Error when using proxy in teneo/hibernate [message #422626] |
Thu, 11 September 2008 08:32  |
Hi.
I've added persistence option to my hibernate data store:
props.setProperty(PersistenceOptions.SET_PROXY, "true");
Now application throws exceptions like:
org.hibernate.HibernateException: Could not build tuplizer
[org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 110)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:48)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:295)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:434)
at
org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:91)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:58)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:226)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1294)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:162)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:82)
at
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:57)
at
com.go.cms.osgi.service.impl.HibernateContentManagerImpl.get Session(HibernateContentManagerImpl.java:243)
at
com.go.cms.osgi.service.impl.HibernateContentManagerImpl.exe cuteReadQuery(HibernateContentManagerImpl.java:814)
at
com.go.cms.classification.osgi.service.impl.ClassificationSe rviceImpl.getClassificationTypes(ClassificationServiceImpl.j ava:26)
at
com.go.cms.classification.resource.element.PClassificationRo ot.getChildren(PClassificationRoot.java:39)
at
com.go.cms.resource.element.impl.PContainerElement.hasChildr en(PContainerElement.java:17)
at
com.go.cms.resource.CmsBasicTreeContentProvider.hasChildren( CmsBasicTreeContentProvider.java:25)
at
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.hasChildren(SafeDelegateTreeContentProvider .java:107)
at
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.hasChildren(SafeDelegateTreeContentProvider .java:292)
at
org.eclipse.ui.internal.navigator.NavigatorContentServiceCon tentProvider.hasChildren(NavigatorContentServiceContentProvi der.java:662)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2072)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer .java:582)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2102)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:2752)
at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.j ava:842)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:828)
at
org.eclipse.ui.navigator.CommonViewer.createTreeItem(CommonV iewer.java:150)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at
org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalInitial izeTree(AbstractTreeViewer.java:1490)
at
org.eclipse.jface.viewers.TreeViewer.internalInitializeTree( TreeViewer.java:823)
at
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1474)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
at
org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:397)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
at
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1467)
at
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
at
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
at
org.eclipse.ui.navigator.CommonNavigator.createPartControl(C ommonNavigator.java:176)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 1)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:649)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:568)
at
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:271)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:964)
at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2593)
at
org.eclipse.ui.internal.WorkbenchWindow$25.run(WorkbenchWind ow.java:2869)
at
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2850)
at
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:759)
at
org.eclipse.ui.internal.Workbench$21.runWithException(Workbe nch.java:1027)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 107)
... 95 more
Caused by: net.sf.cglib.core.CodeGenerationException:
java.lang.reflect.InvocationTargetException-->null
at
net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:237)
at net.sf.cglib.proxy.Enhancer.createHelper(Enhancer.java:377)
at net.sf.cglib.proxy.Enhancer.createClass(Enhancer.java:317)
at
org.hibernate.proxy.pojo.cglib.CGLIBLazyInitializer.getProxy Factory(CGLIBLazyInitializer.java:127)
at
org.hibernate.proxy.pojo.cglib.CGLIBProxyFactory.postInstant iate(CGLIBProxyFactory.java:43)
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.buildPr oxyFactory(EMFTuplizer.java:214)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:135)
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.<init>(EMFTuplizer.java:76)
... 100 more
at net.sf.cglib.core.ReflectUtils.defineClass(ReflectUtils.java :384)
at
net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:219)
... 107 more
Caused by: java.lang.NoClassDefFoundError:
org/hibernate/proxy/HibernateProxy
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
... 113 more
Thanks.
Re: Error when using proxy in teneo/hibernate [message #422658 is a reply to message #422638] |
Fri, 12 September 2008 01:19  |
Hi Mikhail,
Something I encountered with someone else is that there was also a hibernate.jar somewhere else in
their software and therefore they ended up with the same exception as you.
Other than that I don't know why it works in a small application and does not work in a larger
application.
gr. Martin
Mikhail Kadan wrote:
> Hi.
> Yes, I've put all hibernate and cglib (cglib-2.1.3.jar) jars to separate
> plugin, and set it's buddy policy to dependent.
> I've tried to make sample plugin to localize this issue, but everything
> seems fine with it. This problem only occurs in out large application,
> which sources I am not allowed to provide.
> Maybe you have some ideas why can this problem appear in large
> application and not in small sample plugin?
> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.04818 seconds
