Home » Modeling » EMF » Using EMFT Validation in Standalone Java Environment
Using EMFT Validation in Standalone Java Environment [message #421718] Tue, 12 August 2008 08:38 Go to next message
Hi all,
is it possible to use the EMFT Validation Framework (with Java and OCL
Constraints) in a Standalone Environment (plain Java - without a running
Eclipse). I am aware of the fact that all constraints are defined via an
extension point, but is there any way other than reimplementing the
whole validation?
Lars
Re: Using EMFT Validation in Standalone Java Environment [message #421722 is a reply to message #421718] Tue, 12 August 2008 09:05 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Lars,
There is an enhancement request for this in Bugzilla:
https://bugs.eclipse.org/167972
It hasn't seen much activity, I'm afraid. This component was originally
designed with the Eclipse run-time in mind and for a particular
application environment. I suspect that it wouldn't take much work to
add an API for manipulation of the constraint-providers and other
registries, but that the greater effort is in removing dependencies on
Eclipse API such as IStatus. Basically, it would pretty much result in
deprecation of most of the component.
EMF Core, as you probably know, provides a generative validation
solution that works in stand-alone deployments. Is that a possibility
for you? Even using OCL in the generated EValidator is quite
straight-forward, with a bit of custom code...
Christian
Lars Heinemann wrote:
> Hi all,
> whole validation?
> Regards,
> Lars
Re: Using EMFT Validation in Standalone Java Environment [message #421724 is a reply to message #421722] Tue, 12 August 2008 09:21 Go to previous messageGo to next message
Christian W. Damus schrieb:
> Hi, Lars,
Well JFace also too depends on things like IStatus you can use these
classes in none OSGi-Envs without problems. You only have to include the
osgi.jar no matter if you start up the OSGi env or not.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Using EMFT Validation in Standalone Java Environment [message #421731 is a reply to message #421724] Tue, 12 August 2008 11:50 Go to previous message
Hi, Tom,
Good point. Of course, one would rather retro-fit the API to use EMF's
Diagnostic, and I haven't yet taken the time to analyze the extent of
the dependencies ... I'm more worried about behavioural dependencies
than structural ones. I wish I had the time to take another look at the
patch on that bug. :-(
cW
>> Hi, Lars,
>> originally designed with the Eclipse run-time in mind and for a
>> particular application environment. I suspect that it wouldn't take
>> much work to add an API for manipulation of the constraint-providers
>> and other registries, but that the greater effort is in removing
>> dependencies on Eclipse API such as IStatus. Basically, it would
>> pretty much result in deprecation of most of the component.
> Tom
Previous Topic:Accesing to the model from my editor
Next Topic:Where to put the resource of a ChangeDescription?
Current Time: Sat Jul 19 06:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.07503 seconds
