Home » Modeling » EMF » Problems when referencing ChangeDescription
Problems when referencing ChangeDescription [message #422701] Sat, 13 September 2008 23:04 Go to next message
I'm trying something new, and I've run into a problem. I have a
modeled class that references ChangeDescription. I've modeled the
reference with Changeable = false, Containment = true, and Transient =
true. The model is generated with:
protected static final ChangeRecorder CHANGE_RECORDER_EDEFAULT =
(ChangeRecorder)DataFactory.eINSTANCE.createFromString(DataP ackage.eINSTANCE.getChangeRecorder(),
which throws a runtime excepton. Additionally, both the edit and
editor bundles are generated with compile errors. I've hacked around
the problems to make forward progress. Is this something I should just
not be doing as a reference?
Bryan
Re: Problems when referencing ChangeDescription [message #422702 is a reply to message #422701] Sat, 13 September 2008 23:08 Go to previous messageGo to next message
> Bryan
Doh, I pressed send too quickly. I should also mention that I'm
referencing ChangeDescription which is modeled with Changeable = true,
Containment = true, and Transient = true.
Re: Problems when referencing ChangeDescription [message #422703 is a reply to message #422702] Sun, 14 September 2008 02:33 Go to previous messageGo to next message
Hi Bryan,
I think it's not very fair to keep the stack trace and the compiler
messages from us :-P
Cheers
/Eike
>> = true. The model is generated with:
>> just not be doing as a reference?
>> Bryan
Re: Problems when referencing ChangeDescription [message #422704 is a reply to message #422703] Sun, 14 September 2008 07:01 Go to previous messageGo to next message
Eike,
Yes, there are a few details missing. The first sentence talks about a
modeled class that used ChangeDescription, but the example is showing
ChangeRecorder. They're two different things. The code makes it clear
that ChangeRecorder is modeled as an EDataType. That implies that the
generated DataFactoryImpl must have
createdChangeRecorderFromString/convertChangeRecorderToStrin g methods
for it, unless the EDataType is marked as not serializeable. I don't
think it makes sense to support string conversion for it...
How are the ChangeDescription issue and the ChangeRecorder issues related?
Eike Stepper wrote:
> Hi Bryan,
> Cheers
> /Eike
>>> around the problems to make forward progress. Is this something I
>>> should just not be doing as a reference?
>>> Bryan
>> true, Containment = true, and Transient = true.
Re: Problems when referencing ChangeDescription [message #422709 is a reply to message #422704] Sun, 14 September 2008 12:06 Go to previous messageGo to next message
I apologize for the poor post. I was in a hurry. Here are the details:
I have a modeled class that has a containment reference to both a
ChangeRecorder and a ChangeDescription. Both are modeled as transient.
The generated default for ChangeRecorder is:
and when that code executes, the following exception is thrown from
EFactoryImpl on line 441:
throw new IllegalArgumentException("The value '" + stringValue + "'
is invalid. " + exceptionString, formatException);
I've hacked around the problem by:
* The default value of the '{@link #getChangeRecorder() <em>Change
Recorder</em>}' attribute.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @see #getChangeRecorder()
* @generated NOT
* @ordered
protected static final ChangeRecorder CHANGE_RECORDER_EDEFAULT = new
ChangeRecorder();
When I generate the edit bundle, I get two types of compile errors:
Import not found:
import org.eclipse.emf.ecore.change.provider.ChangeEditPlugin;
When I try to "open type" on ChangeEditPlugin, it can't be found. The
other compile error is:
* Create the instance.
* @generated
public DataEditPlugin()
super
(new ResourceLocator []
ChangeEditPlugin.INSTANCE, // compile error here
EcoreEditPlugin.INSTANCE,
When I generate the editor bundle, I get to similar types of compile errors:
Import not found:
import org.eclipse.emf.ecore.change.provider.ChangeItemProviderAdap terFactory;
and
adapterFactory.addAdapterFactory(new ChangeItemProviderAdapterFactory());
Hopefully, this is a more complete description of the problem.
