Home » Modeling » EMF » Initialize an attribute with another attribute
Initialize an attribute with another attribute [message #422350] Tue, 02 September 2008 09:25 Go to next message
Hi all !
I have a question ; is it possible to initialize an attribute with another
attribute value in a EMF model ?
Example :
I have an attribute 'ServerId'. Its default value is 0.
I hava an attribute 'ServerName'.
I would like that default value for 'ServerName' equals 's'+ Server_id
(here = s0).
Is is possible to do that ?
Guillaume
Re: Initialize an attribute with another attribute [message #422351 is a reply to message #422350] Tue, 02 September 2008 09:32 Go to previous messageGo to next message
Guillaume,
Comments below.
Guillaume SOLDERA wrote:
> Hi all !
> another attribute's value in a EMF model ?
I suppose anything is possible in code, but there's no way to declare
that in Ecore.
> Example : I have an attribute 'ServerId'. Its default value is 0.
> (here = s0).
You can set the EAttributes default value literal to "s0" if you like...
You could define the feature to be unsettable and you could specialize
the isSetX and getX methods to compute a default and to reflect when
the value is just a default... I'm not sure if you'd want to keep the
two in sync or produce notification when the ID changes...
> Thanks
> Guillaume
Re: Initialize an attribute with another attribute [message #422352 is a reply to message #422351] Tue, 02 September 2008 09:55 Go to previous message
Hi Ed !
Thanks for your answer.
I just want put this pattern for the initialization. So I initialize with
's0' value.
But, in 'set' method, if there is no value, then I apply my pattern.
Thanks again
Guillaume
Ed Merks wrote:
> Guillaume,
> Comments below.
>> Hi all !
> that in Ecore.
>> (here = s0).
>> Thanks
>> Guillaume
Previous Topic:XSD key-keyref support revisited
Next Topic:CDO offline mode
Current Time: Sun Jul 20 10:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.03887 seconds
