Home » Modeling » EMF » Read-only Property Sheet Page
Read-only Property Sheet Page [message #420481] |
Tue, 01 July 2008 09:44  |
I am using RCP, EMF and GMF in my application. I have a navigator view
which uses the AdapterFactoryContentProvider as content provider. I
added property sheet support to the view by inspecting how it was done
in the generated EMF editor.
The property sheet page is working properly. However, the cells are
editable and this is bad for the navigator view. Because the navigator
view is not an editor and there is no possibility save the changes.
I want to make the property sheet page read-only, which is displayed
when an element is selected in the navigator view. I can't make the
properties globally read-only using the genmodel, because the property
sheets of GMF editors should not be affected. Any solution or idea is
welcome.
Artun
Re: Read-only Property Sheet Page [message #420495 is a reply to message #420490] |
Tue, 01 July 2008 11:00   |
I already tried that. Somehow, it didn't work for me.
I added a selection listener to the navigators viewer. When the
selection changes, I get the Resources of the selected EObjects and add
them to the map you mentioned like this:
myAdapterFactoryEditingDomain.getResourceToReadOnlyMap.put(r esource, true);
This didn't change anything.
Ed Merks schrieb:
> Artun,
> Comments below.
> Artun Subasi wrote:
>> Hello,
> The editing domain as a whole could mark the resource as read only and
> then no commands to change the contents will be executable. You could
> use AdapterFactoryEditingDomain.getResourceToReadOnlyMap to make the
> resource readonly.
>> welcome.
>> Regards,
>> Artun
Re: Read-only Property Sheet Page [message #420509 is a reply to message #420495] |
Tue, 01 July 2008 12:29   |
--------------020806020408080800050001
Artun,
The debugger is your best friend. This method in ItemPropertyDescriptor
should be getting called:
public boolean canSetProperty(Object object)
if (isSettable)
EditingDomain editingDomain = getEditingDomain(object);
if (editingDomain != null)
Resource resource = object instanceof EObject ?
((EObject)object).eResource() :
object instanceof Resource ?
(Resource)object :
null;
return resource == null || !editingDomain.isReadOnly(resource);
else
return true;
else
return false;
You could investigate what's happening here.
> add them to the map you mentioned like this:
> true);
> Ed Merks schrieb:
>> Artun,
>> Comments below.
>> Artun Subasi wrote:
>>> Hello,
>>> view which uses the AdapterFactoryContentProvider as content
>>> provider. I added property sheet support to the view by inspecting
>>> how it was done in the generated EMF editor.
>>> navigator view is not an editor and there is no possibility save the
>>> changes.
>> and then no commands to change the contents will be executable. You
>> could use AdapterFactoryEditingDomain.getResourceToReadOnlyMap to
>> make the resource readonly.
>>> property sheets of GMF editors should not be affected. Any solution
>>> or idea is welcome.
>>> Regards,
>>> Artun
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Artun,<br>
<br>
ItemPropertyDescriptor should be getting called:<br>
<blockquote><small> public boolean canSetProperty(Object object)</small><br>
<small> {</small><br>
<small> if (isSettable)</small><br>
<small> EditingDomain editingDomain = getEditingDomain(object);</small><br>
<small> if (editingDomain != null)</small><br>
<small> Resource resource = object instanceof EObject ?</small><br>
<small> ((EObject)object).eResource() :</small><br>
<small> object instanceof Resource ?</small><br>
<small> (Resource)object :</small><br>
<small> null;</small><br>
<small> </small><br>
<small> return resource == null ||
!editingDomain.isReadOnly(resource);</small><br>
<small> }</small><br>
<small> else</small><br>
<small> return true;</small><br>
<small> return false;</small><br>
</blockquote>
You could investigate what's happening here.<br>
<br>
<br>
Artun Subasi wrote:
<blockquote cite="mid:g4dgqi$4oj$1@build.eclipse.org" type="cite">I
<br>
<br>
<br>
<br>
true);
<br>
<br>
<br>
<br>
Ed Merks schrieb:
<br>
<blockquote type="cite">Artun,
<br>
<br>
Comments below.
<br>
<br>
Artun Subasi wrote:
<br>
<blockquote type="cite">Hello,
<br>
<br>
<br>
<br>
<br>
</blockquote>
resource readonly.
<br>
<blockquote type="cite"><br>
welcome.