Bryan
Re: Problems when referencing ChangeDescription [message #422712 is a reply to message #422709] Sun, 14 September 2008 13:34 Go to previous messageGo to next message
Byran,
Comments below.
> transient. The generated default for ChangeRecorder is:
This is telling me something is very wrong... It's saying you modeled
ChangeRecorder as an EDataType when you need to model it as an EClass.
Or it's fine as an EAttribute too, but it contradicts what you said above.
It also sounds like the empty string worked its way in as the default
value. You should ensure it gets set back to null...
> <em>Change Recorder</em>}' attribute.
> * @generated NOT
> * @ordered
> new ChangeRecorder();
> Import not found:
> * @generated
> super
> errors:
> Import not found:
> import
Did you add a real dependency on the serialized Change.ecore model so
that the Change.genmodel dependency is there in your GenModel? I get
this sense that that's missing...
How did you create your Ecore model and GenModel for this?
> and
> Bryan
Re: Problems when referencing ChangeDescription [message #422714 is a reply to message #422712] Sun, 14 September 2008 14:05 Go to previous messageGo to next message
See below ...
On 2008-09-14 12:34:39 -0500, Ed Merks <Ed.Merks@gmail.com> said:
> Byran,
> Comments below.
> above.
You are correct, I modeled ChangeRecorder as an EDataType and use it as
an EAttribute. This stuff I'm working on right now is very complex for
me, and I often confuse myself and others when I try to explain it.
Hopefully, this problem will get better as I make more progress.
I think I may know what happened here. I started to set the default
value in the properties view, but then backed my change out. Looking
at the ecore model with the text editor, I see that the default value
is set to the empty string. I removed the value from the model, and
now it generates a null. This problem is fixed.
>> * @generated NOT
>> * @ordered
>> Import not found:
>> * @generated
>> super
>> Import not found:
Is this what you are looking for:
usedGenPackages=" platform:/plugin/org.eclipse.emf.ecore.change/model/Change.g enmodel#//change
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.genmodel# //ecore "
After I added ChangeDescription, I reloaded the genmodel and used the
wzard to add the dependency on the Change.genmodel.
>> and
>> Bryan
Re: Problems when referencing ChangeDescription [message #422715 is a reply to message #422714] Sun, 14 September 2008 14:17 Go to previous messageGo to next message
Bryan,
Comments below.
Bryan Hunt wrote:
> See below ...
>> Byran,
>> Comments below.
>>> details:
>> modeled ChangeRecorder as an EDataType when you need to model it as
>> an EClass. Or it's fine as an EAttribute too, but it contradicts
> as an EAttribute. This stuff I'm working on right now is very complex
> for me, and I often confuse myself and others
Especially me. :-P But I can read the generated code to give me the
right clues.
> when I try to explain it. Hopefully, this problem will get better as
It's one of those really annoying aspects of the properties view that
touching a property sets it to the empty string. Oddly this is such a
fundamental problem that I don't see anyone has got any good solutions
for it in data binding or elsewhere. How does one distinguish in the
GUI a string valued property being set to null verses ""? And on the
meta-level, why would such a fundamental problem still be in need of a
solution?!
>>> "' is invalid. " + exceptionString, formatException);
>>> * @generated NOT
>>> * @ordered
This should end up being null...
>>> Import not found:
>>> The other compile error is:
>>> * @generated
>>> super
>>> errors:
>>> Import not found:
>>> import
>> get this sense that that's missing...
So that looks right... I wonder why the dependency on
org.eclipse.emf.ecore.change.edit would be missing from the MANIFEST.MF?
So that sounds okay... It sounds like you added dependencies later and
given that the MANIFEST.MF doesn't regenerate, you're bitten by that age
old problem... :-(
>>> and
>>> Bryan
Re: Problems when referencing ChangeDescription [message #422717 is a reply to message #422715] Sun, 14 September 2008 18:09 Go to previous messageGo to next message
Ed,
Comments below.
