Home » Modeling » EMF » How do I bring editor or view on an existing model instance?
How do I bring editor or view on an existing model instance? [message #420351] Wed, 25 June 2008 16:09 Go to next message
I've been using EMF for sometime now, and it's great. In particular, it
is very helpful to have the generated EMF editor to directly examine data
structures. However, this has always required that I first open an EMF
instance/resource with the EMF editor first.
Now I really need to have pure runtime software which simply creates and
uses EMF objects/structures. No problem: just use
XxxxxFactory.eINSTANCE.createYyyy().
HOWEVER, it would REALLY be helpful to be able to examine and possibly
modify such object structure using the generated EMF editor and/or Outline
View and properties page but without going through the steps of using the
editor UI to open a file, etc... The goal is not to have a file and
possibly not a resource involved.
Can someone suggest a, preferable simple, tactic to programmatically open
the Editor or Outline View and properties page on an existing in-memory
EMF generated object structure?
Thanks in advance.
Steve
Re: How do I bring editor or view on an existing model instance? [message #420361 is a reply to message #420351] Wed, 25 June 2008 23:30 Go to previous messageGo to next message
Steve,
If you look at the generated wizard, it shows how the editor opened when
the wizard completes.
Steve Punte wrote:
> it is very helpful to have the generated EMF editor to directly
> examine data structures. However, this has always required that I
> first open an EMF instance/resource with the EMF editor first.
> and uses EMF objects/structures. No problem: just use
> Outline View and properties page but without going through the steps
> of using the editor UI to open a file, etc... The goal is not to have
> a file and possibly not a resource involved.
> open the Editor or Outline View and properties page on an existing
> in-memory EMF generated object structure?
> Thanks in advance.
> Steve
Re: How do I bring editor or view on an existing model instance? [message #420388 is a reply to message #420361] Fri, 27 June 2008 13:04 Go to previous messageGo to next message
Ed:
Thanks for the reply.
Can you be a bit more specific. I've attempted modifying
XxxEdit.initializeEditingDomain() and creating a custom
AdapterFactoryEditingDomain class but with unsatisfactory results. Where
exactly should I look in the "generated wizard?"
Steve
> Steve,
> Steve Punte wrote:
>> Hi,
>> Thanks in advance.
>> Steve
Re: How do I bring editor or view on an existing model instance? [message #420395 is a reply to message #420388] Fri, 27 June 2008 16:54 Go to previous messageGo to next message
Ed:
Oh, I see now what you are talking about: the XxxModelWizard.java file.
Very interesting. The key issue is supplying some kind of IEditorInput to
page.openEditor(). I tried used CommonSourceNotFoundEditorInput(), but it
resulted in an internal file not found exception.
I'm attempting to create my own IEditorInput class. I see
MyEditorInput.getAdpter() being called with arg classes: IFile,
IFileRevision and IResource. Hmm.
My goals are to open the editor (or possibly the outline view) on an eCore
object preferable with no reference to a file at all. Can I be successful
headed down this path?
Thanks in advance.
Steve
Re: How do I bring editor or view on an existing model instance? [message #420397 is a reply to message #420395] Sat, 28 June 2008 08:04 Go to previous message
Steve,
Yes, it's certainly possible, but you'll need to add special case
handing with the editor to deal with your type of editor input.
Steve Punte wrote:
> Ed:
> IEditorInput to page.openEditor(). I tried used
> CommonSourceNotFoundEditorInput(), but it resulted in an internal file
> eCore object preferable with no reference to a file at all. Can I be
> successful headed down this path?
> Thanks in advance.
> Steve
>>> when the wizard completes.
Previous Topic:seeking advice: making generated contentproviders filterable
Next Topic:Loading certain parts of an XML as text, not EObjects
Current Time: Sun Jul 20 16:18:35 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