<br>
<br>
<br>
Artun
<br>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------020806020408080800050001--
Re: Read-only Property Sheet Page [message #420540 is a reply to message #420509] |
Wed, 02 July 2008 06:09   |
Ed,
I found the cause of the problem.
returns an instance of TransactionalEditingDomain instead of an
AdapterFactoryEditingDomain. The navigator view uses this
TransactionalEditingDomain to manage the resources.
I had to create an additional AdapterFactoryEditingDomain in order to
create the property sheet page like this:
public IPropertySheetPage getPropertySheetPage() {
BasicCommandStack commandStack = new BasicCommandStack();
adapterFactoryEditingDomain =
new AdapterFactoryEditingDomain(adapterFactory, commandStack,
new HashMap<Resource, Boolean>());
if (propertySheetPage == null) {
propertySheetPage =
new ExtendedPropertySheetPage(adapterFactoryEditingDomain);
propertySheetPage.setPropertySourceProvider(
new AdapterFactoryContentProvider(adapterFactory));
return propertySheetPage;
I assume the problem would be solved if I used the same
AdapterFactoryEditingDomain in the navigator view instead of using a
seperate TransactionalEditingDomain. But I can't do this change easily
because the navigator uses AbstractTransactionalCommands which need a
Ed Merks wrote:
> Artun,
> if (isSettable)
> (Resource)object :
> null;
> else
> return true;
> else
> return false;
>> true);
>> Ed Merks schrieb:
>>> Artun,
>>> Comments below.
>>> Artun Subasi wrote:
>>>> Hello,
>>>> changes.
>>>> or idea is welcome.
>>>> Regards,
>>>> Artun
Re: Read-only Property Sheet Page [message #420550 is a reply to message #420540] |
Wed, 02 July 2008 08:25   |
Artun,
Comments below.
Artun Subasi wrote:
> Ed,
That class extends AdapterFactoryEditingDomain though, so why is this
causing a problem?
> propertySheetPage =
I don't really get why it's a problem? Could you elaborate on the
problem? Do you want, for example, editing supported in one place and
not the other?
> Ed Merks wrote:
>> Artun,
>> if (isSettable)
>> (Resource)object :
>> null;
>> else
>> return true;
>> else
>> return false;
>>> true);
>>> Ed Merks schrieb:
>>>> Artun,
>>>> Comments below.
>>>> Artun Subasi wrote:
>>>>> Hello,
>>>>> are editable and this is bad for the navigator view. Because the
>>>>> the changes.
>>>> You could use AdapterFactoryEditingDomain.getResourceToReadOnlyMap
>>>> to make the resource readonly.
>>>>> displayed when an element is selected in the navigator view. I
>>>>> can't make the properties globally read-only using the genmodel,
>>>>> because the property sheets of GMF editors should not be affected.
>>>>> Any solution or idea is welcome.
>>>>> Regards,
>>>>> Artun
Re: Read-only Property Sheet Page [message #420594 is a reply to message #420550] |
Thu, 03 July 2008 02:51  |
Hi Ed,
Comments below.
Ed Merks wrote:
> Artun,
> Comments below.
> Artun Subasi wrote:
>> Ed,
> causing a problem?
The TransactionalEditingDomain interface extends EditingDomain. But
thanks to your comment, I found out that TransactionalEditingDomainImpl
extends AdapterFactoryEditingDomain. I used to use
GMFEditingDomainFactory.INSTANCE.createEditingDomain()
to create an instance of the TransactionalEditingDomain. This method
returns the TransactionalEditingDomain interface. Because I wasn't sure
whether it always uses TransactionalEditingDomainImpl internally, I
changed the creation of the editing domain. Now I create it with the
constructor of TransactionalEditingDomainImpl.
Because TransactionalEditingDomainImpl extends
AdapterFactoryEditingDomain, my problem is solved. Thanks.
>> propertySheetPage =
> not the other?
>> Ed Merks wrote:
>>> Artun,
>>> if (isSettable)
>>> (Resource)object :
>>> null;
>>> else
>>> return true;
>>> else
>>> return false;
>>>> true);
>>>> Ed Merks schrieb:
>>>>> Artun,
>>>>> Comments below.
>>>>> Artun Subasi wrote:
>>>>>> Hello,
>>>>>> the changes.
>>>>>> Regards,
>>>>>> Artun
Current Time: Sat Jul 19 17:25:32 EDT 2025
Powered by FUDForum. Page generated in 0.04179 seconds
