Home » Modeling » EMF » Problem loading XMI resource
Problem loading XMI resource [message #423092] Mon, 22 September 2008 18:38 Go to next message
Hi all,
I have an xmi file that I generated from an ecore model using the ecore
model editor from ecplise
with Create dynamic instance.
the xmi file is shown below :
<?xml version="1.0" encoding="ASCII"?>
<bp:Process xmlns:xmi="http://www.omg.org/XMI"
xmlns:bp="ca.uqam.latece.bpc4s" xsi:schemaLocation="ca.uqam.latece.bpc4s
../../../bp.ecore" name="Ordering">
<succession nextStep="//@ownedCoursePart.0" name="Succession0">
<previousStep href="../../resource/shared/changePart/Start.xmi#/"/>
<successorEvent href="../../resource/shared/event/Event_Start.xmi#/"/>
</succession>
<succession previousStep="//@ownedCoursePart.0"
nextStep="//@ownedCoursePart.1" name="Succession1">
<predeccesorEvent
href="../../resource/shared/event/Event_Finish.xmi#/"/>
</succession>
</bp:Process>
This file opens without any problem using the eclipse ecore editor.
When I tried to load the same file using the following code,
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xmi",
new XMIResourceFactoryImpl());
BpPackage.eINSTANCE.eClass();
URI uri = URI.createURI(fileURI ,true);
Resource resource = resourceSet.getResource(uri, true);
It s giving Feature Not found Exception
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'xmi' not
found.
( file:///C:/Doctorat/Dev/eclipse/ws/bpc4s.specializing/bin/re pository/processes/ordering/dynamic.xmi,
2, 211)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at
ca.uqam.latece.bpc4s.specialization.EmfTest.testParseInforma tionalViewReader(EmfTest.java:54)
If I remove xmlns:xmi="http://www.omg.org/XMI", It's giving Feature 'xsi'
not found..
Any help will be appreciated
Re: Problem loading XMI resource [message #423112 is a reply to message #423092] Tue, 23 September 2008 10:03 Go to previous messageGo to next message
Abdel,
Comments below.
Abdel wrote:
> Hi all,
> ecore model editor from ecplise
> xsi:schemaLocation="ca.uqam.latece.bpc4s ./../../bp.ecore"
> name="Ordering">
> </succession>
> <predeccesorEvent
> </succession>
> </bp:Process>
> BpPackage.eINSTANCE.eClass(); URI uri =
> found.
I'd expect what you show should just work, but the error seems to
indicate that you aren't really loading with an XMIResourceImpl...
> 2, 211)
> at
> at
> at
> at
> 'xsi' not found.
This is even stranger since this is a namespace declaration and should
never be treated as a feature. I've never seen that before, so it makes
me think there's something important you've not shown...
> Thanks
Re: Problem loading XMI resource [message #423145 is a reply to message #423112] Tue, 23 September 2008 14:43 Go to previous messageGo to next message
Thanks Ed,
The problem I got, was with the version 2.4.0 of EMF,
when I switched to the version 2.3.2 every thing works fine.
Thank's again.
Re: Problem loading XMI resource [message #423148 is a reply to message #423145] Tue, 23 September 2008 15:31 Go to previous message
Abdel,
Perhaps some configuration issue with how 2.4 is installed? It's not
something I can reproduce nor something anyone else has reported even
though 2.4 has been out for quite a few months...
Abdel wrote:
> Thanks Ed,
> The problem I got, was with the version 2.4.0 of EMF, when I switched
> Thank's again.
Previous Topic:Re: JMerge customization
Next Topic:Problems reloading a new XML schema
Current Time: Sun Jul 20 14:51:48 EDT 2025
Powered by FUDForum. Page generated in 0.30320 seconds
