Home » Modeling » EMF » namespaceURI retrieval
namespaceURI retrieval [message #421916] Mon, 18 August 2008 08:26 Go to next message
I have code for retrieval of namespaceURI of a resource (see code snippet
below).
This code works fine, but now I need to find the other referenced
namespaceURI's in similar way.
For instance if having below root:
<rbc:RbcAppl xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:rbc="http://www.a.b/data/rbc/v8"
xmlns:rbc_bv="http://www.a.b/data/rbc_bv/v3"
xmi:id="_hFOnoCsXEd2CsoTXrynoRw" projectVersion="3">
code snippet below successfully gets the 'rbc' namespaceURI
"http://www.a.b/data/rbc/v8".
But how do I manage to get the 'rbc_bv' namespaceURI??
Code snippet:
XMLResource xmlResource = load(uri, inputStream, options, context);
EList<EObject> contents = xmlResource.getContents();
if (!contents.isEmpty()) {
EObject eObject = contents.get(0);
if (eObject instanceof XMLTypeDocumentRoot) {
XMLTypeDocumentRoot documentRoot = (XMLTypeDocumentRoot) eObject;
EList<EObject> rootContents = documentRoot.eContents();
String rootElementName = null;
String rootElementNamespace = null;
if (!rootContents.isEmpty()) {
EObject root = rootContents.get(0);
EReference eContainmentFeature = root.eContainmentFeature();
rootElementName = eContainmentFeature.getName();
ExtendedMetaData.INSTANCE.getNamespace(eContainmentFeature);
return rootElementNamespace;
return null;
Joachim
Re: namespaceURI retrieval [message #421917 is a reply to message #421916] Mon, 18 August 2008 08:47 Go to previous messageGo to next message
Joachim,
Comments below.
Joachim Rietz wrote:
> snippet below).
> Code snippet:
Are you parsing the whole document but you only need to get the
information for the root element? EMF has support for content types now
that handle this quite efficiently. You might want to look at how
XMLContentHandlerImpl does this...
You can look at documentRoot.getXMLNSPrefixMap(). It will have mappings
for all the xmlns declarations in the root element.
> return null;
> Regards,
> Joachim
Re: namespaceURI retrieval [message #421919 is a reply to message #421917] Mon, 18 August 2008 09:19 Go to previous messageGo to next message
Ed,
I've tried the documentRoot.getXMLNSPrefixMap(), but it returns an empty
map...
Are there some stuff to do to get this working properly?
/Joachim
Ed Merks wrote:
> Joachim,
> Comments below.
>> Hi,
>> snippet below).
>> Code snippet:
>> return null;
>> Regards,
>> Joachim
Re: namespaceURI retrieval [message #421922 is a reply to message #421919] Mon, 18 August 2008 09:35 Go to previous messageGo to next message
--------------000006030103080601010500
Joachim,
I'd expect this XMLHandler logic to kick in and do the trick:
| *public **void *endDocument()
*if *(deferredExtent != *null*)
extent.addAll(deferredExtent);
// Pretend there is an xmlns="" because we really need to ensure that the null prefix
// isn't used to denote something other than the null namespace.
*if *(usedNullNamespacePackage)
helper.addPrefix("", "");
helper.recordPrefixToURIMapping();
helper.popContext();
handleForwardReferences(*true*);
*if *(disableNotify)
*for *(Iterator<?> i = EcoreUtil.getAllContents(xmlResource.getContents(), *false*); i.hasNext(); )
EObject eObject = (EObject)i.next();
eObject.eSetDeliver(*true*);
*if *(extendedMetaData != *null*)
*if *(extent.size() == 1)
EObject root = extent.get(0);
recordNamespacesSchemaLocations(root);
*if *(DEBUG_DEMANDED_PACKAGES)
// EATM temporary for debug purposes only.
