Home » Modeling » EMF » limit number (other than 1) of children in an EReference
limit number (other than 1) of children in an EReference [message #423275] |
Thu, 25 September 2008 14:55  |
Is there a way to limit the number (other than 1) of children for an
EReference? I basically have a list in which I would like to limit the
number of children to a maximum of 7.
Setting the lower limit to zero and an upper limit to 1 works fine as
the EMF framework prevents me to add a second child. However, when I
change the upper limit to 7, the EMF framework doesn't prevent me to add
8 or 9 children for example.
Would there be a way to make EMF limit the number of children of an
EReference to a number greater than 1? If so, how would this be possible?
Mircea
Re: limit number (other than 1) of children in an EReference [message #423276 is a reply to message #423275] |
Thu, 25 September 2008 15:05   |
Mircea,
Comments below.
Mircea Luchian wrote:
> Hello,
> add 8 or 9 children for example.
The upper bound affects whether you end up with a single value or a list
of values, which imposes some hard limitations, but other than this, the
multiplicity bounds only result in constraint violations that will be
noticed by Diagnostician.INSTANCE.validate, not in hard limits that
can't ever be violated.
Generally it's a bad idea, in my opinion to add hard limits. Obvious if
you set a lower limit like 2, when the list starts empty, it's already
violating this, so you can't expect things never to be in an invalid
state. Also, consider if you want to replace an element in the list.
You might add an element and then remove another element, so forcing the
steps to be done in a different order is not very intuitive. I'd
recommend that you settle for constraints that are diagnosed when
violated rather then trying to enforce them in the model.
Maybe the child creation could be smarter though, but even that's
questionable...
> Mircea
Re: limit number (other than 1) of children in an EReference [message #423277 is a reply to message #423276] |
Thu, 25 September 2008 16:09  |
Thanks Ed,
It is true that in UML no rules other than 0..1, 0..*, 1 or 1..* exist
and EMF should not be any different. I will perform validation instead.
Mircea
Ed Merks wrote:
> Mircea,
> Comments below.
>> Hello,
>> the number of children to a maximum of 7.
> list of values, which imposes some hard limitations, but other than
> this, the multiplicity bounds only result in constraint violations
> that will be noticed by Diagnostician.INSTANCE.validate, not in hard
> limits that can't ever be violated.
>> possible?
> if you set a lower limit like 2, when the list starts empty, it's
> already violating this, so you can't expect things never to be in an
> invalid state. Also, consider if you want to replace an element in
> the list. You might add an element and then remove another element,
> so forcing the steps to be done in a different order is not very
> intuitive. I'd recommend that you settle for constraints that are
> diagnosed when violated rather then trying to enforce them in the model.
> questionable...
>> Thanks,
>> Mircea
Current Time: Sun Jul 20 13:00:00 EDT 2025
Powered by FUDForum. Page generated in 0.26152 seconds
