Home » Modeling » EMF » EMF and JET generating a new package.
EMF and JET generating a new package. [message #423393] Mon, 29 September 2008 15:43 Go to next message
Hi all,
I am currently experimenting with Jet and EMF. I want to generate another
package and other files with ecore and genmodel files. There is an example
of what I am trying to do :
ca.home.impl
HomeFactoryImpl.java
HomeImpl.java
HomePackageImpl.java
ca.home.util
HomeAdapterFactory.java
HomeSwitch.java
ca.home.proxy //this is the new package
HomeProxy.java //This is the new file
Home.java
HomeFactory.java
HomePackage.java
I can create a Proxy.javajet. I don't how exactly I can do this.
I tryed to create an Action that is place in the context menu of The
genmodel Editor. This is the code :
GenModel genModel = null;
GenClass gc = null;
if (s instanceof StructuredSelection)
StructuredSelection selection = (StructuredSelection)s;
Iterator<?> iterator = selection.iterator();
while (iterator.hasNext()) {
Object obj = iterator.next();
if (obj instanceof GenModel)
genModel = (GenModel) obj;
else if (obj instanceof GenClass)
gc = (GenClass) obj;
if (genModel == null && gc==null)
return;
if (gc==null)
gc = genModel.createGenClass();
String uri ="platform:/plugin/mypluggin/templates/model/Proxy.javajet";
JETEmitter emitter = new JETEmitter( uri,getClass().getClassLoader() );
Object[] arg = {gc};
String result = "";
try {
result = emitter.generate( new NullProgressMonitor(), arg );
} catch (JETException e) {
e.printStackTrace();
System.out.println(result);
But It doesn't display anything because it Doesn't like the import in the
first line of Proxy.javajet. For now, the first line of Proxy.javajet is the
same as Class.javajet.
This is the Proxy.javajet :
<%@ jet package="org.eclipse.emf.codegen.ecore.templates.model"
imports="java.util.* org.eclipse.emf.codegen.ecore.genmodel.*" class="Class"
version="$Id: Class.javajet,v 1.75 2008/05/20 14:39:35 emerks Exp $" %>
Hello world.
Why if I remove the "org.eclipse.emf.codegen.ecore.genmodel.*" it print
"Hello world."? In my run configuration, I selected the
"org.eclipse.emf.codegen.ecore" plugin.
What is the best solution to create my Proxy package?
Thanks in adavance,
Marc
Re: EMF and JET generating a new package. [message #423395 is a reply to message #423393] Mon, 29 September 2008 16:09 Go to previous message
Marc,
Comments below.
Marc Gendron wrote:
> Hi all,
You've looked at the Generator Extension example? You can create the
example project (File->New->Example...) your workspace if you have the
EMF SDK installed.
> ca.home.impl
> HomeImpl.java
> ca.home.util
> HomeSwitch.java
> Home.java
> HomeFactory.java
> HomePackage.java
> GenClass gc = null;
> return;
> if (gc==null)
> String result = "";
> try {
> Hello world.
> Thanks in adavance,
> Marc
Previous Topic:EMF + API Tools
Next Topic:Handling Resource moves in Workspace
Current Time: Sun Jul 20 08:43:59 EDT 2025
Powered by FUDForum. Page generated in 0.02630 seconds
