Home » Modeling » EMF » How to copy a ResourceSet
How to copy a ResourceSet [message #422629] Thu, 11 September 2008 09:17 Go to next message
I need to copy a ResourceSet (that is 2 resources depending on each other)
into memory in order to modify them without modifying the original
Resources.
I have looked a EcoreUtil to copy objects but I'd like the 2 copied
resources to reference each other and I do not know how to do that?
SeB.
Re: How to copy a ResourceSet [message #422630 is a reply to message #422629] Thu, 11 September 2008 09:26 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, SeB,
You can collect the contents of both resources into a single collection
of EObjects, and use the EcoreUtil.Copier to copy the whole collection.
This ensures that internal references in the copied graph are copied
correctly.
After the copy is complete, the Copier provides a mapping from the
original objects to their copies, so that you can populate new resources
with the copies of the contents, respectively, of the original resources.
HTH,
Christian
SeB.fr wrote:
> Hello,
> other) into memory in order to modify them without modifying the
> original Resources.
> SeB.
Re: How to copy a ResourceSet [message #422639 is a reply to message #422630] Thu, 11 September 2008 11:40 Go to previous messageGo to next message
SeB,
You could also use an EcoreUtil.Copier directly to call copyAll for each
resource's contents and when you're done with them all, call
copyReferences to make sure that all the cross references among all the
copied objects are copied as well...
Christian W. Damus wrote:
> Hi, SeB,
> collection of EObjects, and use the EcoreUtil.Copier to copy the whole
> collection. This ensures that internal references in the copied graph
> are copied correctly.
> resources with the copies of the contents, respectively, of the
> original resources.
> HTH,
> Christian
> SeB.fr wrote:
>> Hello,
>> original Resources.
>> SeB.
Re: How to copy a ResourceSet [message #422640 is a reply to message #422630] Thu, 11 September 2008 11:43 Go to previous messageGo to next message
Thanks a lot.
Would not it be great to have this method into the EcoreUtil class ?
SeB.
Re: How to copy a ResourceSet [message #422642 is a reply to message #422640] Thu, 11 September 2008 12:02 Go to previous message
SeB,
It's not entirely clear how the resource itself should be copied. Just
create new ones with the same URI? But then there are issues like how
the content type (which will involve parsing the contents referenced by
the URI) determines the resource...
SeB.fr wrote:
> Thanks a lot.
> SeB.
Previous Topic:short note: problem with domain names with "-" in XSD Schema
Next Topic:Bug: SetCommand changes order of elements in collection
Current Time: Sun Jul 20 07:19:02 EDT 2025
Powered by FUDForum. Page generated in 0.07341 seconds
