Home » Modeling » EMF » [EMF Query] recursive conditions
[EMF Query] recursive conditions [message #420335] Wed, 25 June 2008 01:40 Go to next message
Does EMF Query handle recursive conditions? I'm trying to write a
condition along the lines of "p(x) or p(y) where y is a direct or
indirect container of x". I am trying
EObjectCondition p = ...
EObjectCondition p_or_parent_p = null;
EObjectCondition parent_p = new
EObjectReferenceValueCondition(containerReference, p_or_parent_p);
p_or_parent_p = p.OR(parent_p);
I'm having some NullPointerExceptions that I'm trying to sort out, but
if its a fundamental limitation of EMF Query, I'll have to work out some
other way of doing it.
Jim.
Re: [EMF Query] recursive conditions [message #420376 is a reply to message #420335] Thu, 26 June 2008 19:52 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
--=-VcA87hV+ckr/PIX58lUY
Content-Type: text/plain
Hi, Jim,
The stock query conditions (esp. EObjectReferenceValueCondition) only
handle one step of a reference chain. It would be interesting to add
support for predicates on the closure or a reference, such as we can do
in MDT OCL with the "closure" iterator.
Is that what you're getting at? I may have misunderstood.
HTH,
Christian
On Wed, 2008-06-25 at 15:40 +1000, Jim Steel wrote:
> Cheers,
> Jim.
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Jim,<BR>
<BR>
The stock query conditions (esp. EObjectReferenceValueCondition) only handle one step of a reference chain.&nbsp; It would be interesting to add support for predicates on the closure or a reference, such as we can do in MDT OCL with the &quot;closure&quot; iterator.<BR>
<BR>
Is that what you're getting at?&nbsp; I may have misunderstood.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hi,</FONT>
<FONT COLOR="#000000">Does EMF Query handle recursive conditions? I'm trying to write a </FONT>
<FONT COLOR="#000000">condition along the lines of &quot;p(x) or p(y) where y is a direct or </FONT>
<FONT COLOR="#000000">indirect container of x&quot;. I am trying</FONT>
<FONT COLOR="#000000">EObjectCondition p = ...</FONT>
<FONT COLOR="#000000">EObjectCondition p_or_parent_p = null;</FONT>
<FONT COLOR="#000000">EObjectCondition parent_p = new </FONT>
<FONT COLOR="#000000">EObjectReferenceValueCondition(containerReference, p_or_parent_p);</FONT>
<FONT COLOR="#000000">p_or_parent_p = p.OR(parent_p);</FONT>
<FONT COLOR="#000000">I'm having some NullPointerExceptions that I'm trying to sort out, but </FONT>
<FONT COLOR="#000000">if its a fundamental limitation of EMF Query, I'll have to work out some </FONT>
<FONT COLOR="#000000">other way of doing it.</FONT>
<FONT COLOR="#000000">Cheers,</FONT>
<FONT COLOR="#000000">Jim.</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-VcA87hV+ckr/PIX58lUY--
Re: [EMF Query] recursive conditions [message #420378 is a reply to message #420376] Thu, 26 June 2008 21:55 Go to previous messageGo to next message
Yes, that was essentially what I was trying to do in this case. My
question was more general, about whether it was possible to reuse an
EObjectCondition twice in a tree, in this case in a recursive way.
I've since found another way of solving my particular problem, by
shifting the recursive call inside a custom EObjectCondition, a la
EObjectCondition recursiveMatch = new EObjectCondition() {
public boolean isSatisfied(EObject object) {
return matches(object);
private boolean matches(EObject object) {
if isAMatch(object) return true;
else return matches(object.eContainer());
If that makes sense....
Jim.
Christian W. Damus wrote:
> Hi, Jim,
> HTH,
> Christian
>> Hi,
>> Cheers,
>> Jim.
Re: [EMF Query] recursive conditions [message #420382 is a reply to message #420378] Thu, 26 June 2008 23:17 Go to previous message
--=-DCW7Z59C/OrfXVySkZ0n
Hi, Jim,
Yes, that makes perfect sense. That is your best work-around, for now.
If you are interested in a more general/re-usable condition object,
please do raise an enhancement request in Bugzilla.
I don't think any of the pre-fab condition objects have state that
changes during the execution of a query, so it should be possible to use
any of them multiple times in the same query expression.
Christian
> Jim.
> > Hi, Jim,
> > HTH,
> > Christian
> >> Hi,
> >> Cheers,
> >> Jim.
