CDO Adding a new resource [message #422909] |
Thu, 18 September 2008 10:21  |
Hi guys,
Running a CDO server (version 2.0.0 stable build: ,200809110653) I can
now get our client app to connect and disconnect from the server. I can
also add containered objects without a hitch. However, I keep getting
an error when trying to add a new object that is not containered and
thus needs its own resource.
This is the code I use for the commit operation, where eObject is the
newly created object passed into the method:
if (eObject != null && eObject.eContainingFeature() == null &&
eObject.eResource() == null)
/* Object is not a contained feature */
//Create resource
URI newUri = URI.createURI("cdo:/" + getRepositoryName() + "/TEST");
Resource resource = transaction.getOrCreateResource(newUri.path());
if (resource.getContents().isEmpty())
resource.getContents().add(eObject);
for (Resource res : transaction.getResourceSet().getResources())
System.out.println("Resource in resourceSet: " + res + " URI: "
+ res.getURI());
if (transaction.isDirty())
transaction.commit();
I am able to confirm that the resource is successfully added to the
resource set:
Resource in resourceSet: CDOResource@OID7 URI:
cdo://1ff5d226-b1f0-40fb-aba2-0c31b38c764f/ISSE/CDO3
Resource in resourceSet: CDOResource@oid1 URI:
cdo://1ff5d226-b1f0-40fb-aba2-0c31b38c764f/ISSE/TEST
yet I get the following exception:
class org.eclipse.net4j.util.ImplementationError
Message:Missing ID mapping for oid1
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .remapID(CDORevisionImpl.java:800)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .adjustReferences(CDORevisionImpl.java:440)
org.eclipse.emf.internal.cdo.CDOStateMachine$CommitTransitio n.execute(CDOStateMachine.java:517)
org.eclipse.emf.internal.cdo.CDOStateMachine$CommitTransitio n.execute(CDOStateMachine.java:1)
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:161)
org.eclipse.emf.internal.cdo.CDOStateMachine.commit(CDOState Machine.java:309)
org.eclipse.emf.internal.cdo.CDOTransactionImpl$CDOCommitCon textImpl.postCommit(CDOTransactionImpl.java:986)
org.eclipse.emf.internal.cdo.CDOTransactionImpl$CDOCommitCon textImpl.postCommit(CDOTransactionImpl.java:919)
org.eclipse.emf.internal.cdo.CDOSingleTransactionStrategy.co mmit(CDOSingleTransactionStrategy.java:70)
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:285)
isse.project.impl.RepositoryConnectionImpl.commit(Repository ConnectionImpl.java:291)
isse.model.ModelActionProvider.persistElement(ModelActionPro vider.java:146)
isse.netbeans.framework.IDENode.bridge.IDENodeAdapter.notify Changed(IDENodeAdapter.java:82)
Can anyone give me a pointer please. Oddly enough this was working in
CDO 1.0 so maybe I am missing something vital that is the difference
between the versions.
PGR
Re: CDO Adding a new resource [message #422923 is a reply to message #422920] |
Thu, 18 September 2008 15:23   |
phantomjinx schrieb:
> Eike,
> Sorry, not totally certain what you mean by IStore. However, my
> topology is a CDO server running standalone in an osgi session with a
> derby database backend.
> Not using Hibernate.
> Hope that helps. Any more info or debugging required then let me know.
Yes, complete console dumps of client and server would be very helpful
to track down the problem.
Can you please attach them to a new Bugzilla?
Thx
/Eike
> Regards
> PGR
> Eike Stepper wrote:
>> Hi PGR,
>> Which IStore implementation are you using for your repository? IIRC.
>> only today I saw some tests failing in the HibernateStore with the
>> same exception (but didn't come to it yet)...
>> Cheers
>> /Eike
>>> Hi guys,
>>> can now get our client app to connect and disconnect from the
>>> server. I can also add containered objects without a hitch.
>>> However, I keep getting an error when trying to add a new object
>>> that is not containered and thus needs its own resource.
>>> the newly created object passed into the method:
>>> //Create resource
>>> "/TEST");
>>> Resource resource =
>>> URI: " + res.getURI());
>>> resource set:
>>> in CDO 1.0 so maybe I am missing something vital that is the
>>> difference between the versions.
>>> Regards
>>> PGR
Re: CDO Adding a new resource [message #422925 is a reply to message #422923] |
Thu, 18 September 2008 18:34  |
Bug 247910 submitted.
PGR
>> Eike,
> Thx
> /Eike
>> Regards
>> PGR
>> Eike Stepper wrote:
>>> Hi PGR,
>>> Cheers
>>> /Eike
>>>> Hi guys,
>>>> //Create resource
>>>> "/TEST");
>>>> Resource resource =
>>>> resource set:
>>>> Regards
>>>> PGR
FUDForum. Page generated in 0.04680 seconds
