Home » Modeling » EMF » howto to do objects with serial numbers
howto to do objects with serial numbers [message #422401] Thu, 04 September 2008 12:12 Go to next message
Dear all
I hope this is not too much of a ramble and is intelligible.
I have a need to create some objects in emf which have serial numbers
which are unique for each reference type within a container and have a
fast lookup mechanism. Now I have written some classes that track serial
numbers and can add those to the relevant parent classes. However I now
needs a containment EList that looks for a new serial number from its
container when objects are added to the the container.
However there are a few areas where I am not sure what best to do
I guess I need to hack into then the containment contract when the
containment is set (and if it is reset/unset?) So I guess I need to hack a
subclass of EObjectContainmentEList.java and override the methods that
do the setting and removing of objects (however everything appears to lie
in the subclasses and very little goes on in EObjectContainmentEList...
which is a little strange am I right in thinking that most of the
subclasses of BasicEList are to switch things on and off?)
Also, the fast lookup by serial adds another requirement ie that the
container should also be map like (i.e. internally i need to be able to
lookup on serial numbers which I could make a key of the map) but i don't
think there is anything like EObjectContainmentEMap.java ;-)
Finally the object that doles out serial numbers from the parent needs to
an implementation artifact only (i.e not part of the public interface) so
is it possible to have a field in a parent object that is only visible to
the child (which may not be from the same package)
as usually looking for any wise words
gary
Re: howto to do objects with serial numbers [message #422407 is a reply to message #422401] Thu, 04 September 2008 13:31 Go to previous message
Gary,
Comments below.
gary s thompson wrote:
> Dear all
> serial numbers and can add those to the relevant parent classes.
> However I now needs a containment EList that looks for a new serial
> number from its container when objects are added to the the container.
> hack a subclass of EObjectContainmentEList.java and override the
> methods that do the setting and removing of objects (however
> everything appears to lie in the subclasses and very little goes on in
> EObjectContainmentEList... which is a little strange am I right in
> thinking that most of the subclasses of BasicEList are to switch
> things on and off?)
Yes, the factoring is such that much of the logic is in BasicEList,
NotifyingEList, and EcoreEList.
> to lookup on serial numbers which I could make a key of the map) but i
> don't think there is anything like EObjectContainmentEMap.java ;-)
Nope.
> to an implementation artifact only (i.e not part of the public
> interface) so is it possible to have a field in a parent object that
> is only visible to the child (which may not be from the same package)
No. But you could have the parent's class implement some "Internal"
interface so that it's not visible in the public part of the API.
Probably I'm missing the big picture of what will be achieved by
this... Certainly hooks like EObjectImpl.eBasicSetContainer might be a
simple place to know the container and know to compute something based
on that container. The lists themselves have hooks like
didAdd/didRemove... It sounds like an EcoreEMap is almost exactly like
what you want, so that's a good example to consider.
> gary
Previous Topic:[Databinding] Example Application showing Databinding, EMF, Teneo and CDO in action
Next Topic:Detecting a Reource Save Notification
Current Time: Sat Jul 19 08:39:42 EDT 2025
Powered by FUDForum. Page generated in 0.06583 seconds