On 2008-09-14 13:17:32 -0500, Ed Merks <Ed.Merks@gmail.com> said:
> Bryan,
> Comments below.
> Bryan Hunt wrote:
>> See below ...
>>> Byran,
>>> Comments below.
>>> above.
> right clues.
>> when I try to explain it. Hopefully, this problem will get better as I
>> make more progress.
> solution?!
If I were architect for a day, I'd add a checkbox to the property.
Unchecked = null, Checked = value in box.
>>>> * @generated NOT
>>>> * @ordered
>>>> Import not found:
>>>> * @generated
>>>> super
>>>> Import not found:
> age old problem... :-(
I deleted the entire edit bundle, and re-generated it, it's still not
including org.eclipse.emf.ecore.change.edit in the manifest. Same with
the editor.
>>>> and
>>>> Bryan
Re: Problems when referencing ChangeDescription [message #422719 is a reply to message #422717] Sun, 14 September 2008 18:53 Go to previous message
--------------090500000103040406080105
Bryan,
Comments below.
Bryan Hunt wrote:
> Ed,
> Comments below.
>> Bryan,
>> Comments below.
>> Bryan Hunt wrote:
>>> See below ...
>>>> Byran,
>>>> Comments below.
>>>>> details:
>>> complex for me, and I often confuse myself and others
>> right clues.
>>>> default value. You should ensure it gets set back to null...
>>> Looking at the ecore model with the text editor, I see that the
>>> default value is set to the empty string. I removed the value from
>>> the model, and now it generates a null. This problem is fixed.
>> a fundamental problem that I don't see anyone has got any good
>> solutions for it in data binding or elsewhere. How does one
>> distinguish in the GUI a string valued property being set to null
>> verses ""? And on the meta-level, why would such a fundamental
>> problem still be in need of a solution?!
Yes. But the properties sheet doesn't support that nor does the
property descriptor API have enough declarative data for it. Can you
think of any GUI in Eclipse that does this well already?
>>>>> from EFactoryImpl on line 441:
>>>>> + "' is invalid. " + exceptionString, formatException);
>>>>> * @generated NOT
>>>>> * @ordered
>>>>> = new ChangeRecorder();
>>>>> Import not found:
>>>>> * @generated
>>>>> super
>>>>> compile errors:
>>>>> Import not found:
>>>>> import
>>>> so that the Change.genmodel dependency is there in your GenModel?
>>>> I get this sense that that's missing...
>>> the wzard to add the dependency on the Change.genmodel.
>> and given that the MANIFEST.MF doesn't regenerate, you're bitten by
>> that age old problem... :-(
> with the editor.
Ah. It looks like a bug in the Change.genmodel itself. Note that the
Edit Plugin ID property is org.eclipse.emf.ecore.change rather than
org.eclipse.emf.ecore.change.*edit*. Please open a bugzilla so we can
correct it. In the meantime, you can edit the MANIFEST of the generated
..edit project to add it properly.
>>>>> and
>>>>> Bryan
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Bryan,<br>
<br>
Comments below.<br>
<br>
Bryan Hunt wrote:
<blockquote cite="mid:gak23d$h30$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
Comments below.
<br>
<br>
On 2008-09-14 13:17:32 -0500, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> said:
<br>
<br>
<blockquote type="cite">Bryan,
<br>
<br>
Comments below.
<br>
<br>
Bryan Hunt wrote:
<br>
<blockquote type="cite">See below ...
<br>
<br>
On 2008-09-14 12:34:39 -0500, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> said:
<br>
<br>
<blockquote type="cite">Byran,
<br>
<br>
Comments below.
<br>
<br>
Bryan Hunt wrote:
<br>
<blockquote type="cite">I apologize for the poor post.&nbsp; I was
in a hurry.&nbsp; Here are the details:
<br>
<br>
ChangeRecorder and a ChangeDescription.&nbsp; Both are modeled as transient.
