my development, I've generated
the model, edit and editor code for this model. Now when I run the
editor code to create an instance of the model the status bar for the
editor shows 'WrappedException : java.text.ParseException:
Unparsable date: "Tuesday, April 12, 1952"'
Does anyone know if a date can be set via the properties field of
the editor, or do I need to wait until I integrate my model into a more
complete environment before I can set the value of a date attribute?
thanks
Andy.
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
Re: Date attribute in Ecore model [message #423495 is a reply to message #423494] Wed, 01 October 2008 08:33 Go to previous messageGo to next message
Andy,
Comments below.
Did you use Ecore's EDate data type? It looks like maybe you defined
your own EDataType and then didn't specialize the XyzFactoryImpl's
createAbcFromString/convertAbcToString for that data type.
It really comes down to what data type you are using to support your
string round tripping..
> thanks
> Andy.
Re: Date attribute in Ecore model [message #423500 is a reply to message #423495] Wed, 01 October 2008 09:45 Go to previous messageGo to next message
Ed,
Comments below
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gbvqml$vfo$1@build.eclipse.org...
> Andy,
> Comments below.
I used Date in my Emfatic model which appears to have been
mapped to EDate in the resource used to generate the EMF model.
The XyzFactoryImpl contains no 'date' type.
>> thanks
>> Andy.
Re: Date attribute in Ecore model [message #423509 is a reply to message #423500] Wed, 01 October 2008 11:32 Go to previous messageGo to next message
--------------000604000903070200070405
Andy,
In that case, you need to conform to how EDate serializes dates. These
XML Schema-style formats are supported:
protected static final DateFormat [] EDATE_FORMATS =
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSSZ"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSS"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm"),
new SafeSimpleDateFormat("yyyy-MM-dd")
> Ed,
> Comments below
>> Andy,
>> Comments below.
>>> thanks
>>> Andy.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Andy,<br>
<br>
In that case, you need to conform to how EDate serializes dates.&nbsp; These
XML Schema-style formats are supported:<br>
<blockquote><small>&nbsp; protected static final DateFormat [] EDATE_FORMATS
= </small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSSZ"),</small ><br>
<small>&nbsp;&nbsp;&nbsp; new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSS"),</small ><br>
<small>&nbsp;&nbsp;&nbsp; new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss"),</small><br >
<small>&nbsp;&nbsp;&nbsp; new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm"),</small><br>
<small>&nbsp;&nbsp;&nbsp; new SafeSimpleDateFormat("yyyy-MM-dd")</small><br>
<small>&nbsp; };</small><br>
</blockquote>
<br>
<blockquote cite="mid:gbvvaq$7ip$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
Comments below
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:gbvqml$vfo$1@build.eclipse.org">news:gbvqml$vfo$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Andy,
Comments below.
</pre>
<pre wrap="">I have an Ecore model that includes an attribute with the type
</pre>
</blockquote>
<pre wrap="">Did you use Ecore's EDate data type? It looks like maybe you defined
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">Does anyone know if a date can be set via the properties field of
</pre>
</blockquote>
<pre wrap="">It really comes down to what data type you are using to support your
</pre>
<pre wrap=""> thanks
Andy.
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------000604000903070200070405--
Re: Date attribute in Ecore model [message #423512 is a reply to message #423509] Wed, 01 October 2008 11:49 Go to previous message
Ed,
Thanks, that enabled me to enter a value.
Andy.
news:gc0561$8sq$1@build.eclipse.org...
> Andy,
>> Ed,
>> Comments below
>>> Andy,
>>> Comments below.
>>>> thanks
>>>> Andy.
Previous Topic:[CDO] maybe some mistakes about CDO and Teneo
Next Topic:[CDO] NOOP store problems
Current Time: Sat Jul 19 21:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.11778 seconds