Collection<EPackage> demandedPackages = EcoreUtil.copyAll(extendedMetaData.demandedPackages());
*for *(EPackage ePackage : demandedPackages)
ePackage.setName(ePackage.getNsURI());
extent.addAll(demandedPackages);
*protected *EMap<String, String> recordNamespacesSchemaLocations(EObject root)
EClass eClass = root.eClass();
EReference xmlnsPrefixMapFeature = extendedMetaData.getXMLNSPrefixMapFeature(eClass);
EMap<String, String> xmlnsPrefixMap = *null*;
*if *(xmlnsPrefixMapFeature != *null*)
@SuppressWarnings("unchecked") EMap<String, String> newXMLNSPrefixMap = (EMap<String, String>)root.eGet(xmlnsPrefixMapFeature);
xmlnsPrefixMap = newXMLNSPrefixMap;
xmlnsPrefixMap.putAll(helper.getPrefixToNamespaceMap());
*if *(urisToLocations != *null*)
EReference xsiSchemaLocationMapFeature = extendedMetaData.getXSISchemaLocationMapFeature(eClass);
*if *(xsiSchemaLocationMapFeature != *null*)
@SuppressWarnings("unchecked") EMap<String, String> newXSISchemaLocationMap = (EMap<String, String>)root.eGet(xsiSchemaLocationMapFeature);
EMap<String, String> xsiSchemaLocationMap = newXSISchemaLocationMap;
*for *(Map.Entry<String, URI> entry : urisToLocations.entrySet())
xsiSchemaLocationMap.put(entry.getKey(), entry.getValue().toString());
*return *xmlnsPrefixMap;
> Ed, I've tried the documentRoot.getXMLNSPrefixMap(), but it returns an
> empty map...
> /Joachim
> Ed Merks wrote:
>> Joachim,
>> Comments below.
>>> Hi,
>>> snippet below).
>>> Code snippet:
>> now that handle this quite efficiently. You might want to look at
>> how XMLContentHandlerImpl does this...
>>> eObject;
>> mappings for all the xmlns declarations in the root element.
>>> return null;
>>> Regards,
>>> Joachim
<html>
<head>
http-equiv="Content-Type">
</head>
Joachim,<br>
<br>
I'd expect this XMLHandler logic to kick in and do the trick:<br>
<blockquote>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type"
content="text/html; charset=iso-8859-1">
<!-- ======================================================== --><!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">
Re: namespaceURI retrieval [message #421923 is a reply to message #421922] Mon, 18 August 2008 10:14 Go to previous messageGo to next message
Hi again,
Ehh, I'm not sure if I missed something obvious here, but I really don't
know what to do with the code you provided below...
Shall I add it in my code, where? Or how shall I use it?
/Joachim
Ed Merks wrote:
> Joachim,
>> empty map...
>> /Joachim
>> Ed Merks wrote:
>>> Joachim,
>>> Comments below.
>>>> Hi,
>>>> snippet below).
>>>> Code snippet:
>>>> eObject;
>>>> return null;
>>>> Regards,
>>>> Joachim
Re: namespaceURI retrieval [message #421924 is a reply to message #421923] Mon, 18 August 2008 10:22 Go to previous messageGo to next message
Joachim,
That's code which already exists in XMLHandler and which should be
kicking in during the processing of your document. You'll want to see a
breakpoint to see why it's not going there...
> Hi again,
> don't know what to do with the code you provided below...
> /Joachim
> Ed Merks wrote:
>> Joachim,
>> *if *(disableNotify) {
> i.hasNext(); )
>> recordNamespacesSchemaLocations(root); }
>>> an empty map...
>>> /Joachim
>>> Ed Merks wrote:
>>>> Joachim,
>>>> Comments below.
>>>>> Hi,
>>>>> snippet below).
>>>>> Code snippet:
>>>> types now that handle this quite efficiently. You might want to
>>>> look at how XMLContentHandlerImpl does this...
>>>>> eObject;
>>>>> return null;
>>>>> Regards,
>>>>> Joachim
Re: namespaceURI retrieval [message #421961 is a reply to message #421924] Tue, 19 August 2008 07:54 Go to previous messageGo to next message
Ed,
Thanks for your support.
I was actually doing the same as the XMLContentHandlerImpl for my own
code.
But as the XMLContentHandlerImpl.createXMLResource() it creates a
specialized XML resource for consuming just the root elements (i.e.
doesn't parse whole doc) and throws exception when done, I never get to
the functions you mentioned in XMLHandler...and hereby the map is empty...
However, if continue parsing whole doc, the map is there.
