[CDO] using the query interface [message #423342] |
Mon, 29 September 2008 06:20  |
over the weekend I thought about ways to speed up my application.
One of the features of CDO is that it can load only the parts of a model
which are needed. However at the same time every access to a non-cached
object results in a DB query. I thought, I could speed up the process of
reading a larger part of a model by pre-caching it. E.g. if there was a
way to load an CDO object from the database and all of its containments
(children) up to a certain depth (IOW the object O and off of
O.getCildren() and all of O.getChildren().each { c -> c.getChildren() }
, I could pre-load a complete tree in one operation.
Then I came in this morning and I thought, well, there once was a
proposal for a CDO query feature and I found out that the bug is closed
already.
So,
1. Is the CDO query interface usable?
2. Which query language do you support?
3. Is the native mysql DBStore supported?
4. Does one query really lead to one DB-select operation (i.e. is the
query translated to SQL and executed at DB level) or is the query
evaluated and executed at the CDO server resulting in single
DB-operations for reading revisions one by one?
Thaks in advance for your answers!
Stefan
Re: [CDO] using the query interface [message #423355 is a reply to message #423342] |
Mon, 29 September 2008 08:38   |
Stefan Winkler schrieb:
> model which are needed. However at the same time every access to a
> non-cached object results in a DB query. I thought, I could speed up
> the process of reading a larger part of a model by pre-caching it.
> E.g. if there was a way to load an CDO object from the database and
> all of its containments (children) up to a certain depth (IOW the
> object O and off of O.getCildren() and all of O.getChildren().each { c
> -> c.getChildren() } , I could pre-load a complete tree in one operation.
You might also want to look at some other new features to optimize the
characteristics. Have a look at the attached document in:
245654: Provide a "Tweak Performance" tutorial
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245654
Maybe you're able to develop (and contribute?) a special
CDOFeatureAnalyzer...
> closed already.
> So,
If I take the question as it's written, I'd say yes. The API is new but
carefully chosen. But you'll have to provide a query language name that
is implemented either by the backend store (i.e. IStore of CDO) or the
repository itself. And currently only a test language is supported by
the MEMStore and a simple "query resources" language by all
repositories. In other words, the query feature is an extensible
framework rather than a complete set of implemented query languages. It
provides simple service provider interfaces for developers of backend
query languages or repository-level query languages (including an
extension point), as well as a convenient client API to work with
synchronous and asynchronous queries.
See above. We are looking for help with the implementation of additional
query languages. There are currently three obvious ones on the wish list:
244169: [Hibernate] Store to support Query (HQL)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244169
248933: [DB] Support SQL as a CDOQuery language
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248933
245658: [Query] Provide OCL query language
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245658
See above.
It's left completely to the backend query language implementor how a
query translates into backend primitives. Since repository-level queries
are expected to run against the server-side RevisionManager it's likely
that they will not be optimized for certain backend types. If SQL was
provided as a DBStore-level query language I don't see a problem in
backing a query by a single SQL statement.
Cheers
/Eike
> Cheers,
> Stefan
Re: [CDO] using the query interface [message #423653 is a reply to message #423417] |
Sat, 04 October 2008 12:15  |
Hi Eike,
against all odds I was able to find some time (and a good idea).
So please have a look at Bug 249681 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249681 ).
Stefan
>> Hi,
>>>> Anyway, do you want an enhancement request filed? "Support fetching
>>>> of multiple revisions at once in IStoreReader"?
>>> I think it would make sense to discuss if the protocol between
>>> RevisionManager and IStoreReader can be optimized in general (still
>>> with respect to reading multiple revisions at once). But I doubt that
>>> the DBSore with its horizontal mapping strategy will particularly
>>> benefit from it. Would you like to come up with a contribution for
>>> all this?
>> I feared you would ask for this ..
>> Like? yes
>> Have time? regretfully no :-( - at least not right now :-(
> I feared you would say for this .. ;-)
> Cheers
> /Eike
FUDForum. Page generated in 0.04611 seconds