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Jim,<BR>
<BR>
Yes, that makes perfect sense.&nbsp; That is your best work-around, for now.&nbsp; If you are interested in a more general/re-usable condition object, please do raise an enhancement request in Bugzilla.<BR>
<BR>
I don't think any of the pre-fab condition objects have state that changes during the execution of a query, so it should be possible to use any of them multiple times in the same query expression.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
<FONT COLOR="#000000">Yes, that was essentially what I was trying to do in this case. My </FONT>
<FONT COLOR="#000000">question was more general, about whether it was possible to reuse an </FONT>
<FONT COLOR="#000000">EObjectCondition twice in a tree, in this case in a recursive way.</FONT>
<FONT COLOR="#000000">I've since found another way of solving my particular problem, by </FONT>
<FONT COLOR="#000000">shifting the recursive call inside a custom EObjectCondition, a la</FONT>
<FONT COLOR="#000000">EObjectCondition recursiveMatch = new EObjectCondition() {</FONT>
<FONT COLOR="#000000"> public boolean isSatisfied(EObject object) {</FONT>
<FONT COLOR="#000000"> return matches(object);</FONT>
<FONT COLOR="#000000"> }</FONT>
<FONT COLOR="#000000"> private boolean matches(EObject object) {</FONT>
<FONT COLOR="#000000"> if isAMatch(object) return true;</FONT>
<FONT COLOR="#000000"> else return matches(object.eContainer());</FONT>
<FONT COLOR="#000000">};</FONT>
<FONT COLOR="#000000">If that makes sense....</FONT>
<FONT COLOR="#000000">Christian W. Damus wrote:</FONT>
<FONT COLOR="#000000">&gt; Hi, Jim,</FONT>
<FONT COLOR="#000000">&gt; </FONT>
<FONT COLOR="#000000">&gt; The stock query conditions (esp. EObjectReferenceValueCondition) only </FONT>
<FONT COLOR="#000000">&gt; handle one step of a reference chain. It would be interesting to add </FONT>
<FONT COLOR="#000000">&gt; support for predicates on the closure or a reference, such as we can do </FONT>
<FONT COLOR="#000000">&gt; in MDT OCL with the &quot;closure&quot; iterator.</FONT>
<FONT COLOR="#000000">&gt; Is that what you're getting at? I may have misunderstood.</FONT>
<FONT COLOR="#000000">&gt; HTH,</FONT>
<FONT COLOR="#000000">&gt; Christian</FONT>
<FONT COLOR="#000000">&gt; On Wed, 2008-06-25 at 15:40 +1000, Jim Steel wrote:</FONT>
<FONT COLOR="#000000">&gt;&gt; Hi,</FONT>
<FONT COLOR="#000000">&gt;&gt;</FONT>
<FONT COLOR="#000000">&gt;&gt; Does EMF Query handle recursive conditions? I'm trying to write a </FONT>
<FONT COLOR="#000000">&gt;&gt; condition along the lines of &quot;p(x) or p(y) where y is a direct or </FONT>
<FONT COLOR="#000000">&gt;&gt; indirect container of x&quot;. I am trying</FONT>
<FONT COLOR="#000000">&gt;&gt; EObjectCondition p = ...</FONT>
<FONT COLOR="#000000">&gt;&gt; EObjectCondition p_or_parent_p = null;</FONT>
<FONT COLOR="#000000">&gt;&gt; EObjectCondition parent_p = new </FONT>
<FONT COLOR="#000000">&gt;&gt; EObjectReferenceValueCondition(containerReference, p_or_parent_p);</FONT>
<FONT COLOR="#000000">&gt;&gt; p_or_parent_p = p.OR(parent_p);</FONT>
<FONT COLOR="#000000">&gt;&gt; I'm having some NullPointerExceptions that I'm trying to sort out, but </FONT>
<FONT COLOR="#000000">&gt;&gt; if its a fundamental limitation of EMF Query, I'll have to work out some </FONT>
<FONT COLOR="#000000">&gt;&gt; other way of doing it.</FONT>
<FONT COLOR="#000000">&gt;&gt; Cheers,</FONT>
<FONT COLOR="#000000">&gt;&gt; Jim.</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-DCW7Z59C/OrfXVySkZ0n--
Previous Topic:XMLResource.OPTION_CONFIGURATION_CACHE can produce ArrayIndexOutOfBoundsException
Next Topic:seeking advice: making generated contentproviders filterable
Current Time: Sat Jul 19 14:55:42 EDT 2025
Powered by FUDForum. Page generated in 0.25160 seconds