So, I guess I don't have much choice than to parse whole doc?
Btw, which is the easiest way to do this?
Or is there other way than documentRoot.getXMLNSPrefixMap() if parsing
only root element?
/Joachim
Ed Merks wrote:
> Joachim,
>> Hi again,
>> /Joachim
>> Ed Merks wrote:
>>> Joachim,
>> i.hasNext(); )
>>>> an empty map...
>>>> /Joachim
>>>> Ed Merks wrote:
>>>>> Joachim,
>>>>> Comments below.
>>>>>> Hi,
>>>>>> snippet below).
>>>>>> Code snippet:
>>>>>> eObject;
>>>>>> return null;
>>>>>> Regards,
>>>>>> Joachim
Re: namespaceURI retrieval [message #421962 is a reply to message #421961] Tue, 19 August 2008 08:14 Go to previous messageGo to next message
Joachim,
Comments below.
> Ed,
> code. But as the XMLContentHandlerImpl.createXMLResource() it creates
> a specialized XML resource for consuming just the root elements (i.e.
> to the functions you mentioned in XMLHandler...and hereby the map is
> empty...
Oh, I don't really like that. I think I should fix that, even if it
doesn't break the standard use case for this. I could imagine
specialized uses where the content type is determined by the presence of
several different namespaces on the root element...
It should be possible to pop the stacks and force calls to endDocument
before throwing the exception but I'd need to look closely as some of
the cases to ensure that the right set of prefixes are recorded; there
might need to be calls to end element. If you open a bugzilla, I'll
investigate and try to come up with a solution you can reuse.
> only root element?
The SAX callbacks do tell you about the prefixes...
> /Joachim
> Ed Merks wrote:
>> Joachim,
>> see a breakpoint to see why it's not going there...
>>> Hi again,
>>> /Joachim
>>> Ed Merks wrote:
>>>> Joachim,
>>>> ensure
>>>> namespace.
>>> i.hasNext(); )
>>>>> returns an empty map...
>>>>> /Joachim
>>>>> Ed Merks wrote:
>>>>>> Joachim,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>>> code snippet below).
>>>>>>> referenced namespaceURI's in similar way.
>>>>>>> Code snippet:
>>>>>>> eObject;
>>>>>>> return null;
>>>>>>> Regards,
>>>>>>> Joachim
Re: namespaceURI retrieval [message #422324 is a reply to message #421962] Fri, 29 August 2008 14:34 Go to previous message
--------------040700090800090908080402
Joachim,
Thanks for opening a bugzilla:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=245493>
I've committed changes to improve this for 2.5.
Ed Merks wrote:
> Joachim,
> Comments below.
>> Ed,
>> empty...
> of several different namespaces on the root element...
>> parsing only root element?
>> /Joachim
>> Ed Merks wrote:
>>> Joachim,
>>>> Hi again,
>>>> /Joachim
>>>> Ed Merks wrote:
>>>>> Joachim,
>>>>> ensure
>>>>> namespace.
>>>> i.hasNext(); )
>>>>>> /Joachim
>>>>>> Ed Merks wrote:
>>>>>>> Joachim,
>>>>>>> Comments below.
>>>>>>>> Hi,
>>>>>>>> Code snippet:
>>>>>>>> context);
>>>>>>>> eObject;
>>>>>>>> return null;
>>>>>>>> Regards,
>>>>>>>> Joachim
<html>
<head>
</head>
Joachim,<br>
<br>
Thanks for opening a bugzilla:<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=245493"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=245493">https://bugs.eclipse.org/bugs/show_bug.cgi?id=245493</a><br>
</blockquote>
I've committed changes to improve this for 2.5.<br>
<br>
<br>
Ed Merks wrote:
<blockquote cite="mid:g8edfi$5d3$1@build.eclipse.org" type="cite">Joachim,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Ed,
<br>
<br>
<br>
code. But as the XMLContentHandlerImpl.createXMLResource() it creates a
empty...
<br>
</blockquote>
Previous Topic:Question on using CDO to implement distributes telemetry capability.
Next Topic:Generating methods for multiple constraints
Current Time: Sun Jul 20 03:57:00 EDT 2025
Powered by FUDForum. Page generated in 0.26687 seconds
