Home » Modeling » EMF » CDO Adding a new resource
CDO Adding a new resource [message #422909] Thu, 18 September 2008 10:21 Go to next message
Hi guys,
Running a CDO server (version 2.0.0 stable build: ,200809110653) I can
now get our client app to connect and disconnect from the server. I can
also add containered objects without a hitch. However, I keep getting
an error when trying to add a new object that is not containered and
thus needs its own resource.
This is the code I use for the commit operation, where eObject is the
newly created object passed into the method:
if (eObject != null && eObject.eContainingFeature() == null &&
eObject.eResource() == null)
/* Object is not a contained feature */
//Create resource
URI newUri = URI.createURI("cdo:/" + getRepositoryName() + "/TEST");
Resource resource = transaction.getOrCreateResource(newUri.path());
if (resource.getContents().isEmpty())
resource.getContents().add(eObject);
for (Resource res : transaction.getResourceSet().getResources())
System.out.println("Resource in resourceSet: " + res + " URI: "
+ res.getURI());
if (transaction.isDirty())
transaction.commit();
I am able to confirm that the resource is successfully added to the
resource set:
Resource in resourceSet: CDOResource@OID7 URI:
cdo://1ff5d226-b1f0-40fb-aba2-0c31b38c764f/ISSE/CDO3
Resource in resourceSet: CDOResource@oid1 URI:
cdo://1ff5d226-b1f0-40fb-aba2-0c31b38c764f/ISSE/TEST
yet I get the following exception:
class org.eclipse.net4j.util.ImplementationError
Message:Missing ID mapping for oid1
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .remapID(CDORevisionImpl.java:800)
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .adjustReferences(CDORevisionImpl.java:440)
org.eclipse.emf.internal.cdo.CDOStateMachine$CommitTransitio n.execute(CDOStateMachine.java:517)
org.eclipse.emf.internal.cdo.CDOStateMachine$CommitTransitio n.execute(CDOStateMachine.java:1)
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:161)
org.eclipse.emf.internal.cdo.CDOStateMachine.commit(CDOState Machine.java:309)
org.eclipse.emf.internal.cdo.CDOTransactionImpl$CDOCommitCon textImpl.postCommit(CDOTransactionImpl.java:986)
org.eclipse.emf.internal.cdo.CDOTransactionImpl$CDOCommitCon textImpl.postCommit(CDOTransactionImpl.java:919)
org.eclipse.emf.internal.cdo.CDOSingleTransactionStrategy.co mmit(CDOSingleTransactionStrategy.java:70)
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:285)
isse.project.impl.RepositoryConnectionImpl.commit(Repository ConnectionImpl.java:291)
isse.model.ModelActionProvider.persistElement(ModelActionPro vider.java:146)
isse.netbeans.framework.IDENode.bridge.IDENodeAdapter.notify Changed(IDENodeAdapter.java:82)
Can anyone give me a pointer please. Oddly enough this was working in
CDO 1.0 so maybe I am missing something vital that is the difference
between the versions.
PGR
Re: CDO Adding a new resource [message #422913 is a reply to message #422909] Thu, 18 September 2008 10:51 Go to previous messageGo to next message
Hi PGR,
Which IStore implementation are you using for your repository? IIRC.
only today I saw some tests failing in the HibernateStore with the same
exception (but didn't come to it yet)...
Cheers
/Eike
phantomjinx schrieb:
> Hi guys,
> can also add containered objects without a hitch. However, I keep
> getting an error when trying to add a new object that is not
> containered and thus needs its own resource.
> //Create resource
> "/TEST");
> " + res.getURI());
> resource set:
> Regards
> PGR
Re: CDO Adding a new resource [message #422920 is a reply to message #422913] Thu, 18 September 2008 15:18 Go to previous messageGo to next message
Eike,
Sorry, not totally certain what you mean by IStore. However, my topology
is a CDO server running standalone in an osgi session with a derby
database backend.
Not using Hibernate.
Hope that helps. Any more info or debugging required then let me know.
PGR
Eike Stepper wrote:
> Hi PGR,
> Cheers
> /Eike
>> Hi guys,
>> //Create resource
>> "/TEST");
>> " + res.getURI());
>> resource set:
>> Regards
>> PGR
Re: CDO Adding a new resource [message #422923 is a reply to message #422920] Thu, 18 September 2008 15:23 Go to previous messageGo to next message
> Eike,
> topology is a CDO server running standalone in an osgi session with a
> derby database backend.
Yes, complete console dumps of client and server would be very helpful
to track down the problem.
Can you please attach them to a new Bugzilla?
Thx
/Eike
> Regards
> PGR
> Eike Stepper wrote:
>> Hi PGR,
>> same exception (but didn't come to it yet)...
>> Cheers
>> /Eike
>>> Hi guys,
>>> can now get our client app to connect and disconnect from the
>>> server. I can also add containered objects without a hitch.
>>> However, I keep getting an error when trying to add a new object
>>> that is not containered and thus needs its own resource.
>>> the newly created object passed into the method:
>>> //Create resource
>>> "/TEST");
>>> Resource resource =
>>> URI: " + res.getURI());
>>> resource set:
>>> in CDO 1.0 so maybe I am missing something vital that is the
>>> difference between the versions.
>>> Regards
>>> PGR
Re: CDO Adding a new resource [message #422925 is a reply to message #422923] Thu, 18 September 2008 18:34 Go to previous message
Bug 247910 submitted.
PGR
>> Eike,
> Thx
> /Eike
>> Regards
>> PGR
>> Eike Stepper wrote:
>>> Hi PGR,
>>> Cheers
>>> /Eike
>>>> Hi guys,
>>>> //Create resource
>>>> "/TEST");
>>>> Resource resource =
>>>> resource set:
>>>> Regards
>>>> PGR
Previous Topic:Creating EMF model from XML schema - special characters - com.montages.xml.zip (0/1)
Next Topic:[CDO] XMI models referencing elements stored in CDO
Current Time: Sat Jul 19 20:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.06094 seconds
