Home » Modeling » EMF » PropertyColumnLabelProvider and list of referenced objects
PropertyColumnLabelProvider and list of referenced objects [message #419918] Fri, 13 June 2008 06:45 Go to next message
I have a class A which contains one attribute and a list of class B.
Class B has a reference to Class C. Now I have another class which
contains a list of A's which is set as input to the TableViewer.
The first column should show the simple attribute of A which is no
problem. But I want to display all B's in their own columns as well.
Unfortunately only the first B of the list is displayed in every column.
Can this be achieved anyhow? I tried the approach explained in my
previous topic (see
http://www.eclipse.org/newsportal/article.php?id=32818&g roup=eclipse.tools.emf#32818)
but it didn't work.
Matthias
Re: PropertyColumnLabelProvider and list of referenced objects [message #419923 is a reply to message #419918] Fri, 13 June 2008 07:28 Go to previous messageGo to next message
Matthias,
Comments below.
> previous topic (see
> but it didn't work.
I recently answered a question that's perhaps related pointing at
TreeNodeItemProvider's getPropertyDescriptor's specialized code that
creates decorated property descriptors.
I'm not quite sure how this will work, since there can be a variable
number of Bs and hence a variable number of properties yet you generally
have a fixed number of columns. You'll need to do something to ensure
that the property IDs are unique...
> Matthias
Re: PropertyColumnLabelProvider and list of referenced objects [message #419926 is a reply to message #419923] Fri, 13 June 2008 09:33 Go to previous message
Ed,
Please see comments below.
Ed Merks wrote:
> Matthias,
> Comments below.
>> previous topic (see
>> but it didn't work.
Yes, that's exactly what I tried to use. I get the property I want but
the same value is shown in every column (i.e. of the first B of the
list). (it's difficult though as I can't call a.getList because this
would return property descriptors for the list, EContainment... I think)
I create one column for each B so this should not be a problem.
Is this possible anyhow? The problem is that all have the same property ID.
>> Matthias
Previous Topic:[CDO] loading old resources after modifying the model
Next Topic:[CDO] Dynamic models
Current Time: Sat Jul 19 22:05:01 EDT 2025
Powered by FUDForum. Page generated in 0.04233 seconds
