Home » Modeling » EMF » [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176821)
[Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176821) [message #423339] Mon, 29 September 2008 03:00 Go to next message
I just tried adding a comment to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=176821 but bugzilla seems to
be broken. I get an error saying "A Legal Version was not set"
So I'll post it as a news item instead for now
The issue relates to teneo adding id and version fields to subclass
elements which does not comply with the hibernate schema. The comment was
This is still an issue for me. A large part of our ecore models originates
from industry XSD's which have used ID fields in the schema on sub types.
e.g. they might have a Date base type and an IdentifiedDate subtype that
adds an ID field so they can create IDREF fields to point to them. i.e.
they introduce ID fields in subtypes specifically so those subtypes can be
the target of IDREF's elsewhere. I'm not sure why they subtyped for this
reason.
As these are ID fields in XSD they come into ecore as ID fields and cause
this problem in teneo.
Sure I would be inclined to avoid doing this in my own models but I don't
have any control over these industry schema's
Couldn't teneo have a rule that if an ID field appears on a subtype then
simply add the field as a unique property rather than an ID field.
e.g.
<property name="id" lazy="false" insert="true" update="true"
not-null="false" unique="true" type="java.lang.String">
<column not-null="false" unique="false" name="`false`"/>
</property>
Turning ID fields off on the whole model with the option is not desirable
either as in general I'd like it to use my ID fields as PK's when they are
there on the base class.
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176821) [message #423344 is a reply to message #423339] Mon, 29 September 2008 06:33 Go to previous messageGo to next message
Hi Andrew,
Would the following approach work in your case:
- Annote the id-fields in the supertypes/root of the hierarchy with @Id, and
- set the option: PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY to false
gr. Martin
> to be broken. I get an error saying "A Legal Version was not set"
> originates from industry XSD's which have used ID fields in the schema
> on sub types. e.g. they might have a Date base type and an
> IdentifiedDate subtype that adds an ID field so they can create IDREF
> fields to point to them. i.e. they introduce ID fields in subtypes
> specifically so those subtypes can be the target of IDREF's elsewhere.
> I'm not sure why they subtyped for this reason.
> cause this problem in teneo.
> don't have any control over these industry schema's
> e.g. <property name="id" lazy="false" insert="true" update="true"
> </property>
> desirable either as in general I'd like it to use my ID fields as PK's
> when they are there on the base class.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423406 is a reply to message #423344] Mon, 29 September 2008 21:00 Go to previous messageGo to next message
Hi Martin
There are a few problems with this
1/ The models have come from industry standard schemas. We are trying to
avoid any manual changes to the models at this stage. At this stage we are
relying on purely automatic and essentially cosmetic refactoring of the
model (e.g. breaking it up into separate packages and moving classes
around a bit, but no changes to the actual classes themselves). The
reasons for this is that the model is so large it will take us a while to
understand it well enough to consider altering it and secondly we will
always need to maintain compatibility with it so the more we alter it the
more we will need custom transformations to import / export to the
standard.
2/ The base types don't have id fields in this case. Teneo is generating
the eId fields for these.
3/ Setting PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY to false means
that we will lose this feature for our own models. For our hand written
models we will (and have) made use of id fields on our base classes. We
like that teneo generates id elements for these.
The problem really stems from two issues
i/ The industry XSD's are using id's for an XML oriented technique for
referring to elements that are not child elements of the current element.
i.e. they are not considering the impact this has on an implementation
model such as ecore and the ramifications for persistence. i.e. from the
XSD point of view adding id fields to sub types is not an issue.
ii/ Teneo has a mapping bug in this case. Even if it is something best
avoided in an ecore model, its still the case that Teneo creates a
hibernate mapping that does not conform to the hibernate XSD. Surely that
should not happen. At the worst case it should throw an exception but I
still think that generating a unique property is the best answer. Is this
not possible / desirable?
Another possible avenue for us is if we can customise the mapping from XSD
such that the field remains an ID field in XML but is not an ID field in
ecore. I'm not sure if this is possible?
regards
Andrew
Martin Taal wrote:
> Hi Andrew,
> gr. Martin
>> </property>
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423407 is a reply to message #423406] Tue, 30 September 2008 00:10 Go to previous messageGo to next message
Hi Andrew,
Okay, I will change it so that an ID efeature in a subtype is ignored (and a warning is logged).
Can you enter a new bugzilla or reopen the old one for this?
gr. Martin
Andrew H wrote:
> Hi Martin
> are relying on purely automatic and essentially cosmetic refactoring of
> the model (e.g. breaking it up into separate packages and moving classes
> to understand it well enough to consider altering it and secondly we
> will always need to maintain compatibility with it so the more we alter
> it the more we will need custom transformations to import / export to
> the standard.