<br>
<br>
&nbsp;&nbsp;&nbsp; protected static final ChangeRecorder CHANGE_RECORDER_EDEFAULT =
<br>
</blockquote>
This is telling me something is very wrong...&nbsp; It's saying you modeled
ChangeRecorder as an EDataType when you need to model it as an EClass.&nbsp;
above.
<br>
</blockquote>
<br>
an EAttribute.&nbsp; This stuff I'm working on right now is very complex for
<br>
</blockquote>
Especially me.&nbsp; :-P&nbsp; But I can read the generated code to give me the
right clues.
<br>
<blockquote type="cite">when I try to explain it.&nbsp; Hopefully, this
<br>
<br>
<br>
<blockquote type="cite"><br>
value.&nbsp; You should ensure it gets set back to null...
<br>
</blockquote>
<br>
I think I may know what happened here.&nbsp; I started to set the default
value in the properties view, but then backed my change out.&nbsp; Looking
is set to the empty string.&nbsp; I removed the value from the model, and
now it generates a null.&nbsp; This problem is fixed.
<br>
</blockquote>
touching a property sets it to the empty string.&nbsp; Oddly this is such a
for it in data binding or elsewhere.&nbsp; How does one distinguish in the
GUI a string valued property being set to null verses ""?&nbsp; And on the
solution?!
<br>
</blockquote>
<br>
If I were architect for a day, I'd add a checkbox to the property.&nbsp;
<br>
</blockquote>
Yes.&nbsp; But the properties sheet doesn't support that nor does the
property descriptor API have enough declarative data for it.&nbsp; Can you
think of any GUI in Eclipse that does this well already?<br>
<blockquote cite="mid:gak23d$h30$1@build.eclipse.org" type="cite"><br>
<br>
<br>
&nbsp;&nbsp; throw new IllegalArgumentException("The value '" + stringValue + "'
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; /**
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * The default value of the '{@link #getChangeRecorder()
&lt;em&gt;Change Recorder&lt;/em&gt;}' attribute.
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * &lt;!-- begin-user-doc --&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * &lt;!-- end-user-doc --&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * @see #getChangeRecorder()
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * @generated NOT
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * @ordered
<br>
&nbsp;&nbsp;&nbsp;&nbsp; */
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
<br>
<br>
Import not found:
<br>
<br>
<br>
<br>
When I try to "open type" on ChangeEditPlugin, it can't be found.&nbsp; The
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * Create the instance.
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; public DataEditPlugin()
<br>
&nbsp;&nbsp;&nbsp; {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; super
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; (new ResourceLocator []
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ChangeEditPlugin.INSTANCE,&nbsp; // compile error here
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EcoreEditPlugin.INSTANCE,
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; });
<br>
<br>
<br>
errors:
<br>
<br>
Import not found:
<br>
<br>
import
<br>
</blockquote>
that the Change.genmodel dependency is there in your GenModel?&nbsp;&nbsp; I get
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
So that looks right...&nbsp; I wonder why the dependency on
MANIFEST.MF?
<br>
<blockquote type="cite">How did you create your Ecore model and
GenModel for this?
<br>
</blockquote>
<br>
<br>
</blockquote>
So that sounds okay...&nbsp; It sounds like you added dependencies later and
<br>
</blockquote>
<br>
including org.eclipse.emf.ecore.change.edit in the manifest.&nbsp; Same with
the editor.
<br>
</blockquote>
Ah.&nbsp; It looks like a bug in the Change.genmodel itself.&nbsp; Note that the
org.eclipse.emf.ecore.change.<b>edit</b>.&nbsp; Please open a bugzilla so we
can correct it.&nbsp; In the meantime, you can edit the MANIFEST of the
generated .edit project to add it properly.<br>
<br>
and
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; adapterFactory.addAdapterFactory(new
<br>
<br>
<br>
<br>
Bryan
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------090500000103040406080105--
Previous Topic:How to get all the derived classes
Next Topic:[CDO] ExtendedLibrary sample with CDO ?
Current Time: Sat Jul 19 05:29:12 EDT 2025
Powered by FUDForum. Page generated in 0.06174 seconds
