Home » Modeling » EMF » Overriding operations
Overriding operations [message #422942] |
Fri, 19 September 2008 09:03  |
Originally posted by: NOSPAM-magnus.rundlof.saabgroup.com-NOSPAM
Operations can be overridden in EClasses. However, this only affects the
interfaces of the generated code. I would like a method stub to be generated
for me in the implementation class, in the same way a method stub is
generated in the superclass where the method was originally declared. Is
this possible?
Regards/
Magnus
Re: Overriding operations [message #423045 is a reply to message #422943] |
Mon, 22 September 2008 03:14   |
Hi Christian, thanks for a quick reply!
I usually don't tag methods with the "@generated NOT", since the result
seems the same as not adding the tag at all. However, it might simplify
searching for hand-coded methods.
If I declare an overriding operation in the model I probably want to add
some behaviour to the implementing method. Why would I otherwise model it?
This means that I prefer the method to throw an
UnsupportedOperationException instead of just calling a superclass
implementation. It makes it easier to find unimplemented behaviour and that
was the origin of my question.
Regards/
Magnus
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:gb08ei$c1k$1@build.eclipse.org...
> Hi, Magnus,
> Since you will need to supply an operation body, anyway, and tag it with
> "@generated NOT", you can just create the override in the appropriate impl
> class when you are ready to fill in the body.
> The current code pattern ensures that the superclass implementation will
> be inherited instead of replacing it with an UnsupportedOperationException
> HTH,
> Christian
> Magnus Rundlof wrote:
>> Hi
>> generated for me in the implementation class, in the same way a method
>> stub is generated in the superclass where the method was originally
>> declared. Is this possible?
>> Regards/
>> Magnus
Re: Overriding operations [message #423063 is a reply to message #423045] |
Mon, 22 September 2008 10:57  |
--------------020908090303020208090905
Magnus,
In the last release we changed the algorithm so that if the operation
has a body, it will definitely be generated in the Impl, so you can
generate overrides this way. You can also suppress the visibility of
the operation so it doesn't appear in the interface avoiding redundancy
in the API. And of course if you want a TODO you can make that the
method body, though that seems a bit pointless...
> Regards/
> Magnus
>> Hi, Magnus,
>> HTH,
>> Christian
>>> Hi
>>> Regards/
>>> Magnus
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Magnus,<br>
<br>
method body, though that seems a bit pointless...<br>
<br>
<br>
<blockquote cite="mid:gb7gku$28e$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Christian, thanks for a quick reply!
Regards/
Magnus
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@zeligsoft.com"><cdamus@zeligsoft.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gb08ei$c1k$1@build.eclipse.org">news:gb08ei$c1k$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi, Magnus,
HTH,
Christian
</pre>
<pre wrap="">Hi
Regards/
Magnus
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------020908090303020208090905--
Current Time: Sun Jul 20 12:25:52 EDT 2025
Powered by FUDForum. Page generated in 0.04163 seconds