> element. i.e. they are not considering the impact this has on an
> implementation model such as ecore and the ramifications for
> persistence. i.e. from the XSD point of view adding id fields to sub
> that should not happen. At the worst case it should throw an exception
> but I still think that generating a unique property is the best answer.
> Is this not possible / desirable?
> XSD such that the field remains an ID field in XML but is not an ID
> field in ecore. I'm not sure if this is possible?
> regards
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> @Id, and
>> gr. Martin
>>> seems to be broken. I get an error saying "A Legal Version was not set"
>>> was
>>> schema on sub types. e.g. they might have a Date base type and an
>>> elsewhere. I'm not sure why they subtyped for this reason.
>>> then simply add the field as a unique property rather than an ID field.
>>> </property>
>>> PK's when they are there on the base class.
The Netherlands
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423409 is a reply to message #423407] Tue, 30 September 2008 03:51 Go to previous messageGo to next message
Thanks Martin
Appreciate this.
Unfortunately, I can't get bugzilla to work. I get
Bugzilla has suffered an internal error. Please save this page and send it
to webmaster@eclipse.org with details of what you were doing at the time
this message appeared.
URL: https://bugs.eclipse.org/bugs/post_bug.cgi
A legal Version was not set.
cheers
Andrew
Martin Taal wrote:
> Hi Andrew,
warning is logged).
> gr. Martin
> Andrew H wrote:
>> Hi Martin
>> the standard.
>> regards
>> Andrew
>> Martin Taal wrote:
>>> Hi Andrew,
>>> @Id, and
>>> gr. Martin
>>>> was
>>>> </property>
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423410 is a reply to message #423409] Tue, 30 September 2008 04:02 Go to previous messageGo to next message
You also get this when entering a new bugzilla?
gr. Martin
Andrew H wrote:
> Thanks Martin
> Appreciate this.
> it to webmaster@eclipse.org with details of what you were doing at the
> time this message appeared.
> cheers
> Andrew
> Martin Taal wrote:
>> Hi Andrew,
>> (and a
> warning is logged).
>> gr. Martin
>> Andrew H wrote:
>>> Hi Martin
>>> to avoid any manual changes to the models at this stage. At this
>>> stage we are relying on purely automatic and essentially cosmetic
>>> refactoring of the model (e.g. breaking it up into separate packages
>>> and moving classes around a bit, but no changes to the actual classes
>>> themselves). The reasons for this is that the model is so large it
>>> will take us a while to understand it well enough to consider
>>> altering it and secondly we will always need to maintain
>>> compatibility with it so the more we alter it the more we will need
>>> custom transformations to import / export to the standard.
>>> generating the eId fields for these.
>>> means that we will lose this feature for our own models. For our hand
>>> written models we will (and have) made use of id fields on our base
>>> classes. We like that teneo generates id elements for these.
>>> for referring to elements that are not child elements of the current
>>> best avoided in an ecore model, its still the case that Teneo creates
>>> a hibernate mapping that does not conform to the hibernate XSD.
>>> Surely that should not happen. At the worst case it should throw an
>>> exception but I still think that generating a unique property is the
>>> best answer. Is this not possible / desirable?
>>> from XSD such that the field remains an ID field in XML but is not an
>>> ID field in ecore. I'm not sure if this is possible?
>>> regards
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> @Id, and
>>>> gr. Martin
>>>>> set"
>>>>> comment was
>>>>> IDREF fields to point to them. i.e. they introduce ID fields in
>>>>> subtypes specifically so those subtypes can be the target of
>>>>> IDREF's elsewhere. I'm not sure why they subtyped for this reason.
>>>>> field.
>>>>> </property>
The Netherlands
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423544 is a reply to message #423410] Wed, 01 October 2008 19:57 Go to previous messageGo to next message
Strange, I replied to this yesterday but it seems to have been lost.
I was able to create a new bugzilla when I did it from scratch rather than
trying to clone the other issue. Issue is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249246
Note, however, that after I filed this I progressed my persistence code
further and realised that the ID fields that originate from the XSD's are
not suitable as primary keys in the database. They are only intended to be
unique within a single document.
So in the end I used the option you suggested to turn off generation of
primary key fields for these fields.
Consequently, getting a fix for this is no longer a priority for us.
Apologies for the noise. Let me know if you want me to shut the issue down.
I'd be interested in Ed and others thoughts on ID fields. EMF seems to
default XSD ID fields to ID fields in EMF and Teneo then defaults to
setting these as the primary keys. I'm not clear on whether turning this
off in teneo is the right approach or whether I should look to turn it off
in EMF. i.e. are ID fields in EMF supposed to be effectively primary keys
for that class? If so then the mapping from XSD ID is questionable
cheers
Andrew
> gr. Martin
> Andrew H wrote:
>> Thanks Martin
>> Appreciate this.
>> cheers
>> Andrew
>> Martin Taal wrote:
>>> Hi Andrew,
>>> (and a
>> warning is logged).
>>> gr. Martin
>>> Andrew H wrote:
>>>> Hi Martin
>>>> regards
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Andrew,
>>>>> @Id, and
>>>>> gr. Martin
>>>>>> set"
>>>>>> comment was
>>>>>> field.
>>>>>> </property>
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423558 is a reply to message #423544] Thu, 02 October 2008 05:00 Go to previous messageGo to next message
Hi Andrew,
Thanks for reporting back. I will keep the bugzilla for now because it can make sense to be a bit
more lenient when the subtype has an ID field.
gr. Martin
> than trying to clone the other issue. Issue is
> are not suitable as primary keys in the database. They are only intended
> to be unique within a single document.
> off in EMF. i.e. are ID fields in EMF supposed to be effectively primary
> keys for that class? If so then the mapping from XSD ID is questionable
> cheers
> Andrew
>> gr. Martin
>> Andrew H wrote:
>>> Thanks Martin
>>> Appreciate this.
>>> send it to webmaster@eclipse.org with details of what you were doing
>>> at the time this message appeared.
>>> cheers
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> ignored (and a
>>> warning is logged).
>>>> gr. Martin
>>>> Andrew H wrote:
>>>>> Hi Martin
>>>>> trying to avoid any manual changes to the models at this stage. At
>>>>> this stage we are relying on purely automatic and essentially
>>>>> cosmetic refactoring of the model (e.g. breaking it up into
>>>>> separate packages and moving classes around a bit, but no changes
>>>>> to the actual classes themselves). The reasons for this is that the
>>>>> model is so large it will take us a while to understand it well
>>>>> enough to consider altering it and secondly we will always need to
>>>>> maintain compatibility with it so the more we alter it the more we
>>>>> will need custom transformations to import / export to the standard.
>>>>> hand written models we will (and have) made use of id fields on our
>>>>> base classes. We like that teneo generates id elements for these.
>>>>> current element. i.e. they are not considering the impact this has
>>>>> on an implementation model such as ecore and the ramifications for
>>>>> creates a hibernate mapping that does not conform to the hibernate
>>>>> XSD. Surely that should not happen. At the worst case it should
>>>>> throw an exception but I still think that generating a unique
>>>>> property is the best answer. Is this not possible / desirable?
>>>>> an ID field in ecore. I'm not sure if this is possible?
>>>>> regards
>>>>> Andrew
>>>>> Martin Taal wrote:
>>>>>> Hi Andrew,
>>>>>> with @Id, and
>>>>>> false
>>>>>> gr. Martin
>>>>>>> not set"
>>>>>>> subclass elements which does not comply with the hibernate
>>>>>>> and cause this problem in teneo.
>>>>>>> I don't have any control over these industry schema's
>>>>>>> subtype then simply add the field as a unique property rather
>>>>>>> than an ID field.
>>>>>>> </property>
The Netherlands
Re: [Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176 [message #423611 is a reply to message #423558] Thu, 02 October 2008 19:50 Go to previous message
Thanks Martin
I agree its best not to have cases where it produces mappings that don't
comply to the schema.
Martin Taal wrote:
> Hi Andrew,
> gr. Martin
>> cheers
>> Andrew
>>> gr. Martin
>>> Andrew H wrote:
>>>> Thanks Martin
>>>> Appreciate this.
>>>> cheers
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Andrew,
>>>>> ignored (and a
>>>> warning is logged).
>>>>> gr. Martin
>>>>> Andrew H wrote:
>>>>>> Hi Martin
>>>>>> regards
>>>>>> Andrew
>>>>>> Martin Taal wrote:
>>>>>>> Hi Andrew,
>>>>>>> with @Id, and
>>>>>>> false
>>>>>>> gr. Martin
>>>>>>>> not set"
>>>>>>>> than an ID field.
>>>>>>>> </property>
Previous Topic:NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="true"
Next Topic:EMF eclipsecon07 tutorial materials ?
Current Time: Sun Jul 20 10:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.06295 seconds
